2012 Audi A6 3.0 TDI (C7) s-tronic - Gearbox malfunction: You can continue to drive
RobertJB
New Zealand
C?ID=199529
Hi again,
after an issue with my wife's Allroad (not being levelled and still needs resolving), it is my turn :(
Today I got "Gearbox malfunction: You can continue to drive". The message comes and goes. Briefly there was also a RED warning which I didn't capture as it went away. I have also noticed that the car was stuttering a bit while the RED warning was on. I have also lost the PRNDS lights.
If there anything I can check before trying to get the car to Audi (160km away)?
Any feedback would be much appreciated.
Here is the scan:
 Monday,25,May,2020,17:13:21:28799
VCDS Version: 19.6.2.2 (x64)
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 36 3B 42 44 46 52 53
          55 56 5F 62 69 6C 72 85 8B 8E 8F 90
Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0004
   Revision: 53H37---
   Coding: 0A254012057601020000
   Shop #: WSC 00070 824 98310
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: 26430C635997727FFF-8072
18660 - Start interruption due to insufficient engine speed
          P151D 00 [032] - -
   Part No SW: 4G2 927 156 M    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0002
   Revision: --H03---    Serial number: 0000001123
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501021 001010
   ROD: EV_TCMDL501021.rod
   VCID: 387FD21B8323F48F5D-806C
7965 - Signal Line for Gear Display on Selector Lever
          P1893 00 [032] - Electrical Malfunction
                    Reset counter: 40
                    Mileage: 172050 km
                    Date: 2020.05.25
                    Time: 16:57:05
                    Engine speed: 1422 /min
                    Transmission input speed: 1422 /min
                    Transmission output speed: 458 /min
                    Engine torque: 176 Nm
                    Transmission fluid temperature: 72 ∞C
                    Accelerator position: 27.2 %
                    Clutch status: Kupplung 1 kann Moment ¸bertragen
7966 - Signal Line for Gear Display on Selector Lever
          P1894 00 [032] - Implausible Signal
                    Reset counter: 40
                    Mileage: 172050 km
                    Date: 2020.05.25
                    Time: 16:57:08
                    Engine speed: 1235 /min
                    Transmission input speed: 1235 /min
                    Transmission output speed: 396 /min
                    Engine torque: 0 Nm
                    Accelerator position: 12.0 %
7967 - Selector Lever Position Monitoring
          P1892 00 [032] - Malfunction
                    Reset counter: 40
                    Mileage: 172052 km
                    Date: 2020.05.25
                    Time: 17:00:08
                    Engine speed: 902 /min
                    Transmission input speed: 902 /min
                    Transmission output speed: 82 /min
                    Engine torque: -8 Nm
                    Transmission fluid temperature: 81 ∞C
                    Accelerator position: 0.0 %
                    Clutch status: Kupplung 2 kann Moment ¸bertragen
18147 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [032] - -
                    Reset counter: 40
                    Mileage: 172052 km
                    Date: 2020.05.25
                    Time: 16:59:40
                    Engine speed: 751 /min
                    Transmission input speed: 751 /min
                    Engine torque: 52 Nm
                    Voltage terminal 30: 14.700 V
                    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.923 V
7999 - No Communication with Instrument Cluster
          U0155 00 [032] - -
                    Reset counter: 40
                    Mileage: 172052 km
                    Date: 2020.05.25
                    Time: 16:59:45
                    Engine speed: 753 /min
                    Transmission input speed: 753 /min
                    Voltage terminal 30: 14.500 V
                    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.924 V
8015 - Steering Column Control Module
          U0212 00 [032] - No Communications
                    Reset counter: 40
                    Mileage: 172052 km
                    Date: 2020.05.25
                    Time: 16:59:36
                    Engine speed: 925 /min
                    Transmission input speed: 925 /min
                    Transmission output speed: 154 /min
                    Engine torque: 4 Nm
                    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.921 V
   Part No SW: 4G0 907 379 G    HW: 4G0 907 379 G
   Component: ESP PREMIUM   H09 0250
   Coding: 27A68701E465E180DB00
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 3561DB2F943109E746-8060
0067 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 80
                    Mileage: 172052 km
                    Date: 2020.05.25
                    Time: 16:59:39
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: D8
                    Uz: BE
   Part No SW: 4H0 907 064 BT    HW: 4H0 907 064 BT
   Component: BCM2 2.0      H31 0330
   Coding: 01B83006000000000000
   VCID: 7CF70E0BFF9B18AFF9-8028
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 27
                    Mileage: 171645 km
                    Date: 2020.05.09
                    Time: 15:51:03
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
   Component: KLIMA 2 ZONEN H10 0056
   Serial number: 07071100040400
   Coding: 3621600824
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_AirCondiBasisUDS 002033
