Sunday,10,May,2020,13:48:18:50832
VCDS Version: 20.4.0.1 (x64)
VIN: WUAZZZ8K6DA902792 License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 22 30 42 44 46 47 52
53 56 5C 5F 62 6C 72
VIN: WUAZZZ8K6DA902792 Mileage: 123980km-77037miles
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0005
Revision: NAH04---
Coding: 1225003225C6000A2000
ASAM Dataset: EV_ECM42FSI0118T2907560 001008
ROD: EV_ECM42FSI0118T2907560.rod
VCID: 79F25384F81FC24E45-802C
Readiness: 1110 1101
Part No SW: 8K5 927 156 HW: 0B5 927 156 J
Component: 0B5 42 FSIRdW H02 0010
Revision: --H02---
Shop #: WSC 06325 000 00000
ROD: EV_TCMDL501021.rod
VCID: 76E858B8C901AD3628-8022
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Coding: 346D6A
Shop #: WSC 06325 123 12345
VCID: 458AEF74CC6776AE71-8010
Part No SW: 8K0 907 064 GE HW: 8K0 907 064 FE
Component: BCM2 2.0 H12 0633
Coding: 01924000000000000000
VCID: 79F25384F01FC24E45-802C
Subsystem 1 - Part No SW: 8K0 959 754 CH HW: 8K0 959 754 CH
Serial number: 0513000024195010
Serial number: 2313000048466010
Part No SW: 8K2 820 043 T HW: 8K2 820 043 T
Revision: D1000000 Serial number: 01220420132244
Coding: 4804000000
VCID: 3A708C88B59909560C-806E
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000594190001
Coding: 06008011403C9FF23F814083000019094F9DC70A23090201000008004400010200020034000000
VCID: 7AF04C88F519C9564C-802E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 160413 H06 0080
Serial number: SWF13040160239
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 21210963
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AQ HW: 8K0 941 531 AQ
Component: E1 - LDS H03 0031
Serial number: 00000000000304130720
Subsystem 4 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Serial number: 8D3882A6000000000001
Reset counter: 213
Mileage: 123984 km
Date: 2020.05.10
Time: 13:43:40
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 C HW: 8K0 907 561 C
Component: ACC3 H11 0100
Coding: 003352
VCID: 3260A4A86DE9F116C4-8066
Address 14: Susp. Elect. Labels: None
Part No SW: 8T0 907 376 HW: 8T0 907 376 A
Component: J250 DRC FahrwerH01 0020
Revision: 00000000 Serial number: 00875000467600
Coding: 0000000
Shop #: WSC 06435 000 00000
VCID: 7CFC4A903F2DF7665E-8028
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD99PBK$
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 39620 001 1048576
VCID: 4894E640F3756BC68A-801C
Serial number: 6334MSME792079007
Serial number: 6344MSME78247267H
Serial number: 6352QSME3D2F2D7E3
Serial number: 6362QSME402F2D7CX
Serial number: 63732SME2D30015AX
Serial number: 63832SME29303944Y
9444885 - Driver's seat position sensor
B101E 15 [137] - Open or Short to Plus
Mileage: 123984 km
Date: 2020.05.10
Time: 13:43:41
9445141 - Passenger's seat position sensor
B101F 15 [137] - Open or Short to Plus
Mileage: 123984 km
Date: 2020.05.10
Time: 13:43:41
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372MDF000ZK
Coding: 0000FF
VCID: 448CF270C75D4FA666-8010
Part No SW: 8K0 920 982 J HW: 8K0 920 982 J
Component: KOMBIINSTR. H35 0556
Revision: 00300000 Serial number: UW471W94E
Coding: 33EF1100FF012600010400
VCID: 3B7E898CBAA3305E17-806E
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z134130065
Coding: 80E3031600
VCID: 4C9CDA50EF0D87E6AE-8018
Serial number: 4130760303
Part No SW: 8K0 907 144 L HW: 8K0 907 144 L
Component: DYNAMIKLENK. H06 0720
Revision: 50001005 Serial number: --------------
Coding: 030000
VCID: 387496808B951B46FA-806C
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 000704130001397
VCID: 2F66ADDC76DBDCFEAB-807A
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0020
Revision: S0H04000 Serial number: 00000000080260
VCID: 2D5AB7D474D7AEEE99-8078
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C02205021410001
VCID: 56A8383821C1CD3608-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0010385889
Coding: 010001010001
Shop #: WSC 06324 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 346CA2B09FFDFF26D6-8060
Revision: 00002001 Serial number: 0305679616
Coding: 013F062220B908808330023280000000
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813013557902
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
Coding: 011C02205C21410001
VCID: 55AA3F343CC7C62E01-8000
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000259907
ROD: EV_ParkiBrake_AU48.rod
VCID: 3874968083951B46FA-806C
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109D%0D7626765
Coding: 010103010000000001
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 600213416000ED
Coding: 0032201
VCID: 377695BC468B143EF3-8062
Part No SW: 8R2 035 666 L HW: 8R2 035 666 C
Component: H-BN-EU H45 1036
Revision: -------- Serial number: 206DW0D7525435
Coding: 120101010306F9FF2F80CF5E00000403E40000020000000000
VCID: 4280F468DD49419654-8016
Subsystem 1 - Part No: 8R0 060 884 FC
Component: EUR 2018 2601
Component: DU7 High H42 0104
Serial number: A130DZ0D2707877
Subsystem 3 - Part No SW: 8T0 919 611 M HW: 8T0 919 611 H
Serial number: 00000001677305
Component: CD-Database 4949
03623 - Invalid Security/Release Code
Reset counter: 213
Mileage: 123984 km
Date: 2020.05.10
Time: 13:43:42
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C02204021210001
VCID: 59B2330450DFE24E25-800C
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J3190OQ
Coding: 1021007
Shop #: WSC 06335 000 00000
VCID: 387496804B951B46FA-806C
Component: TSG HR H07 0304
End-------------------------(Elapsed Time: 04:17)--------------------------
