2012 Audi A8, 4.2L, Intermittent rough idle, misfire
derekmyoung
C?ID=402768
**First Post**
I purchase this car used around 70k miles....first time Audi owner. After a first couple of weeks of honeymoon phase....I noticed a slight hesitation from stop position. Seems like a 1 sec delay then car snaps into acceleration. If I do an agressive start, you cant feel it.....only when you give it gas slowly. I took it to Audi Allentown, they could not find anything with their diagnostics....not sure if they did road test).....so I let it go.....I thought maybe this is just how Audi's are. A few more months after that, I noticed a "whistling noise" coming from engine when it is cold. I took my car in for oil service, and they told me my BREATHER CONTROL VALVE is bad. I orderd the part myself and replaced it (Im not sure if this procedure requires a vacuume or coolant purge, I just simply removed and replaced). The whistling sound was less, but did not go away completely. So, thought maybe something else is causing this pressure in my crankcase, so I replaced the OE air filters with brand new K&N filters, and I changed the spark plugs while at it. The original spark plugs i removed were NGK PN 101905621B, and I Installed NGK PFR6W-TG5547 (OE equivalent)......I still have original plugs. During the spark plug change, this was my first time dealing with the D plugs on the coils.....(I broke clips on #4 and #8).....I installed plugs on. The first start up, was very rough.....I knew sometheing was wrong....so I went and secure the plugs again as best as i can and car ran much better......I actually got a misfire code on #4 cylinder on first start up.....but I got that to clear. Now, air filter, new Breather control valve, and new spark plugs are on my car......but the whistling sound was Still there. I took car back to dealership for diagnostics.....another $170, just for them to tell me that the Breather control valve was bad again. So I got another Breather control valve via warranty....and installed that one. This valve seems to be MUCH better......every now and again, i still hear a faint whistle. My car still runs like it has intermittent misfires.....feels like a vaccume leak or something.
My autoscan tells me too rich/too lean....but im stuck here. Is there any measure values that I can take a look at with car running?
IDE01975,76, 77,78....ALL have extreme misfire counts. But the values for Misfires per 1000 revolutions are 0
Tuesday,05,May,2020,23:15:49:57557
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAURVAFD4BN019274   License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 34 36 3B 42 46 47 52
          53 55 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
VIN: WAURVAFD4BN019274   Mileage: 215827km-134108miles
Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0005
   Revision: N5H07---
   Coding: 0106000A290F0168
   Shop #: WSC 59317 001 1048576
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001006
   ROD: EV_ECM42FSI011_AU64.rod
   VCID: 2A0D07BF9C71240B2DF-807E
16475 - Fuel Trim; Bank 2
          P0175 00 [096] - System Too Rich
                    Mileage: 214526 km
                    Date: 2020.04.28
                    Time: 13:51:27
                    Engine speed: 706.00 /min
                    Normed load value: 28.6 %
                    Coolant temperature: 100 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 14.041 V
                    Unlearning counter according OBD: 31
                    AFS dm: 25.8 kg/h
                    Median injection timing: 0.729 ms
                    Engine operating condition: Idling
16497 - Fuel Trim; Bank 1
          P0172 00 [096] - System Too Rich
                    Mileage: 214526 km
                    Date: 2020.04.28
                    Time: 13:51:18
                    Engine speed: 738.50 /min
                    Normed load value: 31.0 %
                    Coolant temperature: 101 °C
                    Voltage terminal 30: 14.112 V
                    AFS dm: 29.0 kg/h
                    Median injection timing: 0.786 ms
   Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 AF
   Component: 0BK 42 FSIUSA H19 1007
   Revision: --H19---
   Coding: 000002
   ASAM Dataset: EV_TCMALX51011 002018
   VCID: 72BDDFDF74212CCB55F-8026
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 B    HW: 4H0 907 379 B
   Component: ESP PREMIUM   H10 0273
   Coding: 44E6F20022674F00E200
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 005006
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 313F10D3B1A757D3EC5-8064
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 AD
   Component: BCM2 2.0      H24 0510
   Coding: 0D872000000000000000
   Shop #: WSC 51988 000 1048576
   VCID: 6E85CBAF6099082BB17-803A
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000024780007
