2011 Passat B7 (EU) AFS bixenon retrofit
Artiforgs
Norway
Hi all!
And please bare with me, just realised I may joined the wrong forum for this, so please be gentle if its not appropriate.
Im retrofitting OEM bixenons on my 2011/2012 B7 (EU) Passat, and found some useful info here ln this forum, hence why i joined, only to learn that its for VCDS owners only(?)
Anyhow; Here is where im at a loss, cause every retrofit ive read is almost different, several are NMS Passat, and the two other ive found, are EU passats, but NON-DCC.
My car has DCC, so the sensor at the rear control arm is present, and I have the kufatec 10-14pin headlight harness.
The OEM lights are so-called AFS lights?
Bought them used from my dealer, who had a rear ended passat, so i got them for cheap.
My dealer is also going to code for me, but they had no clue what I needed.
But have I understood right regarding this?
-I have the OEM HID lights, and i have the 10-14 wiring adapter.
So the lights should mount just fine.
But ive read something about when coding the lights, the bumper-cornering circuit will become my shutter signal for the xenons?
Or do I just use the original high beam signal for shutters?
Or do i have to wire them to BCM/BECM or something?
And regarding the AFS part of the lamps, what do i need except the AFS module itself?
Does the adaptive part of them get info via can/steering wheel angle and so on, and/or what signals do the AFS module need to get?
And is the sensor at rear used on DCC sending signals via CAN? So no wiring needed there to get autoleveling?
My dealer did really not have a clue on how to retrofit this, so the mounting and wiring im doing myself (im a truck mechanic).
And they will only do the coding.
Sorry if this is the wrong place, but Norway kinda suck for reference on retrofitting, and not many guys do coding, so not much help there either..
Indeed, this forum is operated by Ross-Tech, who produce VCDS, and is primarily intended as a resource for VCDS users.
We do have two dealers in Norway. ;)
Artiforgs
Norway
Hi again!
So ive gotten myself an VCDS, borrowed from a buddy, and could really use some help regarding coding my OEM bi-xenons.
Anyone care to help a noob-coder?🙏🏼
downtime
Finland
C?ID=280813
Buy one hour access to erwin and you can download all wiring schematics, headlight install/removal, control module install/removal instructions for your car. No need to guess.
Here : https://erwin.volkswagen.de/erwin/showHome.do
Artiforgs
Norway
But i could really need someone who done it before to guide me a little..
Ive installed both headlights, the 10-14pin adapters are all wired up, ive mounted and wires the AFS module, so right know i have a few questiona about coding, as ive seen several good coders also have trouble getting eveything 100%..
Ive seen @m87a is a wise man regarding my retrofit..
iichel
Eindhoven, NB, NL
C?ID=284912
Hi and welcome, hope you'll enjoy your stay here at the home of VCDS.
Would you mind posting an autoscan? This way we can look along.
Most of the answers to your questions regarding wiring will be much easier to answer with a wiring diagram. But for that, an autoscan would be good.
That will tell us exactly what module is fitted in your car.
Artiforgs
Norway
Hi, and thank you for anwsering!
so far ive done:
Byte 14, check bit 3
Byte 15, check bit 3
Byte 15, check bit 6
Byte 17, check bit 2
Byte 25, check bit 7
ive not changed Byte 18 yet, hence the warnings..?
high beam has suddenly become fog light?
And LED drls not working, not even as parking lights..
no sign of auto leveling either..
heres a scan.