   VCID: 2447166B2FAB806FE1-8070
   Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0100
   Revision: 20012002    Serial number: 00000000965136
   Coding: 2600201040349FE281810083A0001D0CCF9DE30827090101000004602101
   VCID: 6DD1334FB4E181277E-8038
   Component: WWS57X 110516  H35 0051
   Serial number:         110608053655
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11526277
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 22 06 2011  00000527
   Component: Humidity_Sens  H02 0002
   Serial number: 3968C5B5000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2345157722A5875798-8076
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Revision: 11001001    Serial number: 55901118300643
   Coding: 290B06
   Shop #: WSC 32336 000 1048576
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3B75CD17B215DF97B0-806E
   Part No SW: 4G0 907 561     HW: 4G0 907 561
   Component: ACC3          H15 0160
   Coding: 3D04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 001003
   ROD: EV_AdaptCruisContrAU57X_001.rod
   VCID: 67DD41679E1DAB7704-8032
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 80
                    Mileage: 172052 km
                    Date: 2020.05.25
                    Time: 16:59:39
                    Control Module temperature: 17 ∞C
                    Voltage terminal 15: 14.647 V
                    Longitudinal_acceleration_vehicle_reference: -0.30 m/s≤
105984 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 80
                    Mileage: 162829 km
                    Date: 2019.10.04
                    Time: 08:11:31
                    Control Module temperature: 13 ∞C
                    Voltage terminal 15: 14.690 V
                    Velocity_vehicle_reference: -0.01 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.00 m/s≤
106240 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 80
                    Mileage: 162829 km
                    Date: 2019.10.04
                    Time: 08:11:31
140288 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 80
                    Mileage: 162829 km
                    Date: 2019.10.04
                    Time: 08:11:31
                    Voltage terminal 15: 14.651 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 40
                    Mileage: 168107 km
                    Date: 2020.01.30
                    Time: 17:00:00
                    Control Module temperature: 26 ∞C
                    Voltage terminal 15: 13.355 V
                    Velocity_vehicle_reference: -0.02 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.09 m/s≤
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG00338Y0
   Coding: 30323436313330303630554A305234473053
   VCID: 3663DC23893702FF4F-8062
   Serial number: 3575HRB405V0INGSFP9Y
   Serial number: 3585HRB40550IODOF8H.
   Serial number: 3515JRB40550JNPM9H1T
   Serial number: 3525JRB404T0JL5E49BK
   Serial number: 3554VRB405J0JE3G29FK
   Serial number: 3564VRB405L0JE3GDO4
   Revision: --------    Serial number: 90372KFR000RC
   Coding: 00003C
   VCID: 377DD127863DFBF754-8062
   Component: E221 - MFL  H07 0009
   Serial number: 30 05 2011  B0020967
   Part No SW: 4G8 920 931 J    HW: 4G8 920 931 J
   Component: TDieRdwAcc    H71 0375
   Revision: 26181114    Serial number: 658080711592017
   Coding: 338708000F010008010000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K_AU57.rod
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000191824
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 326BE033655F1EDF63-8066
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650829486
   Voltage stabilizer:
   Serial number: 11188001794011200181
0264 - Powertrain Databus (VAG Single-Wire Mode) (SAE  L Shorted H)
          U0009 00 [008] - -
                    Fault Frequency: 38
                    Reset counter: 80
                    Mileage: 172046 km
                    Date: 2020.05.25
                    Time: 16:49:23
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.6 V
                    Control Module temperature: 20 ∞C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006299091
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77FD1127C6BD3BF794-8022
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4201A0W00
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D51F34F7C6141273E-8078
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F16204E01628002080003
   VCID: 4189BFFFD8F9B547EA-8014
                    Fault Status: 01101100
                    Fault Frequency: 12
                    Reset counter: 249
                    Mileage: 159570 km
                    Date: 2019.08.13
                    Time: 16:47:36
   Component: RCEPS         H33 0010
   Revision: 00001000    Serial number: 0021103429
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0153037276
   Coding: 011A062000B90400832008842C0100000000000000000000000000000000
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00000290349
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
                    Fault Frequency: 68
                    Reset counter: 46
                    Mileage: 164175 km
                    Date: 2019.11.02
                    Time: 13:37:58
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F16204E01628002080002
                    Fault Status: 00101100
                    Fault Frequency: 145
                    Reset counter: 77
                    Mileage: 159750 km
                    Date: 2019.08.15
                    Time: 12:01:05
