Seat Leon Cupra MY19 - ACC Retrofit
Somnus
SLC, USA
C?ID=215931
As far as the interior mirror, when I did my A5 camera retrofit (on a GTI with the 3Q0 facelift camera, mind you, so this may not apply completely) I didn't want to put the auto-dimming mirror at the time. so instead, I used a standard mirror (Part# 3G0-857-511-N-9B9) with the Rain-Light sensor mount and it fits rather well in the camera mount.
However, as darkchina said, if it is the 5Q0 camera, it is a whole different mirror.
stefan147
Greece
C?ID=361962
Yes I can see that for the Golf. The mirrors for Leon seem to be the same either with or without the A5. Only some plastic caps and trim changes.
   #23
siLc
Tallinn, Estonia
C?ID=330192
I would say you can use your existing auto-dimming interior mirror with the A5 camera windscreen mount without a worry. Did a A5 retrofit to a B8 and the old mirror fit without issues, just changed the plastic caps.
   #24
stefan147
Greece
C?ID=361962
So I'm waiting for all the parts (windscreen, harness, camera) to arrive for the A5 retrofit and yesterday I was playing with the coding. Should I be looking to something more than the famous XaGiCo pdf? I saw some differences in the adaptation channels between the pdf and my system which is production of late 2018.
Also I think I'm getting a brand new camera. What are the steps I should take? Coding with VCDS, parametrization with the "other tool" and then calibration?
I will be building VAS6430 on my own since I got a friend with a printing shop and then I'm taking it to a specialist with ODIS. Is there something I should have in mind? I have read all workshop manual instructions regarding distancing etc but I don't know if the calibration should take place in both daylight and night.
   #25
downtime
Finland
C?ID=280813
Enough if you calibrate it at normal room lighting. They don’t calibrate that for both in workshop either.
You can get the VAS boards printed from Aliexpress as well. The front camera cal board was around 50€
   #26
stefan147
Greece
C?ID=361962
Yeah I saw the boards at Aliexpress but god knows when it's coming from china to greece. Plus my friend will do it for free.
I also talked to that specialist about next steps with ACC and if I understood correctly he may be able to purchase some FeC codes. Is that a thing or is he just going to get to those "hacker" guys who I have already spoken to?
   #27
darkchina811
ITALY
C?ID=333184
the FeC code for ACC cannot be obtained officially. we are still not sure how those "hackers" do it, best guess is they clone it from a VIN who had it from the factory. there are chances you'll lose the FeC if you bring the car to a dealer for service and they do some advanced stuff with ODIS. it's your choice.
   #28
downtime
Finland
C?ID=280813
I’ve seen some of these specialist selling developer keys. If you have bad luck and you get blacklisted key, your car VIN might get banned from mothership server which means no CP nor IMMO jobs for that VIN anymore in the future.
stefan147
Greece
C?ID=361962
I will have to check back with the guy to get a better understanding of what he means. That's way too risky.
   #30
stefan147
Greece
C?ID=361962
So this ACC retrofit has made me feel like a criminal searching and talking to all those underground guys who ask for crazy money. I have a 3Q camera with trim and new windscreen on the way. If I understand correctly the round radar with only CP is not an option, right?
   #31
downtime
Finland
C?ID=280813
Not with 3Q0 camera :( It does not comply with that. The round radar is from 2013-2014 when there still were 5Q0 cameras only.
So only option is the expensive ACC :(
   #32
stefan147
Greece
C?ID=361962
Bummer...I guess I will retrofit all parts as they arrive and then activate only the A5 which is for free! :P If I don't spend much on vacation I will do the criminal part as well! :P
These radars should be fine with a 3Q0980654H (with TJA & Emergency assist) camera?
3QF907561A
3QF907561
5Q0907561G
5Q0907561H
Or maybe there are other compatible revisions too?
   #33
downtime
Finland
C?ID=280813
2Q0 works as well but I don’t know if they’re hackable.
   #34
stefan147
Greece
C?ID=361962
I will go for a 5Q since I will have to deal with hackers sooner or later and it has to be something they have done before. Question was more for the ending letter of the part number.
   #35
stefan147
Greece
C?ID=361962
So, since I'm still waiting for parts from our beloved China, I decided to fit the 3-lever stalk on the steering column in order to be ready for ACC coding. After taking off the old stalk (5Q0953507GP 2-lever with CC on the signals) I found out that it was connected with 3 different plugs whereas the 3-lever stalk (5Q1953507BQ) had only one input.
