We changed the clock spring after it´s cable has failed. With new clock spring module there appeared several fault codes. Most of the codes and indicator lights turned off when we made steering angle configuration through ABS module and teached the steering wheel turning limits by turning wheel from one limit to another. We also modified the steering wheel module long coding to be proper (cruise control and some other buttons were mixed). Now the power steering MIL is still on and i have no more ideas what to redefine or modify.
According to autoscan it seems that G85 has no connection to other systems, i suppose. When we tried to calibrate steering angle sensor through Steering wheel module, VCDS says that data is in wrong form.
New clock spring part should be same kind as original, spare part is OE part from VW seller and it has been ordered with part number from original part.
What should i do next? Thanks in advance
Sunday,17,May,2020,17:21:06:05483
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 20.4.1.0
Dealer/Shop Name: Valtterin Paja Oy
VIN: WVGZZZ5NZDW101302 License Plate: CIZ-307
Mileage: 150600km-93578mi Repair Order: tiguan skannaus3
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 18 19 22 25 42 44 46 4C 52 53 56 61 62
69 72
VIN: WVGZZZ5NZDW101302 Mileage: 150600km-93578miles
04-Steering Angle -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 E HW: 03L 907 309 AE
Component: R4 2.0l TDI X28 9977
Revision: 41X28--- Serial number: 00000000000000
Coding: 0019001A043601080000
Shop #: WSC 16004 205 00000
ASAM Dataset: EV_ECM20TDI01103L906018E 003010
ROD: EV_ECM20TDI01103L906018E_VW36.rod
VCID: 2C570AEC471E5CE687-8078
4984 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 00 [101] - Electrical Fault
Mileage: 150601 km
Date: 2020.05.17
Time: 00:21:39
Engine speed: 890.50 /min
Normed load value: 34.1 %
Coolant temperature: 19 °C
Intake air temperature: 9 °C
Voltage terminal 30: 12.380 V
Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
Electric auxiliary heater: relay activation-Bits 0-7: 0
Preheat time: 300 ms
Glow status-Bits 0-7: 0
Glow status-Bits 0-7: 176
Glow cycles above temperature threshold-Bits 0-7: 8
Glow cycles above temperature threshold-Bits 0-7: 10
Glow cycles below temperature threshold-Bits 0-7: 6
Glow cycles below temperature threshold-Bits 0-7: 74
Outside air temperature: 8.0 °C
4729 - Steering Effort Control Module
U0130 00 [038] - No Communications
Mileage: 150601 km
Date: 2020.05.17
Time: 00:21:30
Limitation: accelerator pedal: 126.6 Nm
Cruise Control System (CCS): status-Bits 0-7: 40
selected gear-Bits 0-7: 0
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BD HW: 5N0 614 109 BD
Component: J104 C6 450M VD61 0011
Revision: --H07--- Serial number: 00000006828627
Coding: 0037950
VCID: 6ED3C0E479826EF6E9-803A
Part No SW: 5K0 907 044 GM HW: 5K0 907 044 GM
Component: Climatronic H19 1313
Revision: 00001004
Coding: 0010004003
VCID: 7CF7FAACF7FE0C6657-8028
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0068
Revision: BC021001
Coding: 40180A3B88251AC0408800C0340081644B51AA88636DAD606480C7000041
VCID: 3E7330A4A962DE7639-806A
Subsystem 1 - Part No SW: 5N1 955 119 C HW: 5N1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 19021 10 0603
Coding: 009795
Component: RLS 040413 05 54 0403
Coding: 02304D
Reset counter: 136
Mileage: 150591 km
Date: 2014.10.07
Time: 05:41:30
Term 15 Off
Voltage: 12.30 V
Reset counter: 137
Mileage: 150591 km
Date: 2014.10.07
Time: 05:25:42
Term 15 On
Voltage: 12.35 V
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 97
