2013 RS4 Wingback Seat Retrofit
RS11SMS
C?ID=55636
I have retrofitted OEM Wingback seats which were a factory option but not installed in my car originally. Have successfully resolved the issue with the seat airbags however I still have codes and airbag light due to the new seats not having position sensors. The original seats were electric movement, new wingbacks are not (just electric for bolsters)
As the seats were a factory option I assume there must be coding to confirm this which should disable the position sensors, would anyone have access to this information please
South Molton, UK
A full unedited VCDS Auto-Scan would be a great help...
RS11SMS
C?ID=55636
Apologies here's my scan...
Sunday,10,May,2020,13:48:18:50832
VCDS Version: 20.4.0.1 (x64)
VIN: WUAZZZ8K6DA902792   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 22 30 42 44 46 47 52
          53 56 5C 5F 62 6C 72
VIN: WUAZZZ8K6DA902792   Mileage: 123980km-77037miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560     HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H04 0005
   Revision: NAH04---
   Coding: 1225003225C6000A2000
   ASAM Dataset: EV_ECM42FSI0118T2907560 001008
   ROD: EV_ECM42FSI0118T2907560.rod
   VCID: 79F25384F81FC24E45-802C
Readiness: 1110 1101
   Part No SW: 8K5 927 156     HW: 0B5 927 156 J
   Component: 0B5 42 FSIRdW H02 0010
   Revision: --H02---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 76E858B8C901AD3628-8022
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Component: ESP8 quattro  H09 0100
   Coding: 346D6A
   Shop #: WSC 06325 123 12345
   VCID: 458AEF74CC6776AE71-8010
   Part No SW: 8K0 907 064 GE    HW: 8K0 907 064 FE
   Component: BCM2 2.0      H12 0633
   Coding: 01924000000000000000
   VCID: 79F25384F01FC24E45-802C
   Subsystem 1 - Part No SW: 8K0 959 754 CH    HW: 8K0 959 754 CH
   Serial number: 0513000024195010
   Serial number: 2313000048466010
   Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
   Revision: D1000000    Serial number: 01220420132244
   Coding: 4804000000
   VCID: 3A708C88B59909560C-806E
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000594190001
   Coding: 06008011403C9FF23F814083000019094F9DC70A23090201000008004400010200020034000000
   VCID: 7AF04C88F519C9564C-802E
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 160413  H06 0080
   Serial number: SWF13040160239
   Coding: 00FD11
   Serial number: 21210963
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000304130720
   Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 8D3882A6000000000001
                    Reset counter: 213
                    Mileage: 123984 km
                    Date: 2020.05.10
                    Time: 13:43:40
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
   Component: ACC3          H11 0100
   Coding: 003352
   VCID: 3260A4A86DE9F116C4-8066
Address 14: Susp. Elect.        Labels: None
   Part No SW: 8T0 907 376     HW: 8T0 907 376 A
   Component: J250 DRC FahrwerH01 0020
   Revision: 00000000    Serial number: 00875000467600
   Coding: 0000000
   Shop #: WSC 06435 000 00000
   VCID: 7CFC4A903F2DF7665E-8028
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD99PBK$
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 39620 001 1048576
   VCID: 4894E640F3756BC68A-801C
   Serial number: 6334MSME792079007
   Serial number: 6344MSME78247267H
   Serial number: 6352QSME3D2F2D7E3
   Serial number: 6362QSME402F2D7CX
   Serial number: 63732SME2D30015AX
   Serial number: 63832SME29303944Y
9444885 - Driver's seat position sensor
          B101E 15 [137] - Open or Short to Plus
                    Mileage: 123984 km
                    Date: 2020.05.10
                    Time: 13:43:41
9445141 - Passenger's seat position sensor
          B101F 15 [137] - Open or Short to Plus
                    Mileage: 123984 km
                    Date: 2020.05.10
                    Time: 13:43:41
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372MDF000ZK
   Coding: 0000FF
   VCID: 448CF270C75D4FA666-8010
   Part No SW: 8K0 920 982 J    HW: 8K0 920 982 J
   Component: KOMBIINSTR.   H35 0556
   Revision: 00300000    Serial number: UW471W94E
   Coding: 33EF1100FF012600010400
   VCID: 3B7E898CBAA3305E17-806E
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z134130065
   Coding: 80E3031600
   VCID: 4C9CDA50EF0D87E6AE-8018
   Serial number: 4130760303