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00001002323265
   Coding: C018320085043201010001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 353724C3454F7BF3B0D-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
   Component: Klima 3 Zonen H14 0063
   Coding: 4881222E88
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 221DEF9FE441FC4B65F-8076
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [008] - Signal Amplitude Too High
                    Reset counter: 253
                    Mileage: 214447 km
                    Date: 2020.04.27
                    Time: 23:45:16
0378 - Coolant Circulation Pump
          B10D0 04 [008] - Internal System Fault
                    Fault Frequency: 8
                    Reset counter: 10
                    Mileage: 214464 km
                    Date: 2020.04.28
                    Time: 13:05:41
   Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0092
   Revision: 15012002    Serial number: 00000000954392
   Coding: 02002091163C9FE1CB008804A0003908009CD30882000121800008402000
   VCID: 313F10D3B12757D3EC5-8064
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 110209  H32 0040
   Serial number:         110220170422
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10062557
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 D    HW: 4H0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 16 02 2011  00000311
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0B2L06
   Subsystem 5 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA101933000000179814
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 8348C095000000000001
02893 - Valet Parking Lock Button (E536)
                    Reset counter: 1
                    Mileage: 214615 km
                    Date: 2020.04.28
                    Time: 19:20:00
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 D    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0180
   Revision: AA001001
   VCID: 211FE093E1C7E7537C5-8074
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55901103503100
   Coding: 300102
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 372B2ECB5FC389E3A21-8062
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H41 0041
   Revision: --------    Serial number: 003JS0011W42
   Coding: 303143303230303030344A55304C34483053
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Serial number: 5850000R1112801DNW
   Serial number: 3575HRB405H09RECA034
   Serial number: 3585HRB405H0C15IFGQN
   Serial number: 3515JRB405P0AMH0LGEX
   Serial number: 3525JRB405P0AMH0B04+
   Serial number: 3554VRB404V0BTBEA84/
   Serial number: 3564VRB404V0BTBEI1JE
   Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KB100003
   Coding: 000434
   VCID: 323D1FDFB4216CCB95F-8066
   Subsystem 1 - Part No SW: 4H0 951 528 H    HW: 4H0 951 528 H
   Component: E221 - MFL  H04 0009
   Serial number: 04 09 2010  33021996
   Part No SW: 4H0 920 920 C    HW: 4H0 920 920
   Component: TBenUSA------ H30 0309
   Revision: 26110011    Serial number: 658030211593005
   Coding: 0B6608011B00D705020000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU64.rod
   VCID: 2517F483F56F0B7300D-8070
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1110206000573
   Part No SW: 4H0 907 468 E    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000100973
   Coding: 00C1034A00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 33331ADB4BBB65C39E9-8066
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650552908
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0096
   Coding: 008000
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2C0101A796853A3BDF3-8078
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00001002323224
   Coding: C0183B0085053201010001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA3100D5EU0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6C81C1A75605FA3B9F3-8038
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0162
   Revision: --------    Serial number: 0000113119179
   Coding: 011F1F205E0062C202000006
   Shop #: WSC 02312 785 00200
   VCID: 3B2332FB636BAD83469-806E
   Revision: 00002001    Serial number: 0143176864
   Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000021323
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.028  H06 0006
   Serial number:     WOO11367361
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H11 0080
   Serial number: A2011000000000339709
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS009  H05 0004
   Serial number:     WOO1000BSO
   Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0070
   Revision: CJ007000    Serial number: 00000000020232
   VCID: 1B63D27BC3ABCD83A69-804E
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Component: TSG BF        H02 0162
   Revision: --------    Serial number: 0000113125256
   VCID: 3A2D37FF6C51948B5DF-806E