Mileage: 150601 km
Date: 2014.10.08
Time: 00:00:05
Term 15 Off
Voltage: 12.75 V
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__20J VW10 HI 2118
Revision: 26019000 Serial number: 003L7P5XT1VQ
Coding: 0012362
VCID: 7CF7FAAC3FFE0C6657-8028
Subsystem 1 - Serial number: 6332MTS612120733
Subsystem 2 - Serial number: 6342MTS632030723
Subsystem 3 - Serial number: 6351HTS6EQ4FRBKR
Subsystem 4 - Serial number: 6361HTS60MVFRBKJ
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20200303200218
Coding: 1182140000
Shop #: WSC 01286 386 08256
VCID: 020B8454951A7A961D-8056
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Serial number: 0560351
Coding: 820000
Part No SW: 5N0 920 883 A HW: 5N0 920 883 A
Component: KOMBI H05 0505
Coding: 111F01
VCID: 326B1494653A0A16CD-8066
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 C
Component: Standheizer 044 4840
Revision: 00044000 Serial number: 09024302000000
Coding: 0031032
VCID: 35612F885C541D2EE8-8060
Part No SW: 7N0 907 530 AG HW: 7N0 907 530 AG
Component: J533 Gateway H53 1634
Revision: H53 Serial number: 290313F1001044
Coding: 356002
VCID: 75E1EF88DCD45D2E28-8020
Reset counter: 137
Mileage: 150591 km
Date: 2014.10.07
Time: 05:25:41
Fault Status: 00110100
Reset counter: 136
Mileage: 150591 km
Date: 2014.10.07
Time: 05:41:31
Part No SW: 0AY 907 554 E HW: 0AY 907 554 E
Component: Haldex 4Motion 0043
Coding: 0000005
VCID: 4D916768D4C475EEB0-8018
Reset counter: 10
Mileage: 150583 km
Date: 2014.10.07
Time: 03:58:40
Component: IMMO H05 0505
VCID: 6ADBCCF48D6A82D6B5-803E
Part No SW: 5N0 959 701 G HW: 3C0 959 793 C
Component: TUER-SG FT 002 0503
Revision: 12110009 Serial number: 0006728189
Coding: 0210BE
VCID: 397923B8B84CF94E0C-806C
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 F HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1504
Serial number: 00000007793485
Coding: 000090
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.287 1202
Revision: 1BH04839 Serial number: 00130800160701
Coding: 0000258
VCID: 3F8D4DA06E68D77E32-806A
03375 - Steering Motor
003 - Mechanical Failure - MIL ON
Fault Status: 11100011
Reset counter: 95
Mileage: 150583 km
Date: 2014.09.23
Time: 02:14:53
(no units): 7.0
Steering Angle: 0.00°
OK
(no units): 11
Reset counter: 137
Mileage: 150601 km
Date: 2014.10.08
Time: 00:21:52
Term 15 On
RPM: 902 /min
(no units): 7.0
Voltage: 14.70 V
Part No SW: 5N0 959 702 G HW: 3C0 959 792 C
Component: TUER-SG BT 002 0503
Revision: 14110009 Serial number: 0006722182
Coding: 0211BE
VCID: 3A7B3CB4BD4AF25605-806E
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 F HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1504
Serial number: 00000007790997
Coding: 000090
Revision: H19 Serial number: 00000000865900
Coding: 0026167
VCID: 3663288441521636E1-8062
Address 56: Radio
Part No SW: 7N0 907 534 HW: 7N0 907 530 AG
Component: Batt.regelung H53 1634
Coding: 230F1859
VCID: 71E9DB98A8BC710EF4-8024
Component: J367-BDM H07 0180
Serial number: 40081A55571491170082
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Anhaenger H10 0110
Revision: 3B001001 Serial number: 00000193132056
Coding: 410D000101000000
VCID: 31691B98683C310EB4-8064
End-------------------------(Elapsed Time: 02:47)--------------------------
Address 09: DTCs cleared
Address 16,5K0 953 569 AL,recoded (Long Coding),from,1182140000,to,1182150000,(01286/386/08256),
Address 16,5K0 953 569 AL,recoded (Long Coding),from,1182140000,to,1182140002,(01286/386/08256),
Address 16,5K0 953 569 AL,recoded (Long Coding),from,1182140002,to,1182140000,(01286/386/08256),
Address 44: DTCs cleared
