- Jun 13, 2019
- 42
- 20
- Birmingham, UK
- C?ID=368132
Good evening guys, iv just recently bought this vehicle from a trader and it came with the steering light on red, no previous repair history known.
So no power steering at all, very hard and no damage to the body at all.
i was looking around forums and came across a few threads on other sites that this steering rack has a sensor or torque sensor, something along those lines that may fail and can be repaired. any thoughts on this please, ? i also came across someone mentioning frf flash..
did clear all dtcs and new scan attached
many thanks for any replies
Tuesday,12,May,2020,16:45:29:58999
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G7GN100762 License Plate:
Mileage: 115114km-71528mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 55 5F 62
72 85 AC
VIN: WAUZZZ4G7GN100762 Mileage: 115114km-71528miles
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FQ HW: 04L 907 309
Component: R4 2,0L EDC H23 1649
Revision: 85H23---
Coding: 0A254012242401080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
ROD: EV_ECM20TDI01104L906021FQ_002.rod
VCID: 79AFEC7F795735B3145-802C
U1113 00 [039] - -
Mileage: 115114 km
Date: 2020.05.10
Time: 05:34:52
Engine speed: 0.00 /min
Coolant temperature: 87 °C
Intake air temperature: 69 °C
Voltage terminal 30: 12.240 V
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 44
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
U1113 00 [039] - -
Mileage: 115114 km
Date: 2020.05.10
Time: 05:34:52
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G1 927 153 B HW: 0CK 927 156 S
Component: 0CK 20TDI RdW H03 0002
Revision: --H03--- Serial number: 0000000026
Coding: 100001
ASAM Dataset: EV_TCMDL382021 002020
ROD: EV_TCMDL382021_VW51.rod
VCID: 290FFC3FC9774533245-807C
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP HB1 0572
Serial number: 75117051150250000029
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A29E41604579829B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41DF449F5107AD731C5-8014
178432 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
[SCL_EPS_Lenkmoment_Error]
Mileage: 115114 km
Date: 2020.05.10
Time: 05:34:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 02
Bit Info 4: 1F
Uz: 9D
178688 - Function Restriction due to Implausible Message(s)
U1112 00 [035] - -
[SCL_EPS_Lenkmoment_Invalid]
179200 - Function Restriction due to Faults in Other Modules
U1113 00 [035] - -
[SCL_EPS_Unterstuetzungsleistung_Error]
179456 - Function Restriction due to Implausible Message(s)
U1112 00 [035] - -
[SCL_EPS_Unterstuetzungsleistung_Invalid]
201728 - Control Module Incorrectly Coded
U1014 00 [253] - -
[VarECUDSRVariantCodingIncorrect]
MIL ON - Confirmed - Not Tested Since Memory Clear
Mileage: 114953 km
Date: 2020.03.02
Time: 17:18:59
VzRef: 00
Bit Info 1: 40
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
Uz: 91
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Coding: 01B8704E000000000000
VCID: 7BA3F67773EB07A3069-802E
Serial number: 3215000159692014
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 19101500040548
Coding: 34210978250000
VCID: 6393AE17EBDBDF632E9-8036
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001193291801
Coding: 0705801541349FE04101408300001800CF9DC3082F08020100000894E100120200400024030000
VCID: 71BFD45F21A77DF3AC5-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 150715 H38 0080
Serial number: 150819224225
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 20789534
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 23 10 2015 00001359
Serial number: 2E9882D7000000000001
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 113
Mileage: 115114 km
Date: 2020.05.10
Time: 05:34:48
Reset counter: 113
Mileage: 115114 km
Date: 2020.05.10
Time: 05:34:48
Revision: -------- Serial number: 003P1006XHLK
Coding: 30333130313630323639554A305234473053
VCID: 3B23367733EBC7A3469-806E
Serial number: 3575HRB405L3LHKGBOUW
Serial number: 3585HRB405L3LHKEA0DW
Serial number: 3515JRB405D3JK62FG24
Serial number: 3525JRB40693IE74A06O
Serial number: 3554VRB40593JK5UJ8UN
Serial number: 3564VRB405T3JPCQK0R%
B13BC F2 [137] - No function
Mileage: 115114 km
Date: 2020.05.10
Time: 05:35:05
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OJJ0011D
Coding: 000034
VCID: 3B233677336BC7A3469-806E
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 17 08 2015 C0046112
Part No SW: 4G8 920 986 M HW: 4G8 920 986 M
Component: TDieGb H11 0104
Revision: 07001088 Serial number: 658040915596013
Coding: 23AF0A000B412600010000
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 42DD4B935401B66B05F-8016
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002018385
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 001028
Serial number: 5488577903
Voltage stabilizer:
Serial number: 15080800000000000603
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 20101500041266
Coding: 22
VCID: 3D27386F2DFFC99378D-8068
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820ADGUU
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3635274308C91ACBB97-8062
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F16015C01620002080002
VCID: 47CB5A877FA39343D21-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000003 Serial number: 0000303372
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2D33733CD1FEAB5DF-806E
5258756 - Steering
C10AC 07 [137] - Mechanical Failure
[Blockieren der Lenkung]
Mileage: 114953 km
Date: 2020.03.02
Time: 06:13:17
Write only channel
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
[Lenkungsendanschläge nicht angelernt]
Reset counter: 113
Mileage: 115114 km
Date: 2020.05.10
Time: 05:34:49
Write only channel
7341572 - Position Sensor for Motor
C10AD 29 [137] - Signal Implausible
[Überwachung der Resolverrohsignale]
Mileage: 114953 km
Date: 2020.03.02
Time: 06:13:00
Write only channel
Revision: 00002001 Serial number: 0383425659
Coding: 011F062280B90080C320080400010E470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Component: TSG BF H03 0511
Coding: 011F16015E01620002080002
VCID: 46D5578378A98A4B297-8012
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001627395
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D07082FFD9F5913C8D-8078
Component: MxB-ECU 001 0100
Coding: 04FE02202A130200
VCID: 34311D4B1EB508DB873-8060
Coding: E01F00
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 021 D HW: 4G1 035 021
Component: MU-H-LND-EU 042 0389
Serial number: A588J0F7528546
Coding: 017501010000000013111102000A00132F0006E7F1700100DF
VCID: 1B63D6F7932BA7A3A69-804E
Subsystem 1 - Part No SW: V03 959 801 FB HW: -----------
Component: ECE 2016/2017 --- 0153
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY80332D
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349OJE0010S
Compact Disc Database:
Component: Gracenote2 --- 1012
Component: TSG HL H03 0511
Coding: 010F14004001620002080002
VCID: 49CF5CBF69B76533C45-801C
Component: TSG HR H03 0511
Component: DPC-SG H27 0081
Coding: 60140000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C01052BC685501BDF3-8078
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 152741561
ROD: EV_RDCMA00100.rod
VCID: 2F3B1227F7932B03FA1-807A
End----------(Elapsed Time: 01:52, VBatt start/end: 12.3V/12.2V)-----------
