SEAT LEON 5F ABS CODING LOST/ CODING PLEASE (MK100ESP)
Shuhel
Birmingham, UK
C?ID=368132
hello all, this vehicle came to me today with the abs wiped from another garage, can anyone suggest abs coding please, thanks
Monday,04,May,2020,17:52:45:58999
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: VSSZZZ5FZER022024   License Plate:
Mileage: 152643km-94847mi   Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZER022024   Mileage: 152643km-94847miles
Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 F    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H08 5760
   Revision: WAH08---
   Coding: 01190032232401080000
   Shop #: WSC 00049 770 00124
   ASAM Dataset: EV_ECM14TFS01104E906016F 002008
   ROD: EV_ECM14TFS01104E906016F.rod
   VCID: 2517F00FA56F615F9A3-8070
17158 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:56:40
                    Engine speed: 0.00 /min
                    Coolant temperature: 91 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 12.180 V
                    Mass flow through throttle valve: 0.0 kg/h
                    Median injection timing: 0.000 ms
                    Engine operating condition: Idling
12888 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
          [Invalid Data Received FromAnti-Lock Brake System Control Module]
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:41
                    Vehicle speed: 255 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 40 °C
                    Unlearning counter according OBD: 37
                    selected gear-Bits 0-7: 0
          U0428 00 [047] - -
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:56:40
4278 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:41
Readiness: 0010 0001
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 616330000000CA
   Shop #: WSC 00049 770 00101
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_SE37.rod
   VCID: 4BC366B7634B772F6C7-801E
14 Faults Found:
0039 - Front Left Wheel Speed Sensor
          C101A 4A [008] - Incorrect component(s) installed
                    Reset counter: 122
                    Date: 2020.05.02
                    Time: 12:57:40
0055 - Front Right Wheel Speed Sensor
          C101B 4A [008] - Incorrect component(s) installed
                    Reset counter: 122
                    Date: 2020.05.02
                    Time: 12:57:40
0071 - Rear Left Wheel Speed Sensor
          C101C 4A [008] - Incorrect component(s) installed
                    Reset counter: 122
                    Date: 2020.05.02
                    Time: 12:57:40
0087 - Rear Right Wheel Speed Sensor
          C101D 4A [008] - Incorrect component(s) installed
                    Reset counter: 122
                    Date: 2020.05.02
                    Time: 12:57:40
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 82
                    Date: 2020.05.02
                    Time: 12:57:40
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 82
                    Date: 2020.05.02
                    Time: 12:57:40
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 82
                    Date: 2020.05.02
                    Time: 12:57:40
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 82
                    Date: 2020.05.02
                    Time: 12:57:40
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 82
                    Date: 2020.05.02
                    Time: 12:57:40
0398 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Vehicle equipped with vacuum sensor but no vacuum sensor coded]
                    Fault Frequency: 16
                    Reset counter: 85
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:42
8278 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [FCAN: Mismatch between bytecoding and Lenkerposition signal]
                    Reset counter: 82
                    Date: 2020.05.02
                    Time: 12:57:40
8290 - Coding Not Possible
          U10BC 00 [137] - -
          [FCAN: Unplausible VIN number]
                    Reset counter: 82
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:45
8306 - Databus
          U1122 00 [137] - Implausible Message
                    Reset counter: 82
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:45
8308 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Fault Frequency: 8
                    Reset counter: 85
                    Date: 2020.05.02
                    Time: 12:57:40
   Part No SW: 5F0 907 044 D    HW: 5F0 907 044 D
   Component: Climatronic   H03 0705
   Revision: 00001K07
   Coding: 00100004200100011005004000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 270BFA07DF63734FA8F-8072
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011318501975
   Coding: 0B000A42424102FB0BA44000B1040328102A000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77ABEA474F4323CFF8F-8022
   Subsystem 1 - Part No SW: 5F2 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130610  041 0574
   Serial number:         130613105914
   Coding: 0BC5FD
   Component: RLFS  024 0042
   Serial number: Y13M07D06H06M58S55S1
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY131470M5D
   Serial number: 00000000000057250153
0522 - Footwell Illumination
          B11FF 15 [008] - Open or Short to Plus
                    Fault Frequency: 9
                    Reset counter: 124
                    Mileage: 152595 km
                    Date: 2020.05.02
                    Time: 12:30:29
0531 - Footwell Illumination
          B11FF 01 [009] - Electrical Failure
                    Fault Frequency: 8
                    Reset counter: 84
                    Mileage: 152584 km
                    Date: 2020.05.01
                    Time: 17:23:34
11274 - Bulb for Center Brake Light
          B12C6 15 [009] - Open or Short to Plus
                    Reset counter: 81
                    Mileage: 152584 km
                    Date: 2020.05.01
                    Time: 18:30:03
934149 - Rain/Light Recognition Sensor
          B1366 76 [008] - Wrong mounting position
                    Reset counter: 124
                    Mileage: 152635 km
                    Date: 2020.05.04
                    Time: 15:51:35
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231316300242
   Coding: 0031051001
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   VCID: 3A2D33733CD1FEA7C71-806E
13637421 - Databus
          [Bremsensteuergerät - ESP_21.ESP_v_Signal - Fehlerspeicher auslesen]
                    Reset counter: 122
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:40
13637426 - Databus
                    Reset counter: 81
