Air Bag Light after Seat Swap - Fault Code
angrybacongod
C?ID=238646
I got my microCAN in the mail today. I am not yet verified but perhaps a mod can help with that. My store order number is 20170447 & invoice number 150209268711. I can pm anything else needed.
I installed a new set of seats into my 2014 GLI. The replacement seats were also out of a 2014 GLI, just the fancier edition (full power/heat)
The scan you see below is the initial scan that I took right after I got the tool.
I was able to successfully clear all the codes except this one:
9445973 - Seat occupied recognition control module
B1022 55 [137] - Not configured
Mileage: 41067 km
Date: 2015.02.10
Time: 00:01:07
Airbag light will not come off the dash. Code refuses to clear.
Hoping somebody could lend me a hand here. I have the original seats so I could swap out modules if necessary but hoping there is another way with coding.
Thanks!
Wednesday,11,February,2015,15:19:21:13723
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
VIN: 3VW5T7AJ7EM367203   License Plate: ROGERS
Mileage: 41060km-25513mi   Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 75 77
VIN: 3VW5T7AJ7EM367203   Mileage: 41060km-25513miles
Address 01: Engine (J623-CPPA)       Labels: None
   Part No SW: 06K 906 070 AB    HW: 06K 907 425
   Component: Simos12.2     H09 6111
   Revision: --H09---    Serial number: 00000000000000
   Coding: 00190012242400170000
   Shop #: WSC 00066 000 00200
   ASAM Dataset: EV_ECM20TFS02006K906070AB 001005
   ROD: EV_ECM20TFS02006K906070AB.rod
   VCID: 6AF533B68D4A7271D04-803F
   Revision: 00H31001
   Coding: A14B600C49280001850D06E4921C0041B71800
   Shop #: WSC 00066 000 00000
   VCID: 7DDF08EAE4C4F5C9056-8028
                    Mileage: 40299 km
                    Date: 2015.02.01
                    Time: 00:22:59
                    Count: 2
                    Count: 2
                    Count: 12800
                    Count: 16390
                    Count: 50432
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 Q    HW: 5C0 820 047 Q
   Component: J301  Klimaanlage   0103
   Revision: 2000908S    Serial number: 00000000228679
   VCID: 2E7DFFA6B922DE51CCC-807B
00229 - Refrigerant Pressure
                    Reset counter: 161
                    Mileage: 84637 km
                    Date: 2017.01.04
                    Time: 06:37:48
                    Fault Status: 00101101
                    Reset counter: 161
                    Mileage: 84638 km
                    Date: 2017.01.26
                    Time: 10:49:23
   Part No SW: 5K0 937 086 R    HW: 5K0 937 086 R
   Component: BCM PQ35 M    122 0173
   Revision: BJ122001
   Coding: AF200A1A902F06C4018800810000054401000088408009205C8020000040
   VCID: 43ABBE12C2A04339332-8016
                    Fault Status: 00101011
                    Reset counter: 80
                    Mileage: 41067 km
                    Date: 2015.02.10
                    Time: 04:41:22
                    Voltage: 11.90 V
                    Reset counter: 80
                    Mileage: 41067 km
                    Date: 2015.02.10
                    Time: 04:40:21
                    Voltage: 11.85 V
02742 - Bulb for Brake/Turn Signal Light; Left
                    Fault Status: 00101010
                    Reset counter: 49
                    Mileage: 39970 km
                    Date: 2015.01.28
                    Time: 15:29:27
                    Voltage: 14.10 V
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD00M106
   Coding: 00004139
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 74C92DCEDF8EB4817A8-8021
   Serial number: 6940000Y120000K0YX0E
   Coding: 303041
   Serial number: 3572MSME4818537BZZZ/
   Serial number: 3582MSME34597079ZZZ
   Serial number: 3516KSME60011626ZZZB
   Serial number: 3526KSME25074426ZZZK
   Serial number: 3556LSME26517926ZZZW
   Serial number: 3566LSME565A7926ZZZ2
                    Mileage: 41067 km
                    Date: 2015.02.10
                    Time: 00:01:07
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010042    Serial number: 20130708100505
   Coding: 008A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76CD17C6C9F2A69144C-8023
   Coding: 820000
   Part No SW: 5C6 920 973 B    HW: 5C6 920 973 B
   Coding: 271E01