Wednesday,22,July,2020,22:14:38:63646
VCDS Version: 20.4.1.0 (x64)
VIN: WVWZZZ3CZBE348093   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 18 19 20 22 25 36 37 42 44
          46 47 4F 52 53 55 56 61 62 65 69 6C 6D 72 77
VIN: WVWZZZ3CZBE348093   Mileage: 160840km-99941miles
37-Navigation -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Not registered 0011
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BN    HW: 03L 907 309 N
   Component: R4 2.0l TDI   X24 9979
   Revision: 47X24---    Serial number: 00000000000000
   Coding: 001D001A047601080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BN 003009
   ROD: EV_ECM20TDI01103L906018BD.rod
   VCID: 77C4649ACE35DA3E3A-8022
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 159401 km
                    Date: 2020.07.07
                    Time: 14:43:35
                    Engine speed: 0.00 /min
                    Coolant temperature: 68 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 13.660 V
                    Unlearning counter according OBD: 19
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 7
                    Status of ACC/CCS acceleration interface-Bits 0-7: 3
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
   Part No SW: 02E 300 013 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2601
   Revision: 05351112    Serial number: 00001012300863
   Shop #: WSC 05311 000 08193
   VCID: 1B0C582ADA5D5E5EFE-804E
   Part No SW: 3AA 614 109 P    HW: 3AA 614 109 D
   Component: J104   C2 450M V5E1 0011
   Revision: --H07---    Serial number: 00000002930702
   Coding: 0121279
   Shop #: WSC 05311 000 00000
   VCID: 3A42BDAE75A7075605-806E
   Part No SW: 5K0 907 044 EC    HW: 5K0 907 044 EC
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000003
   Shop #: WSC 00015 115 00000
   VCID: 70D65F86AB5B8D06FB-8024
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
   Component: BCM PQ47 H    413 0452
   Revision: BB413001
   Coding: 0002000000000000001C0088740089EC43550088476DA5606480C7200041
   Shop #: WSC 05311 123 12345
   VCID: 3846A7A68BAB1546F3-806C
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 15011  10  0603
   Coding: 00B795
   Component: RLS 210111 05  54  0403
   Coding: 035028
00061 - Footwell Lights
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 225
                    Mileage: 160843 km
                    Date: 2014.12.13
                    Time: 00:38:42
                    Voltage: 12.20 V
                    Reset counter: 225
                    Mileage: 160843 km
                    Date: 2014.12.13
                    Time: 00:38:41
                    Voltage: 12.20 V
                    Reset counter: 225
                    Mileage: 160843 km
                    Date: 2014.12.13
                    Time: 00:38:41
                    Voltage: 12.20 V
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631101505630
   Coding: 318102
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 7CCE7BB6F713F96657-8028
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567     HW: 3AA 907 567
   Component: AC201  RDW A    031 0143
   Revision: 00031000    Serial number: 00000000085101
   Coding: 0010000
   VCID: 77C4649A0635DA3E3A-8022
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 225
                    Mileage: 160843 km
                    Date: 2014.12.13
                    Time: 00:05:34
                    Count: 8
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 20011104580002
   Coding: 030180
   Shop #: WSC 05314 000 00000
   VCID: 276474DA56158ABE6A-8072
01319 - Control Module for Distance Control (J428)
                    Fault Status: 00101101
                    Reset counter: 244
                    Mileage: 159401 km
                    Date: 2014.11.28
                    Time: 14:43:35
                    Bin. Bits: 00000000 00000001
03262 - Comfort Restriction
                    Fault Frequency: 8
                    Reset counter: 225
                    Mileage: 159401 km
                    Date: 2014.11.28
                    Time: 14:43:35
                    Error Code: 2
                    Bin. Bits: 00000000
01769 - Sensor for Vehicle Leveling; Front Right (G289)
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2014.11.28
                    Time: 14:43:35
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__10H VW10 HI   1918
   Revision: 22014000    Serial number: 003JZPSQAHTK
   Coding: 0012360
   VCID: 4BACE86A2A3D8EDEAE-801E
   Subsystem 1 - Serial number: 6332MTS611330041
   Subsystem 2 - Serial number: 6342MTS675533510
   Subsystem 3 - Serial number: 6351HTS6Q5P6M9KJ
   Subsystem 4 - Serial number: 6361HTS6FDK6M9KR
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            010 - Open or Short to Plus - Intermittent - MIL ON
                    Fault Status: 10101010
                    Mileage: 160843 km
                    Date: 2014.12.13
                    Time: 10:44:13
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                    Mileage: 160843 km