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000038343
   ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0011
   Serial number: 110210-0004-027
   Coding: 12116F33701AA400
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
   VCID: 303915D7BAAD5EDBE3B-8064
H02 0006
   Coding: 1C0000
H02 0006
   Coding: 1C0000
   Part No SW: 4H0 035 082 A    HW: 4H0 035 082
   Component: Radio U SIRIU H51 0068
   Revision: AB001007    Serial number: 155BX0B7500858
   Coding: 020007010000000001
   VCID: 1F1BE66BD7B3D1A34A1-804A
   Part No SW: 4H0 035 664 B    HW: 4H0 035 664
   Component: H-BN-NA       H48 0294
   Revision: --------    Serial number: 098B.0B7501558
   Coding: 020200000001F1EF45128B0E00000003F400010000000000
   VCID: 2615F38F88E9006B097-8072
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
   Component: DU8 D4 SV NB  H46 0021
   Serial number: AUZ8ZDB1100DVP+
   Subsystem 3 - Part No SW: 4H1 919 600 D    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0063
   Serial number: 00000000029007
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Component: TSG HL        H04 0162
   Revision: --------    Serial number: 0000113074909
   Coding: 010F1F20400062C202000006
   VCID: 392F28F369579F93545-806C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H04---    Serial number: 525 PA8J11D1C9
   Coding: 1020003
   VCID: 6597B483B96FCB73C0D-8030
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0036
   Revision: 10011001    Serial number: 039100495
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001025
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3B2332FB63EBAD83469-806E
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000024276
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393AA9BBBDBB5432E9-8036
   Component: TSG HR        H04 0162
   Revision: --------    Serial number: 0000113075007
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H07 0083
   Revision: 0L0D5012    Serial number: SN110118  0107
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2B0302BB938B3D03D69-807E
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00000003154701
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F3B16ABA7934123FA1-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00000003154402
   Coding: 364FF2
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F000000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 6FBBD6AB67130123BA1-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 70B9D5D77A2D1EDBA3B-8024
End----------(Elapsed Time: 02:44, VBatt start/end: 12.0V/12.0V)-----------
Gone But Not Forgotten
Could the high crankcase PCV pressures be from blow by and fuel contamination in sump from faulty HPP EVAP and possible leaking injectors?
Sure sounds like a safety recall campaign waiting to happen no & since passed useful life, did you report to NHTSA yet?
Did you know you are behind for firmware update level?
derekmyoung
C?ID=402768
What firmware are you referring to exactly? Are you talking about ECM software version?
I wasn’t aware that my misfires/PCV were NHTSA related. Seems like there are a lot of PCV issues in these cars in the Audiworld forum.....therefore a recall would have been initiated
Yes, Engine. I searched our TSB/TPI collection and although there were 12 documents all of them were for SWL 004 and lower. Oddly, there's a level 0006 but I can't locate the TPI associated with it. Jack may be able to add clarity.
HPFP failure is common so I agree with that suggestion. One of the high pressure fuel pumps could be leaking gas directly into the oil resulting in Rich on both banks. Although it would only mask the problem you could change the oil to see if the problem and reoccurring rich DTCs return within a few days or not but if one of those pumps is blown out it could contaminate new oil in a few hours.
I suppose the better option might be to get a dipstick (or something you can grab a sample with) and see if the existing oil smells like gas. If it does I wouldn't run the engine like that until the source has been identified and corrected followed by an oil change.
Does anyone doubt Dana is indeed correct?
Does anyone doubt me?:rolleyes:
Let me ask some more questions okay?
Did you know OP, it is strongly recommended you report your issue's to NHTSA & to possibly protect your ability to seek reimbursement for an obvious need for a Safety recall?
Hey did you additionally know that due to laziness by ORVR, that EVAP and fuel system related certified components as Zero type & for clear widespread failure of reclamation, indeed are a safety issue and a SMOG related useful life warranty when a carry over is used that was certified for 15 years or 150k, however, additionally since a safety issue by design documented mechanical and electronic AECD failure, this is an unlimited timeline for extension of such coverage?