   Revision: --------    Serial number: 00000000098725
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A5BF8534D8F561FDB-807E
67840 - Left Parking Brake Motor Voltage Supply
          C100D 01 [000] - Electrical Malfunction
397568 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Reset counter: 80
                    Mileage: 172052 km
                    Date: 2020.05.25
                    Time: 17:00:02
                    Voltage terminal 30: 14.9 V
                    Internal Fault ID: 118
                    Vehicle speed: 16 km/h
                    Network management state: normal
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    General Inspection Function: not active
                    Internal Parking Brake state: Dynamic
                    Status of parking brake button: Not operated
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Serial number: 110703-0004-046
   Coding: 1121A6101000A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C57FE4B477B482F29-8078
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H52 0133
   Revision: AB001007    Serial number: 051GU0B7523382
   Coding: 070003020100000001
   VCID: 285F025B5B83640FCD-807C
   Part No SW: 4G0 035 754 P    HW: 4G0 035 754
   Component: H-BN-RW       H47 1034
   Revision: --------    Serial number: 430FU0B7507390
   Coding: 050A01000003E9EF6510AB2E00000003FC0001020000000000
   VCID: 3365E537924517D768-8066
   Subsystem 1 - Part No: 8R0 060 884 DJ
   Component: ROW 2016  0806
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB13010P11
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 A
   Component: E380 BDT C7  H08 0204
   Serial number: 90349KFS0007U
   Subsystem 4 - Part No: 8R0 060 961 B
   Component: CD-Database  3371
                    Reset counter: 40
                    Mileage: 159569 km
                    Date: 2019.08.13
                    Time: 14:06:53
                    Text: DUA009,Front,M,0,0,6
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14204001628002080002
   VCID: 4487B6EBC7EBA06FC1-8010
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H07 0100
   Revision: 5G001001    Serial number: 00000135482843
   Coding: 0109080000000000
   VCID: 71E92F3FA8D965C75A-8024
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J19G1C7
   Coding: 1090004
   VCID: 26430C639197727FFF-8072
   Component: TSG HR        H04 0212
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: 6A040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 65C14B6F6411B96736-8030
   Part No SW: 4G0 907 541     HW: 4G0 907 541
   Coding: 3D04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
   ROD: EV_AdaptCruisContr2AU57X_001.rod
          U1113 00 [008] - -
                    Reset counter: 80
                    Mileage: 172052 km
                    Date: 2020.05.25
                    Time: 16:59:39
                    Voltage terminal 15: 14.699 V
                    Velocity_vehicle_reference: -0.00 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.22 m/s≤
          U1113 00 [008] - -
                    Reset counter: 80
                    Mileage: 162829 km
                    Date: 2019.10.04
                    Time: 08:11:31
                    Voltage terminal 15: 14.179 V
          U1113 00 [008] - -
                    Reset counter: 80
                    Mileage: 162829 km
                    Date: 2019.10.04
                    Time: 08:11:31
                    Voltage terminal 15: 14.203 V
          U1113 00 [008] - -
                    Reset counter: 80
                    Mileage: 162829 km
                    Date: 2019.10.04
                    Time: 08:11:31
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H29 0034
   Serial number: 000040182006117
   Coding: 0480081C0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 25410B6F24917967F6-8070
0080 - Video Cable for Image Processing
          C1107 02 [024] - Signal Failure
                    Fault Frequency: 9
                    Reset counter: 249
                    Mileage: 169372 km
                    Date: 2020.02.26
                    Time: 21:45:24
                    Outside air temperature: 21.0 ∞C
                    Voltage terminal 15: 13.1 V
                    Control Module temperature: 24.0 ∞C
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
                    Fault Frequency: 139
                    Reset counter: 40
                    Mileage: 171422 km
                    Date: 2020.04.05
                    Time: 14:31:39
                    Outside air temperature: 17.0 ∞C
                    Voltage terminal 15: 13.2 V
                    Control Module temperature: 17.0 ∞C
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00660600031F037E000308004248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FED2947B6ED73374C-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70EF2A3BABD36CCF55-8024
End-------------------------(Elapsed Time: 06:16)--------------------------
RobertJB
New Zealand
C?ID=199529
Checking some other posts, it looks like it might be a corroded TCM connector due to coolant leak. Is this the one on the attached diagram, can I get to it on my driveway?
https://imgur.com/a/1xV4CtB
I would think you'd have to raise the car some to get access. Ramps or jack-stands?
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
Hi, I think this could actually be the case where the coolant valve lets the cooling water through the wiring harness to the control unit. But you need a lift to get to the valve.
