Attention: The Engine is running
tykru
C?ID=51476
Does anyone know how to disable the beeping when the driver's door is open while the engine is running? It beeps 6 times and displays the following message in the MID: "Attention: The Engine is running."
tykru
C?ID=51476
sorry, it's a 2019 GTI. No need for autoscan as there's no errors.
Because we're all supposed to know exactly how you 2019 GTI is equipped and what the configuration options are in that equipment? ;)
tykru
C?ID=51476
i have an older vag com cable for my 2009 gti and have not upgraded for my 2019 gti yet because if it can't do what i want it to do i will not spend the money. i currently have an obd eleven pro but not sure if i can run a scan with that.
Your old HEX+CAN interface will complain that this car is an "Unsupported Vehicle" but you can run a scan with it it.
tykru
C?ID=51476
ah good to know. see the attached scan. looks like i did have a couple faults, probably because i was making changes using OBD Eleven to try and disable the chime. Thanks, Uwe.
Skip to content
Using Gmail with screen readers
1 of 33
scan
Inbox
x
Tyler Krumm <tykrumm@gmail.com>
10:52 PM (2 minutes ago)
to me
Attachments area
Tuesday,05,May,2020,21:57:25:36667
VCDS Version: 19.6.2.2
Chassis Type  AU (3Q0)
Scan: 01 03 05 08 09 13 14 15 17 19 2B 32 3C 42 44 47 4B 52 5F 75
          A9 BB BC
VIN: 3VW5T7AU4KM037282
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
BB-Door Rear Drv -- Status: Not registered 0001
BC-Door Rear Pass -- Status: Not registered 0001
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0005
   Revision: --H13---
   Coding: 091900122424002F1000
   Shop #: WSC 00066 790 00424
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001006
   ROD: N/A
   VCID: 3C7CFE7BB7E49CAFB9-8068
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM20TFS0205G0906259Q" ()
Readiness: 0000 0100
   Part No SW: 5Q0 614 517 DR    HW: 5Q0 614 517 BM
   Component: ESC           H45 0108
   Revision: 00000000    Serial number: 52379000000912
   Coding: 01FA6BA1502309734079020860C56880D60A900240061636104350D1D0894B0B0000000012121212B835351919323200
   Shop #: WSC 00066 790 00080
   ROD: N/A
   VCID: 040C469B8F94246F81-8050
No ASAM data for: "EV_Brake1UDSContiMK100IPB" ()
Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0523862173
   Coding: 132C0C0623
   ROD: N/A
   VCID: 458A9B9FC42EDD67D6-8010
No ASAM data for: "EV_KessyHellaMQBAB" ()
Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 00020004200110000000000000010004
   ROD: N/A
   VCID: 4C9CAEBBE7442C2F09-8018
No ASAM data for: "EV_ACManueBHBVW37X" ()
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86401101906M6
   Shop #: WSC 00066 790 00245
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: N/A
   VCID: 7BFE3D67F26A5B97F0-802E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190701  043 0551
   Serial number: 97022066190718142026
   Subsystem 2 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  051 0206
   Serial number: S5Y19M07D18H14M23S58
   Coding: 0008DD
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03690802562812180940
   Coding: 181803
   Subsystem 4 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300240920190C201920
No ASAM data for: "EV_BodyContrModul1UDSBosc" ()
Address 13: Auto Dist. Reg (J428)       Labels:. 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 2D00008101FFC728949C810500401600000000000000000004
   ROD: N/A
   VCID: 448C869BCF14E46FC1-8010
No ASAM data for: "EV_ACCBOSCHVW416" ()
   Serial number: 24071941350429
   ROD: N/A
   VCID: 3874E26B83DCB08F5D-806C
No ASAM data for: "EV_DRCONTITEMIC" ()
Address 15: Airbags (J234)       Labels:. 5Q0-959-655.clb
   Serial number: 003GCR0CJ9Z4
   ROD: N/A
   VCID: 47969197FE22CF7724-8012
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000C1VW70
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 607 19
   Serial number: 357000000005E1407E3K
   Subsystem 3 - Part No SW: -----------    HW: 480 002 607 19
   Serial number: 35800000000793D43C3R
   Subsystem 4 - Part No SW: -----------    HW: 480 402 007 19
   Component: SideSensor_Dr  004 6149
   Serial number: 3510001102C94682D4B$
   Subsystem 5 - Part No SW: -----------    HW: 480 400 108 19
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001062C061F4842S
   Subsystem 6 - Part No SW: -----------    HW: 480 400 309 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001C2F27DCC4480J
   Subsystem 7 - Part No SW: -----------    HW: 480 400 309 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001C2F27DCC471FV
No ASAM data for: "EV_AirbaVW20SMEVW37X" ()
Address 17: Instruments (J285)       Labels:. 5G0-920-XXX-17.clb
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2700
