- May 5, 2020
- 11
- 1
- Pittsburgh, USA
- C?ID=271108
I have a 2014 Audi Q7 3.0t. Trying to figure out why so many functions do not work. Trailer module does not appear to be installed on the car. Red connector in tailgate plus another clear connector has nothing going to it. Looking for ideas on how to restore functionality to adaptive cruise, side assist and back up camera. Any help appreciated. vf
See below:
See below:
VIN: WA1LGAFE1ED003825 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 4C 4F 52
55 56 5F 62 69 6C 6D 6F 72
VIN: WA1LGAFE1ED003825 Mileage: 73880km-45906miles
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
10-Park/Steer Assist -- Status: Cannot be reached 1100
13-Auto Dist. Reg -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
3C-Lane Change -- Status: Cannot be reached 1100
4C-Tire Pressure II -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
69-Trailer -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Cannot be reached 1100
Address 01: Engine (CTW) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4L0 910 551 P HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0A28
Shop #: WSC 31414 790 00001
VCID: 3560A0E55CD4B7E744-8060
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 N HW: 0C8 927 750 N
Component: AL1000 AISIN 002 2441
Coding: 001378
Shop #: WSC 28827 002 1048576
ROD: EV_TCMAL991031_002.rod
VCID: 377CAAED8ED845F756-8062
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0623697
VCID: 34669DE157AEAEEF73-8060
Reset counter: 64
Mileage: 73452 km
Date: 2012.07.09
Time: 00:00:12
Count: 128
Count: 11073
Count: 128
Count: 29696
Reset counter: 64
Mileage: 73452 km
Date: 2012.07.09
Time: 00:00:07
Count: 128
Count: 11073
Count: 297
Count: 30720
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702076283
Coding: 0000135
Shop #: WSC 28452 004 1048576
VCID: 254070A5EC74C767F4-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Component: FBSAUDIC6 KSG H03 0020
Component: FBSAUDIC6 IDG H01 0053
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 38
Mileage: 73861 km
Date: 2020.05.01
Time: 09:50:27
00191 - Passenger's Door Handle Touch Sensor (G416)
Reset counter: 38
Mileage: 73861 km
Date: 2020.05.01
Time: 09:50:27
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AP
Revision: 00---031 Serial number: 00000000385296
Coding: 0008C026
VCID: 254070A52C74C767F4-8070
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0139123
VCID: 6ED24F897902C43F45-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55931318900333
Coding: 29011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34669DE19FAEAEEF73-8060
13632257 - Databus
Reset counter: 37
Mileage: 73782 km
Date: 2020.04.30
Time: 14:14:52
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0051111
VCID: 275C7AAD9678D577C6-8072
01517 - Control Module for Trailer/Towing Sensor (J345)
Reset counter: 37
Mileage: 73782 km
Date: 2020.04.30
Time: 14:14:52
Temperature: 27.0°C
Voltage: 14.46 V
Bin. Bits: 00011
Hex Value: 0x0447
Hex Value: 0x0006
Speed: 64.8 km/h
Lateral Accel.: 0.25 m/s^2
00234 - Sensor for Automatic Distance Regulation Misadjusted
Reset counter: 37
Mileage: 73782 km
Date: 2020.04.30
Time: 14:14:52
Temperature: 27.0°C
Voltage: 14.46 V
Bin. Bits: 00011
Hex Value: 0x0941
Hex Value: 0x0001
Speed: 64.8 km/h
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH44 0230
Revision: 08H44000 Serial number: 0038QD0C9GZ-
Coding: 0014131
VCID: 2B54869D8A90F11722-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME1532184A9
Subsystem 3 - Serial number: 6342QSME13323F68H
Subsystem 4 - Serial number: 6352QSME5E482762P
Subsystem 5 - Serial number: 6362QSME4A333A60H
Subsystem 6 - Serial number: 63734SME6B360740
Subsystem 7 - Serial number: 63834SME6836095A6
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H09000 Serial number: 90026131520059
Coding: 0012252
VCID: 285E79919B66DA0FCF-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 F HW: 4L0 920 985 F
Component: KOMBIINSTR. H35 0317
Revision: 00000000 Serial number: VIP01987E
Coding: 8BD663040500CF05020205
VCID: 377CAAED86D845F756-8062
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB700037 Serial number: 3700M136130098
Coding: 00C303
VCID: 3F8CC2CDAEE87DB79E-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 30183K18074121711412
Reset counter: 37
Mileage: 73782 km
Date: 2020.04.30
Time: 14:14:53
Bin. Bits: 01111
Voltage: 14.50 V
Count: 7
Bin. Bits: 10011
Time: 25.40 s
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000065454255
Coding: 00581B00000011110000
VCID: 326A9BF96DBAA0DF61-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH02 0050
Revision: 00H02000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E528F89B982843F05-807A
Component: J0770_SWA_Slave_H02 0050
Subsystem 3 - Serial number: 5F08.07.1300H02000AMS14965ÿ
Subsystem 4 - Serial number: S14965ÿ
Reset counter: 37
Mileage: 73780 km
Date: 2020.04.30
Time: 14:14:53
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000068083135
Coding: 011F57205E40440004
VCID: 489ED911FB263A0F2F-801C
Fault Status: 01101000
Reset counter: 37
Mileage: 73782 km
Date: 2020.04.30
Time: 14:14:51
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01934393830000
Coding: 3569949
VCID: 387EA9D14BC64A8F5F-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004000 Serial number: 00000000018313
Coding: 030000
VCID: 29587C95406CE307D0-807C
03405 - Bass Loudspeaker
Fault Status: 00111011
Reset counter: 78
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191015714
Coding: 0693965
VCID: 23446EBDE24039579A-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000148997
Coding: 0012001
VCID: 5EB21F4989A254BFF5-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000068088163
VCID: 479CDA2DF638357726-8012
Reset counter: 37
Mileage: 73782 km
Date: 2020.04.30
Time: 14:14:52
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 130704-0004-052
Coding: 1147A71010020400
ROD: EV_HeadlRegulBasic.rod
VCID: 428ACB39D51A105FF1-8016
Revision: AB001007 Serial number: 156G10D7824618
Coding: 020007010000000000
VCID: 24466DA1274E3E6FE3-8070
Part No SW: 4L2 035 746 D HW: 4L2 035 746 D
Component: H-BNT-NA H40 0738
Revision: -------- Serial number: 224G00D7525875
Coding: 180200060004E9EF710023456F632003140000000100000000
VCID: 2F6C928D7E888D370E-807A
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Component: DU7 High H42 0104
Serial number: A130GV0D2776324
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002123837
Component: CD-Database 5298
Reset counter: 37
Mileage: 73782 km
Date: 2020.04.30
Time: 14:15:04
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000100
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000068113635
Coding: 010E57204040230004
VCID: 4682D729F1322C7FDD-8012
Address 69: Trailer
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0094576
Coding: 020C010001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6ED24F89B102C43F45-803A
13701376 - Databus
Reset counter: 37
Mileage: 73782 km
Date: 2020.04.30
Time: 14:14:52
Voltage terminal 30: 14.6 V
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD645814F1E362F6B-8038
ó
________________________________________
[1]
Subsystem 3 - Serial number: RD08.07.13--H57001002E0307ÿ
Subsystem 4 - Serial number: 2E0307ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0062562992----
Coding: 0003595
VCID: 264277A99172CC7FFD-8072
Component: J_245_EE16_SKB10H14 0220
Component: J_394_EE16_SKB10H14 0220
Component: J_392_EE16_SKB10H14 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000068113734