Luckily next door there is a shop which sort of specializes in VAGs and the guy saw me in trouble and suggested that I could exchange the 3-lever stalks with the old round part (the tape part). Which I did and it all seems to work fine. Signals, high beam, front/rear wipers etc are working fine.
I then coded J527 to have the "CC controlled via separate lever" but it doesn't work. I don't get any VCDS faults just sign B on the VC:
Is that something I should expect? ACC lever can only work as ACC and not as simple CC? Since I cannot fit the rest of the ACC parts to complete the retrofit for at least a month, it would be nice to have the CC working with the 3-lever stalk.
   #36
stefan147
Greece
C?ID=361962
Hi guys,
This weekend I managed to finish the installation of an ACC radar and an A5 camera. Both modules are used and the harness was purchased from Ali. As expected I am getting some fault codes. So I wanted to ask if any of these faults suggest wiring issues that should be taken care of before reassembling the car. I am mostly concerned about these "DATABUS" faults on the ACC & A5 cause all others pretty much make sense.
AutoScan: VSSZZZ5FZKR033386
VIN: VSSZZZ5FZKR033386   License Plate:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 32 42 44 4B 52 5F 6C A5
          A9 D6 D7
VIN: VSSZZZ5FZKR033386   Mileage: 27650km-17180miles
Address 01: Engine (J623-DNUC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 R    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 0B2540122424010B2000
   Shop #: WSC 00049 770 00185
   ASAM Dataset: EV_ECM20TFS0208V0906259R 001002
   ROD: EV_ECM20TFS0208V0906259N_AU37.rod
   VCID: 4FFA86EA575198539B9-801A
Readiness: 1110 0001
   Part No SW: 0GC 300 020 F    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2301
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 25160442656DB203015-8070
   Part No SW: 5Q0 614 517 DG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0654
   Revision: 00000000    Serial number: 62818000000025
   Coding: 20EE6B92C423216F877A060860C96904D62384E160069677204250F5C206430100000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 79AE1832B955E6E315D-802C
   Part No SW: 5F0 907 044 AM    HW: 5F0 907 044 AM
   Component: Climatronic   H05 1801
   Revision: 00001K09
   Coding: 00000014200114011005004000101020
   Shop #: WSC 00049 770 00103
   VCID: 71BE2012E125AEA3ADD-8024
   Air quality sensor:
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 00001830401711
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7DA60C22AD7DDAC3395-8028
   Subsystem 1 - Part No SW: 5F1 955 119 A    HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 181013  041 0574
   Serial number:         181022160952
   Coding: 0BC5FD
   Serial number: 21972964X81A955555A0
   Coding: 00005D
   Sun Roof:
   Subsystem 3 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.405  H04 0005
   Serial number: 0000FST0026VNZP00000
   Coding: 180102
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418018275
   Coding: 0471151011
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC091E6A647A34BFEB-8018
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 2D00608111FF8728949C814560400600000000000000000000
   Shop #: WSC 00049 770 00173
   VCID: 3C20C126F6E713CB4EB-8068
2185 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_TRANSMISSIONTYPE]
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:57
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 12.1 V
2141 - Databus
          [FAULT_DIS_FAIL]
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:57
0101 - Databus
          [FAULT_GRA_CODE]
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:57
          U1101 00 [009] - Active
          [FAULT_THP_EC_INVALID_IKA]
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:57
2119 - Databus
          [FAULT_TSK_ACC_CODING_PLAUS_FAIL]
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:57
   Serial number: 24071841351228
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3828DD36C2DF3FEBAA3-806C
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W4PMUFQXI
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 055664C2C5AD9203615-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 001 810 18
   Serial number: 35700000000567405234
   Subsystem 2 - Part No SW: -----------    HW: 454 001 810 18
   Serial number: 35800000000381CCE13R
   Subsystem 3 - Part No SW: -----------    HW: 454 801 610 18
   Serial number: 3510023129C160000002
   Subsystem 4 - Part No SW: -----------    HW: 454 801 210 18
   Serial number: 352004EE79F16000000.
