Audi a6 c7 2016
costinibm
Romania
C?ID=399185
hello colleagues
I want to activate developer mode on my audi but I can't.
I have an error "request aut of range".
I searched the forum but I couldn't understand.
I would also like to increase the speed for self-lowering from 50km0h to 100km / h
thanks.
Wednesday,20,May,2020,18:38:51:33100
VCDS Version: 20.4.1.0  HEX-NET CB: 0.4508.4
VIN: WAUZZZ4G3GN104663   License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 28 34 36 3B 3C 42 44
          46 52 53 55 5F 62 6C 6D 72 85 8B 8E 8F 90 AC
VIN: WAUZZZ4G3GN104663   Mileage: 159625km-99186miles
Address 01: Engine (J623-CRTD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G2 907 401 B    HW: 4G2 907 401
   Component: 3.0TDI EDC17  X34 0007
   Revision: 92X34---
   Coding: 0A25401A046601030000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM30TDI0114G2907401B 001007
   ROD: EV_ECM30TDI011_AU57.rod
   VCID: 2404C71B2F5AB3A64F-8070
   Part No SW: 4G0 927 166 C    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0007
   Revision: --H03---
   Coding: 100001
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2D12223F7C9072EE90-8078
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 17A6DE49E8657B929B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41CA6E8FD008868E44-8014
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Component: BCM2 2.0      H37 0572
   Coding: 01A8700E000000000000
   VCID: 7BB6DC67FA642C5E5E-802E
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 27101500041430
   Coding: 361111782D0000
   VCID: 638684076AD4F49E76-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001197529301
   Coding: 0105001440349FE2C9014083A0001800CF9CC3082E08020100000894E10117020040003D030000
   VCID: 71AAFE4FA828560EF4-8024
   Component: WWS57X 150724  H38 0080
   Serial number:         150827080205
   Coding: 0045F7
   Serial number: 20832182
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 23 10 2015  00001067
   Serial number: DAE844D7000000000001
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 291AD62F48786ECE7C-807C
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P100733VU
   Coding: 30333130313730323535554A304C34473053
   VCID: 3B361C67B2E4EC5E1E-806E
   Serial number: 3575HRB405J3LHKEDH3$
   Serial number: 3585HRB40653LHKI7GCX
   Serial number: 3515JRB405L3JK62EGV/
   Serial number: 3525JRB405F3JRS29HM8
   Serial number: 3554VRB4014553HEF8PF
   Serial number: 3564VRB401C553HEEA66
   Revision: --------    Serial number: 90372OJQ0001Z
   Coding: 0000FC
   VCID: 373E005786CCC83EFA-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 11 09 2015  A0028007
   Part No SW: 4G8 920 934 H    HW: 4G8 920 934 H
   Component: TDieRdwAcc    H11 0106
   Revision: 08001098    Serial number: 658211015596021
   Coding: 13860A001F550008000000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 36200D5389C63136E1-8062
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 J    HW: 4H0 265 105 J
   Component: Standheizung  H26 0270
   Revision: 77007007    Serial number: 20151013232122
   Coding: 5D3F01
   VCID: 291AD62F40786ECE7C-807C
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002026189
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 1860608103
   Voltage stabilizer:
   Serial number: 150810000000000001EF
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   VCID: 679E901796EC98BEAA-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 26101500040990
   Coding: 21
   VCID: 3D32127FACF0E26E20-8068
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F2E3837769C00FEA2-807A
   Revision: AA000000    Serial number: 00000169760875
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77BEC057C64C083E3A-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820AE53-
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H07 0060
   Serial number: 0384442133
   Coding: 040311
   VCID: 393A066FB8D8DE4E0C-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H07 0060
   Serial number: 0384590216
   Coding: 040311
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F16015E00628002080013
   VCID: 45C27A9FCC20AAAE78-8010
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000329158
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A381963BDDED55605-806E
   Revision: 00002001    Serial number: 0384080595
   Coding: 011A062080B93084C32008840E010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000LRXLU00000
   Coding: 901F02
   Subsystem 4 - Part No SW: 4G0 947 135 F    HW: 4G0 947 135
   Serial number: 0000000AP00016038501
   Component: TSG BF        H03 0511
   Coding: 011F16015E00628002080002
   VCID: 46C07D93F126A1B671-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001638040
   ROD: EV_ParkiBrake_VW51.rod
   Coding: 04FA02102A630200
   VCID: 3424375B9FBA2326DF-8060
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 043 S    HW: 4G1 035 043 D
   Component: MU-H-N-EU     051 0389
   Serial number: A736J0FB000892
   Coding: 01750101FF0A000013110001000A00032F0006E5F17001009F
   VCID: 2E102533719609F6A9-807A
   Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
   Component: ECE 2016  --- 0134
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0006
   Serial number: AUZ8Z9FY803677
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349OJN000U1
   Compact Disc Database:
   Component: Gracenote2  --- 1012
   Component: TSG HL        H03 0511
   Coding: 010F14004000628002080002
   VCID: 49DA76AFE0384ECE9C-801C
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 0275000102002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001.rod
   VCID: 78BCC36BC352074633-802C
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 277500969
   Coding: 111104C000
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   VCID: 3228314365AE2D16CD-8066
   Component: TSG HR        H03 0511
   Component: DPC-SG        H27 0081
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C142F3B478A7BE687-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 271ED0175E6C58BE6A-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000623010157
   Coding: 04C0BB181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H14 0080
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 312A3E4F60A8160EB4-8064
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 152750670
   ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 02:49, VBatt start/end: 12.4V/12.3V)-----------