RobertJB
New Zealand
C?ID=199529
Just got this checked and here are some photos:
Why the issue with the coolant valve hasn't been recalled by Audi is beyond me.
BTW What is the part number for the coolant control valve for Audi A6 4F (2011)?
Amazing how this hasn't been recalled already, Worldwide huh?
Does NZ have an equivalent of US NHTSA, if so maybe reach out to them?
RobertJB
New Zealand
C?ID=199529
I have already complained about this to Audi NZ and will follow this up with https://www.nzta.govt.nz
What is even more interesting is the fact that the authorised Audi dealers which regularly service the cars don't inform (clearly they must know, no?) their customers about such issues, perhaps waiting for it to happen and cause a lot of damage, so they can then charge big dollars for big jobs.
Or maybe let the consumers die in an accident wilfully wanton and deal with the civil suits versus the cost of recall worldwide?
RobertJB
New Zealand
C?ID=199529
ok, it looks like this is the right part for A6 4F (C7) 3.0 TDI 2012: 4H0121671D (N82/N509/N488)
RobertJB
New Zealand
C?ID=199529
Any idea why 4H0121671D is called HVAC HEATER CONTROL VALVE on the europaparts website and in my service manual it is referred to as Gearbox Oil Cooling valve (as shown below), is this still the same part (looks the same on the photo above and the diagram below)?
Is there anything else I need to replace? Should I also get the 2-pin wiring harness 1J0-973-702 ?
ai_Ingo
C?ID=56975
Hi, please also check the connector on the engine control unit, in the cases I had, there was some moisture in the connector for some.
The spare part number you are showing is correct.
ai_Ingo
C?ID=56975
Incidentally, Audi has known this problem for years. I've worked for Audi in a car dealership for 27 years. It is just that in the technical product information, I think it is called service bullitin in English, this problem has been described for a long time, but not clearly in the heading. I think it said something like: Various malfunctions and a reference to the coolant valve. But actually you look for various CAN errors and ignore the entry.
A friend of mine from the factory, Audi, brought me to it at the time and it was exactly as he described it, as I said, they have known this for years.
ai_Ingo
C?ID=56975
Yes, because this part is also used in other vehicles mainly for the heating circuit.
RobertJB
New Zealand
C?ID=199529
Thank you a lot, much appreciated.
Also, managed to locate a nice diagram showing how the N509 fits into the system (if that is of any interest)
ai_Ingo
C?ID=56975
Yes thank you. I've already seen that. I spent a long time looking for the cause of the first case and luckily I got the tip from Audi. There were about 24 control units in the A7 with different errors. Then again only 15 it was a disaster. Then we finally found the cooling water in the transmission connector, but the cause was not clear how it got there. The valve also happens to be close to the connector housing. I then replaced it myself, removed a strut and you can get the valve.
WBNa6
C?ID=119887
Hi and sorry to hear people are still having this problem and there hasn't been a recall on it before now. Definitely looks like the transmission valve is letting coolant pass. Looks like you have now got the car home, so would suggest the following actions.
- Clean up multipoint connector and brass pins (both sides) and install a new cooling solenoid. Check and also clean the 2 pin cable connection. Please note you can get an replacement valve on the usual auction sites. I actually think these are better than the VAG/Audi units and at 1/10th of the cost.
- Perform a calibration procedure (See VCDS procedures). Make sure it actually completes the full procedure, otherwise you are still likely to have issues. Please ensure that before performing the calibration procedure, make sure the transmission temperature is between 38 and 60 C also that there are no address 02 (transmission) errors, otherwise you will not be able complete the procedure.
- If the car runs fine after performing the calibration procedure (See VCDS procedures), then consider yourself to have been very lucky. If not, suggest you carry out a full transmission service, changing both filters and oil. Make sure the oil pan is removed and any emulsion build up in the base of the oil pan, PCBs and the ECU where the multipoint connector is removed. Once done redo the calibration procedure.
Hope this is of assistance and god luck.
WBNa6
RobertJB
New Zealand
C?ID=199529
Thank you for your feedback, much appreciated.
So far only the multipoint connector and plug was cleaned. No more errors and the car drives normally.
The next step is to order/replace the valve and clean the multipoint connector and plug once again. I will most likely order the following: https://www.europaparts.com/catalogsearch/result/?q=4H0121671D. Not sure which brand out of many available on the available auction houses would be good enough.
Is the calibration process still required? I believe you are referring to the following: http://wiki.ross-tech.com/wiki/index.php/7-Speed_S-Tronic_Direct-Shift_Gearbox_(DSG/0B5)
