Audi Q3: Zero setting of the Brake fluid pressure transmitter 1 - G201 ?
Bap33
FRANCE
C?ID=175563
Hi all,
I intend to replace the brake fluid on our Audi Q3 (8U MY2015 - TDI 150HP). The service manual indicates that after fluid replacement on the 4 wheels, a zero setting must be performed on the brake fluid pressure transmitter 1 (G201). Then a test drive and ABS triggering must be done before normal use. Thus I've plugged my VCDS to find how I could do this zero setting.
Unfortunatelly, I did find any (G201) reference :confused:. May be I did not look at the right submenus in the "03 - ABS Brakes" Control Unit.
I didn't thought to make a screen shot, but here is one (thank you google) that shows exactly the same buttons ('greyed' and 'normal ones'):
If anyone knows more about this 'brake fluid transmitter 1 (G201)' zero setting, I'd be glad to learn more about it.
Thanks for your help! ;)
Bap33
FRANCE
C?ID=175563
Does this really help? I have no fault code at this time.
Or is it only to see the references of the controller?
Here is the latest full AutoScan:
Friday,07,February,2020,22:57:00:04899
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8U7FR012345   License Plate:
Mileage: 124540km-77385mi   Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 55 5F 62 72
VIN: WAUZZZ8U7FR018618   Mileage: 124540km-77385miles
Address 01: Engine (J623-CUVC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 BG    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 2913
   Revision: 8AH20---
   Coding: 01190012043401080000
   Shop #: WSC 12784 002 1048576
   ASAM Dataset: EV_ECM20TDI01104L906016BG 004002
   ROD: EV_ECM20TDI01104L906016BF_004.rod
   VCID: 6FC333B5B68E2F374E-803A
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CA    HW: 5N0 614 109 CA
   Component: ESC-EBC460iV1 H08 0004
   Serial number: A00QK2M
   Coding: 22F124A10921E374207D440124CB90C704355700F08B4884
   Shop #: WSC 00049 770 00154
   ASAM Dataset: EV_Brake1ESCEPBTRW 003039
   ROD: EV_Brake1ESCEPBTRW_003.rod
   VCID: 6CF924B98798D42F6B-8038
   Part No SW: 8U0 820 043 F    HW: 8U0 820 043 F
   Component: E87  Klimavoll      0210
   Revision: 00H05000    Serial number: 8U0820043F
   VCID: 3449FCD957284CEF73-8060
   Part No SW: 8X0 907 063 AB    HW: 8X0 907 063 AB
   Component: BCM PQ35  M   113 0817
   Revision: AB113817
   Coding: 26080A2CA8051AC4201848C10144894C47FF23AA007F912BE400878400C1
   Shop #: WSC 00049 770 00099
   VCID: 7CD914F9FFF844AFFB-8028
   Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 150107  H37 0090
   Serial number:         150119074023
   Coding: 0047F7
   Serial number: 23658232
   Coding: 02006E
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 AH    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0080
   Revision: 11001001    Serial number: 61061502601236
   Coding: 08C208
   Shop #: WSC 00049 770 00117
   ASAM Dataset: EV_EPHVA18AU21X0000 003008
   ROD: EV_EPHVA18AU21X0000_003.rod
   VCID: 0C394439A758742FCB-8058
   Part No SW: 8U0 959 655 C    HW: 8U0 959 655 C
   Component: AirbagVW-AU10 H09 0900
   Serial number: 003PAR0AAV2W
   Coding: 304D3232333030303030554A304C38553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 001010
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 47B3BB15FEBED77726-8012
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME23040B34ZZZN
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME2C387834ZZZZ
   Serial number: 3516KSME7C160B34ZZZX
   Serial number: 3526KSME320F7834ZZZW
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME797A7032ZZZ4
   Part No SW: 8X0 953 501 D    HW: 5K0 953 569 AL
   Component: LENKS.MODUL   016 0162
   Revision: FF010018    Serial number: 20150126300461
   Coding: 1184204000
   VCID: 3B5BD7E5B2768397B2-806E
   Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
   Serial number: 10 01 2015  A0025132
   Part No SW: 8U0 920 940 H    HW: 8U0 920 940 H
   Component: KOMBI_COLOUR  H02 0350
   Coding: 12CF01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 3D5FD9FDAC628DA78C-8068
   Part No SW: 8U0 907 468 AQ    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0090
   Revision: 1P140041    Serial number: 4141P1512208B7
   Coding: FBCF1A5A000108610253
   VCID: 1107554DC87A59C738-8044
   Component: J367-BDM  H07 0180
   Serial number: 42024F25511491416064
   Serial number: 15015003559021200181
   Component: IMMO          H02 0350
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H11 0415
   Coding: 011803201C00000000
   VCID: 52859A410DFC62DF41-8006
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.377 1401
   Revision: 1BH04841    Serial number: 00150070336701
   Coding: 0000258
   VCID: 41A7A50D189AE947E8-8014
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H11 0415
   Coding: 011803201E00000000
   VCID: 5187954D08FA19C778-8004
   Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
   Serial number: 150124-0002-091
   Coding: 11C794101002A500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 44A9AC19CF88FC6FC3-8010
   Part No SW: 8U1 035 193 A    HW: 8U1 035 193 A
   Component: RMC Cnct Nav  H61 0139
   Coding: 01000600024153470823020103010000000000
   VCID: 3449FCD997284CEF73-8060
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 8U0 919 603 A    HW: 8U0 919 603 A
   Component: DUBasic AU316  H42 0018
   Serial number: AUZ8ZDEM502QDVT
   Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
   Component: TSG HL        H08 0415
   Coding: 010003200000000000
   VCID: 5081904903F010CF77-8004
   Component: TSG HR        H08 0415
End-------------------------(Elapsed Time: 02:11)--------------------------
Thanks!
Does this really help? I have not fault code at this time.
Yes; on UDS modules, knowing which ASAM dataset is being used is critical.
This ABS module should have a Basic Setting called:
IDE03650 -- Basic setting for brake pressure sensor
However, I do not have any kind of procedure for this.
I also think it is possible to replace brake fluid without any such Basic Setting -- use a pressure or vacuum bleeder and make sure the reservoir does not run dry!
Bap33
FRANCE
C?ID=175563
OK, thanks for all these answers. I'll do that!
