Hi, I've a 2020 T6.1 van that I'm looking to put a leisure battery in, for this I am needing to get an engine run signal for the battery to battery charger (Schaudt WA 121525), this is as appose to an ignition live which would be much easier....
I've checked Erwin, this shows T73b/58 on the BCM as the pin for this in the factory second battery installation, this is changed from the T6 where it was T73a/3.
I've stuck the wire in but doesn't look to be enabled, anyone know how I'd enable this output? Had a good search but can't seem to find anything for the T6.1.
Autoscan is below for info.
Cheers, Lewis
Cheers, Lewis
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 22 3C 44 55 5F 65 69 6C 6D 75
A5 D6 D7
VIN: WV1ZZZ7HZLH040334 Mileage: 1203km-747miles
Address 01: Engine (J623-CXEC) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 RR HW: 04L 907 445 N
Component: R4 2.0l BTD H01 9970
Revision: 23401001
Coding: 002540144376050800000000000000000000000000000000
Shop #: WSC 00012 790 00025
ASAM Dataset: EV_ECM20BTD03004L906056RR 004005
ROD: EV_ECM20BTD03004L906056AG.rod
VCID: 0E45AF2550D2908BD17-805A
Readiness: N/A
Part No SW: 0BT 300 012 E HW: 0GC 927 711 H
Component: GSG DQ500 H06 3106
Revision: 00H06V11
ROD: EV_TCMDQ500021_VN46.rod
VCID: 313F14D9E1ACAF73EC5-8064
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 7LA 614 517 A HW: 7LA 614 517
Component: ESC_high H01 0700
Serial number: 08505604200115
Coding: 31556452C84BEE858C5726A7136A7776392723B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
VCID: 3D2738E92DF45B1378D-8068
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 7LA 907 426 HW: 7LA 907 426
Component: AC Manuell H01 0502
Coding: A03110000810000001000800504001050000000000030100A00000000000
ASAM Dataset: EV_AirCondiBHTCT6PA 001004
ROD: EV_AirCondiBHTCT6PA.rod
VCID: 55F78049B584A35350D-8000
Operating and display unit 1 for air conditioning:
Subsystem 1 - Part No SW: 7LA 907 049 HW: 7LA 907 049
Component: E857 H02 0301
Serial number: 00002301019133833605
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q5 937 090 HW: 2Q5 937 090
Component: BCM T6PA Std+ H10 0935
Serial number: 01102002200373
Shop #: WSC 00012 790 00047
ASAM Dataset: EV_BCMA0 205001
ROD: EV_BCMA0_205.rod
VCID: 74B1DDCD5E3EDA5B473-8020
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: S5Y20M01D03H15M13S48
Coding: 02B8EE
Drivers Door Control Module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000035229005
Coding: 1F0007
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000036035083
Coding: 050007
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY193400YEC
Serial number: 00000000000032263351
Part No SW: 5QA 919 298 H HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0061
Serial number: 000150057220009
Coding: 0B79167951
ASAM Dataset: EV_EPHVA2CAU3700000 009048
ROD: EV_EPHVA2CAU3700000_VW27.rod
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3204670B41FF8748949C815580508700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43D34E114B102DE30E9-8016
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 015 0506
Revision: --------
Coding: 8800C00000000000800000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X_VW27.rod
VCID: 7F5B02E1677889032A1-802A
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 7LA 920 941 HW: 7LA 920 941
Component: KOMBI 205 6750
Coding: 27A40A8A64AC260001886A0F3401000000600000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 7DA7F8E96D749B1338D-8028
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 15121910802934
