Retrofitting 3C0 614 109 D ABS into 2006 Passat 3C Variant 2.0 FSI BVY
Martijn_Slippens
C?ID=116076
Hello Guys,
I have retrofitted a 7N0 907 530 BG gateway (Software version 7N0 907 530 BL) and a 3AA 959 433 CCM to my 2.0l FSI 2006 Passat with Engine code BVY.
At the same time, I have replaced the Steering Wheel Lock.
(I have also retrofitted more new components in the car, however I think they are not relevant to my question)
However, the 3AA CCM requires an 3C0 614 109 C or higher ABS pump, otherwise it will display an error in the MFA saying that you must visit the dealer.
(Which is the case at the moment, hence why I am going to replace the ABS Pump)
So I am going to replace my 3C0 614 095 P ABS with an 3C0 614 109 D as that pump comes from a donor car with the same Engine code.
However, the coding is not known, as the replacement ABS Pump is bought from a car breaker. Is there anyway someone could help me with coding the ABS pump?
Here is the autoscan of the car before replacing the ABS pump. (The faultcode from the steering wheel module is correct, I still need to replace the stalks in order to resolve it)
Wednesday,18,March,2020,07:49:49:01319
VCDS Version: 19.6.2.0 (x64)
Dealer/Shop Name: Slippens Techniek
Workshop Code: 790 06186 000184
VIN: WVWZZZ3CZ6E210990   License Plate: 35-ST-JF
Mileage: 268140km   Repair Order: Martijn
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62
          69 72
VIN: WVWZZZ3CZ6E210990   Mileage: 268140km-166614miles
   Part No SW: 06F 906 056 GN    HW: Hardware No
   Component: MED9.5.10       G00 3369
   Revision: 69H03---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00264 211 85522
   VCID: 7BFFC9003AE04797F2-802E
Readiness: 1110 0101
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0667284443
   Coding: 0030094
   VCID: 2F672D50BE186B370E-807A
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AA    HW: 3C0 907 044 AA
   Component: ClimatronicPQ46 050 0404
   Revision: 00050005    Serial number: 00000000000000
   VCID: 60C59E6CB346844FC7-8034
   Revision: 00H54000    Serial number: 00000003327813
   Coding: E10C0EA700041A00D20000001700640064314D435C40000C000000000000
   Shop #: WSC 06186 790 00184
   VCID: 336F212052304FD76A-8066
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00065525
   Shop #: WSC 06186
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00471077
   Shop #: WSC 06186
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 3C8 919 475     HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0007
   Revision: --------    Serial number: 97530805701579
   Coding: 110002
   Shop #: WSC 86106 790 00184
   VCID: 71E3EB28A8AC3DC758-8024
   Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
   Component: 04 AIRBAG VW8   029 2521
   Revision: 09029000    Serial number: 003A2P3Q6XVA
   Coding: 0012340
   Shop #: WSC 05311 000 00000
   VCID: 2D5B3758B41419273C-8078
   Subsystem 1 - Serial number: 6332MSME0E36727F
   Subsystem 2 - Serial number: 6342MSME103D6034
   Subsystem 3 - Serial number: 6351HTS6TLLE1543
   Subsystem 4 - Serial number: 6361HTS6TLLAHA33
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0030
   Revision: 00032000    Serial number: 3C5953507BN
   Coding: 0000712
   VCID: 74EDE23C17BE08EFB3-8020
   Subsystem 1 - Part No: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6   H06 0022
   Coding: 00000226
   Part No SW: 3AA 920 881     HW: 3AA 920 881
   Component: KOMBI         H03 0705
   Coding: 061F00
   VCID: 71E3EB28A0AC3DC758-8024
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 201015F1000916
   Coding: 462006
   VCID: 7BFFC900FAE04797F2-802E
03406 - Control Module for Battery Monitoring
                    Reset counter: 128
                    Mileage: 268149 km
                    Date: 2020.03.18
                    Time: 07:41:35
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         042 0399
   VCID: 76E9D83401C21AFF8D-8022
   Part No SW: 3C8 035 279 F    HW: 3C8 035 279 F
   Component: RNS315-EU   H77 0418
   Serial number: VWZAZ2P0021199
   Coding: 000002110200000000030008
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2E5930547112623F05-807A
   Component: EUR_W_V11  0073
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1517
   Revision: 71009005    Serial number: 00000509289024
   Coding: 0000180
   VCID: 71E3EB2868AC3DC758-8024
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   Component:    KSG PQ47 ELV 042 0631
   Coding: 0A9102805103407F0002151560080F0A607C01
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1682
   Coding: 00000008
   VCID: 6FE7ED50BE982B374E-803A
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1517
   Revision: 71009005    Serial number: 00000548089107
   Coding: 0000181
   VCID: 72E1E4246DAA06DFA1-8026
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000011
   VCID: 2143DB68F8CCCD4788-8074
   Component: Batt.regelung H56 1682
   Coding: 0020085A
02071 - Local Databus
                    Fault Status: 01101100
                    Reset counter: 128
                    Mileage: 268149 km
                    Date: 2020.03.18
                    Time: 07:41:37
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000581509
   Coding: 0000144
   VCID: 70E5EE2C63A634CF57-8024
Address 69: Trailer        Labels: 8P0-907-383.clb
   Part No SW: 8P0 907 383     HW: 8P0 907 383
   Component: ANHAENGERELEKTR H01 0010
   Coding: 0000001
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000571081
   Coding: 0000144
End-------------------------(Elapsed Time: 02:34)--------------------------
Martijn_Slippens
C?ID=116076
From my understanding and the Dutch VWPassat Forum, the 109D works. However they provide no coding examples for my car.
diskoboy
Denmark
C?ID=50403
Okay. I’ve would go for a newer one if it was me... HW 24/25 for example
Martijn_Slippens
C?ID=116076
I did some more research and the closest coding I found is 000966 for the ABS, can someone confirm?
dieseltje
The Netherlands
C?ID=148044
Hi Martijn
The recode will not be so hard. Just look for the base code of the abs. Start at one en go up till the first alarms are gone. Then just a case of posting your auto scan and I can tell you the complete coding through Dreke his abs tool.
Martijn_Slippens
C?ID=116076
After trying a lot of codes, I finally found the right one:
0000333
That’s for a BVY 2.0 FSI 6 speed manual (front wheel drive) with the mentioned 3C0 614 109 D ABS pump.
Later I will alter it for Tire pressure, but for now the ABS has no faults anymore.
