- Jun 13, 2015
- 13
- 5
- Cedar Hill, Tx
- C?ID=249410
2020 Atlas Cross Sport SEL Premium
Looking to enable the Windows up / down using the remote as well as tail gate close.
Currently You can roll the windows up, but not down.
Tailgate can be opened via remote from any direction, but cannot be closed unless you are behind the rear doors (from 4 - 8 position on the clock face if sitting in the drivers rear seat.. That is correct, you can not stand in your garage and close the tailgate. You have to walk out into the cold driving rain to do it.
I understand this is a brand new vehicle for VW, and a lot of the VCDS coding is not verified.
Friday,15,May,2020,19:37:42:18073
VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4508.4
VIN: 1V2NE2CA3LC214523 License Plate:
Mileage: 1046km-649mi Repair Order:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 36 3C 42 44 47 4B 52 5F
69 6C 6D 75 A5 CA D6 D7
VIN: 1V2NE2CA3LC214523 Mileage: 1046km-649miles
CA-Sunroof -- Status: Malfunction 0010
Address 01: Engine (J623-CDVC) Labels: None
Part No SW: 03H 906 026 AG HW: 03H 907 309 K
Component: VR6 3.6l FSI H21 9970
Revision: 52H21000
Coding: 012A003244740108F0000000000000000000000000000000
Shop #: WSC 06050 062 00200
ASAM Dataset: EV_ECM36FSI01103H906026AG 001006
ROD: EV_ECM36FSI01103H906026AG.rod
VCID: 6A98EB708D3970D6BC-803E
CAN Converter 01:
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 DR HW: 09G 927 158
Component: AISIN AQ8 206 3742
Coding: 0000000100000000000000000000000000000000
ROD: EV_TCMAQ450031_VW37.rod
VCID: 0640BFC0B961B4B638-8052
Part No SW: 5Q0 614 517 DL HW: 5Q0 614 517 BP
Component: ESC H35 0113
Revision: 00000000 Serial number: 50630000000099
Coding: 85FC6B8D80211A70C57C0302A2C669A1D60158A3C045967638415058D2AA4A0B004023641C12141A1D8DDB45506CC8CF
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 7EB0D720E1B1EC7670-802A
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0537440862
Coding: 1F20000723
ROD: EV_KessyHellaMQBAB.rod
VCID: 45C278CCC4E77FAE71-8010
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 14309068
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 3CM 907 044 B HW: 3CM 907 044 B
Component: Climatronic H05 2401
Revision: 00001K04
Coding: 1402002620001C0C1104010C9210D534
ASAM Dataset: EV_ACClimaBHBVW416 002015
ROD: EV_ACClimaBHBVW416.rod
VCID: 3D32102CAC37376E29-8068
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 CC HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H40 0312
Serial number: 0043013002ÿÿÿÿ
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 7CB4DD28F7ADFE665E-8028
Subsystem 1 - Part No SW: 5Q0 955 555 A HW: 5Q0 955 555 A
Component: RLHSS 051 0207
Serial number: S6Y20M01D16H06M40S50
Coding: 0018DD
Steering Column Switch:
Subsystem 2 - Part No SW: 5Q1 953 521 AC HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0300170220200C200686
Seat Backrest Fan 1 Front Left:
Subsystem 3 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0623253
Seat Cushion Fan 1 Front Left:
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0953175
Seat Backrest Fan 1 Front Right:
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0576785
Seat Cushion Fan 1 Front Right:
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0953223
Part No SW: 5QA 919 298 H HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0061
Serial number: 000259541420013
Coding: 0271267951
ASAM Dataset: EV_EPHVA2CAU3700000 009048
ROD: EV_EPHVA2CAU3700000_VW41.rod
VCID: 55E2A88C3447CF2E01-8000
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 320007CB58FF8728949C810530409700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43C666D4CAD3419E5F-8016
Part No SW: 3Q0 959 655 DB HW: 3Q0 959 655 DB
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 00310M3C1AWf
Coding: 8CCCFC00000000005000001AC20840000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 014AACDC904F938E0D-8054
Occupant Detection:
Component: Occ.Detection H14 0022
Serial number: IBH0000D20000D7EZT0U
Coding: 303030
Subsystem 2 - Part No SW: ----------- HW: 454 000 812 19
Serial number: 35700000000921143440
Subsystem 3 - Part No SW: ----------- HW: 454 000 112 19
Serial number: 3580000000075D0DC34U
Subsystem 4 - Part No SW: ----------- HW: 454 802 002 20
Serial number: 351008D89D21A000000U
Subsystem 5 - Part No SW: ----------- HW: 454 802 002 20
Serial number: 35200F1DB1F1B000000Z
Subsystem 6 - Part No SW: ----------- HW: 454 802 002 20
Serial number: 35500FD4A321B000000T
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 454 802 002 20
Component: FrontSensor_P 304 0149
Serial number: 35600AD29A91A000000Z
Part No SW: 3G0 920 890 E HW: 3G0 920 890 E
Component: KOMBI 503 4193
Coding: 08A438086F8CCF050288630B50010000A0001009
