VW Touareg 2007 Tyre filling connection 007 short to ground-intermittent
Plekko
England
C?ID=400740
There doesn't seem to be much info about this fault,
it has been looked into thoroughly in the past changing the filler valve didn't cure it,
changing the module also didn't cure it,
so my guy who had been through the wiring diagram could only cure it by bypassing the valve and wiring in a resistor,
that cured it for sometime but now its back, any ideas?
Thanks.....
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 G
Component: LUFTFDR.-CDC- 3C3P1 3112
Coding: 0015521
Shop #: WSC 01544 002 1048576
VCID: 372B2D37035B40D3A21-5184
00311 - Tire Filling Connection
Also if anyone can shed some light on the lamda sensor fault too, that would be great.
Monday,25,May,2020,15:43:29:27718
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVGZZZ7LZ8D017168   License Plate:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 22 34 37 46 55 56 68 69 76
          77
VIN: WVGZZZ7LZ8D017168   Mileage: 293400km-182310miles
68-Wiper Electr. -- Status: OK 0000
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 7L0 907 401 F    HW: 7L0 907 401 D
   Component: 3.0L V6TDI  G001AG  0040
   Revision: --H04---    Serial number: VWX3Z0G3634463
   Coding: 0011775
   Shop #: WSC 12334 024 00000
   VCID: 2E050853FC01811BF17-5184
009236 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
               P2414 - 002 -
                    Fault Status: 01110010
                    Fault Frequency: 14
                    Mileage: 292570 km
                    Date: 2020.05.07
                    Time: 04:21:46
                    RPM: 756 /min
                    Torque: 105.3 Nm
                    Duty Cycle: 1.0 %
                    Duty Cycle: 21.9 %
                    (no units): 0.0
                    (no units): 64.0
008598 - Oxygen (Lambda) Sensor B1 S1
               P2196 - 002 - Signal too High (Rich)
                    Mileage: 292584 km
                    Date: 2020.05.07
                    Time: 06:30:56
                    RPM: 1596 /min
                    Torque: 0.0 Nm
                    Speed: 47.0 km/h
                    Duty Cycle: 1.0 %
                    Duty Cycle: 23.9 %
                    (no units): 0.0
                    (no units): 80.0
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 FA    HW: 09D 927 750 FA
   Component: AL 750 6A           0992
   Revision: 00H61000    Serial number:
   Coding: 0004456
   Shop #: WSC 31414 790 00001
   VCID: 72BDDC2328B9E5FB55F-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 K    HW: 7L0 907 379 K
   Component: ESP ALLRAD MK25E1   0302
   Revision: 00H53001
   Coding: 0004482
   VCID: 41DF43EF5DCF0E631C5-8014
   Part No SW: 3D0 909 137 D    HW: 5WK 485 05
   Component: 20 Kessy            6840
   Revision: 68406418    Serial number: VWX3Z0G3634463
   Coding: 0147688
   VCID: 2809FE4BDEB5DF2B3BB-807C
00190 - Driver's Door Handle Touch Sensor (G415)
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AD
   Component: CLIMAtronic R/L     4326
   Coding: 0000530
   VCID: 72BDDC2328E9E5FB55F-8026
            014 - Defective
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2000
   Revision: -0004---    Serial number: --------------
   Coding: 600004002B221C000000000000000000
   VCID: 005986EB1645C76B53B-8054
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234  37 VW8T       0250
   Revision: 92011025    Serial number: 0039P0025JL+
   Coding: 0013111
   VCID: 7AADF40370999DBB1DF-802E
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 F
   Component: J527                3601
   Coding: 0010011
   VCID: 42DD4CE358C9157B05F-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 985 Q    HW: 7L6 920 985 Q
   Component: J285 KOMBI-INST.    7520
   Revision: KHH06V02
   Coding: 0007401
   Shop #: WSC 01184 210 175833
   VCID: 4BC361C76FC3D433F69-801E
                    Reset counter: 196
                    Mileage: 292890 km
                    Date: 2020.05.16
                    Time: 09:42:31
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 815 071 G
   Component: Standheizung E1MAC  0425
   Coding: 0000000
   VCID: 363520330441B9DBB97-8062
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 985 Q
   Component: J533  GW-K-CAN TP20 7520
   Coding: 7FE2E78BC8056003
   VCID: 70B9D62B26A5D7EBA3B-8024
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0119
   VCID: 7F5B05176BEBB8932A1-5160
   Coding: 0015521
Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
   Part No: 7L6 919 887 P
   Component:      Navigation     0019
   Coding: 0000101
   VCID: 53F379A7B7F38CF3BE9-8006
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L6 959 933
   Component: 13 HSG              7124
   Coding: 0000085
   VCID: 7F5B05176BEBB8932A1-4B1E
   Subsystem 1 - Part No: 7L0 959 701 S
   Component: Tuersteuergeraet FS 6302
   Subsystem 2 - Part No: 7L0 959 702 S
   Component: Tuersteuergeraet BF 6302
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
   Subsystem 5 - Part No: 7L0 907 719 A
   Subsystem 6 - Part No: 7L6 951 171 B
   Component:    Innenraumsensor  0020
00485 - Drivers Outside Door Handle Central Locking Button (E369)
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Component: AFS-Steuergeraet    0001
   Revision:   H02       Serial number:
   Coding: 1288451
   VCID: 392F2B0F351F56A3545-806C
   Component: AFS-Lst.-Modul l    X008
   Coding: 00000019
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    X008
   Coding: 00000019
Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
   Part No: 7L6 035 186 G
   Component:        Radio        0019
   Coding: 0012432
   VCID: 372B2D37034B40D3A21-8062
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 A
   Component: J400__ Front Wiper  5101
   Coding: 0000341
   VCID: 38292E0B0E554FABABB-806C
   Component: RLS     220819 054  0403
   Coding: 00209069
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000001
   VCID: 38292E0B0E154FABABB-806C
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 7L6 035 730     HW: 7L6 035 730
   Component: Telefon             2209
   Revision: 00011000    Serial number: 0000000028905
   Coding: 0020041
   Shop #: WSC 00591 210 83198
   VCID: 6B83C1470F833433969-803E
End----------(Elapsed Time: 02:04, VBatt start/end: 12.0V/12.1V)-----------
DrPeter
16.4905° S, 151.7375° W
The fault code above means the [J197-Adaptive suspension control unit] sees a shorted wire to ground to the [E472-Tyre pressure operating unit].
So if replacing the J197 and the E472 did not fix the concerns, it sounds like an 'overlay' harness will be the next logical step.
Be sure you have checked these steps too.... Testing - Open Circuits, Short to Ground or Positive, etc....
Just wanting to explain things a bit here and to help others understand the details:
  • The [E472] is connected to the [J197-Adaptive suspension control unit] via three wires.
  • There are two 'normally open' (NO) switches in the E472, with Pin-2 being the common.
  • The T4v connector is on the E472, located in the front passenger footwell.
  • The E472 is sometimes called the "Tire Inflation 'Cut-off' Control Head".
  • The J197 is located in the right side of the rear cargo area, behind the trim cover.
We do recommend the use of the Official Factory Repair Information.
Hope this helps,
drpeter
