ABS "coding rejected"
khaledabdulaziz
Israel
C?ID=394371
Hello all
today i had a skoda octavia 2011, ABS coding was lost, so I entered https://diagnostics.vis4vag.com to get the ABS coding for it, I gave them VIN, part number and address as usual, they gave me this coding
113B201C092700*F*3881204E990220041300000
and i entered it to the ABS but it rejected it, then i remembered that i did an autoscan for this car before and i found the original coding for the ABS.
which is
113B201C092700*0*3881204E990220041300000
and as you can see the only difference between them is between stars.
my question is if this happens to me in the future and i dont have the original coding, how can i find the difference and solve the case
here an autoscan today while the ABS coding was lost
Thursday,21,May,2020,17:57:53:04619
VIN: TMBCT61Z4B2159759   License Plate:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBCT61Z4B2159759   Mileage: 176380km-109597miles
15-Airbags -- Status: Not registered 0011
25-Immobilizer -- Status: Malfunction 1010
   Part No SW: 03L 906 023 LP    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 8810
   Revision: --H43---    Serial number:
   Coding: 00114016032400080000
   Shop #: WSC 73430 031 00066
   ASAM Dataset: EV_ECM16TDI02103L906023LP 003005
   ROD: EV_ECM16TDI02103L997557A.rod
   VCID: 7F5B05C7977C5C432A8-802A
7402 - Throttle Actuator Control System
          P2111 00 [096] - Stuck Open
                    Mileage: 176213 km
                    Date: 2020.05.21
                    Time: 00:04:29
                    Engine speed: 781.00 /min
                    Normed load value: 40.4 %
                    Coolant temperature: 44 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 13.666 V
                    Throttle valve adapter: offset closed-V_THR_BOL[0]: 0.698 V
                    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 89.215 %
                    Throttle valve adapter: actual value-ANG_THR[0]: 99.997 %
                    Air mass: actual value (mg/stroke)-MAF_MES: 36.6246 mg/stroke
                    Sensor for temp after charge air cooler: raw value-TBA_MES: 38 °C
6116 - Function Restriction due to Faults in Other Modules
          U1113 00 [044] - -
                    Mileage: 176213 km
                    Date: 2020.05.21
                    Time: 00:04:27
                    Engine speed: 779.75 /min
                    Normed load value: 40.8 %
                    Accelerator position: normalized-Accelerator position: 99.90 %
                    Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS: 00000010
Readiness: 1010 0000
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Revision: 00H31001
   Shop #: WSC 73430 790 00066
   VCID: 75B7E7EFA5C01613704-8020
                    Reset counter: 64
                    Date: 2014.10.12
                    Time: 00:05:27
                    Count: 7
                    Count: 29184
                    Count: 195
                    Count: 48896
                    Count: 63744
                    Fault Status: 01100101
                    Reset counter: 64
                    Date: 2014.10.12
                    Time: 00:05:27
                    Count: 7
                    Count: 29184
                    Count: 279
                    Count: 48896
                    Count: 63744
                    Reset counter: 64
                    Date: 2014.10.12
                    Time: 00:05:27
                    Count: 7
                    Count: 29184
                    Count: 295
                    Count: 48896
                    Count: 63744
                    Reset counter: 64
                    Date: 2014.10.12
                    Time: 00:05:27
                    Count: 7
                    Count: 29184
                    Count: 270
                    Count: 48896
                    Count: 63744
   Part No SW: 3T0 907 044 BD    HW: 3T0 907 044 BD
   Component: Climatronic   H16 0402
   Revision: 00006001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 75B7E7EFA5401613704-8020
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AE
   Coding: 40000AB8A03708C040100080110081E4436151AE52008160DC8440000040
   VCID: 38292EDBF252AB7BAB2-806C
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 21041  26  0601
   Coding: 00D7B7
18 Faults Found:
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 143
                    Reset counter: 66
                    Mileage: 176152 km
                    Date: 2014.10.06
                    Time: 17:44:03
                    Voltage: 13.80 V
                        Term 50 Off
                    Reset counter: 66
                    Mileage: 176152 km
                    Date: 2014.10.06
                    Time: 17:44:03
                    Voltage: 13.80 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Reset counter: 105
                    Mileage: 677845 km
                    Date: 2012.08.22
                    Time: 00:00:11
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 89
                    Mileage: 176152 km
                    Date: 2014.10.06
                    Time: 17:45:48
                    Voltage: 13.10 V
                        Term 50 On
                    Reset counter: 89
                    Mileage: 176152 km
                    Date: 2014.10.06
                    Time: 17:46:02
                    Voltage: 13.60 V
                        Term 50 Off
                    Reset counter: 89
                    Mileage: 176152 km
                    Date: 2014.10.06
                    Time: 17:46:04
                    Voltage: 13.70 V