                    Mileage: 152584 km
                    Date: 2020.05.01
                    Time: 17:23:11
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P4PD6LLTI
   Coding: 98CCC000000000005C0000CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B026767731B8FB0F-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 306 13
   Serial number: 3576U000000EC358EC0X
   Subsystem 2 - Part No SW: -----------    HW: 454 002 606 13
   Serial number: 3586U000000959892D0L
   Subsystem 3 - Part No SW: -----------    HW: 454 800 706 13
   Serial number: 3516R30137C01000000Q
   Subsystem 4 - Part No SW: -----------    HW: 454 800 706 13
   Serial number: 3526R31077C01000000V
   Subsystem 5 - Part No SW: -----------    HW: 454 800 604 13
   Serial number: 3556V59A97E00000000I
1052933 - Databus
          [NWD: 0x0FD ESP_21 error value ESP_v_Signal]
                    Reset counter: 122
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:40
          B13BC F2 [137] - No function
                    Mileage: 152584 km
                    Date: 2020.05.01
                    Time: 17:23:11
   Part No SW: 8V0 953 521 JD    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 10071604400745
   Coding: A008
   Shop #: WSC 06385 790 00016
   VCID: 0557908F05AF415FFA3-8050
   Part No SW: 5F0 920 971 G    HW: 5F0 920 971 G
   Component: KOMBI         303 2210
   Coding: 27AD02002980260001087A00000000
   ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
   VCID: 2E050F23F09922076B9-807A
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 81
                    Mileage: 152584 km
                    Date: 2020.05.01
                    Time: 17:23:11
13637376 - Databus
          [Steuergerät für Bremse: bitte Fehlerspeicher auslesen]
                    Reset counter: 122
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:40
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000780874
   Coding: 030100F42B086400EF0006C8080F00010001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 3B23367733EBC7AFDC7-806E
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H03 0120
   Serial number: 000000000A0101030613
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051692656
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000067602078
   Coding: 00100220D001020000001000
   VCID: 025D8B9314817667DF1-8056
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000296293
   Coding: 2D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 80
   Shop #: WSC 12345 000 00117
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D27386F2DFFC99FE23-8068
15873 - Steering angle sensor
                    Reset counter: 84
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 12.50 V
                    Temperature: 22.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 4B
                    uAdSensI_U5VFiltered_xdu16: 5.06842 V
                    uioUdNotFilt_xdu16: 12.47 V
                    uAdSensI_SwitchedKl30_xdu16: 12.46 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 01
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 125
                    Mileage: 152635 km
                    Date: 2020.05.04
                    Time: 15:51:29
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 12.00 V
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.23 V
                    uAdSensI_SwitchedKl30_xdu16: 12.24 V
20740 - Databus
          [ESP_21 Botschaft - SNA-Check]
                    Reset counter: 122
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:41
                    Motor status: 00
                    Temperature: 40.0 °C
                    KFC: 51
                    KFA: 00 04
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 12.05 V
                    uAdSensI_SwitchedKl30_xdu16: 12.04 V
20228 - Databus
          [ESP_19 Botschaft - SNA-Check]
                    Reset counter: 122
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:41
                    Motor status: 00
                    KFC: 4F
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 12.17 V
                    uAdSensI_SwitchedKl30_xdu16: 12.16 V
19716 - Databus
          [ESP_10 Botschaft - SNA-Check]
                    Reset counter: 122
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:41
                    Motor status: 00
                    KFC: 4D
                    KFA: 00 04
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000064351871
   Coding: 00100220D401020000001000
   VCID: 015F849F11876D7FC6B-8054
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000300785
   Coding: 350000
   Component: LWR-ECU       005 0070
   Coding: 048E000009000000
   VCID: 75B7E04F554F51DFEA3-8020
13705984 - Databus
          [ESP_19: Fehlerwert im Signal ESP_VL_Radgeschw]
                    Reset counter: 122
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:40
13705985 - Databus
          [ESP_19: Fehlerwert im Signal ESP_HL_Radgeschw]
                    Reset counter: 122
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:40
13705986 - Databus
          [ESP_19: Fehlerwert im Signal ESP_VR_Radgeschw]
                    Reset counter: 122
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:40
13705987 - Databus
          [ESP_19: Fehlerwert im Signal ESP_HR_Radgeschw]
                    Reset counter: 122
                    Mileage: 152606 km
                    Date: 2020.05.02
                    Time: 12:57:40
13705992 - Databus
          [LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
                    Fault Frequency: 25
                    Reset counter: 85
                    Mileage: 152584 km
                    Date: 2020.05.01
                    Time: 17:23:11
   Part No SW: 5F0 035 858 A    HW: 5F0 035 858 A
   Component: MU-S-ND-ER    040 0421
   Serial number: E5F00207130463
   Coding: 04730001D70A000021111101000800002F0101060100010046
   ASAM Dataset: EV_MUStd6C1PASE 002030
   ROD: EV_MUStd6C1PASE.rod
   VCID: 290FFC3FC977453FBEB-807C
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H45 0020
   Serial number: SEZ8Z9N5600RP2
   Subsystem 2 - Part No SW: 5F0 919 866 E    HW: -----------
   Component:  ECE 2013/14  --- 0034
0512 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 1: Unterbrechung]
                    Reset counter: 81
                    Mileage: 152595 km
                    Date: 2020.05.02
                    Time: 12:30:29
                    Voltage terminal 30: 12.3 V
End----------(Elapsed Time: 01:20, VBatt start/end: 12.5V/12.5V)-----------
Stopro92
Poland
C?ID=364459
Try 20EE62922422096E0077060241C7240446249000608224F200610070C002
