Tiguan Steering angle sensor problem
Valpaoy
Finland
We changed the clock spring after it´s cable has failed. With new clock spring module there appeared several fault codes. Most of the codes and indicator lights turned off when we made steering angle configuration through ABS module and teached the steering wheel turning limits by turning wheel from one limit to another. We also modified the steering wheel module long coding to be proper (cruise control and some other buttons were mixed). Now the power steering MIL is still on and i have no more ideas what to redefine or modify.
According to autoscan it seems that G85 has no connection to other systems, i suppose. When we tried to calibrate steering angle sensor through Steering wheel module, VCDS says that data is in wrong form.
New clock spring part should be same kind as original, spare part is OE part from VW seller and it has been ordered with part number from original part.
Sunday,17,May,2020,17:21:06:05483
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 20.4.1.0
Dealer/Shop Name: Valtterin Paja Oy
VIN: WVGZZZ5NZDW101302   License Plate: CIZ-307
Mileage: 150600km-93578mi   Repair Order: tiguan skannaus3
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 18 19 22 25 42 44 46 4C 52 53 56 61 62
          69 72
VIN: WVGZZZ5NZDW101302   Mileage: 150600km-93578miles
04-Steering Angle -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Sporadic communication error 1000
   Part No SW: 03L 906 018 E    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   X28 9977
   Revision: 41X28---    Serial number: 00000000000000
   Coding: 0019001A043601080000
   Shop #: WSC 16004 205 00000
   ASAM Dataset: EV_ECM20TDI01103L906018E 003010
   ROD: EV_ECM20TDI01103L906018E_VW36.rod
   VCID: 2C570AEC471E5CE687-8078
4984 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [101] - Electrical Fault
                    Mileage: 150601 km
                    Date: 2020.05.17
                    Time: 00:21:39
                    Engine speed: 890.50 /min
                    Normed load value: 34.1 %
                    Coolant temperature: 19 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 12.380 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Preheat time: 300 ms
                    Glow status-Bits 0-7: 0
                    Glow status-Bits 0-7: 176
                    Glow cycles above temperature threshold-Bits 0-7: 8
                    Glow cycles above temperature threshold-Bits 0-7: 10
                    Glow cycles below temperature threshold-Bits 0-7: 6
                    Glow cycles below temperature threshold-Bits 0-7: 74
                    Outside air temperature: 8.0 °C
4729 - Steering Effort Control Module
          U0130 00 [038] - No Communications
                    Mileage: 150601 km
                    Date: 2020.05.17
                    Time: 00:21:30
                    Engine speed: 0.00 /min
                    Limitation: accelerator pedal: 126.6 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    selected gear-Bits 0-7: 0
   Part No SW: 5N0 614 109 BD    HW: 5N0 614 109 BD
   Component: J104   C6 450M VD61 0011
   Revision: --H07---    Serial number: 00000006828627
   Coding: 0037950
   VCID: 6ED3C0E479826EF6E9-803A
   Part No SW: 5K0 907 044 GM    HW: 5K0 907 044 GM
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004003
   VCID: 7CF7FAACF7FE0C6657-8028
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0068
   Revision: BC021001
   Coding: 40180A3B88251AC0408800C0340081644B51AA88636DAD606480C7000041
   VCID: 3E7330A4A962DE7639-806A
   Subsystem 1 - Part No SW: 5N1 955 119 C    HW: 5N1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 19021  10  0603
   Coding: 009795
   Component: RLS 040413 05  54  0403
   Coding: 02304D
                    Reset counter: 136
                    Mileage: 150591 km
                    Date: 2014.10.07
                    Time: 05:41:30
                        Term 15 Off
                    Voltage: 12.30 V
                    Reset counter: 137
                    Mileage: 150591 km
                    Date: 2014.10.07
                    Time: 05:25:42
                    Voltage: 12.35 V
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 97
                    Mileage: 150601 km
                    Date: 2014.10.08
