- May 13, 2020
- 11
- 5
- New Zealand
- C?ID=199529
Hi again,
after an issue with my wife's Allroad (not being levelled and still needs resolving), it is my turn
Today I got "Gearbox malfunction: You can continue to drive". The message comes and goes. Briefly there was also a RED warning which I didn't capture as it went away. I have also noticed that the car was stuttering a bit while the RED warning was on. I have also lost the PRNDS lights.
If there anything I can check before trying to get the car to Audi (160km away)?
Any feedback would be much appreciated.
Here is the scan:
Here is the scan:
Monday,25,May,2020,17:13:21:28799
VCDS Version: 19.6.2.2 (x64)
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 36 3B 42 44 46 52 53
55 56 5F 62 69 6C 72 85 8B 8E 8F 90
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0004
Revision: 53H37---
Coding: 0A254012057601020000
Shop #: WSC 00070 824 98310
ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 26430C635997727FFF-8072
18660 - Start interruption due to insufficient engine speed
P151D 00 [032] - -
Part No SW: 4G2 927 156 M HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0002
Revision: --H03--- Serial number: 0000001123
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 001010
ROD: EV_TCMDL501021.rod
VCID: 387FD21B8323F48F5D-806C
7965 - Signal Line for Gear Display on Selector Lever
P1893 00 [032] - Electrical Malfunction
Mileage: 172050 km
Date: 2020.05.25
Time: 16:57:05
Engine speed: 1422 /min
Transmission input speed: 1422 /min
Transmission output speed: 458 /min
Engine torque: 176 Nm
Transmission fluid temperature: 72 ∞C
Accelerator position: 27.2 %
Clutch status: Kupplung 1 kann Moment ¸bertragen
7966 - Signal Line for Gear Display on Selector Lever
P1894 00 [032] - Implausible Signal
Mileage: 172050 km
Date: 2020.05.25
Time: 16:57:08
Engine speed: 1235 /min
Transmission input speed: 1235 /min
Transmission output speed: 396 /min
Engine torque: 0 Nm
Accelerator position: 12.0 %
7967 - Selector Lever Position Monitoring
P1892 00 [032] - Malfunction
Mileage: 172052 km
Date: 2020.05.25
Time: 17:00:08
Engine speed: 902 /min
Transmission input speed: 902 /min
Transmission output speed: 82 /min
Engine torque: -8 Nm
Transmission fluid temperature: 81 ∞C
Accelerator position: 0.0 %
Clutch status: Kupplung 2 kann Moment ¸bertragen
18147 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
Mileage: 172052 km
Date: 2020.05.25
Time: 16:59:40
Engine speed: 751 /min
Transmission input speed: 751 /min
Engine torque: 52 Nm
Voltage terminal 30: 14.700 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.923 V
7999 - No Communication with Instrument Cluster
U0155 00 [032] - -
Mileage: 172052 km
Date: 2020.05.25
Time: 16:59:45
Engine speed: 753 /min
Transmission input speed: 753 /min
Voltage terminal 30: 14.500 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.924 V
8015 - Steering Column Control Module
U0212 00 [032] - No Communications
Mileage: 172052 km
Date: 2020.05.25
Time: 16:59:36
Engine speed: 925 /min
Transmission input speed: 925 /min
Transmission output speed: 154 /min
Engine torque: 4 Nm
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.921 V
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 G HW: 4G0 907 379 G
Component: ESP PREMIUM H09 0250
Coding: 27A68701E465E180DB00
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004017
VCID: 3561DB2F943109E746-8060
0067 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 80
Mileage: 172052 km
Date: 2020.05.25
Time: 16:59:39
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: D8
Uz: BE
Part No SW: 4H0 907 064 BT HW: 4H0 907 064 BT
Component: BCM2 2.0 H31 0330
Coding: 01B83006000000000000
VCID: 7CF70E0BFF9B18AFF9-8028
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 27
Mileage: 171645 km
Date: 2020.05.09
Time: 15:51:03
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 H HW: 4G0 820 043 H
Component: KLIMA 2 ZONEN H10 0056
Serial number: 07071100040400
Coding: 3621600824
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AirCondiBasisUDS 002033
