My 2003 Passat's door locks and power windows are intermittently not working. The Scan tells me there is a fault in the wiring or CCM. Does any body have any ideas were to start? Not sure if I should chase down the wiring or if do to the amount of communication errors just start with replacing the CCM?
Tuesday,28,April,2020,10:53:49:21118
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWPD63B93P103139 License Plate:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWPD63B93P103139 Mileage: 275960km-171473miles
Address 01: Engine Labels: 06B-906-018-AWM.clb
Part No SW: 4B0 906 018 DA HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0003
Coding: 0016551
Shop #: WSC 00028 000 00000
VCID: 6393A98127409FF32E9-5160
17887 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure - Intermittent
16826 - EVAP Emission Control Sys
P0442 - 001 - Small Leak - MIL ON
16839 - EVAP System
P0455 - 001 - Large Leak Detected - MIL ON
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 3B0 927 156 AH
Component: AG5 01V 1.8l5VT USA 0810
Coding: 0001104
VCID: 6C81C2BDCA9ED08B9F3-5160
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00021
Shop #: WSC 00028
VCID: 53F3794172E06F73BE9-51F2
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0001
Coding: 12345
Shop #: WSC 00028
VCID: 2411EA9D67CED8CB173-513C
06-10 - Signal too High - Intermittent
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 927 B
Component: KOMBI+WEGFAHRSP VDO V08
Coding: 07235
WVWPD63B93P103139 VWZ7Z0B5597307
37-10 - Faulty - Intermittent
49-00 - No Communications
80-00 - Single-Wire Operation
00476 - Control Module for Fuel Pump (J538)
01304 - Radio
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00028
VCID: 70B9D6CDE3B6346BA3B-513C
11 Faults Found:
01304 - Radio
End----------(Elapsed Time: 04:46, VBatt start/end: 14.3V/14.1V)-----------
