2013 q5 3.0T redirect fail!?
travrose36
C?ID=310803
Hey guys I'm new here so ill try not to muff this all up. My wifes q5 started getting warm on the way to the gas station the other day. Now it never actually overheated. i noticed my ac stopped blowing cold and instantly saw my temp gauge was slowly rising so i pulled over to have a look. I was able to turn the heater on and cruise home and the gauge dropped back down. I have since scanned it and get two key faults that seem to be irrelevant (again im not the most technically or mechanically inclined human) However the other thing i noticed is my Hvac system has a redirectfail. I'v been reading through these forums pretty religiously in an attempt to not post repetitive threads but i can't seem to figure this thing out so some help would be greatly apreciated. :D
Sunday,24,May,2020,17:46:43:35731
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WA1DGAFP5DA042374   License Plate: MOMBEAR
Mileage: 106600km-66238mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
          6C 6D 72
VIN: WA1DGAFP5DA042374   Mileage: 106600km-66238miles
Address 01: Engine (J623-CTUC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8R0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0003
   Revision: --H07---
   Coding: 2A2A0034052601060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218R0907551A 001004
   ROD: EV_ECM30TFS0214G0907551D.rod
   VCID: 36362EC7A8CFC48BB97-8062
   Part No SW: 8R0 927 158 AM    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1003
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002020
   VCID: 084A903F92BB827B1BB-805C
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 AK    HW: 8R0 907 379 AK
   Component: ESP8 quattro  H09 0080
   Coding: 191D1C
   Shop #: WSC 06335 000 00000
   VCID: 094C953B8931FB73045-805C
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H11 0621
   Coding: 0DA54040000000000000
   VCID: 0452840FAE13A61B773-8050
   Serial number: 2312000245721012
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 97
                    Mileage: 104440 km
                    Date: 2020.02.22
                    Time: 09:19:49
00955 - Key 1
                    Reset counter: 233
                    Mileage: 106176 km
                    Date: 2020.04.30
                    Time: 10:39:59
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01211120120261
   Coding: 6621228000
   VCID: 392C25FB99512BF3545-806C
"Redir Fail" means there's no label file for that module in the language version of VCDS you're using (English). Looks like there is one for that module in German.
I also see no fault codes relevant to the AC cutting out or the coolant overheating in the data you posted above. I agree that the Key faults in the Kessy module not related to this.
The first thing I'd check that is that the radiator fans come on as expected. You can do this in the comfort of your driveway, just let the vehicle warm up at idle with the AC on to see if the problem is reproducible.
travrose36
C?ID=310803
okay so i just did a little rereation test
1) turned vehicle on- no fans running
2) turned A/c on- both fans on high (keep in mind im in southern california and its 97F out)
3) turned a/c back off- both fans turn off
4) temp gauge to center- both fans on low
5) drove around the block with no a/c and temp gauge started rising above center, both fans were on super high and the car sounded like a boing 757 airliner
6) turned the heater on full blast and the gauge began to drop as drove the car home.
7) sat in the driveway and clicked the A/c back on at idle and the gauge began to rise again.
8) turned off came inside and here we are
Sounds like the fans aren't the problem then. Stuck thermostat?
travrose36
C?ID=310803
yea i was thinking the same, do you think it would be the temp sensor? if its the thermostat im pretty sure i need to pull the supercharger
travrose36
C?ID=310803
im honestly not sure
NostraJackAss
Petrol Dave is correct this function for fan operation is bifurcated!
Fuse for radiator fan temp switch faulty directly or fan controller checked yet?
Fans come on for several inputs please check RTFB and WD to familiarize circuit.
Want to post screen shots what you don't understand for clarity on WD?
