VW Transporter 2007 2.5tdi bpc
Gapel3
Australia
C?ID=313356
Using vcds and trying to test turbo....software freezing up everytime i hit turbo button.any idea why?
Bruce
Near Philadelphia, PA, USA
As you are not a new poster here on our forum, what might we need to help you? That's right... every time we go to work on a different vehicle, those on the forum willing to help need a point of reference. An Autoscan please.
The [Turbo] button does not test the turbo. ;)
The [Turbo] button is there to speed up sample rates using various techniques that are not 100% kosher and may not work on every control module.
Gapel3
Australia
C?ID=313356
thx uwe.....can i change value of egr flow between air mass sensor?i cannot see egr valve adaptation in it.should have it if is equipped isnt it?
Do we have an Auto-Scan from this vehicle somewhere? Because without seeing exactly what ECU it has, I can't even begin to check what functionality said ECU supports.
Gapel3
Australia
C?ID=313356
TRANSPORTER
Thursday,14,May,2020,16:11:38:39620
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WV1ZZZ7HZ8H047706   License Plate: HAKK
Mileage: 285180km-177202mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ8H047706   Mileage: 285180km-177202miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 906 016 DQ    HW: 070 906 016 DQ
   Component: R5 2,5L EDC G000SG  1583
   Revision: --H05---    Serial number: VWZ7Z0G5746272
   Coding: 0051172
   Shop #: WSC 02736 790 00000
   VCID: E288F0DD3CD5F596FD-5160
008214 - Intake Manifold Flap Position Sensor (Bank 1)
               P2016 - 000 - Short to Ground - Intermittent
                    Mileage: 285183 km
                    RPM: 777 /min
                    Voltage: 14.44 V
                    Duty Cycle: 100.2 %
                    Lambda: 0.0 %
                    Lambda: -0.2 %
                    (no units): 4.0
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
   Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
   Component: ESP MK25E1          0104
   Revision: 00H31001
   Coding: 0001634
   VCID: C4C4164586019BA6EF-5118
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H0 820 045 R
   Component: CLIMA/AC            0202
   VCID: B4244685D6A12B265F-5118
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 AD
   Component: BORDNETZ SGVER 1.0  2101
   Coding: 0000101
   VCID: F4A4868596216B269F-5118
00968 - Right Turn Signals
   Part No: 1C0 909 605 F
   Component: 0T AIRBAG VW61 0R   0004
   Coding: 12372
   Shop #: WSC 02736
   VCID: A71EA1C9477750BEEA-5118
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 851 R
   Coding: 00722
   Shop #: WSC 00001
   VCID: BA3868BDA4C5DD5685-5118
   WV1ZZZ7HZ8H047706     VWZ7Z0G5746272
            30-00 - Open or Short to Plus
   Part No: 6N0 909 901
   Coding: 00022
   Shop #: WSC 02736
   VCID: F0AC8A95B23957067B-5118
Address 22: AWD        Labels: 7H0-907-554.clb
   Part No: 7H0 907 554 F
   Component: HALDEX 4Motion      2110
   Coding: 0000002
   VCID: B3264599D3AF2C1E46-5118
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C11 Komfortgerát     0004
   Coding: 00031
   Shop #: WSC 02736
   VCID: B228409D7CB525164D-4B00
Address 76: Park Assist        Labels: 7H0-919-283.lbl
   Part No: 7H0 919 283
   Component: Parkingsyst. T5 T5N 401
   Coding: 00137
   Shop #: WSC 02736
   VCID: EFAE89E9AF0748FE62-513C
01545 - Sensor for Parking Aid; Rear Left (G203)
            37-00 - Faulty
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
End----------(Elapsed Time: 05:56, VBatt start/end: 14.3V/14.3V)-----------
Address 01: DTCs cleared
EGR valve "adaptation" is done in Basic Settings, Group 003 on this engine.
; Ignition ON, Engine ON (Idling)
; Activate Basic Setting
; Press and Hold both Brake Pedal and Gas Pedal
; Exhaust Gas Recirculation (EGR) is alternately switched on and off
; The Deviation between "EGR ON" and "EGR OFF" must at least be 100.0 mg/Str.
Gapel3
Australia
C?ID=313356
Yes done it but doesnt seems to be doing as explained.....just wondering what should be right value for injector on idle and deviation on idle too?
I got one code which is terminal 30. not sure if tat can cause power lost.
Tuesday,19,May,2020,14:46:43:39620
VIN: WV1ZZZ7HZ8H047706   License Plate: HAKO
Mileage: 285220km-177227mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ8H047706   Mileage: 285220km-177227miles
   Coding: 0051172
   VCID: E288F0DD3CD5F596FD-513C
   Revision: 00H31001
   Coding: 0001634
                    Reset counter: 38
                    Mileage: 285189 km
                    Count: 128
                    Count: 6401
                    Count: 128
                    Count: 255
   Coding: 0000101
            014 - Defective
   Coding: 12372
   Shop #: WSC 02736
   Coding: 00722
   Shop #: WSC 00001
   Coding: 00022
   Shop #: WSC 02736
   Coding: 0000002
   Coding: 00031
   Shop #: WSC 02736
   Coding: 00137
   Shop #: WSC 02736
            37-00 - Faulty
End----(Elapsed Time: 06:05, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 22: DTCs cleared
Address 46: DTCs cleared
Address 76: DTCs cleared
Gapel3
Australia
C?ID=313356
VW TRANSPORTER 2008 T5 2.5TDI
no power oil level reses,good start ,no power under load gutless
Gapel3
Australia
C?ID=313356
uwe...also what i relised is after engine is runing get egr read 475mg/str duty cycle 0.0%...rev up bit and is back to 275 mg/str and aroun 21.4% duty cycle
South Molton, UK
Need a lot more context than that to be able to help :popcorn:
Sorry, I'm not familiar enough with that engine to make informed comments on those values.