Are you prepared to do your part and submit a complaint to NHTSA?
https://forums.ross-tech.com/showth...uot-JPPSG-quot&p=156577&viewfull=1#post156577
Yup question marks in place check!
derekmyoung
C?ID=402768
What part of the Autoscan depicts the actual SWL?? is it the "0005"??
Also, in order to get this updated...will dealer charge me for this? Or should a software update be a complimentary service when I have already paid for 3 diagnostic checks within the past year??
Im just asking becuase, i like to be armed with information before i go the dealer and claim something. I want to be able to show them my Autoscan depicting the old software version, and what is should be
Revision: N5H07---
derekmyoung
C?ID=402768
Thanks for the suggestion about dipstick. Simple nomenclature that I can understand. I know my way around cars.....just new to Audi technology and nomenclature.
Yes.
It's an 8 year old car. I wouldn't expect much free from a dealer unless there's some kind of special campaign or recall.
ARE NOT FIRMWARE UPDATES PART OF USEFUL LIFE WARRANTY & SHEAR ADMITTANCE A VEHICLE FAILS OR FAILED TO COMPORT AS CERTIFIED IF NOT MADE AVAILABLE FOR FREE OR BY CAMPAIGN IN ADR?
IS THE WARRANTY 10/120K OR 15/150K IS THERE AN ORVR, LET'S HAVE A LOOK AT THE SLIPPERINESS?
OH DEAR?
Section 17 Pg. 6 California ARB Information Engine Code: R.CH-No.: Revision Date:Part 1 Test Group: BADXV04.23UH CDR 12-27-2010
https://literature.audiusa.com/calibration_lookup.asp
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=23725&flag=1
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=23726&flag=1
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=24165&flag=1
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=23727&flag=1
ECM4H0560C 00060F744E53BADXV04.23UH
Revision: N5H07---
Revision: --H19---
Coding: 000002
ModelAudi A8L qu. 4.2
A8Q
Date of production01.03.2011
Model year2011
Sales type4H85AA
Engine CodeCDRA
Transmission CodeMXR
Emission standard7GBEmission standard ULEV 2
derekmyoung
C?ID=402768
Ok...I havent been able to troublshoot car further since first post, but I have some time on my hand now due to Covid.
THINGS THAT HAVE CHANGED:
  • The weather is a consistent 80+ degrees outside
  • Intermittent startups are becoming more frequent
  • More random misfires occuring
The most recent nonstart occured 6/1/, I drove car about two hours, drove fine....it sat at my destination for a couple hours......car would not start up on first try.....second try it started in a REALLY REALLY Rough idle, that sounded like it was cycling and limping. I happend to have my laptop and cable with me, so I did a scan while it was running. SEE SCAN BELOW.
I popped the hood to see if i can hear anthing obivios.....I heard a high pitched hissing sound coming from the area just left of Breather control valve.....but it wasnt from the valve or the hoses going directly to it......i couldnt pin point it. I took the Oil cap off, and the noise dissipated by 50% but not completely...and the engine ran about 50% better but still cycling. In all honesty, car just sounded like it was out of whack. So after I got my scan completed......I shut the car off.........I restarted the car....then all of a sudden.....car is running like normal.
Anything in my scan below indicates any other simple issues like vaccume leak or fouled plugs (brand new plugs)?? Andy IDE addresses I can look at measurements??
Im all about checking analog meausurements like cylinder compression test, spraying down hoses looking for leaks........Is there a way to test the HPP fuel pumps within VCDS???