                    Date: 2014.12.13
                    Time: 10:44:11
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20110126300924
   Coding: 399AA50001
   Shop #: WSC 00015 115 08193
   VCID: 75D86E92D439A82E28-8020
   Coding: E30000
   Part No SW: 3AA 920 880 A    HW: 3AA 920 880 A
   Component: KOMBI         H02 0206
   Coding: 161F00
   Shop #: WSC 05314 115 00000
   VCID: 31509A8260D1C40EB4-8064
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 A
   Component: Standheizer     043 4730
   Revision: 00043000    Serial number: 09022127000000
   Coding: 0031032
   Shop #: WSC 39270 002 1048576
   VCID: 335C908A52CDF61EC6-8066
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 260111F1002719
   Coding: 462006
   VCID: 345E939697C3F126DF-8060
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2014.11.28
                    Time: 14:43:40
01304 - Radio
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2014.11.28
                    Time: 14:43:40
                    Mileage: 160843 km
                    Date: 2014.12.13
                    Time: 00:05:29
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 01018E67727261565623393E00
   VCID: 2D6886F274E9A0EE90-8078
   Part No SW: 0BS 907 554 B    HW: 0BS 907 554 B
   Component: Haldex 4Motion      4015
   Coding: 0000005
   VCID: 45B8DE520C5978AE78-8010
   Part No SW: 3AA 959 799     HW: 3AA 959 799
   Component:    IMMO         083 0399
   Revision: 00083000    Serial number: VWZCZ000000000
   VCID: 05381E524CD9B8AE38-8050
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2301
   Revision: 00H05000
   Coding: 000039
   VCID: 335C908A92CDF61EC6-8066
Address 37: Navigation
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0529
   Revision: 12110009    Serial number: 0002162499
   Coding: 0211FF
   Shop #: WSC 05311 115 00000
   VCID: 3558AE9294B9E82EE8-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703     HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000001869458
   Coding: 0000D8
67584 - Warning Light for Front Door
          B11F5 01 [009] - Electrical Failure
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2020.07.07
                    Time: 14:43:34
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.318 0802
   Revision: 1AH03729    Serial number: 00110140074001
   Coding: 0000258
   VCID: 3B4CB8AA7A9D3E5E1E-806E
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 02 KESSY PQ47   083 0323
   Coding: 01900A00D2C30E76300494157E00CFCE705801030424B8
   Subsystem 1 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HORN H11 9005
   Component: Neigungssensor  004 0611
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3AA 035 456 A    HW: 3AA 035 456 A
   Component: DSP 10 Kanal        0020
   Revision: 00H02001    Serial number: 75818000275105
   VCID: 2D6886F2B4E9A0EE90-8078
                    Fault Status: 00101011
                    Reset counter: 7
                    Mileage: 159680 km
                    Date: 2014.12.02
                    Time: 13:42:32
   Component: EZE_2         H41 1614
   Coding: 050B0508
   VCID: 6FD45CFABE6592FEE2-803A
   Component: J245EE20SKB13  H02 0220
   Subsystem 3 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0529
   Revision: 14110009    Serial number: 0002152883
   Coding: 0211FE
   VCID: 365AA99E89BFE336E1-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704     HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000001799220
   Coding: 0000D8
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000149663
   Coding: 0022067
   Component: AFS-ECU       H04 0111
   Coding: 04BA00000B000200
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 3744A49A8EB51A3EFA-8062
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0011
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0011
   Coding: 230000
          U1014 00 [137] - -
                    Reset counter: 71
5276145 - Power Output Module for Left Headlamp
          C1081 F1 [137] - Incorrectly Coded
                    Reset counter: 71
5276401 - Power Output Module for Right Headlamp
          C1082 F1 [137] - Incorrectly Coded
                    Reset counter: 71
5276209 - Power Output Module for Right Headlamp
          C1082 31 [008] - No Signal
                    Reset counter: 10
                    Mileage: 20434 km
                    Date: 2014.07.19
                    Time: 16:56:25
9574144 - Bulb for Low Beam Headlamp Left
          B1217 00 [008] - -
                    Reset counter: 10
                    Mileage: 160843 km
                    Date: 2020.07.22
                    Time: 00:05:31
9574400 - Bulb for Low Beam Headlamp Right
          B1218 00 [008] - -
                    Reset counter: 111
                    Mileage: 20434 km
                    Date: 2014.07.19
                    Time: 16:56:27
Address 56: Radio
   Component: Batt.regelung H41 1614
   Coding: 030B185A
   VCID: 71D05A82A851840EF4-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370416969
   Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0008
   Serial number: 10000000013796
   ASAM Dataset: EV_RDKBERU30 003010
   ROD: EV_RDKBERU30_003.rod
   VCID: 335C908A9ACDF61EC6-8066
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00000141242259
   Coding: 4106040000000000
   VCID: 73DC508AD24DB61E06-8026
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Component: J772__Rearview      0020
   Revision: 00H09000    Serial number: 525PA8-J0Z2485
   Coding: 0030007
   VCID: 68E637E65B8B45C6A3-803C
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 J    HW: 3C9 827 383 J
   Component: J605  HECKDECKEL    0804
   Revision: 00H52001
   VCID: 3846A7A64BAB1546F3-806C
   Subsystem 1 - Part No: 3C9 827 384 J
   Component: J756  HECKDECKEL    0804
   Subsystem 2 - Serial number: 1100H52001001B0156ÿ
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 5N0 035 730 D    HW: 5N0 035 730 D
   Component: Telefon       009 0511
   Revision: --------    Serial number: 35909603102474
   Coding: 020100000000000000010000
   ASAM Dataset: EV_UHVPremi A01005
   ROD: EV_UHVPremi_A01.rod
   VCID: 296072E24801BCCE7C-807C
          B104F 13 [009] - Short to GND
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2020.07.07
                    Time: 14:43:34
          B104E 13 [009] - Short to GND
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2020.07.07
                    Time: 14:43:34
9455635 - Telephone Microphone
          B1048 13 [009] - Open Circuit
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2020.07.07
                    Time: 14:43:34
9459463 - Cradle for telephone
          B1057 07 [009] - mechanical malfunction
                    Fault Frequency: 50
                    Reset counter: 225
                    Mileage: 159401 km
                    Date: 2020.07.07
                    Time: 14:43:34
0022 - Radio
          U1066 00 [009] - No Communication
                    Fault Frequency: 69
                    Reset counter: 225
                    Mileage: 159401 km
                    Date: 2020.07.07
                    Time: 14:43:34
End-------------------------(Elapsed Time: 03:53)--------------------------
iichel
Eindhoven, NB, NL
C?ID=284912
So could you please go to 19 can gateway, installation list and tick 55 headlight range and save?
Then go to applications, gateway installation list, clear all DTCs and make a new scan? :)
Should clear some of your errors
Artiforgs
Norway
So i did what u said, but cant seem to made any difference..
BTW, my AFS module came from another car, and when i checked bit 55 and save, it came up something like new control module detected, will you like to use standard 12345 settings blablabla, and i choose yes.
If i choose NO, it would use the "old" settings something..
heres a new scan, after clearing DTCs:
Thursday,23,July,2020,11:48:38:63646
          U1113 00 [032] - -
                    Mileage: 159401 km
                    Date: 2020.07.08
                    Time: 14:43:35
   Coding: 0121279
   Revision: 00003001
   Coding: 0000000003
   Revision: BB413001
   Coding: 00B795
   Coding: 035028
                    Fault Status: 00101010
                    Reset counter: 10
                    Mileage: 160843 km
                    Date: 2014.12.14
                    Time: 00:38:42
                    Voltage: 12.20 V
                    Reset counter: 225
                    Mileage: 160843 km
                    Date: 2014.12.14
                    Time: 00:38:41
                    Voltage: 12.20 V
                    Reset counter: 225
                    Mileage: 160843 km
                    Date: 2014.12.14
                    Time: 00:38:41
                    Voltage: 12.20 V
   Coding: 318102
   Coding: 0010000
                    Reset counter: 225
                    Mileage: 160843 km
                    Date: 2014.12.14
                    Time: 13:49:18
                    Count: 8
   Coding: 030180
                    Reset counter: 244
                    Mileage: 159401 km
                    Date: 2014.11.29
                    Time: 14:43:35
                    Fault Frequency: 8
                    Reset counter: 225
                    Mileage: 159401 km
                    Date: 2014.11.29
                    Time: 14:43:35
                    Error Code: 2
                    Bin. Bits: 00000000
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2014.11.29
                    Time: 14:43:35
   Coding: 0012360
                    Mileage: 160843 km
                    Date: 2014.12.14
                    Time: 10:44:13
                    Mileage: 160843 km
                    Date: 2014.12.14
                    Time: 10:44:11
   Coding: 399AA50001
   Coding: E30000
   Coding: 161F00
   Coding: 0031032
   Coding: 462006
   Shop #: WSC 05314 123 12345
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2014.11.29
                    Time: 14:43:40
01304 - Radio
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2014.11.29