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 2447166B2FAB806FE1-8070
Part No SW: 4H0 907 063 BF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0100
Revision: 20012002 Serial number: 00000000965136
Coding: 2600201040349FE281810083A0001D0CCF9DE30827090101000004602101
VCID: 6DD1334FB4E181277E-8038
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 110516 H35 0051
Serial number: 110608053655
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11526277
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 22 06 2011 00000527
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: 3968C5B5000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 2345157722A5875798-8076
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901118300643
Coding: 290B06
Shop #: WSC 32336 000 1048576
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3B75CD17B215DF97B0-806E
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Coding: 3D04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X_001.rod
VCID: 67DD41679E1DAB7704-8032
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 80
Mileage: 172052 km
Date: 2020.05.25
Time: 16:59:39
Control Module temperature: 17 ∞C
Voltage terminal 15: 14.647 V
Longitudinal_acceleration_vehicle_reference: -0.30 m/s≤
105984 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 80
Mileage: 162829 km
Date: 2019.10.04
Time: 08:11:31
Control Module temperature: 13 ∞C
Voltage terminal 15: 14.690 V
Longitudinal_acceleration_vehicle_reference: -0.00 m/s≤
106240 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 80
Mileage: 162829 km
Date: 2019.10.04
Time: 08:11:31
140288 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 80
Mileage: 162829 km
Date: 2019.10.04
Time: 08:11:31
Voltage terminal 15: 14.651 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Mileage: 168107 km
Date: 2020.01.30
Time: 17:00:00
Control Module temperature: 26 ∞C
Voltage terminal 15: 13.355 V
Velocity_vehicle_reference: -0.02 m/s
Longitudinal_acceleration_vehicle_reference: -0.09 m/s≤
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG00338Y0
Coding: 30323436313330303630554A305234473053
VCID: 3663DC23893702FF4F-8062
Serial number: 3575HRB405V0INGSFP9Y
Serial number: 3585HRB40550IODOF8H.
Serial number: 3515JRB40550JNPM9H1T
Serial number: 3525JRB404T0JL5E49BK
Serial number: 3554VRB405J0JE3G29FK
Serial number: 3564VRB405L0JE3GDO4
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372KFR000RC
Coding: 00003C
VCID: 377DD127863DFBF754-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Serial number: 30 05 2011 B0020967
Part No SW: 4G8 920 931 J HW: 4G8 920 931 J
Component: TDieRdwAcc H71 0375
Revision: 26181114 Serial number: 658080711592017
Coding: 338708000F010008010000
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K_AU57.rod
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000191824
Coding: 00CD077D00
ROD: EV_GatewUDS_AU57.rod
VCID: 326BE033655F1EDF63-8066
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650829486
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11188001794011200181
0264 - Powertrain Databus (VAG Single-Wire Mode) (SAE L Shorted H)
U0009 00 [008] - -
Fault Frequency: 38
Reset counter: 80
Mileage: 172046 km
Date: 2020.05.25
Time: 16:49:23
Voltage terminal 30: 14.5 V
Voltage terminal 15: 14.6 V
Control Module temperature: 20 ∞C
System status: Terminal 15 on
IN ESP_standstill flag: no standstill detected
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00000006299091
Coding: 0078130000006001000001010101102030303232203232
VCID: 77FD1127C6BD3BF794-8022
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4201A0W00
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D51F34F7C6141273E-8078
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F16204E01628002080003
VCID: 4189BFFFD8F9B547EA-8014
Fault Status: 01101100
Fault Frequency: 12
Reset counter: 249
Mileage: 159570 km
Date: 2019.08.13
Time: 16:47:36
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0021103429
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0153037276