Monday,01,June,2020,16:58:00:57557
VIN: WAURVAFD4BN019274   Mileage: 220159km-136800miles
   Revision: N5H07---
12 Faults Found:
16501 - Fuel Trim; Bank 2
                    Mileage: 216451 km
                    Date: 2020.05.12
                    Time: 01:04:06
                    Engine speed: 1296.00 /min
                    Normed load value: 33.7 %
                    Vehicle speed: 60 km/h
                    Coolant temperature: 106 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 13.970 V
                    Unlearning counter according OBD: 10
                    AFS dm: 57.0 kg/h
                    Median injection timing: 0.795 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
16516 - Fuel Trim; Bank 1
                    Mileage: 216451 km
                    Date: 2020.05.12
                    Time: 01:04:20
                    Engine speed: 1418.00 /min
                    Normed load value: 49.8 %
                    Vehicle speed: 66 km/h
                    Coolant temperature: 104 °C
                    AFS dm: 92.7 kg/h
                    Median injection timing: 1.355 ms
7676 - Oxygen (Lambda) Sensor B1 S1
          P2237 00 [096] - Pump Current Open Circuit
                    Mileage: 220147 km
                    Date: 2020.06.01
                    Time: 14:04:18
                    Engine speed: 658.00 /min
                    Normed load value: 22.0 %
                    Coolant temperature: 98 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 13.853 V
                    AFS dm: 17.1 kg/h
                    Median injection timing: 0.300 ms
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [101] - -
                    Mileage: 220159 km
                    Date: 2020.06.01
                    Time: 16:29:54
                    Normed load value: 34.9 %
                    Coolant temperature: 82 °C
                    Intake air temperature: 67 °C
                    Voltage terminal 30: 13.805 V
                    Unlearning counter according OBD: 80
                    AFS dm: 42.2 kg/h
                    Median injection timing: 1.130 ms
10595 - Cylinder 5
          P0305 00 [101] - Misfire Detected
                    Mileage: 220159 km
                    Date: 2020.06.01
                    Time: 16:31:21
                    Engine speed: 681.50 /min
                    Normed load value: 29.0 %
                    Coolant temperature: 86 °C
                    Intake air temperature: 66 °C
                    Voltage terminal 30: 13.711 V
                    AFS dm: 20.7 kg/h
                    Median injection timing: 1.406 ms
10598 - Cylinder 8
          P0308 00 [101] - Misfire Detected
                    Mileage: 220159 km
                    Date: 2020.06.01
                    Time: 16:31:05
                    Engine speed: 662.00 /min
                    Normed load value: 29.4 %
                    Voltage terminal 30: 13.735 V
                    AFS dm: 22.4 kg/h
                    Median injection timing: 2.257 ms
10596 - Cylinder 6
          P0306 00 [101] - Misfire Detected
                    Mileage: 220159 km
                    Date: 2020.06.01
                    Time: 16:31:05
                    Engine speed: 618.00 /min
                    Voltage terminal 30: 13.640 V
                    AFS dm: 21.9 kg/h
                    Median injection timing: 0.000 ms
10593 - Cylinder 3
          P0303 00 [096] - Misfire Detected
                    Mileage: 216093 km
                    Date: 2020.05.09
                    Time: 20:32:13
                    Engine speed: 1810.00 /min
                    Normed load value: 52.9 %
                    Vehicle speed: 17 km/h
                    Coolant temperature: 9 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 13.428 V
                    Unlearning counter according OBD: 7
                    AFS dm: 28.9 kg/h
                    Median injection timing: 1.117 ms
10597 - Cylinder 7
          P0307 00 [101] - Misfire Detected
                    Mileage: 220159 km
                    Date: 2020.06.01
                    Time: 16:29:54
                    AFS dm: 24.9 kg/h
                    Median injection timing: 2.669 ms
10205 - Cylinder Disabling
          P130A 00 [036] - -
                    Mileage: 220159 km
                    Date: 2020.06.01
                    Time: 16:30:31