                    Time: 14:43:40
                    Mileage: 160843 km
                    Date: 2014.12.14
                    Time: 00:05:29
   Revision: AA001002
   Coding: 0000005
   Revision: 00H05000
   Coding: 000039
   Coding: 0211FF
   Slave Driver:
   Coding: 0000D8
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2020.07.08
                    Time: 14:43:34
   Coding: 0000258
                    Reset counter: 7
                    Mileage: 159680 km
                    Date: 2014.12.03
                    Time: 13:42:32
   Coding: 050B0508
   Coding: 0211FE
   Slave Passenger:
   Coding: 0000D8
   Coding: 0022067
   Coding: 230000
   Coding: 230000
          U1014 00 [137] - -
                    Reset counter: 71
                    Reset counter: 71
                    Reset counter: 71
                    Reset counter: 10
                    Mileage: 20434 km
                    Date: 2014.07.20
                    Time: 16:56:25
          B1217 00 [008] - -
                    Reset counter: 10
                    Mileage: 160843 km
                    Date: 2020.07.23
                    Time: 00:05:31
          B1218 00 [008] - -
                    Reset counter: 111
                    Mileage: 20434 km
                    Date: 2014.07.20
                    Time: 16:56:27
Address 56: Radio
   Coding: 030B185A
   Coding: 0030007
   Revision: 00H52001
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2020.07.08
                    Time: 14:43:34
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2020.07.08
                    Time: 14:43:34
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2020.07.08
                    Time: 14:43:34
                    Fault Frequency: 51
                    Reset counter: 225
                    Mileage: 159401 km
                    Date: 2020.07.08
                    Time: 14:43:34
0022 - Radio
                    Fault Frequency: 71
                    Reset counter: 225
                    Mileage: 159401 km
                    Date: 2020.07.08
                    Time: 14:43:34
End-------------------------(Elapsed Time: 03:43)--------------------------
siLc
Tallinn, Estonia
C?ID=330192
I'm not very familiar with DCC but chances are if DCC is made happy again by fixing this issue, the xenon leveling might be one step closer to working.
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2014.11.28
                    Time: 14:43:35
Artiforgs
Norway
                    Reset counter: 204
                    Mileage: 159401 km
                    Date: 2014.11.28
                    Time: 14:43:35
Im not sure thats true, autoleveling is communicating from rear level sensor via can, and since i have can gateway dtc, i think its a coding or programming issue with afs..
But do i need to code byte 18?
Every retrofit ive read talks about byte 18 bit 65..
Anyone who knows? And why wont the drl light up?
golfi_vend
Tartu, Estonia
C?ID=195131
I will tag this thread by posting here.
I can help You with this, but i need to check Your autoscan and think of a Coding to apply, but I won't do this behind mobile.
When I'm behind PC I'll write here again or if I haven't in a timely manner, please remind me :) .
Artiforgs
Norway
Ah, sounds good!
As of right now, i got the DRL working,
Highbeam have currently become my fog lights, so i guess i just wire them from fogs and up to xenon shutter pin in 14pin contact.
Or is there a way i still have fog lights, and get shutters to work?
So i guess whats left, is get rid of the can gateway fault..
downtime
Finland
C?ID=280813
Have you coded headlight module 55 to use CAN info for leveling instead of sensor? There’s a labeled bit for that in module 55 long coding.
Artiforgs
Norway
When i uncheck bit 3 in module 55 (level info via sensor NOT can), i get «coding rejected, general reject»
downtime
Finland
C?ID=280813
Are you sure the headlight module is correct for Passat?
Artiforgs
Norway
Do you mean the AFS?
I was told by my dealer that the partnr was identical with touran, so i got my hands on a used afs from a touran, with the same partnr the dealer told me.
But how can i be sure?
Artiforgs
Norway
Also, i havent programmed the afs yet, and no calibration of the lights etc, cause i dont know if i need to. Ive only checked the bits on the bytes explained earlier in thread.
Ive not changed anything in byte 18 yet, because noone can anwser me if i have to, and what bit do i choose..?
-DRL/parking lights works
-LOW beam works
-HIGH beam works
But they do not self level after startup, and i get AFS fault, cornering light malfunction in display..?
downtime
Finland
C?ID=280813
Your headlight control module 55 is correct for Passat but seems to be incorrectly coded.
Try this as module 55 coding :
02A200000B000200
Car type is Passat (byte 0), headlight leveling is set via CAN and rear axle type is changed tp 4WD axle.
Artiforgs
Norway
02A200000B000200
No matter if i just uncheck bit 3, or write youre code, i get coding rejected..
Aah, so close now..