   Subsystem 5 - Part No SW: -----------    HW: 454 801 210 18
   Serial number: 35500534D3B16000000G
   Part No SW: 5Q0 953 507 GP    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 28101820240153
   Coding: 2410
   VCID: 0A4C57FEECB3FD7B0C7-805E
   Part No SW: 5F0 920 790 A    HW: 5F0 920 790 A
   Component: KOMBI         609 1701
   Coding: 04AC29083B800008010876001001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_SE37.rod
   VCID: 270A0E4A1F61A013339-8072
          U1014 00 [009] - -
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:56
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0008592886
   Coding: 030100F42F085900EB0082699C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_SK26.rod
   VCID: 3D26CC22EDFD1AC3795-8068
   Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
   Serial number: 000000000H0769091018
   Coding: 012000
   Serial number: 75886002001810090719
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:56
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H52 8043
   Serial number: HA1-00020.07.18
   Coding: 0101
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FC8F9E4463F5BBB47-8006
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 0000349612563
   Coding: 00140320DC00020000001000
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000024396683
   Coding: 310000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   Component: FCM MQB Low   002 0345
   Serial number: 19101810520178
   Coding: 000000070900094A07000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 3536D402D5CDC283B15-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 0000349881950
   Coding: 00140120DE00020000001000
   VCID: 4EC49BEE505B915B90F-801A
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000024655943
   Coding: 290000
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5F0 035 877     HW: 5F0 035 877
   Component: MU-S-ND-ER    H50 0514
   Serial number: SEZAZ2U0842737
   Coding: 04738001FF0A00001111000100080A002F0202A101200400CE
   ASAM Dataset: EV_MUStd6C3TSAT 001015
   ROD: EV_MUStd6C3TSAT_SK25.rod
   VCID: 698E4872C9F55663E5D-803C
   Subsystem 1 - Part No SW: 5F0 919 606 A    HW: 5F0 919 606 A
   Component: ABTm-2_8-BL  H41 1042
   Serial number: SEZ8Z9V6D002G9
   Subsystem 2 - Part No SW: 6P0 919 866 AF    HW: -----------
   Component: ECE1 2018/19  --- 1030
   Coding: 04030101A2002017000060
   Shop #: WSC 00046 123 12345
   VCID: 392ED832F9D526E355D-806C
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:56
                    passive
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 20091815P24296
   Coding: 0002070600000401002200448150A90084000E000000
   Shop #: WSC 00020 999 00000
   ROD: EV_MFKBoschMQBB_001_SE37.rod
0768 - No Basic Setting
          B2010 00 [009] - -
          [Calibration_VIN_mismatch]
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:56
                    Outside air temperature: 19.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 169.7 s
                    Voltage terminal 15: 11.9 V
                    mid: 00 53
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Variant_coding_failure]
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:56
                    mid: 00 29
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122597 - Databus
          [Timeout_RDR1_Header]
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:56
                    System run time: 170.1 s
                    mid: 01 43
                    Status of camera: System malfunction
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
0659 - Steering
          C10AC F2 [009] - Lane-Holding Assistance Not Coded
          [HC_interface_at_the_steering_not_activated]
                    Reset counter: 80
                    Mileage: 27650 km
                    Date: 2020.11.09
                    Time: 11:24:57
                    System run time: 170.3 s
                    mid: 02 A6
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5F0 907 159 E    HW: 4H0 907 159 A
   Serial number: 180823202836
   VCID: 2F3AE66A3791F853FB9-807A
   ROD: EV_LED_PLUS_L_KEBODAVW416_SE37.rod
   VCID: 7EA40B2EA07BC1DB20F-802A
End----------(Elapsed Time: 01:44, VBatt start/end: 12.2V/12.2V)-----------
downtime
Finland
C?ID=280813
Code the modules first. That should get rid of most of the errors. For A5 you should be left with basic setting required and for ACC naturally removing of CP and insertion of SWaP.
   #38
stefan147
Greece
C?ID=361962
By coding I guess you mean the real deal with adaptions etc (of course the other tool too)? Because I tried some coding (but no adaptions) earlier today and all I got was more faults. Plus the radar refuses to even accept coding of auto trans (gives "out of range" message), probably coming from a manual T-Roc. Anyway I will do it properly as per Xagico manual and I will get back with a new scan.
   #39
downtime
Finland
C?ID=280813
Yes coding and adaptation :) plus possible datasets.
   #40
stefan147
Greece
C?ID=361962
So my freshly retrofitted ACC decided to go misaligned right after 300-400km of driving. Fault says "vertical misalignment". Is there anything VCDS can do about the calibration needed or I can only do that via ODIS?