                        Term 50 Off
                    Fault Frequency: 165
                    Reset counter: 66
                    Mileage: 176152 km
                    Date: 2014.10.06
                    Time: 17:46:05
                    Voltage: 13.70 V
                        Term 50 Off
00985 - Right Tail Light (M2)
                    Fault Status: 00101110
                    Fault Frequency: 72
                    Reset counter: 105
                    Mileage: 176152 km
                    Date: 2014.10.06
                    Time: 17:49:20
                    Voltage: 13.55 V
                        Term 50 Off
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:00:09
                    Voltage: 12.35 V
                        Term 50 On
02391 - Terminal 30 Reference
                    Fault Status: 00101011
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:00:02
                    Voltage: 12.35 V
                        Term 50 Off
                    Fault Status: 00101001
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:00:02
                    Voltage: 12.35 V
                        Term 50 Off
01516 - Terminal 30; Left
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:00:02
                    Voltage: 12.35 V
                        Term 50 Off
00927 - Terminal 30 (Right)
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:00:02
                    Voltage: 12.35 V
                        Term 50 Off
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:09:17
                    Voltage: 12.00 V
                        Term 50 On
                    Reset counter: 105
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:00:17
                    Voltage: 12.15 V
                        Term 50 On
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 105
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:00:41
                    Voltage: 13.95 V
                        Term 50 On
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:09:17
                    Voltage: 12.00 V
                        Term 50 On
                    Reset counter: 101
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:09:17
                    Voltage: 12.00 V
                        Term 50 On
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC2549J1
   Coding: 0020790
   VCID: 3D273FCFD1708E53784-8068
   Subsystem 1 - Serial number: 6332MSME5F103220%
   Subsystem 2 - Serial number: 6342MSME5F04504EJ
   Subsystem 3 - Serial number: 6351HSME2701413E%
   Subsystem 4 - Serial number: 6361HSME2701504B+
            013 - Check DTC Memory - Intermittent - MIL ON
01217 - Side Airbag Igniter; Driver Side (N199)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
            004 - No Signal/Communication - Intermittent - MIL ON
   Part No SW: 1K5 953 521 AG    HW: 5K0 953 569
   Revision: FF010040    Serial number: 20110426201382
   Coding: 4080140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 72BDDCF3D42E012B556-8026
147462 - Terminal 15
          B1148 12 [009] - Short to Plus
                    Fault Frequency: 22
                    Reset counter: 66
                    Mileage: 677845 km
                    Date: 2018.04.01
                    Time: 00:29:55
147464 - Terminal 15
          B1148 29 [008] - Signal Implausible
                    Reset counter: 104
226057 - Ignition Starter Switch; Terminal S
          B1147 F1 [009] - Open or Short to GND
                    Reset counter: 64
                    Mileage: 677845 km
                    Date: 2018.04.01
                    Time: 00:30:12
226566 - Ignition Starter Switch; Terminal 50
          B1147 F0 [008] - Short to Plus
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2020.05.21
                    Time: 00:00:13
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
                    Fault Frequency: 19
                    Reset counter: 60
                    Mileage: 172950 km
                    Date: 2020.02.18
                    Time: 21:28:48
332564 - Databus
                    Reset counter: 104
   Part No SW: 1Z0 920 803 M    HW: 1Z0 920 803 M
   Component: KOMBI         H05 0405
   Coding: 110800
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 3E2538C3D0F6954B61E-806A
9453841 - Oil Level Thermal Sensor
          B1041 33 [009] - Signal low time > maximum
                    Fault Frequency: 49
                    Reset counter: 65
                    Mileage: 172986 km
                    Date: 2020.02.20
                    Time: 04:00:11
9453842 - Oil Level Thermal Sensor
          B1041 35 [008] - Signal high time > maximum
                    Fault Frequency: 48
                    Reset counter: 105
                    Mileage: 172986 km
                    Date: 2020.02.20
                    Time: 04:02:12
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
          [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2020.05.21
                    Time: 00:12:16
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2020.05.21
                    Time: 00:00:09
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 250411F1002226
   Coding: 351302
   Shop #: WSC 73430 444 00550
   VCID: 303916FB1A22733BE32-8064
                    Fault Status: 00110100
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:00:07
                    Reset counter: 104
                    Mileage: 677845 km
                    Date: 2012.08.22
                    Time: 00:31:17
                    Reset counter: 104
                    Reset counter: 65
                    Mileage: 173091 km
                    Date: 2014.07.16
