- Aug 10, 2016
- 2,063
- 2,466
- Eindhoven, NB, NL
- C?ID=284912
I don't even have a remote clue how to help you out, but I just wanted to inform you I'm thoroughly enjoying this.
It just goes to show that no one is totally worthless, they can always be a bad example for someone else.I don't even have a remote clue how to help you out, but I just wanted to inform you I'm thoroughly enjoying this.
Are you enjoying the trials and tribulations of making it run, or the lunacy of it all, or the concept of the finished project?
Wednesday,13,May,2020,15:01:05:41227
VCDS Version: 20.4.1.0
VIN: 3VW2B7AJ6HM404140 License Plate:
Mileage: 132470km-82313mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 17 19 25
VIN: 3VW2B7AJ6HM404140 Mileage: 132470km-82313miles
17-Instruments -- Status: Not registered 0011
25-Immobilizer -- Status: Not registered 0001
Address 01: Engine (J623-CZTA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AL HW: 04E 907 309 AP
Component: R4 1.4l TFS H22 3669
Revision: X5H22---
Coding: 011A0012230400000000
Shop #: WSC 00066 790 00016
ASAM Dataset: EV_ECM14TFS01104E906023AL 005004
ROD: EV_ECM14TFS01104E906023AL.rod
VCID: 6ADBAAB28DDEE2D6B5-803E
CAN Converter 01:
8 Faults Found:
4527 - Coolant Fan Control Circuit 1
P0480 00 [039] - Electrical Malfunction
Mileage: 132475 km
Date: 2020.05.13
Time: 00:11:29
Engine speed: 0.00 /min
Coolant temperature: 34 °C
Intake air temperature: 24 °C
Voltage terminal 30: 12.957 V
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
Mileage: 132475 km
Date: 2020.05.13
Time: 00:11:31
Outside air temperature: 215 °C
Absolute intake pressure: 97 kPa abs
Engine torque: 0.0 Nm
Fuel level: 327.67 l
E-machine torque actual value: 0.0 Nm
14643 - Coolant Pump for Intercooler
P16BA 00 [039] - Running Dry
Mileage: 132475 km
Date: 2020.05.13
Time: 00:11:34
7249 - No Communications with Steering Angle Sender (G85)
U0126 00 [039] - -
Mileage: 132475 km
Date: 2020.05.13
Time: 00:11:29
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
Mileage: 132475 km
Date: 2020.05.13
Time: 00:11:29
17143 - Oxygen (Lambda) Sensor B1 S2
P0137 00 [039] - Signal too Low
Mileage: 132475 km
Date: 2020.05.13
Time: 00:11:36
Exh mss flw bef main cat conv bank 1 filtered: 0.0 kg/h
Exhaust gas temperature before catalytic converter: -36.52 °C
Heated oxygen sensor bank 1: sensor 1: activation: 0.000 %
Heated oxygen sensor bank 1: sensor 1: resistance: 0.00 Ohm
Oxygen sensor 1 bank 1 ceramic temp: -273.15 °C
Intake camshaft bank1 active operating mode-Bits 0-7: 0
5523 - Engine Start Blocked by Immobilizer
P1570 00 [167] - -
Mileage: 132475 km
Date: 2020.05.13
Time: 00:11:30
4201 - Fuel Level too Low
P1250 00 [039] - -
Mileage: 132475 km
Date: 2020.05.13
Time: 00:11:36
Readiness: 1110 0101
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: A14B400C49250001851402EB9221004120100012
Shop #: WSC 00066 000 00000
VCID: 75E189CEDC603D2E28-8020
10 Faults Found:
Fault Status: 01101100
Reset counter: 2
Mileage: 132475 km
Date: 2020.05.13
Time: 00:05:52
Count: 16391
Count: 12
Count: 8192
Count: 272
Count: 47360
Count: 255
Count: 7936
Reset counter: 2
Mileage: 2228480 km
Date: 2000.08.00
Time: 16:03:20
Count: 256
Count: 20498
Count: 256
Count: 16390
Count: 80
Count: 256
Count: 16386
Count: 256
Reset counter: 2
Mileage: 132475 km
Date: 2020.05.13
Time: 00:07:10
Count: 16391
Count: 12
Count: 8192
Count: 107
Count: 46848
Count: 16383
Count: 7936
Fault Status: 01101000
Reset counter: 2
Mileage: 132475 km
Date: 2020.05.13
Time: 00:05:52
Count: 16391
Count: 12
Count: 8192
Count: 266
Count: 47360
Count: 255
Count: 7936
Reset counter: 2
Mileage: 132475 km
Date: 2020.05.13
Time: 00:05:52
Count: 16391
Count: 12
Count: 8192
Count: 8195
Count: 47360
