2015 Audi Q5 - Change from US BiXenon to Adaptive Headlights (AFS)- Problem with CP
Mezzo1161
TX, USA
C?ID=14476
Hi all,
I have recently swapped headlights from US BiXenon to AFS BiXenon with cornering lights. I am now stuck with the following:
- Error in the dash 'Audi adaptive headlight error'
- headlights do not level. The do the dip when engine starts but not sideways. When I raise the back of the car the headlights do not adjust
- Cornering light does not work
- Some features inhibited due to CP on the BCM
This was the extent of the retrofit so far:
- 2 new Headlights with the AFS control modules
- Swapped BCM from 8K0 907 063 DH to 8K0 907 063 DJ. (BCM -DH includes J431 which directly control the HL leveling. -DJ communicated with the AFS units and includes the HL washer output.)
- Modified wiring to connect Power and CAN bus comms to headlights and remove BCM control of headlight motors
- Added Headlamp washer system, connected to BCM
The new BCM was bought used and shows 'Component Protection' - went to the Audi dealer but unfortunately he was unable to remove CP. His statement was that the system would not allow it to program as it found 'hardware issues not allowing the control unit to sync with the vehicle'.
The following are the errors:
02095 - Component Protection Active (shown in BCM and CAN Gateway, the Gateway is original and I guess it is showing the BCM error, correct?)
02658 - Power Output Stage for Left Headlight (J667); Incorrectly Coded
02659 - Power Output Stage for Right Headlight (J668); Incorrectly Coded
The other errors seem to be irrelevant.
I have confirmed that the cabling is correct (the BCM lists the AFS modules as submodules and lights are working, except the cornering lights).
I have seen other scans that have successfully removed CP when matching the DJ BCM with my CAN Gateway on a similar age Q5.
I am unable to adjust the Headlights - when I enter Basic Settings and select 'Headlight Adjustment' it comes back with 'Wait' and 'N/A'.
The scan below also shows some HVAC errors which I have deleted in the meantime.
Any assistance on how to proceed would be much appreciated.
Werner
Friday,22,May,2020,11:41:30:16457
VCDS Version: 20.4.1.0
VIN: WA1CMAFP5EA033454   License Plate: MAY 22
Mileage: 104850km-65150mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
          62 6C 6D 72 AC
VIN: WA1CMAFP5EA033454   Mileage: 104850km-65150miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 401 J    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0014
   Revision: 58H14---
   Coding: 2A2A4012052603050000
   Shop #: WSC 29413 001 1048576
   ASAM Dataset: EV_ECM30TDI0118K5907401J 002014
   ROD: EV_ECM30TDI0118K5907401J_002.rod
   VCID: 3777C4CA8E0DCD3EFA-8062
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H16 1007
   Revision: --H16---
   VCID: 4B9F883AE28559DEAE-801E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AM    HW: 8R0 907 379 AM
   Component: ESP8 quattro  H09 0030
   Coding: 231D1C03
   Shop #: WSC 06335 000 00000
   VCID: 0B1F483AAA0519DE6E-805E
   Part No SW: 8K0 907 064 HP    HW: 8K0 907 064 GP
   Component: BCM2 2.0      H13 0641
   Coding: 0DA54040000000000000
   VCID: 050B7E028C616FAE38-8050
   Serial number: 0213000293035011
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01280820132045
   Coding: 3621228000
   VCID: 3973C2F2B019DB4E0C-806C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 62
                    Mileage: 104824 km
                    Date: 2020.05.21
                    Time: 09:08:48
                    Reset counter: 106
                    Mileage: 104824 km
                    Date: 2020.05.21
                    Time: 11:18:59
                    Temperature: 26.0∞C
                    Reset counter: 106
                    Mileage: 104824 km
                    Date: 2020.05.21
                    Time: 11:19:02
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000439094602
   Coding: 2600001100209F000020000300001D0D0F1C4700A6080261000008000000030200000034000000
   Shop #: WSC 06325 123 12345
   VCID: 7AF11DFEF59F105645-802E
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 130731  H11 0050
   Serial number: 90243014130723155619
   Coding: 01DD13
   Serial number: 21652870
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000308130164
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R72YY02
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H04 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H04 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 898881C6000000000001
                    Reset counter: 65
                    Mileage: 104846 km
                    Date: 2020.05.21
                    Time: 15:02:13
                    Fault Status: 01100101
                    Reset counter: 64
                    Mileage: 104846 km
                    Date: 2020.05.21
                    Time: 15:02:14
                    Reset counter: 64
                    Mileage: 104846 km
                    Date: 2020.05.21
                    Time: 15:02:14
                    Reset counter: 64
                    Mileage: 104846 km
                    Date: 2020.05.21
                    Time: 15:02:14
01229 - A/C Humidity Sensor (G260)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 64
                    Mileage: 104846 km
                    Date: 2020.05.21
                    Time: 15:02:17