                    Time: 09:13:16
                    Mileage: 173091 km
                    Date: 2014.07.16
                    Time: 09:13:16
   Component: IMMO          H05 0405
   VCID: 6A8DC493FCFEC9EBED6-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 176369 km
                    Date: 2020.05.21
                    Time: 00:01:09
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2119
   Coding: 0004340
   VCID: 48C95E1B8EB2DBFBDB2-801C
00912 - Window Regulator Switch; Front Left (E40)
00913 - Window Regulator Switch; Front Right Driver (E81)
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H17000
   Shop #: WSC 73430 790 00000
   VCID: 2F3B15870B1C6CC3FA8-807A
                    Fault Status: 11100101
                    Battery Volts: 12.2 V
                        PD
                    Temperature: 37.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:00:09
                    Voltage: 12.38 V
                        DU
                    Temperature: 38.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:12:26
                    Voltage: 12.25 V
                        DU
                    Temperature: 42.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
                    Fault Status: 00101101
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:03:16
                    Voltage: 13.88 V
                        DU
                    Temperature: 33.0°C
                    RPM: 915 /min
                    Speed: 39.0 km/h
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0004340
   VCID: 47CB5D2783ACD483D28-8012
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         009 0065
   Revision: 0I001001    Serial number: SKZ1Z2L9051551
   Coding: 050004000001
   VCID: 313F13FF11287A33ECC-8064
00849 - S-contact at Ignition/Starter Switch (D)
                    Reset counter: 104
00625 - Vehicle Speed Signal
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:00:23
01704 - Terminal 58 (Dimming)
                    Reset counter: 104
                    Reset counter: 104
                    Mileage: 176369 km
                    Date: 2014.10.12
                    Time: 00:07:56
03138 - Input AUX IN
                    Reset counter: 199
                    Mileage: 172950 km
                    Date: 2014.07.11
                    Time: 21:35:11
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012546
   VCID: 323D1CF3182E412B956-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 333319F7E73448239E0-8066
End----------(Elapsed Time: 00:59, VBatt start/end: 12.5V/12.5V)-----------
Mari
C?ID=150535
You can't prevent loosing the coding...
But what you can do is when you get a "new" car do an autoscan and create channel-maps of all modules in the car. Save them on a safe place! Then when you loose or "accidentaly" change your coding, you can allways revert to the original one.
There are lots of reference scans and channel-maps to be found on this forum, big chance there is one of a similar car that you have --> https://forums.ross-tech.com/forumdisplay.php?45-Reference-Scans-and-Maps-of-Non-Broken-Cars
iichel
Eindhoven, NB, NL
C?ID=284912
I agree with Mari. Better to be safe than sorry.
Scan everything you have and save it, preferably after eachosifocation you do. ABS modules are known to be very picky when it comes to accepting coding. And with good reason, it must be done well.
If all else fails, panic. And then ask for help. The VW dealer is able to restore factory coding. This works well if you didn't reteofit other components or upgraded the module itself. Ross Tech forum can often find you a proper coding as well.
NostraJackAss
Do tell. :)
Easy..........a few ways your Eminence!
THESE STEPS ARE JPPSG CERTIFIED!
Step 1
Before doing any work, do an auto-scan to stop stupidity, as aforementioned, no one appears to RTFB anyway, however, to prevent entirely do the following by JPPSG.
Step 2 SAFE STEP
Disconnect battery by proper procedure, perform work on bench of components and reinstall and power up.
Step 3 "HOT" STEP WITH 100% SUCCESS FOR MAJESTIC ONLY!
When needing to work stuff hot or perform programming on clusters etc. in car for Gypsy locksmiths.
Unplug module for ABS directly or not be lazy and RTFB WD, pull respective fuses to stop the terminal's 15, 30 and 31 for sleep mode routine for ram savings & again with all consumers OFF & first before commencing work hot!
Complete work details, shut down, re-plug or install fuses powered down for ABS module.
All settings for components should be in working order provided you did your job details correct when commencing a reboot.
This works perfect for retrieving ABS coding on bench too in shadow & if you know WTF you are doing!
The ones that dont get their one shot! :rolleyes:
The rest seek our guidance in ABS decoding........
NostraJackASS Has Spoken!
khaledabdulaziz
Israel
C?ID=394371
thanks everyone
i found it very useful and safe to do an autoscan before doing anything
as for losing abs coding, these days i only working in diagnostic and tuning, im not a mechanic yet
so friends brings me cars since they dont know how to deal with vcds and most of diagnostic and tuning tools
NostraJackAss
thanks everyone
Don't feel bad you are probably ahead of most dealer tech's now, did you know "they" just use guided fault finding & since "they" made the formally unqualified janitor or wash guy a lead tech, he just uses the Nazi in a white coat back in Neu Swabia via online connection?
:p
Dumb down the industry, get Diesel-Gate!
khaledabdulaziz
Israel
C?ID=394371
Well I think I'm on the right track
Thanks to your advices
