Radio work fine but there is no sound
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
It isnice to share you this problem which is not acceptable ,,,I got this car with good working radio ( all speakers are working with high and low sound ) I have replace the dead battery only the battery with a good one ,after that the speakers were like there is no sound even when I make the volume to the high degree, the radio work but there is no sound .
any help
Thank you
Monday,09,February,2015,13:56:29:25282
VCDS Version: 15.2.0.0
Data version: 20150130
Dealer/Shop Name: Ferwana Workshop Bros.
Workshop Code: 123 12345 023456
VIN: TMBHT61Z6A2094370   License Plate: AHMED ABU AISCHA
Mileage: 139530km-86699mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: TMBHT61Z6A2094370   Mileage: 139530km-86699miles
Address 01: Engine
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 113B201C092B00FE880E04EB90190041340000
   Shop #: WSC 73430 790 00999
   VCID: 78F58CA2CBB189F85B-802D
                    Fault Status: 00101101
                    Reset counter: 190
                    Mileage: 137837 km
                    Date: 2015.01.28
                    Time: 00:00:30
                    Count: 2
                    Count: 2
                    Count: 20736
                    Count: 8196
                    Count: 37376
                    Count: 1
02214 - Tire Pressure Warning
                    Fault Frequency: 31
                    Reset counter: 190
                    Mileage: 124993 km
                    Date: 2014.11.21
                    Time: 17:42:13
                    Count: 32768
                    Count: 12800
                    Count: 397
                    Count: 48673
                    Count: 512
   Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 030FEB4E8A77DA207E-8056
9481200 - Coolant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 82
                    Mileage: 95201 km
                    Date: 2014.05.18
                    Time: 08:22:43
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 40180AB8B00508C040080080110081E4430100AE424D85605C0540000000
   VCID: 32617E8A6D4DA3A8A5-8067
   Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 30011  22  0601
   Coding: 00D7B7
15 Faults Found:
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 164
                    Mileage: 119939 km
                    Date: 2014.10.28
                    Time: 07:24:36
                    Voltage: 13.75 V
                        Term 50 Off
                    Reset counter: 164
                    Mileage: 119939 km
                    Date: 2014.10.28
                    Time: 07:24:36
                    Voltage: 13.75 V
                        Term 50 Off
                    Fault Frequency: 8
                    Reset counter: 180
                    Mileage: 128436 km
                    Date: 2014.12.10
                    Time: 22:27:39
                    Voltage: 13.90 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 185
                    Mileage: 136623 km
                    Voltage: 12.45 V
                        Term 50 Off
                    Reset counter: 164
                    Mileage: 121251 km
                    Date: 2014.11.06
                    Time: 17:52:00
                    Voltage: 13.80 V
                        Term 50 Off
                    Reset counter: 164
                    Mileage: 127337 km
                    Date: 2014.12.04
                    Time: 11:16:16
                    Voltage: 11.85 V
                        Term 50 Off
                    Fault Status: 00101110
                    Reset counter: 201
                    Mileage: 128329 km
                    Date: 2014.12.10
                    Time: 16:56:58
                    Voltage: 13.80 V
                        Term 50 Off
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 164
                    Mileage: 128917 km
                    Date: 2014.12.14
                    Time: 00:59:45
                    Voltage: 14.05 V
                        Term 50 Off
                    Reset counter: 164
                    Mileage: 137860 km
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 102
                    Mileage: 131189 km
                    Date: 2014.12.26
                    Time: 12:49:16
                    Voltage: 14.00 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 196
                    Mileage: 132034 km
                    Date: 2014.12.31
                    Time: 13:35:30
                    Voltage: 13.90 V
                        Term 50 Off
                    Reset counter: 164
                    Mileage: 132121 km
