B8 A4 Tpms problem
VinceI
C?ID=284950
I have an 09 A4 that the tpms light has been on since I bought it. I tested the sensors with a scan tool and only one was reading so I replaced all with autel sensors. All of the sensors Id's are being read in vcds but there is no temperature or pressure reading as well as no speed input in vcds. I reset the pressures using the display and waited 20 minutes then drove the car for a little bit but still isn't reading anything but the identification numbers. I loked at the coding and the coding in the abs module has both the tpms 1 and tpms 2 boxex unchecked. I tried to code one both in at separate times and it wont allow it. It says error 31 request out of range. Any help would be appreciated.
Tuesday,28,April,2020,17:39:06:60802
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
Dealer/Shop Name: 1234512312345
VIN: WAULF78K59N068768   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 65 72
          77
VIN: WAULF78K59N068768   Mileage: 206830km-128518miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0001
   Revision: E1H14---
   Coding: 0104010A190F0160
   Shop #: WSC 09396 002 1048576
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 79BACD3FF834D04E4C-802C
Readiness: 0010 0101
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 C    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0050
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 3620060389AAFF36E1-8062
   Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
   Component: ESP8 quattro  H04 0210
   Coding: 150100
   VCID: 7DB2D92FE41CEC6E60-8028
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H80 0145
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 33263F1792D8EA1EC6-8066
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0509000010202006
   Component: ELVAUDIB8  H36 0041
   Serial number: 0209000012848015
   Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
   Component: KLIMA 1 ZONE  H06 0150
   Revision: A1000000    Serial number: 01130320090031
   Coding: 64002000
   Shop #: WSC 02391 823 56573
   VCID: 70ACF01BA34E9106FB-8024
   Component: BCM1 1.0      H24 0253
   Revision: 05024001    Serial number: 00000000225447
   Coding: 690000B1063C00010000080300007F5F0F14520800000001000000
   VCID: 302C301B63CED106BB-8064
   Component: WWS 180309  H06 0070
   Serial number: SWF09030185532
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 T    HW: 8K0 941 531 T
   Component: E1 - LDS  H07 0090
   Serial number: 00000000001203091159
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD14XSN5
   Coding: 303836354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   VCID: 40CC60DBDB6E41864B-8014
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R0900003JA6
   Serial number: 6334MSME46340C1BE
   Serial number: 6344MSME4463086EJ
   Serial number: 6352QSME621E520EL
   Serial number: 6362QSME461F0922H
   Serial number: 63732SME7C21043C/
   Serial number: 63832SME36213C14W
   Revision: --------    Serial number: 90304ICD0004X
   Coding: 000034
   VCID: 3D32192FA49C2C6E20-8068
   Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
   Component: KOMBIINSTR.   H18 0224
   Revision: 00000000    Serial number: 9DR1EGC39
   Coding: 8B1209000300D705020200
   VCID: 2D12296F74FCBCEE90-8078
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G0930686F2
   Coding: 000303
   VCID: 4BD647F7EA2892DEAE-801E
   Component: J367-BDM  H06 0160
   Serial number: 19068C5E110209
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Component: SG ext.Player H06 0210
   Revision: 00000000
   Coding: 020302
   VCID: 78BCC83BCB3EC94633-802C
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008591368
   Coding: 011C03204000410001
   VCID: 41CA65DFD864488E44-8014
   Revision: 00002001    Serial number: 0117171294
   Coding: 0106023A007A000400B001
   Subsystem 2 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S2100000
   Coding: 0203010102
   VCID: 6E90EE63B97A87F6E9-803A
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008606952
   VCID: 40CC60DBD36E41864B-8014
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 10000000194622
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H01 0301
   Revision: 00000003    Serial number: AUZ5Z6I1188533
   Coding: 04020002010185034119070800
   VCID: 46C076C3F14A6FB671-8012
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
                    Reset counter: 20
                    Mileage: 206833 km
                    Date: 2020.04.28
                    Time: 15:12:49
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100819785
   Coding: 010C03204000210001
   VCID: 44C46CCBC7765DA66F-8010
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13374790243434
   Coding: 0CD154
                    Fault Status: 11100100
                    Reset counter: 20
                    Mileage: 206833 km
                    Date: 2020.04.28
                    Time: 15:12:40
                    Bin. Bits: 00000000 00010000
                    Voltage: 12.00 V
                    Text:  12,5°C;n.erkannt;3390855811;--h;---°C
   Revision:             Serial number: 0000100819719
   Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005034728
   Coding: 0010370
   Shop #: WSC 02335 785 00200
   VCID: 3B3617377A88225E1E-806E
End----------(Elapsed Time: 01:30, VBatt start/end: 13.6V/13.7V)-----------
autel sensors
Surely you misspelled "Audi", right? ;)
Do you know for certain that the IDs you're seeing in the TPMS module are for the new sensors you've installed rather than the IDs of the previous ones?
FWIW, the text in the freeze-frame data of your DTC "n.erkannt" means "not detected" or "not recognized".
VinceI
C?ID=284950
Yeah I meant Audi. Damn spellcheck LOL. Actually this not working because of this virus forces the use of non factory parts at least for me anyway. Thanks for the reply, I just figured it out. While unchecking the tpms box in the ABS module coding it changed the coding but didn't change it back to the original coding when I rechecked the box. I went back to check the coding against an old scan and found that it was different. I ended up having to manually type the coding in instead of using the coding helper. After doing that and driving the car it picked up the new TPMS sensors. and all warning lights went out. Thanks again.