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003GPDB09P4K
   Coding: 303634313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 4797B40AFEEDBDBE8A-8012
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R130000F34T
   Serial number: 6334MSME7C712675K
   Serial number: 6344MSME7D742B76V
   Serial number: 6352QSME14354E7ET
   Serial number: 6362QSME6135386CM
   Serial number: 63732SME5C3916787
   Serial number: 63832SME5C391A489
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862MHR000GD
   Coding: 000017
   VCID: 4895B736FBF3B2C683-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 A    HW: 8R0 920 982 A
   Component: KOMBIINSTR.   H35 0563
   Revision: 00300000    Serial number: WZE24PU8E
   Coding: 83BF22000B01D705020000
   Shop #: WSC 26348 004 104857
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z138120003
   Coding: 80CF03FF00
   Shop #: WSC 06335 123 12345
   VCID: 4C9D8B26EF8B5EE6A7-8018
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 40205B28291461796306
                    Reset counter: 63
                    Mileage: 104824 km
                    Date: 2020.05.21
                    Time: 11:11:52
                    Bin. Bits:    11111
                    Voltage: 12.50 V
                    Count: 6
                    Text: FFF1742C04828102
                    Text: 0000000000000000
                    Raw, Form. N/A: 000 000 000
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000072240714
   Coding: 01581B00000000000000
   VCID: 4281A51EDDCF98965D-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0312714733
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: 3F87ACEAA63DF57E32-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0313278237
   Coding: 010211
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000071679201
   Coding: 011D13205E00440004
   VCID: 4FA79C2A1E9D65FEC2-801A
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H38 0507
   Revision: 00001000    Serial number: 0012759425
   Coding: 100000000001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3B7FD8FAB225E95E1E-806E
   Revision: 00002001    Serial number: 0312970358
   Coding: 0126023A20BA709784A0053600040047
   Shop #: WSC 06334 123 12345
   Component: GTO BF  H01 0080
   Serial number: 00000000000000714945
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H05 0220
   Revision: 00005001    Serial number: 94813018967303
   VCID: 2D5BE6A2745177EE90-8078
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000071699308
   VCID: 4E99812E19976CF6C9-801A
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 20000000320427
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3973C2F2B819DB4E0C-806C
   Revision: AB001007    Serial number: 156H90D7838629
   Coding: 020007010000000001
   VCID: 244D0386279BB6A64F-8070
   Part No SW: 8R1 035 746 D    HW: 8R1 035 746 D
   Component: H-BNT-NA      H40 0738
   Revision: --------    Serial number: 204H+0D7595327
   Coding: 160200060005A1EF51028B4E00000403140000000000000000
   VCID: 3875C7F68B13C246F3-806C
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Component: DU7 High  H42 0104
   Serial number: A130HM0D2804430
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001591133
   Component: CD-Database  5298
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000072214610
   Coding: 010C13204000240004
   VCID: 4689B90EF1E7A4B671-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H08---    Serial number: 525PA8-J36A3G5
   Coding: 1020010
   VCID: 346DF3C6577B2626DF-8060
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B7FD8FABA25E95E1E-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000072214726
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0010
   Revision: 00000000    Serial number: 131910095
   ROD: EV_RDCMA00100.rod
   VCID: 2B5FE8BA424579DE8E-807E
End-------------------------(Elapsed Time: 05:55)--------------------------
Mezzo1161
TX, USA
C?ID=14476
I did some more digging and found some corrections in the BCM coding. Main question remains, how do I get the dealer to remove the cComponent Correction? I read somewhere else that VCDS may have issues to adjust the Headlights so that the remaining errors are removed and that the dealer should try this with VAS (?). Is that something I should try?
darkchina811
ITALY
C?ID=333184
as a rule of thumb, headlights won't work until you perform basic settings, and I bet you can't do that because CP is active.
I cannot (nor should) teach your dealer how to unlock CP, but their ODIS software is pretty simple/limited, all it usually takes is following the instructions on the screen.
if he cannot figure it out you need another (capable) dealer, or better one of the independents with dealer-level access. those are way more inclined to retrofits and know all ODIS tricks.
for the record, the gateway flagged CP because of the BCM swap. it will all be cleared during CP unlock procedure. nothing you can do with VCDS unfortunately.
golfi_vend
Tartu, Estonia
C?ID=195131
How do (group) of people get legal permission to use ODIS when they don't know how and then there are people who are very capable, but just aren't allowed?
As for OP, You should work out the Incorrecty Coded fault code. Your dealer failed, because of SVM on 09-BCM which is meant to fail when incorrect part is installed.
Let Your dealer do CP removal for BCM or CP Basic for gateway which will work through all modules.