                    Engine speed: 653.00 /min
                    Coolant temperature: 84 °C
                    Voltage terminal 30: 13.688 V
                    AFS dm: 26.2 kg/h
                    Median injection timing: 1.855 ms
                    Mileage: 220147 km
                    Date: 2020.06.01
                    Time: 13:54:42
                    Engine speed: 660.50 /min
                    Normed load value: 21.2 %
                    Intake air temperature: 53 °C
                    Unlearning counter according OBD: 35
                    AFS dm: 16.6 kg/h
                    Median injection timing: 0.307 ms
                    Mileage: 220147 km
                    Date: 2020.06.01
                    Time: 13:48:38
                    Engine speed: 660.00 /min
                    Normed load value: 20.4 %
                    Coolant temperature: 102 °C
                    Intake air temperature: 52 °C
                    AFS dm: 16.4 kg/h
                    Median injection timing: 0.308 ms
   Revision: --H19---
   Coding: 000002
   Coding: 4881222E88
0130 - Motor for  Left Side Window Defrost Flap
          B10D7 21 [008] - Signal Amplitude Too Low
                    Fault Frequency: 31
                    Mileage: 217865 km
                    Date: 2020.05.17
                    Time: 16:24:40
          B10D8 22 [009] - Signal Amplitude Too High
                    Fault Frequency: 58
                    Reset counter: 9
                    Mileage: 217374 km
                    Date: 2020.05.14
                    Time: 20:31:52
                    Fault Frequency: 37
                    Reset counter: 49
                    Mileage: 215868 km
                    Date: 2020.05.07
                    Time: 10:46:01
   Coding: 0045F7
   Coding: 025523
   Coding: 020300
   Revision: AA001001
   Coding: 300102
   Coding: 000434
   Analog_clock:
   Coding: 00C1034A00
   Coding: 008000
   Coding: 020200
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
                    Mileage: 218824 km
                    Date: 2020.05.26
                    Time: 12:31:10
H02 0006
   Coding: 1C0000
H02 0006
   Coding: 1C0000
   Coding: 1020003
02203 - Audio / Video Input 1
                    Fault Status: 00101011
                    Reset counter: 45
                    Mileage: 218341 km
                    Date: 2020.05.21
                    Time: 17:34:44
                        Reverse OFF
                    Count: 3
                    Reset counter: 43
                    Mileage: 219658 km
                    Date: 2020.05.27
                    Time: 21:21:41
                        Reverse OFF
                    Count: 3
   Coding: 0210044100
   ROD: EV_Ambie.rod
   Coding: 764FF2
   Coding: 364FF2
End----------(Elapsed Time: 02:44, VBatt start/end: 12.3V/12.3V)-----------
I'm not sure how a vacuum leak would cause "too rich". Seems that should push things toward lean.
If this was a single-bank engine, I'd say: Chase the Lambda sensor Pump Current fault first, but that's only on one bank, while both banks are showing rich, and besides, that fault is flagged "Intermittent - Not Confirmed".
Anyway, nothing strikes me as obvious here. If it were mine, I guess I'd try to pinpoint the hissing sound. Automotive stethoscopes are cheap:
https://www.amazon.com/dp/B004KEHGZY/
HMC
C?ID=28246
Hi Uwe,
There are circumstances (not necessarily this one) where a vacuum leak can cause a rich mixture. If a leak is close to a MAP sensor it can fool the system into thinking the engine is under more load than it is, and so providing more fuel than it should. More common with a remote MAP using a hose to the induction, never used by VAG as far as I know.
Regards HMC
Additionally a vacuum leak can cause the result of such a rich mixture the OXS becomes contaminated and always reports an anomaly or the controller adapts to think that is where it belongs in a learned loop and requires default.
Indeed a pump current circuit DTC and is this not the reason for alleged firmware update and possibly a part number changed?
The result of no OXS report & as a vicarious vacuum leak purported, causes controller to perform the inverse and dump fuel until it gets a report of voltage.
The vacuum leak may indeed be isolated to the one bank too.
A stuck open injector could also create a PSI drop across rail on bank and net the same result!