                    Time: 00:00:05
                        Term 15 Off
                    Voltage: 12.75 V
   Component: J234__20J VW10 HI   2118
   Revision: 26019000    Serial number: 003L7P5XT1VQ
   Coding: 0012362
   VCID: 7CF7FAAC3FFE0C6657-8028
   Subsystem 1 - Serial number: 6332MTS612120733
   Subsystem 2 - Serial number: 6342MTS632030723
   Subsystem 3 - Serial number: 6351HTS6EQ4FRBKR
   Subsystem 4 - Serial number: 6361HTS60MVFRBKJ
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20200303200218
   Coding: 1182140000
   Shop #: WSC 01286 386 08256
   VCID: 020B8454951A7A961D-8056
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0560351
   Coding: 820000
   Part No SW: 5N0 920 883 A    HW: 5N0 920 883 A
   Component: KOMBI         H05 0505
   Coding: 111F01
   VCID: 326B1494653A0A16CD-8066
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 C
   Component: Standheizer     044 4840
   Revision: 00044000    Serial number: 09024302000000
   Coding: 0031032
   VCID: 35612F885C541D2EE8-8060
   Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
   Component: J533  Gateway H53 1634
   Revision:   H53       Serial number: 290313F1001044
   Coding: 356002
   VCID: 75E1EF88DCD45D2E28-8020
                    Reset counter: 137
                    Mileage: 150591 km
                    Date: 2014.10.07
                    Time: 05:25:41
                    Fault Status: 00110100
                    Reset counter: 136
                    Mileage: 150591 km
                    Date: 2014.10.07
                    Time: 05:41:31
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: 4D916768D4C475EEB0-8018
                    Reset counter: 10
                    Mileage: 150583 km
                    Date: 2014.10.07
                    Time: 03:58:40
   Component: IMMO          H05 0505
   VCID: 6ADBCCF48D6A82D6B5-803E
   Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0503
   Revision: 12110009    Serial number: 0006728189
   Coding: 0210BE
   VCID: 397923B8B84CF94E0C-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1504
   Serial number: 00000007793485
   Coding: 000090
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.287 1202
   Revision: 1BH04839    Serial number: 00130800160701
   Coding: 0000258
   VCID: 3F8D4DA06E68D77E32-806A
03375 - Steering Motor
            003 - Mechanical Failure - MIL ON
                    Fault Status: 11100011
                    Reset counter: 95
                    Mileage: 150583 km
                    Date: 2014.09.23
                    Time: 02:14:53
                    (no units): 7.0
                    Steering Angle: 0.00°
                        OK
                    (no units): 11
                    Reset counter: 137
                    Mileage: 150601 km
                    Date: 2014.10.08
                    Time: 00:21:52
                    RPM: 902 /min
                    (no units): 7.0
                    Voltage: 14.70 V
   Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0503
   Revision: 14110009    Serial number: 0006722182
   Coding: 0211BE
   VCID: 3A7B3CB4BD4AF25605-806E
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1504
   Serial number: 00000007790997
   Coding: 000090
   Revision:   H19       Serial number: 00000000865900
   Coding: 0026167
   VCID: 3663288441521636E1-8062
Address 56: Radio
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
   Component: Batt.regelung H53 1634
   Coding: 230F1859
   VCID: 71E9DB98A8BC710EF4-8024
   Component: J367-BDM  H07 0180
   Serial number: 40081A55571491170082
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00000193132056
   Coding: 410D000101000000
   VCID: 31691B98683C310EB4-8064
End-------------------------(Elapsed Time: 02:47)--------------------------
Address 09: DTCs cleared
Address 16,5K0 953 569 AL,recoded (Long Coding),from,1182140000,to,1182150000,(01286/386/08256),
Address 16,5K0 953 569 AL,recoded (Long Coding),from,1182140000,to,1182140002,(01286/386/08256),
Address 16,5K0 953 569 AL,recoded (Long Coding),from,1182140002,to,1182140000,(01286/386/08256),
Address 44: DTCs cleared
What should i do next? Thanks in advance :)
Hi and welcome.
Do you have a scan from before you replaced the clock spring?
PS: Based on the scan, I've been able to Verify the OP, so moving to Car Repair Support.