Mezzo1161
TX, USA
C?ID=14476
Thank you both for your reply. I agree that a competent dealer will make it easier, unfortunately they are Limited were i live. The first dealer I asked didn’t even understand what CP meant....
Golfi_vend - when you say (You should work out the Incorrecty Coded fault code. Your dealer failed, because of SVM on 09-BCM which is meant to fail when incorrect part is installed) Can you please elaborate.
What is the incorrect fault code?
Do you think that an incorrect part is installed? I have seen the combination of Headlights, BCM and gateway with these PNs in the same model.
Thanks a lot for your time
Werner
Mezzo1161
TX, USA
C?ID=14476
Thinking about the dealer part ....
Is there a good process description I can use to ´educate my dealer ?
darkchina811
ITALY
C?ID=333184
it doesn't matter if that BCM actually works in your vehicle. if it's not the part that ETKA indicates for your VIN, then any ODIS guided procedure will fail because the server knows you are not using the "correct" replacement part.
there are of course ways around it but these are little secrets that are kept by the few who knows.
dealers know only official procedures and most retrofits are not.
Mezzo1161
TX, USA
C?ID=14476
Alright - so how do I ediucate my dealer to perform that modification?
Mezzo1161
TX, USA
C?ID=14476
Update on this journey:
The dealer was able to remove the component protection but could not do the Headlight adjustment via VAS. He attempted to 'adapt headlight power output stages but coding is not yet compatible with vehicle'. When we spoke i was happy that at least he was able to remove cp but in the aftermath should have asked him if he indeed tried to do the headlight adjustment so that the error go away (at least that is what i heard from other to do). Will call him tomorrow.
Error is still the same on DIS 'Audi adaptive headlight error'. The lights dip on startup, that's it.
I still can't do the headlight adjustment in VCDS - it always comes with 'Wait' when i go into address 9, Basic settings, group 11. Did post a question in another section of the forum but was politely asked to include the question here.
1. Does anyone have an idea why this does not work?
2. Also, can anyone with a A4 B8 with AFS send me their address 9 coding to compare?
3. I am still not sure if the system works without a front left level sensor... i only have the one in the rear left installed. Feedback?
For reference
Tuesday,26,May,2020,17:58:17:16457
VIN: WA1CMAFP5EA033454   License Plate: MAY25
Mileage: 104990km-65237mi   Repair Order:
          62 6C 6D 72 AC
VIN: WA1CMAFP5EA033454   Mileage: 104990km-65237miles
   Revision: 58H14---
   Revision: --H16---
   Coding: 231D1C03
   Coding: 3621228000
                    Reset counter: 69
                    Mileage: 104957 km
                    Date: 2020.05.26
                    Time: 15:00:26
                    Reset counter: 69
                    Mileage: 104990 km
                    Date: 2020.05.26
                    Time: 16:43:12
   Coding: 2680009100209F000020000300001D0D0F1C4700A6080261000000000000030200080034000000
   Coding: 01DD13
   Coding: 02005C
H04 0012
H04 0012
                    Reset counter: 69
                    Mileage: 104990 km
                    Date: 2020.05.26
                    Time: 16:52:46
                    Reset counter: 69
                    Mileage: 104990 km
                    Date: 2020.05.26
                    Time: 16:52:46
                    Reset counter: 69
                    Mileage: 104990 km
                    Date: 2020.05.26
                    Time: 16:52:46
            014 - Defective
                    Reset counter: 69
                    Mileage: 104990 km
                    Date: 2020.05.26
                    Time: 16:52:49
   Coding: 000017
   Coding: 80CF03FF00
   Coding: 010211
   Coding: 010211
   Coding: 1020010
End-------------------------(Elapsed Time: 04:53)--------------------------
Werner
Mrclopec
Nipomo, CA
C?ID=149231
The front level sensor is REQUIRED.
The headlights do not do the left/right dance like a VW. They will only dip and go back up so thats normal.
The power output modules are not directly coded. They will sync with the BCM automatically once your coding is correct.
I have a 2015 Q5 with factory AFS. You can compare my 09 coding to yours.
From what I remember, the basic settings procedure will just put the headlights into adjustment mode for you to make manual adjustments via the adjustment points on the headlights and then when you click next/done the procedure is complete.
None of this will work if you don't have your coding correct and all hardware installed properly.
Break out your wiring diagram and VERIFY VERIFY VERIFY.
Mezzo1161
TX, USA
C?ID=14476
Thanks Mrclopec
I have ordered the front left level sensor and will test it once installed. Your notes about coding is what i was told earlier so that is great.
I have quadrupel checked the wiring and believe it is correct. The fact that i can reach the AFS controllers (sub address via BCM), the dipping and the other functions make me believe that it is correct.
Where can i find your Q5 coding? I'll search the forum but if you could post or send it i would very much appreciate it. I am especially interested to see your module partnumbers (BCM, AFS...).