   VCID: 2E7DFFA67122DE51CCC-807B
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 02071303000725
   Coding: 351002
   VCID: 79D71CFAF0ECC9E929E-802C
Address 1C: Position Sensing
Address 2E: Media Player 3
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0007154128
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 5B9B667252101BF95B2-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1508
   Serial number: 00000008037947
   Coding: 000490
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 69     3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3957DCFA706C09E969E-806C
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.0 V
                        PD
                    Temperature: 17.0*C
                    Count: 2
                    Steering Angle: 0.00*
                        SteerAng n.Init
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0007143255
   Coding: 0004B4
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 5C99656E571E1CC1528-8009
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1508
   Serial number: 00000008029355
   Coding: 000490
   Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
   Component: Radio Prem-8  H05 0008
   Revision: -----09S    Serial number: VWZ4Z7N3491372
   Coding: 01000400020006
   VCID: 64E95D8E676E2401EA8-8031
Address 75: Telematics (J949)       Labels: None
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0086
   Serial number: 000003554140503
   Coding: 02630102C2161A107F1606C00000
   ROD: EV_OCULow_SE12.rod
   VCID: 538B8E523AC0D3B9832-8006
12670464 - Databus
                    Fault Frequency: 40
                    Reset counter: 81
                    Mileage: 28009 km
                    Date: 2014.09.13
                    Time: 15:35:57
0035 - Databus
                    Fault Frequency: 149
                    Reset counter: 81
                    Mileage: 20 km
                    Date: 2013.10.03
                    Time: 12:36:30
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 0
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007665011609
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 02:09)--------------------------
Moved to Retrofits now that you're verified and can post in this section.
angrybacongod
C?ID=238646
Found this in the wiki.
It for a Golf/Jetta V but I'll see if procedure is similar for the MKVI Jetta since nothing is listed past the MKV:
Seat Occupied Recognition Control Module (J706)
If the Seat Occupied Recognition Control Module (J706) or the seat itself have been replaced, the basic setting has to be performed.
[Select]
[15 - Airbags]
[Security Access - 16]
Enter 20324, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The reset has been performed.
[Done, Go Back]
angrybacongod
C?ID=238646
Ok followed these instructions:
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(5K)_AirbagVW10
They appear not to apply to my MKVI Jetta. The MKV is close as I can get in the wiki. Nothing higher. Anyway I tried so:
This happens:
note: I have tried using just 0 in the reserved box also with same results.
If I try and cut and paste the same coding for the airbag as mentioned:
Click No
Im at a loss.
golfi_vend
Tartu, Estonia
C?ID=195131
I have found this link, where the guy replaces the seat recognition box.
http://www.golfmk6.com/forums/showthread.php?t=50337
I'm meaning to ask, to NAR and ROW seat recognition differ somehow? I've seen that some use some sort of air pressure sensor when you sit on the seat. What i do know is that my car doesn't have any of that, just a seat-pad, which I'm able to feel when i touch the seat with hand.
angrybacongod
C?ID=238646
Thanks for the link golfi_vend
I actually had found that thread too through my googling.
I ended up swapping out the seat occupied sensor as I still had my old seats.
Disconnected the battery, swapped the sensors, and reconnected the battery.
Started the car and the airbag light went out.
Rescan showed no error codes.
So while this isn't exactly a 'coding' fix, it worked for me and I am happy.
Recoding these things sounds like a pain in the butt.
What the modules look like. Mounted under passenger seat. You can see that the part numbers were exactly the same for both units. Apparently not plug and play though.