   Coding: 03AD1112B988CF0502897F090800000080000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   ROD: N/A
   VCID: 2F66D937769277370C-807A
No ASAM data for: "EV_DashBoardVDDMQBAB" ()
Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Serial number: 01101900842147
   Coding: 0101000830085900FB00002B880F00000001070000000000000000000000
   ROD: N/A
   VCID: 6ED80433B1183E3F47-803A
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190000938420079184
   Coding: 28FFFF
No ASAM data for: "EV_GatewNF" ()
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000208938005
   ROD: N/A
   VCID: 3162DF4F60A661C71A-8064
No ASAM data for: "EV_ELVMarqMQBA0" ()
Address 32: Differential Locks (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00028.03.19
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: N/A
   VCID: 52A0B0C305607ADF43-8006
No ASAM data for: "EV_LockElectHA1VW37X" ()
Address 3C: Lane Change (J1086)       Labels:. 5Q0-907-686.clb
   Serial number: 0521927280
   Coding: 01011103
   ROD: N/A
   VCID: 3D7AF37FACFE95A78E-8068
No ASAM data for: "EV_HREntryHella" ()
Address 42: Door Elect, Driver (J386)       Labels:. 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038924602665
   Coding: 003E13200000040000000000
   Shop #: WSC 01383 790 50316
   ROD: N/A
   VCID: 4FA6B9B7165217376C-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000004247567
   Coding: 011000
No ASAM data for: "EV_DCU2DriveSideMAXHCONT" ()
Address 44: Steering Assist (J500)       Labels:. 5Q0-909-144.clb
   Part No SW: 5QN 909 144 B    HW: 5QN 909 144 A
   Coding: 810A0000
   ROD: N/A
   VCID: 51A2BFCF006601C77A-8004
No ASAM data for: "EV_SteerAssisMQB" ()
Address 47: Sound System (J525)       Labels:. 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD05QFD+
   Coding: 2200000000AAAAAA000000000000
   ROD: N/A
   VCID: 2E58C43371987E3F07-807A
No ASAM data for: "EV_AMPMst12C1Gen2ALPI" ()
Address 4B: Multifunc. Module
Interface not compatible.
Address 52: Door Elect, Pass. (J387)       Labels:. 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038926001784
   Coding: 003E13201C00040000000000
   ROD: N/A
   VCID: 4E98A4B311581E3F67-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000004246517
   Coding: 091000
No ASAM data for: "EV_DCU2PasseSideMAXHCONT" ()
Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     724 0890
   Coding: 027310000000000041220002001808009F0503F40120050002
   ROD: N/A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  254 8130
   Serial number: VWZ6ZMW2785424
No ASAM data for: "EV_MUStd4CDELP" ()
Address 75: Telematics (J949)       Labels:. 5QE-035-285.clb
   Component: OCULowMQBUS   009 0570
   ROD: N/A
   VCID: 438E8587CA1AE357F8-8016
No ASAM data for: "EV_OCULowMQB" ()
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 190702200341
   ROD: N/A
   VCID: 3260D04365A05ADF63-8066
No ASAM data for: "EV_SoundActuaGen2AU64X" ()
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End-------------------------(Elapsed Time: 05:05)--------------------------
Log-2019_GTI.txt
Displaying Log-2019_GTI.txt.
downtime
Finland
C?ID=280813
Go to instruments -> Adaptation and try changing adaptation channel : IDE06588-Ignition active message: actuator to no display.
tykru
C?ID=51476
ok i'll give it a shot but i believe i already made this changeon my OBD Eleven and it only works for the door open chime when the ignition is on but the engine is not running.
quailallstar
Ormond Beach, FL & Washington DC
C?ID=53119
This does not work on a 2019+ MK7.5 no matter how many times you attempt to code. It will accept the code but won't make the changes. Many others have tried and failed (including me).
What could have changed from 2018 to 2019 not allowing this to work any longer? Calling all Ross-Tech gurus :confused:
downtime
Finland
C?ID=280813
Different security code?
Westbury, UK
Software changes for WLTP and to avoid accusations of VAG allowing software cheats?
Some things, such as start/stop defeat, no longer work in 2019 models, maybe this is another of those?
quailallstar
C?ID=53119
Who knows. But I've been able to defeat my start stop via VCDS ;)
"software cheats"? I and I suspect all of our colleagues here resemble (or, "resent" if your like) this accusation!!:)
Westbury, UK
I have to count myself amongst those who "tweak" the settings of their cars, I was using the vernacular term that the media and politicians like to use but it's not one I would agree with either ;)
tykru
C?ID=51476
I know it's been a while, but have you ever been able to get rid of the engine running door chime?
JMR
Romania
C?ID=432218
:banghead:
it's been 2 years and 3 weeks..
vag_scan
C?ID=508646
I'm holding out it can be done via 17-Instruments for the A5 B9, but I haven't yet been able to find the security code for the MLB platform.