   Part No SW: 8K0 907 144 L    HW: 8K0 907 144 L
   Component: DYNAMIKLENK.  H06 0720
   Revision: 50001005    Serial number: --------------
   Coding: 030000
   VCID: 387496808B951B46FA-806C
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 000704130001397
   VCID: 2F66ADDC76DBDCFEAB-807A
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000080260
   Coding: 01010101000000000001000102
   VCID: 2D5AB7D474D7AEEE99-8078
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C02205021410001
   VCID: 56A8383821C1CD3608-8002
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0010385889
   Coding: 010001010001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 346CA2B09FFDFF26D6-8060
   Revision: 00002001    Serial number: 0305679616
   Coding: 013F062220B908808330023280000000
   Revision: 00005001    Serial number: 94813013557902
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   Coding: 011C02205C21410001
   VCID: 55AA3F343CC7C62E01-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000259907
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3874968083951B46FA-806C
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109D%0D7626765
   Coding: 010103010000000001
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600213416000ED
   Coding: 0032201
   VCID: 377695BC468B143EF3-8062
   Part No SW: 8R2 035 666 L    HW: 8R2 035 666 C
   Component: H-BN-EU       H45 1036
   Revision: --------    Serial number: 206DW0D7525435
   Coding: 120101010306F9FF2F80CF5E00000403E40000020000000000
   VCID: 4280F468DD49419654-8016
   Subsystem 1 - Part No: 8R0 060 884 FC
   Component: EUR 2018  2601
   Component: DU7 High  H42 0104
   Serial number: A130DZ0D2707877
   Subsystem 3 - Part No SW: 8T0 919 611 M    HW: 8T0 919 611 H
   Serial number: 00000001677305
   Component: CD-Database  4949
03623 - Invalid Security/Release Code
                    Reset counter: 213
                    Mileage: 123984 km
                    Date: 2020.05.10
                    Time: 13:43:42
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010C02204021210001
   VCID: 59B2330450DFE24E25-800C
   Revision: --H07---    Serial number: 525PA8-J3190OQ
   Coding: 1021007
   Shop #: WSC 06335 000 00000
   VCID: 387496804B951B46FA-806C
   Component: TSG HR        H07 0304
End-------------------------(Elapsed Time: 04:17)--------------------------
RS11SMS
C?ID=55636
I've not seen any real coding info for those airbag modules. The Coding in them seems to be an ASCII string expressed as a hexadecimal value. My guess is that the equipment is determined using a separate parameter table rather than coding.
If it were mine, I think I would look for some electrical means of making the module believe the position sensors are present.
morski
Cheshire UK
C?ID=90186
Take the sensors off the old seats and wire them back into the loom so the car knows they are there. Whether or not they will be looking for comparison values against its stored values is unknown
RS11SMS
C?ID=55636
Thanks, wish I had the old seats to do this! I did a swap :(
morski
Cheshire UK
C?ID=90186
You can buy the loom with the sensors on it but they are £50 per seat. but it needs to connect into the sensor, seat occ mat, belt buckle etc so you must have that partial loom already there but missing the section for the position sensor part
RS11SMS
C?ID=55636
Thanks, will look into this further. I have identified one pin on the black plug where there is no wire but a pin in the male side in the car. Wondering whether there is a way to utilise this and resolve as it looks to be the only pin without anything connected to it
South Molton, UK
Rather than guess what the function of that pin is, would it not be a good idea to buy a 1 hour subscription to the Audi erWin website and download all the WD for your RS4 as pdf files?
Then not only you would know for sure what the function is of that pin, but you would have the information for future problem solving?
morski
Cheshire UK
C?ID=90186
I doubt you will be able to pin it out or something as the sensor looks like a hall sensor or similar defo not a microswitch
RS11SMS
C?ID=55636
I'll take a look, never come across that site before, sounds interesting thank you
RS11SMS
C?ID=55636
I've downloaded all the WD's I could find that were relative to the seats but can't find anything that references the 'Seat Position Sensor' , any ideas where I should be looking?