Count: 255
Count: 7936
Reset counter: 2
Mileage: 132475 km
Date: 2020.05.13
Time: 00:05:52
Count: 16391
Count: 12
Count: 8192
Count: 8226
Count: 47360
Count: 255
Count: 7936
Reset counter: 2
Mileage: 329219 km
Date: 2002.08.02
Time: 00:04:17
Count: 1794
Count: 180
Count: 512
Count: 8262
Count: 288
Count: 769
Count: 8226
Count: 513
Reset counter: 2
Mileage: 132475 km
Date: 2020.05.13
Time: 00:07:15
Count: 16391
Count: 12
Count: 8192
Count: 8211
Count: 46848
Count: 7936
Reset counter: 2
Mileage: 132475 km
Date: 2020.05.13
Time: 00:05:52
Count: 16391
Count: 12
Count: 8192
Count: 80
Count: 47360
Count: 255
Count: 7936
Reset counter: 2
Mileage: 132475 km
Date: 2020.05.13
Time: 00:05:52
Count: 16391
Count: 12
Count: 8192
Count: 64
Count: 47360
Count: 255
Count: 7936
Part No SW: 5C6 920 955 A HW: 5C6 920 955 A
Component: KOMBI H04 1007
Coding: 2700000000
Shop #: WSC 00066 790 00318
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 2D5161AE7CB035EE90-8078
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Resistance Too High
9453330 - Outside temperature sensor
B103F 1B [009] - Resistance Too High
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Part No SW: 7N0 907 530 AJ HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1634
Revision: H51 Serial number: 18011400F16012
Coding: 350000
VCID: 78FF80FACB72404633-802C
Reset counter: 2
Mileage: 132475 km
Date: 2020.05.13
Time: 00:09:17
Mileage: 132475 km
Date: 2020.05.13
Time: 00:09:17
Component: IMMO H04 1007
9456433 - Key
B104B 31 [009] - No Signal
End-------------------------(Elapsed Time: 01:10)--------------------------
Scan: 01 03 19
Revision: X5H22---
CAN Converter 01:
U1017 00 [039] - -
Coolant temperature: 26 °C
Intake air temperature: 28 °C
Voltage terminal 30: 11.167 V
Absolute intake pressure: 98 kPa abs
Fuel level: 0.00 l
U0126 00 [039] - -
Voltage terminal 30: 11.190 V
U1017 00 [039] - -
Voltage terminal 30: 11.308 V
Outside air temperature: -40 °C
Fuel level: 0.00 l
30428 - ECM Power Relay Load Circuit
P068A 00 [039] - Opens Too Early
Voltage terminal 30: 11.285 V
Fuel level: 0.00 l
P1570 00 [167] - -
Revision: 00H46001
10 Faults Found:
Reset counter: 15
Count: 16391
Count: 12
Count: 8192
Count: 16390
Count: 41728
Count: 255
Count: 7936
Reset counter: 15
Count: 16391
Count: 12
Count: 8192
Count: 107
Count: 41216
Count: 255
Count: 7936
Reset counter: 15
Count: 16391
Count: 12
Count: 8192
Count: 266
Count: 40448
Count: 255
Count: 7936
Reset counter: 15
Count: 16391
Count: 12
Count: 8192
Count: 166
Count: 40448
Count: 255
Count: 7936
Reset counter: 15
Count: 16391
Count: 12
Count: 8192
Count: 8195
Count: 40448
Count: 255
Count: 7936
Reset counter: 15
Count: 16391
Count: 12
Count: 8192
Count: 8226
Count: 40448
Count: 255
Count: 7936
Reset counter: 15
Mileage: 393475 km
Date: 2002.04.05
Time: 00:20:06
Count: 1800
Count: 8242
Count: 3840
Count: 8262
Count: 288
Count: 8705
Count: 142
Count: 3841
Reset counter: 15
Mileage: 393473 km
Date: 2003.12.00
Time: 16:04:19
Count: 256
Count: 26911
Count: 256
Count: 8211
Count: 107
Count: 256
Count: 20494
Count: 256
Reset counter: 14
Count: 16391
Count: 12
Count: 8448
Count: 80
Count: 41472
Count: 50174
Count: 7936
Reset counter: 14
Count: 16391
Count: 12
Count: 8448
Count: 64
Count: 41472
Count: 50174
Count: 7936
Coding: 350000
9 Faults Found:
Fault Frequency: 106
Reset counter: 55
Fault Status: 00110100
Reset counter: 42
Fault Status: 00101110
Fault Frequency: 52
Reset counter: 15
Mileage: 132475 km
Date: 2046.14.12
Time: 00:09:17
Fault Frequency: 11
Reset counter: 12
00469 - Infotainment Databus in Single Wire Operation
Fault Frequency: 9
Reset counter: 13
Mileage: 132475 km
Date: 2046.14.12
Time: 00:09:17
Fault Status: 00100001
Reset counter: 42
