- May 12, 2014
- 52
- 13
- Palestine Gaza
- C?ID=11756
Hi
It isnice to share you this problem which is not acceptable ,,,I got this car with good working radio ( all speakers are working with high and low sound ) I have replace the dead battery only the battery with a good one ,after that the speakers were like there is no sound even when I make the volume to the high degree, the radio work but there is no sound .
any help
Thank you
any help
Thank you
Monday,09,February,2015,13:56:29:25282
VCDS Version: 15.2.0.0
Data version: 20150130
Dealer/Shop Name: Ferwana Workshop Bros.
Workshop Code: 123 12345 023456
VIN: TMBHT61Z6A2094370 License Plate: AHMED ABU AISCHA
Mileage: 139530km-86699mi Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: TMBHT61Z6A2094370 Mileage: 139530km-86699miles
Address 01: Engine
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 113B201C092B00FE880E04EB90190041340000
Shop #: WSC 73430 790 00999
VCID: 78F58CA2CBB189F85B-802D
Fault Status: 00101101
Reset counter: 190
Mileage: 137837 km
Date: 2015.01.28
Time: 00:00:30
Count: 2
Count: 2
Count: 20736
Count: 8196
Count: 37376
Count: 1
02214 - Tire Pressure Warning
Fault Frequency: 31
Reset counter: 190
Mileage: 124993 km
Date: 2014.11.21
Time: 17:42:13
Count: 32768
Count: 12800
Count: 397
Count: 48673
Count: 512
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
ROD: EV_ClimaAutoBasis_SK12.rod
VCID: 030FEB4E8A77DA207E-8056
9481200 - Coolant Pressure
B10AB F0 [009] - Too Low
Reset counter: 82
Mileage: 95201 km
Date: 2014.05.18
Time: 08:22:43
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 40180AB8B00508C040080080110081E4430100AE424D85605C0540000000
VCID: 32617E8A6D4DA3A8A5-8067
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 30011 22 0601
Coding: 00D7B7
15 Faults Found:
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 164
Mileage: 119939 km
Date: 2014.10.28
Time: 07:24:36
Term 15 On
Voltage: 13.75 V
Term 50 Off
Reset counter: 164
Mileage: 119939 km
Date: 2014.10.28
Time: 07:24:36
Term 15 On
Voltage: 13.75 V
Term 50 Off
Fault Frequency: 8
Reset counter: 180
Mileage: 128436 km
Date: 2014.12.10
Time: 22:27:39
Term 15 On
Voltage: 13.90 V
Term 50 Off
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 185
Mileage: 136623 km
Term 15 On
Voltage: 12.45 V
Term 50 Off
Reset counter: 164
Mileage: 121251 km
Date: 2014.11.06
Time: 17:52:00
Term 15 On
Voltage: 13.80 V
Term 50 Off
Reset counter: 164
Mileage: 127337 km
Date: 2014.12.04
Time: 11:16:16
Term 15 On
Voltage: 11.85 V
Term 50 Off
Fault Status: 00101110
Reset counter: 201
Mileage: 128329 km
Date: 2014.12.10
Time: 16:56:58
Term 15 On
Voltage: 13.80 V
Term 50 Off
01502 - Bulb for Rear Fog; Left (L46)
Reset counter: 164
Mileage: 128917 km
Date: 2014.12.14
Time: 00:59:45
Term 15 On
Voltage: 14.05 V
Term 50 Off
Reset counter: 164
Mileage: 137860 km
Term 15 Off
Voltage: 12.40 V
Term 50 Off
00834 - Signal for Activation of Heated Rear Window
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 102
Mileage: 131189 km
Date: 2014.12.26
Time: 12:49:16
Term 15 On
Voltage: 14.00 V
Term 50 Off
Fault Status: 00101010
Reset counter: 196
Mileage: 132034 km
Date: 2014.12.31
Time: 13:35:30
Term 15 On
Voltage: 13.90 V
Term 50 Off
Reset counter: 164
Mileage: 132121 km
Date: 2015.01.01
Time: 08:25:06
Term 15 On
Voltage: 14.00 V
Term 50 Off
Reset counter: 190
Mileage: 134783 km
Date: 2015.01.12
Time: 19:45:24
Term 15 Off
Voltage: 12.40 V
Term 50 Off
01598 - Drive Battery Voltage
Fault Status: 00101011
Reset counter: 194
Mileage: 132489 km
Date: 2015.01.03
Time: 00:01:52
Term 15 On
Voltage: 13.90 V
Term 50 Off
Reset counter: 165
Mileage: 133733 km
Date: 2015.01.07
Time: 04:41:41
Term 15 On
Voltage: 13.70 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0006
Revision: -------- Serial number: 66641003401707
Coding: 100001
VCID: 40852442D3E1013823-8015
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2JNK2T
Coding: 0020790
VCID: 3D7B5DB664136CD048-8068
Subsystem 1 - Serial number: 6332MSME4F132F72K
Subsystem 2 - Serial number: 6342MSME4F412E30F
Subsystem 3 - Serial number: 6351HSME203A1A5CA
Subsystem 4 - Serial number: 6361HSME202B144B3
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000732
VCID: 78F58CA20BB189F85B-802D
Subsystem 1 - Part No: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 00000130
Part No SW: 1Z0 920 843 G HW: 1Z0 920 843 G
Component: KOMBI H05 0305
Coding: 110B00
Shop #: WSC 73430 031 00999
VCID: 3C7D50B2B70965D87F-8069
9459995 - Covering for fuel level indicator sensor 1
B1059 1B [008] - Resistance Too High
Fault Frequency: 167
Reset counter: 189
Mileage: 131716 km
Date: 2014.12.29
Time: 15:36:51
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K1020503AD
Coding: E9A07F06400602002302
VCID: 69D3D9E6401B2070D4-803C
Component: IMMO H05 0305
VCID: 6AD1A6EA8D1D2B68DD-803F
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 3T0 035 680 A
Component: RNS-MID H05 2684
Revision: AB001001 Serial number: SKZ6Z7K8022066
Coding: 040200020001008100
Shop #: WSC 12345 123 23456
VCID: 2E596AFA79758748C1-807B
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2113
Coding: 0000244
VCID: 48953C623BD13978EB-801D
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 31637186A84B98B0DC-8064
Fault Status: 00110010
Reset counter: 194
Mileage: 138460 km
Date: 2015.02.02
Time: 19:39:58
Battery Volts: 9.8 V
DU
Temperature: 55.0°C
Torque: 0.251 Nm
Torque: 3.3 Nm
RPM: 517 /min
Drive Current: 26.8 A
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000244
VCID: 47973F5E36CF3600E2-8012
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012551
VCID: 32617E8AAD4DA3A8A5-8067
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 336F7B8E5257AAA0AE-8066
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial number: 00000005186464
Coding: 0010401
VCID: 3A7156AA753D5BE86D-806F
01304 - Radio
Reset counter: 186
Mileage: 137177 km
Date: 2015.01.25
Time: 03:17:50
End-------------------------(Elapsed Time: 02:18)--------------------------