Coding: 011A062000B90400832008842C0100000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Serial number: 0000000AP00000290349
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
Fault Frequency: 68
Reset counter: 46
Mileage: 164175 km
Date: 2019.11.02
Time: 13:37:58
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F16204E01628002080002
02123 - Door Warning Light / Entry Light
Fault Status: 00101100
Fault Frequency: 145
Reset counter: 77
Mileage: 159750 km
Date: 2019.08.15
Time: 12:01:05
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000098725
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A5BF8534D8F561FDB-807E
67840 - Left Parking Brake Motor Voltage Supply
C100D 01 [000] - Electrical Malfunction
397568 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Reset counter: 80
Mileage: 172052 km
Date: 2020.05.25
Time: 17:00:02
Voltage terminal 30: 14.9 V
Internal Fault ID: 118
Vehicle speed: 16 km/h
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: Dynamic
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 110703-0004-046
Coding: 1121A6101000A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2C57FE4B477B482F29-8078
Part No SW: 4G0 035 056 J HW: 4G0 035 056
Component: Radio U STD H52 0133
Revision: AB001007 Serial number: 051GU0B7523382
Coding: 070003020100000001
VCID: 285F025B5B83640FCD-807C
Part No SW: 4G0 035 754 P HW: 4G0 035 754
Component: H-BN-RW H47 1034
Revision: -------- Serial number: 430FU0B7507390
Coding: 050A01000003E9EF6510AB2E00000003FC0001020000000000
VCID: 3365E537924517D768-8066
Subsystem 1 - Part No: 8R0 060 884 DJ
Component: ROW 2016 0806
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB13010P11
Subsystem 3 - Part No SW: 4G2 919 610 C HW: 4G2 919 610 A
Component: E380 BDT C7 H08 0204
Serial number: 90349KFS0007U
Component: CD-Database 3371
Mileage: 159569 km
Date: 2019.08.13
Time: 14:06:53
Text: DUA009,Front,M,0,0,6
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14204001628002080002
VCID: 4487B6EBC7EBA06FC1-8010
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H07 0100
Revision: 5G001001 Serial number: 00000135482843
Coding: 0109080000000000
VCID: 71E92F3FA8D965C75A-8024
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J19G1C7
Coding: 1090004
VCID: 26430C639197727FFF-8072
Component: TSG HR H04 0212
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Coding: 6A040000
ROD: EV_OnBoardCamerDPC.rod
VCID: 65C14B6F6411B96736-8030
Part No SW: 4G0 907 541 HW: 4G0 907 541
Coding: 3D04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X_001.rod
U1113 00 [008] - -
Reset counter: 80
Mileage: 172052 km
Date: 2020.05.25
Time: 16:59:39
Voltage terminal 15: 14.699 V
Velocity_vehicle_reference: -0.00 m/s
Longitudinal_acceleration_vehicle_reference: -0.22 m/s≤
U1113 00 [008] - -
Reset counter: 80
Mileage: 162829 km
Date: 2019.10.04
Time: 08:11:31
Voltage terminal 15: 14.179 V
U1113 00 [008] - -
Reset counter: 80
Mileage: 162829 km
Date: 2019.10.04
Time: 08:11:31
Voltage terminal 15: 14.203 V
U1113 00 [008] - -
Reset counter: 80
Mileage: 162829 km
Date: 2019.10.04
Time: 08:11:31
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H29 0034
Serial number: 000040182006117
Coding: 0480081C0111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 25410B6F24917967F6-8070
0080 - Video Cable for Image Processing
C1107 02 [024] - Signal Failure
Fault Frequency: 9
Reset counter: 249
Mileage: 169372 km
Date: 2020.02.26
Time: 21:45:24
Outside air temperature: 21.0 ∞C
Voltage terminal 15: 13.1 V
Control Module temperature: 24.0 ∞C
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
Fault Frequency: 139
Mileage: 171422 km
Date: 2020.04.05
Time: 14:31:39
Outside air temperature: 17.0 ∞C
Voltage terminal 15: 13.2 V
Control Module temperature: 17.0 ∞C
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 00660600031F037E000308004248D2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FED2947B6ED73374C-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70EF2A3BABD36CCF55-8024
End-------------------------(Elapsed Time: 06:16)--------------------------
