- Jun 29, 2020
- 50
- 43
- Vermont, USA
- C?ID=16454
I'm thinking you will need the magnet type ABS wheels as your Jetta uses active ABS sensors versus passive like with the steel reluctor wheels.
The rings will press over a 61 millimeter shaft, they measure 60.88 mm.
Being in Vermont we replace many wheel bearings from road salt. This bearing is a different part number than your (3 bolt flange vs. 4 bolts on the Jetta). I would bet they all use 86 teeth wheels.
I didn't read what trans you used but one might be able to machine the inner side of the CV joint flange closest to the trans case and maybe mount those 2 that way.
https://imgur.com/a/NiGHyvT
PM me your address I will send you this ring.