Coding: 030100344F05730401100018100F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 70B9D1DD2A26E67BA3B-8024
Component: 4-00-11-01-04
Subsystem 2 - Part No SW: 3G0 959 442 F HW: 3G0 959 442 F
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440036009200036
Coding: 2C1D00
Subsystem 3 - Part No SW: 7E0 915 181 N HW: 7E0 915 181 N
Component: J367-BDMConti H03 1052
Serial number: 77343301001912171000
Part No SW: 0CQ 907 554 L HW: 0CQ 525 130 C
Component: Haldex4Motion H56 7822
Serial number: HA1-00029.11.19
Coding: 0105
VCID: 4EC56F259052D08B917-801A
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0149
Serial number: 00000535549409
Coding: A2954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392F2CF939DC6733545-806C
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 1306
Shop #: WSC 00012 790 00053
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB_VN46.rod
VCID: 45D75009452413D320D-8010
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 0C8E020009200003
Shop #: WSC 00012 790 00032
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41DF4419510C3FF31C5-8014
Part No SW: 3G5 035 820 HW: 3G5 035 820
Component: MU-O-ND-EU H12 0156
Serial number: VWZAZ2W1163623
Coding: 64600008000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_SE27.rod
VCID: 619FA499F1CC5FF33C5-8034
Part No SW: 5Q0 907 273 D HW: 5Q0 907 273
Component: RDKBERU30 H05 0010
Serial number: 30000000373143
ROD: EV_RDKBERU30_VW41.rod
VCID: 363527C508C2884BB97-8062
8397058 - Front Left TPMS Sensor
C1050 31 [009] - No Signal
Reset counter: 4
Mileage: 923 km
Date: 2020.03.09
Time: 15:03:16
Vehicle speed: 82 km/h
Outside air temperature: 8.5 °C
Reception level antenna 1: 460 mV
Offset level antenna 1: 200 mV
8397314 - Front Right TPMS Sensor
C1051 31 [009] - No Signal
Reset counter: 4
Mileage: 923 km
Date: 2020.03.09
Time: 15:03:16
Reception level antenna 1: 410 mV
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Reset counter: 4
Mileage: 923 km
Date: 2020.03.09
Time: 15:03:16
Reception level antenna 1: 430 mV
8397826 - Rear Right TPMS Sensor
C1053 31 [009] - No Signal
Reset counter: 4
Mileage: 923 km
Date: 2020.03.09
Time: 15:03:16
Address 69: Trailer (J345) Labels:* None
Part No SW: 5H0 907 383 HW: 5H0 907 383
Component: Anhaenger H09 0040
Serial number: 000000000005400
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 6B83C6B1030005A3969-803E
Part No SW: 5Q0 980 568 B HW: 5Q0 980 568 B
Component: RVC Compact+ H09 0250
Coding: 0155000123002017000048
ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 007012
ROD: EV_CamSysRVRVCARPANAMQBAB_007.rod
VCID: 3C2135ED36EE521B4F3-8068
Address 6D: Trunk Elect. (J605) Labels:* None
Part No SW: 7LA 959 107 HW: 4M0 959 107 C
Component: HDSG-Modul H14 0672
Revision: -------- Serial number: A2-C769-9790-2
Coding: 4180
ASAM Dataset: EV_DeckLidCONTIVN46T 001017
ROD: EV_DeckLidCONTIVN46T.rod
VCID: 03538E110B90EDE34E9-8056
Part No SW: 5WA 035 284 HW: 5WA 035 284
Component: OCUGen3High H20 0088
Serial number: 0000000911VIJH1
Coding: 06462000196898209005460160500607
ASAM Dataset: EV_OCUGen3High 002115
ROD: EV_OCUGen3High_002_AU27.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 HW: 2Q0 980 653
Component: MQB MFK 3.0 H11 1029
Serial number: E33417011193030
Coding: 000108081178C020409F00001030002006010000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005035
ROD: EV_MFK3ValeoMQB_005_VW27.rod
VCID: 72BDDBD5242AD46B55F-8026
Part No SW: 992 941 571 AA HW: 992 941 571 A
Component: LED1L H08 9002
ROD: EV_LLPGen3LKEBODPO68X_SK25.rod
Component: LED1R H08 9002