Valpaoy
Finland
Thanks about getting verified :thumbs:
Here is the scan with old clock spring:
Saturday,02,May,2020,14:52:08:05483
Mileage: 150580km-93566mi   Repair Order:
          69 72
VIN: WVGZZZ5NZDW101302   Mileage: 150580km-93566miles
15-Airbags -- Status: Malfunction 1010
5132 - Valve for Fuel Metering (N290)
          P0090 00 [032] - Open Circuit
                    Mileage: 150334 km
                    Date: 2020.04.05
                    Time: 09:57:58
                    Coolant temperature: 16 °C
                    Intake air temperature: 4 °C
                    Voltage terminal 30: 13.160 V
                    Unlearning counter according OBD: 36
                    Engine status: COENG_FINISH
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
          P0671 00 [047] - Electrical Fault
                    Mileage: 91968 km
                    Date: 2018.01.18
                    Time: 10:38:44
                    Engine speed: 1039.00 /min
                    Normed load value: 56.1 %
                    Vehicle speed: 2 km/h
                    Coolant temperature: 22 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 12.220 V
                    Preheat time: 0 ms
                    Glow cycles above temperature threshold-Bits 0-7: 4
                    Glow cycles above temperature threshold-Bits 0-7: 200
                    Glow cycles below temperature threshold-Bits 0-7: 4
                    Glow cycles below temperature threshold-Bits 0-7: 52
                    Outside air temperature: 19.5 °C
4710 - No Communications with Airbag Control Module
          U0151 00 [032] - -
                    Mileage: 150334 km
                    Coolant temperature: 0 °C
                    Intake air temperature: 1 °C
                    Voltage terminal 30: 11.540 V
                    Cruise Control System (CCS): status-Bits 0-7: 44
   Component: J104   C6 450M VD5F 0011
   Coding: 0037950
                    Reset counter: 131
                    Mileage: 150334 km
                    Date: 2014.08.27
                    Time: 09:55:11
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.25 V
                    Bin. Bits: 00011111
                    Count: 257
                    Hex Value: 0x0000
   Revision: 00001004
   Coding: 0010004003
   Revision: BC021001
   Coding: 009795
   Coding: 02304D
8 Faults Found:
                    Fault Status: 00101011
                    Reset counter: 135
                    Mileage: 150334 km
                    Date: 2014.08.27
                    Time: 09:40:50
                        Term 15 Off
                    Voltage: 12.50 V
                    Reset counter: 135
                    Mileage: 150582 km
                    Date: 2014.09.23
                    Time: 14:30:03
                        Term 15 Off
                    Voltage: 12.25 V
                    Fault Status: 00101001
                    Reset counter: 135
                    Mileage: 150582 km
                    Date: 2014.09.23
                    Time: 14:26:56
                        Term 15 Off
                    Voltage: 12.30 V
00924 - Relay for Headlamp Cleaning System (J39)
                    Reset counter: 135
                    Mileage: 150334 km
                    Date: 2014.08.27
                    Time: 09:40:50
                        Term 15 Off
                    Voltage: 12.50 V
                    Reset counter: 131
                    Mileage: 150334 km
                    Date: 2014.08.27
                    Time: 09:55:14
                    Voltage: 11.85 V
                    Fault Status: 00101010
                    Reset counter: 131
                    Mileage: 147138 km
                    Date: 2014.06.04
                    Time: 11:47:35
                    Voltage: 11.95 V
                    Reset counter: 135
                    Mileage: 150582 km
                    Date: 2014.09.23
                    Time: 14:26:56
                        Term 15 Off
                    Voltage: 12.30 V
                    Reset counter: 135
                    Mileage: 150334 km
                    Date: 2014.08.27
                    Time: 09:40:50
                        Term 15 Off
                    Voltage: 12.50 V
   Coding: 0012362
                    Fault Status: 11100001
                    Mileage: 148213 km
                    Date: 2014.06.30
                    Time: 14:27:56
   Part No SW: 5K0 953 501 BH    HW: 5K0 953 569 L
   Revision: FF010041    Serial number: 20130402200667
   Coding: 1182140000
   VCID: 71E9DB98A0BC710EF4-8024
365080 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 27
                    Mileage: 148213 km
                    Date: 2020.02.07
                    Time: 14:27:53
   Coding: 111F01
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 131
                    Mileage: 150334 km
                    Date: 2020.04.05
                    Time: 09:55:12
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 135
                    Mileage: 150582 km
                    Date: 2020.05.02
                    Time: 14:30:02
   Coding: 0031032
                    Reset counter: 131
                    Mileage: 150334 km
                    Date: 2014.08.27
                    Time: 09:55:14
00664 - Fuel gauge
                    Fault Frequency: 107
                    Reset counter: 130
                    Mileage: 140650 km
                    Date: 2014.02.25
                    Time: 11:04:42
   Coding: 356002
                    Reset counter: 131
                    Mileage: 150334 km
                    Date: 2014.08.27
                    Time: 09:55:12
                    Reset counter: 135
                    Mileage: 150582 km
                    Date: 2014.09.23
                    Time: 14:30:02
   Coding: 0000005
   Coding: 0210BE
   Slave Driver:
   Coding: 000090
68107 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 131
                    Mileage: 150334 km
                    Date: 2020.04.05
                    Time: 09:55:13
   Coding: 0000258
   Coding: 0211BE
   Slave Passenger:
   Coding: 000090
          U1111 00 [008] - -
                    Reset counter: 131
                    Mileage: 150334 km
                    Date: 2020.04.05
                    Time: 09:55:13
   Coding: 0026167
                    Reset counter: 131
                    Mileage: 150334 km
                    Date: 2014.08.27
                    Time: 09:55:11
                    Voltage: 11.40 V
                    Count: 74
                    Hex Value: 0x1273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 56: Radio
   Coding: 230F1859
02563 - Trailer; Right Tail Lamps (M61)
                    Fault Status: 11101010
                    Reset counter: 94
                    Mileage: 150551 km
                    Date: 2014.08.30
                    Time: 12:53:33
End-------------------------(Elapsed Time: 03:15)--------------------------
United States
Thanks for including the older scan! The original 5K0-953-501-BH module does super several times but the 5K0-953-569-AL unit they sold you appears to be correct. We do have some 5K0-953-569-AL specific notes here but that (5N) Tiguan Limited horror story had a conflict with 02-Auto transmission. Since this vehicle has a manual transmission I don't believe that's the issue.