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: 2B162E744243A9DE87-807E
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 24012000841928
Coding: 0B0500347F087300FB03225A1E0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 70ACF918ABE58A06F2-8024
Component: 4-01-0e-01-04
Subsystem 2 - Part No SW: 3G0 959 442 H HW: 3G0 959 442 H
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440066014204380
Coding: 2E0B00
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 7314077200
Power Converter DC AC:
Subsystem 4 - Part No SW: 3CN 907 155 HW: 3CN 907 155
Component: U13DCAC H23 0890
Serial number: B054194
231017 - Voltage Converter Temporary Malfunction
C113A FB [008] - Overcurrent in Secondary Circuit
Reset counter: 62
Mileage: 791 km
Date: 2020.05.12
Time: 14:00:06
Supply voltage: Terminal 30: 14.8 V
Terminal 15: OFF
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00003.12.19
Coding: 0101
VCID: 4CD44DE8E78D8EE6AE-8018
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 E HW: 5Q0 959 760 E
Component: Sitzmemory H09 0026
Serial number: Y0007TAL21042
Coding: 0010000000000500018280808080000000008100000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3FCE6A24A63B257E3B-806A
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0148
Serial number: 11230023019641
Coding: 62954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 393A043CB81F0B4E05-806C
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0325
Serial number: YA008TAO00FID
Coding: 003B1B205200020000040000
VCID: 49DA74FCE8FF9BCE95-801C
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000005313674
Coding: 011000
Part No SW: 3QF 909 144 B HW: 3QF 909 144 A
Component: EPS_MQB_ZFLS 570 1582
Coding: 9B1F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 47DE72C4FEEB6DBE83-8012
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1KMD06U9H1
Coding: 2200000002A2AAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E1027607151DCF6A0-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 10022000840504
Coding: 000000070900135202112300030000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW41.rod
VCID: 373E02048E0B1D3EF3-8062
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0325
Serial number: YA008TBD003E5
Coding: 003B13205E00020000040000
VCID: 48DC71F8F3F562C68A-801C
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000005319789
Coding: 091000
Part No SW: 2GM 035 876 C HW: 2GM 035 876 C
Component: MU-S-NS-US 854 0523
Coding: 022436020000000051220002001808211F0500E40120040586
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 46C07FC0F9E174B678-8012
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav 261 8214
Serial number: VWZ6ZMX0525519
Subsystem 2 - Part No SW: 5NA 919 866 AF HW: -----------
Component: NAR 2020 --- 1320
3077 - Telephone baseplate
B1051 13 [008] - Open Circuit
[Bracket for mobile phone holder - open circuit]
Reset counter: 44
Mileage: 44 km
Date: 2020.05.03
Time: 11:22:11
Voltage terminal 30: 12.5 V
Address 69: Trailer (J345) Labels:* None
Part No SW: 5H0 907 383 HW: 5H0 907 383
Component: Anhaenger H09 0040
Serial number: 000000000005401
Coding: 0200000200001300
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 6B96EE7482C369DEC7-803E
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG068632
Coding: 01140600A30F20003000400C
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C758-8680-4
Coding: 2F88
Part No SW: 5WA 035 283 HW: 5WA 035 283
Component: OCUGen3Low H10 0295
Serial number: 0000000912NVAX8
Coding: 0241602019682C208005461160500607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_VW41.rod
VCID: 0248A3D09549889614-8056
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 HW: 2Q0 980 653
Component: MQB MFK 3.0 H11 1029
Serial number: E33417011193390
Coding: 00000A081178C020B09F00001020002000210000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005035
ROD: EV_MFK3ValeoMQB_005_VW27.rod
VCID: 72A8F310A5E9B81604-8026
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 00804074161C
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75A2C80CD487AF2E21-8020
0278 - Switch for Sunroof
B1574 29 [008] - Signal Implausible
Reset counter: 44
Mileage: 21 km
Date: 2020.05.02
Time: 18:57:07
Controls-Sunroof button: not activated
Controls-Sunroof shade button: not activated
Controls-Button for sliding roof: ERROR
Controls-Search lights: Current cannot be measured
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 992 941 572 AA HW: 992 941 572 A
Component: LED1L H08 9002
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 628883507509289674-8036
Address D7: Light Ctrl Right 2 (A27) Labels: None
Component: LED1R H08 9002
End----------(Elapsed Time: 01:55, VBatt start/end: 13.3V/13.3V)-----------