                    Date: 2015.01.01
                    Time: 08:25:06
                    Voltage: 14.00 V
                        Term 50 Off
            000 -  -  - Intermittent
                    Reset counter: 190
                    Mileage: 134783 km
                    Date: 2015.01.12
                    Time: 19:45:24
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
01598 - Drive Battery Voltage
                    Fault Status: 00101011
                    Reset counter: 194
                    Mileage: 132489 km
                    Date: 2015.01.03
                    Time: 00:01:52
                    Voltage: 13.90 V
                        Term 50 Off
                    Reset counter: 165
                    Mileage: 133733 km
                    Date: 2015.01.07
                    Time: 04:41:41
                    Voltage: 13.70 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0006
   Revision: --------    Serial number: 66641003401707
   Coding: 100001
   VCID: 40852442D3E1013823-8015
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2JNK2T
   Coding: 0020790
   VCID: 3D7B5DB664136CD048-8068
   Subsystem 1 - Serial number: 6332MSME4F132F72K
   Subsystem 2 - Serial number: 6342MSME4F412E30F
   Subsystem 3 - Serial number: 6351HSME203A1A5CA
   Subsystem 4 - Serial number: 6361HSME202B144B3
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000732
   VCID: 78F58CA20BB189F85B-802D
   Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H07 0012
   Coding: 00000130
   Part No SW: 1Z0 920 843 G    HW: 1Z0 920 843 G
   Component: KOMBI         H05 0305
   Coding: 110B00
   Shop #: WSC 73430 031 00999
   VCID: 3C7D50B2B70965D87F-8069
9459995 - Covering for fuel level indicator sensor 1
          B1059 1B [008] - Resistance Too High
                    Fault Frequency: 167
                    Reset counter: 189
                    Mileage: 131716 km
                    Date: 2014.12.29
                    Time: 15:36:51
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K1020503AD
   Coding: E9A07F06400602002302
   VCID: 69D3D9E6401B2070D4-803C
   Component: IMMO          H05 0305
   VCID: 6AD1A6EA8D1D2B68DD-803F
   Part No SW: 3T0 035 680 A    HW: 3T0 035 680 A
   Component: RNS-MID       H05 2684
   Revision: AB001001    Serial number: SKZ6Z7K8022066
   Coding: 040200020001008100
   Shop #: WSC 12345 123 23456
   VCID: 2E596AFA79758748C1-807B
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2113
   Coding: 0000244
   VCID: 48953C623BD13978EB-801D
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   VCID: 31637186A84B98B0DC-8064
                    Fault Status: 00110010
                    Reset counter: 194
                    Mileage: 138460 km
                    Date: 2015.02.02
                    Time: 19:39:58
                    Battery Volts: 9.8 V
                        DU
                    Temperature: 55.0°C
                    Torque: 0.251 Nm
                    Torque: 3.3 Nm
                    RPM: 517 /min
                    Drive Current: 26.8 A
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000244
   VCID: 47973F5E36CF3600E2-8012
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 32617E8AAD4DA3A8A5-8067
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336F7B8E5257AAA0AE-8066
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 E    HW: 1Z0 035 729 E
   Component: FSE_2P8x        H40 0190
   Revision: 00000000    Serial number: 00000005186464
   Coding: 0010401
   VCID: 3A7156AA753D5BE86D-806F
01304 - Radio
                    Reset counter: 186
                    Mileage: 137177 km
                    Date: 2015.01.25
                    Time: 03:17:50
End-------------------------(Elapsed Time: 02:18)--------------------------
AIB Wolfgang
Hi,
maybe the fault is based in the malfunktion of "77" telephone. Please look at the MB 2 of "56" Radio. Mute by telephone?
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
Maybe I will check and let you know ,,,
DrPeter
16.4905° S, 151.7375° W
- If the radio [Output Tests-03] works fine, have a look at the Measuring Value Block Groups, the ones for the antenna, MVB-007, 008 and 010. Be sure the radio is getting the signal from the stations.
- Check your coding for the Radio, it looks like [byte 4] [bit0-7] is set to [00]=Not coded, try to use this coding [040200020401008100], see if that helps.
- - -> "After the Coding has modified the Unit needs to be reset/restarted. Press and hold the [<] + [>] + [EJECT] buttons simultaneously. < - - -
- You may also want to remove the fuse to the radio for 10 minutes and see if that does anything.
Hope this helps,
drpeter