Instead, I wonder if the brand new slip ring/16 module has problems? We encountered a brand new, dealer sourced, faulty new slip ring last week on a NAR market 2014 Passat and that car used:
>    Revision: --X01---    Serial number: Removed
>    Coding: 098A140000
>    Shop #: Removed
>    Multifunction steering wheel control module:
>    Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
>    Component: E221__MFL-YVJ  H07 0022
>    Coding: E20000
> 1 Fault Found:
> 1140738 - Steering angle sensor
>           B1168 54 [009] - Missing Calibration / Basic Setting
That car needed G85 activated in address 16 coding (just like yours) and the ABS module would NOT calibrate G85 until the new module was replaced with another new unit from the dealer.
I don't usually point blame at brand new dealer sourced parts but if the manufacture happened to have a bad run of parts you may have the same problem. I don't see any signs of G85 problems prior to the new 16 module installation and it looks more like it had the common N95 Airbag issue previously.
United States
P.S. I never really looked at serial numbers in those modules but I tend to remove them when I'm posting scan data that I don't have explicit permission to share. In this case that was the new defective module so I believe it OK to share:
Serial number: 20200121300539 (His)
Serial number: 20200303200218 (Yours)
My guess is they were manufactured on Jan 21st and March 3rd of this year. I don't have a final scan from that exact Passat but if you end up determining it twas a faulty new unit please post the final scan. It might help if we end up receiving more of these inquiries with new G85 problems after repairs.
NostraJackAss
You may find that SVM dealer session is needed and I'm hearing this more and more, so please let us know if that is the case?
Valpaoy
Finland
Thanks a lot about your tips and advises!
1. I talked with local VW dealer about the situation and they ordered a new clock spring.
2.I installed it. And scan looked like this:
Wednesday,03,June,2020,22:35:43:05483
Mileage: 150600km-93578mi   Repair Order: 1. scan with 3.clock spring
          69 72
4481 - Cruise Control Switch (E45)
          P0568 00 [039] - Implausible Signal
                    Mileage: 150601 km
                    Date: 2020.06.03
                    Time: 06:44:54
                    Coolant temperature: 23 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 11.440 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 128
                    Cruise Control System (CCS): status-Bits 0-7: 8
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 150601 km
                    Date: 2020.06.03
                    Time: 06:44:54
                    Cruise Control System (CCS): switch position-Bits 0-7: 192
                    Cruise Control System (CCS): status-Bits 0-7: 200
          P0671 00 [109] - Electrical Fault
                    Mileage: 150601 km
                    Date: 2020.05.17
                    Time: 00:21:39
          U0130 00 [032] - No Communications
                    Mileage: 150601 km
                    Date: 2020.05.17
                    Time: 00:21:30
   Coding: 0037950
                    Reset counter: 97
                    Mileage: 150601 km
                    Date: 2014.10.25
                    Time: 06:45:04
                    Hex Value: 0x0000
                    Voltage: 12.50 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
                    Reset counter: 97
                    Mileage: 150601 km
                    Date: 2014.10.25
                    Time: 06:45:04
   Revision: 00001004
   Coding: 0010004003
   Revision: BC021001
   Coding: 009795
   Coding: 02304D
   Coding: 0012362
   Revision: --X01---    Serial number: 20200306100810
   Coding: 7982A00000
   Coding: 820000
13 Faults Found:
0516 - Databus
                    Reset counter: 97
                    Mileage: 150601 km
                    Date: 2020.06.03
                    Time: 06:44:55
147462 - Terminal 15
          B1148 12 [009] - Short to Plus
226827 - Turn Signal Switch
          B1144 13 [008] - Open Circuit
                    Reset counter: 137
226839 - Turn Signal Switch
          B1144 11 [008] - Short to Ground
                    Reset counter: 137