Werner
Mezzo1161
TX, USA
C?ID=14476
Mrclopec - can you share your address 09 code with me? Or anyone with a Q5 (8R) with AFS.
Confirmed with the dealer that they in fact went into the BCM setting but VAS also was not able to finish the setup. He says it is either the coding or any HW/Firmware incompatibilities.
I checked the wiring again and it is as per the diagram. Interestingly there are 2 versions of AFS headlights (one has a swivel level sensor - the other does not) but the interface wiring is the same.
The front left sensor should be here tomorrow ...
Mezzo1161
TX, USA
C?ID=14476
Tested with the front left sensor installed but no success. Still not able to do the Headlight adjustment in VCDS. Too bad....
If anyone has another idea please let me know
Mezzo1161
TX, USA
C?ID=14476
Alright - time to call it a failure. The BCM does not recognize the front sensor, only the rear sensor throws an error when disconnected. I will revert back to non AFS headlights and call it a day. Thank you for your help
Mrclopec
Nipomo, CA
C?ID=149231
Here is a comparison of my coding to your May 27 post:
Quick comparison of two codings
Coding 1: 26000091867CAFF21100488300003D0D4F9CE708A6090221000008004000010200040034000000
Coding 2: 2680009100209F000020000300001D0D0F1C4700A6080261000000000000030200080034000000
Byte 1, Bit 7
Byte 4, Bit 1
Byte 4, Bit 2
Byte 4, Bit 7
Byte 5, Bit 2
Byte 5, Bit 3
Byte 5, Bit 4
Byte 5, Bit 6
Byte 6, Bit 4
Byte 6, Bit 5
Byte 7, Bit 1
Byte 7, Bit 4
Byte 7, Bit 5
Byte 7, Bit 6
Byte 7, Bit 7
Byte 8, Bit 0
Byte 8, Bit 4
Byte 9, Bit 5
Byte 10, Bit 3
Byte 10, Bit 6
Byte 11, Bit 7
Byte 14, Bit 5
Byte 16, Bit 6
Byte 17, Bit 7
Byte 18, Bit 5
Byte 18, Bit 7
Byte 19, Bit 3
Byte 21, Bit 0
Byte 23, Bit 6
Byte 26, Bit 3
Byte 28, Bit 6
Byte 30, Bit 1
Byte 33, Bit 2
Byte 33, Bit 3
Mezzo1161
TX, USA
C?ID=14476
Thank you - i am looking thru these now.
Quick question: You have not coded Byte 9 Bit 5 (Cornering light via AFS) and Byte 33 Bits 1-3 (Static cornering light NOT active). Do you have dynamic lights without the fixed cornering bulb (H7 i think)?
Mrclopec
Nipomo, CA
C?ID=149231
Sometimes the VCDS labels can be somewhat misleading/vague. Just because a box says AFS, doesn't mean its supposed to be checked. Do not enable Byte 9 bit 5.
Per your last autoscan on May 27, your byte 33 bits 1-3 are set to 08 - Static Cornering Light (SKL) According to SAE Specification J582. Mine is set to 04 - Static Cornering Light (SKL) According to ECE Specification R119.
Mrclopec
Nipomo, CA
C?ID=149231
Private Message Sent
Mezzo1161
TX, USA
C?ID=14476
With the help of Mrclopec i have modified my coding based on his suggestions - and surprise, surprise the BCM is now expecting a front left level sensor. Installed the sensor i had but i believe it is faulty (resistive values differ quite a bit from the same sensor at the back). Have ordered an original 9R0981285G and will test it again. Interestingly i kept on having Headlight adjust errors and both output stage errors while i had the other front sensor tested. Now that i have removed it, the only error is the missing front sensor...
This is my current scan
Monday,08,June,2020,21:42:58:16457
VIN:    License Plate:
Mileage:    Repair Order:
          62 6C 6D 72 AC
VIN:    Mileage:
   Revision: 58H14---
Readiness: 0 0 0 1 1
   Revision: --H16---
   Coding: 231D1C03
   Coding: 3621228000
                    Reset counter: 81
                    Mileage: 105540 km
                    Date: 2020.06.08
                    Time: 20:37:15
   Coding: 26000091863CAF000000400300001D0D0F1C4708A6090261000008004000010200040034000000
   Coding: 01DD13
   Coding: 02005C
H04 0012
H04 0012
00496 - Sensor for Vehicle Leveling; Front
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 81
                    Mileage: 105540 km
                    Date: 2020.06.08
                    Time: 20:37:16
            014 - Defective
                    Reset counter: 81
                    Mileage: 105540 km
                    Date: 2020.06.08
                    Time: 20:37:19
   Coding: 000017
   Coding: 80CF03FF00
   Coding: 010211
   Coding: 010211
   Coding: 1020010
End-------------------------(Elapsed Time: 04:50)--------------------------