227339 - Windshield Wiper Switch
          B1145 13 [008] - Open Circuit
                    Reset counter: 137
          B1149 13 [009] - Open Circuit
                    Fault Frequency: 8
                    Reset counter: 97
229127 - Cruise Control Switch
          B1154 11 [009] - Short to Ground
229147 - Cruise Control Switch
          B1154 13 [009] - Open Circuit
332660 - Databus
                    Reset counter: 137
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
          U108E 00 [008] - No Communications
                    Reset counter: 137
617736 - Selector Lever Park Position Lock Switch
          B1162 29 [008] - Signal Implausible
                    UBat: 13.30 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Coding: 111F01
   Coding: 0031032
   Coding: 356002
                    Reset counter: 137
                    Mileage: 150591 km
                    Date: 2014.10.07
                    Time: 05:25:41
                    Reset counter: 136
                    Mileage: 150591 km
                    Date: 2014.10.07
                    Time: 05:41:31
   Coding: 0000005
                    Reset counter: 138
                    Mileage: 150583 km
                    Date: 2014.10.07
                    Time: 03:58:40
   Coding: 0210BE
   Slave Driver:
   Coding: 000090
   Coding: 0000258
                    Reset counter: 95
                    Mileage: 150583 km
                    Date: 2014.09.23
                    Time: 02:14:53
                    (no units): 7.0
                        OK
                    (no units): 11
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 97
                    (no units): 4.0
                    Voltage: 11.40 V
                    Reset counter: 97
                    Mileage: 150601 km
                    Date: 2014.10.25
                    Time: 06:48:04
                    (no units): 4.0
                        Not OK
                    (no units): 2
   Coding: 0211BE
   Slave Passenger:
   Coding: 000090
   Coding: 0026167
Address 56: Radio
   Coding: 230F1859
End-------------------------(Elapsed Time: 03:17)--------------------------
3. I tried to configure G85 through steering wheel module basic settings. basic settings gave exactly same error as with the previous clock spring: ERROR: incorrect message length or invalid format.
4. Through ABS module the calibration was accepted in some level and some faults was erased.
5. Then I taught steering wheel limits by turning wheel from one limit to another as told here.
6. I edited the steering wheel module coding to be as supposed. Cruise control button generated some "impalusible signal" fault code to engine module but that was erased after the button was turned on and off few times.
7. I took a new scan and it looks like this:
Wednesday,03,June,2020,23:28:34:05483
          69 72
   Coding: 0037950
   Revision: 00001004
   Coding: 0010004003
   Revision: BC021001
   Coding: 009795
   Coding: 02304D
                    Reset counter: 97
                    Mileage: 150601 km
                    Date: 2014.10.25
                    Time: 07:15:50
                    Voltage: 11.80 V
   Coding: 0012362
   Coding: 118A100000
   Coding: 820000
   Coding: 111F01
   Coding: 0031032
   Coding: 356002
   Coding: 0000005
   Coding: 0210BE
   Slave Driver:
   Coding: 000090
   Coding: 0000258
                    Reset counter: 95
                    Mileage: 150583 km
                    Date: 2014.09.23
                    Time: 02:14:53
                    (no units): 7.0
                        OK
                    (no units): 11
   Coding: 0211BE
   Slave Passenger:
   Coding: 000090
   Coding: 0026167
Address 56: Radio
   Coding: 230F1859
End-------------------------(Elapsed Time: 02:44)--------------------------
8. Now the situation with G85 seems to be fixed!!! :thumbs: But the fault code related to power steering sounds relatively fatal. Power steering works perfectly and that fault appeared after the first new clock spring was installed. So my suggest is that fault code is some kind of ghost but what do you think? Is there some trick to erase that fault or is it really true that now power steering motor is faulty in some way :confused:
Ps. what SVM delaer session means? :D
