2018 VW Polo steering assist crash detection query
petesparks18
C?ID=43428
This car has been repaired after front end accident damage. We're left with a heap of issues to resolve but my main question is regarding the crash data stored in 44 steering assist. This has shut done the power steering. From the research I have done so far, it looks like from 2018 onwards, it is not possible to clear crash data and the steering assist ECU will need replacing. Can anyone confirm this?
Tuesday,28,April,2020,15:11:28:54575
VIN: WVWZZZAWZJU036957   License Plate:
Mileage: 1930km-1199mi   Repair Order:
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: WVWZZZAWZJU036957   Mileage: 1930km-1199miles
10-Park/Steer Assist -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHYC)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 AP    HW: 04C 907 309 BE
   Component: R3 1.0l MPI   H20 5636
   Revision: 33H20000
   Coding: 01110032020405080000
   Shop #: WSC 31414 790 00200
   ASAM Dataset: EV_ECM10MPI01104C906057AP 001004
   ROD: EV_ECM10MPI01104C906057AP_VW27.rod
   VCID: 73B3DE51DB387A635E0-8026
9803 - No Communications with Parking Assist Control Module A
          U0159 00 [047] - -
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:22
                    Engine speed: 0.00 /min
                    Coolant temperature: 87 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 12.345 V
                    selected gear-Bits 0-7: 0
          U0428 00 [047] - -
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:21
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:07:12
                    Coolant temperature: 7 °C
                    Intake air temperature: 7 °C
                    Voltage terminal 30: 9.612 V
4710 - No Communications with Airbag Control Module
          U0151 00 [040] - -
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:07:11
                    Voltage terminal 30: 10.201 V
Readiness: 0100 0000
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 AA    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0222
   Serial number: 08509092180110
   Coding: 09034A64154490B35205A81B24E142A649124926114A242444541254452442659248926488522424222A482AA251D64A3D8A6B52BC
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0_004.rod
   VCID: 6D87C829BD1CAC93884-8038
1152 - Databus
          [ComScl_ACC_10_Timeout]
                    Reset counter: 94
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:28
1312 - Databus
          [ComScl_PLA_01_Timeout]
                    Reset counter: 84
                    Mileage: 1902 km
                    Date: 2019.07.15
                    Time: 03:19:15
0922 - No Communications with Airbag Control Module
          U0151 00 [008] - -
          [ComScl_Airbag_01_Timeout]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:07:12
1171 - Multiple collision brake
          B13BC F2 [008] - No function
                    Fault Frequency: 12
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:07:20
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 94
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 2G2 820 045 D    HW: 2G2 820 045 D
   Component: SG_AC_Manuell H50 0301
   Coding: 012100000800010011000400020000000000000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001011
   ROD: EV_ACManuePrehMQBA0_VW27.rod
   VCID: 221DEB153442A3EB656-8076
197890 - Temperature Sensor for Evaporator Vent
          B108A 15 [008] - Open or Short to Plus
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 03:39:45
                    Outside air temperature: 13.5 °C
                    Voltage terminal 30: 11.3 V
                    Compressor current: specified value: 0.000 A
459009 - Databus
          [Airbagsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 03:54:29
262914 - Refrigerant Pressure
          B10AB F0 [008] - Too Low
                    Reset counter: 134
                    Mileage: 1919 km
                    Date: 2020.02.14
                    Time: 16:57:46
                    Refrigerant pressure: 1.0 bar
                    Outside air temperature: 12.5 °C
                    Temperature after evaporator: 16.9 °C
                    System run time-Terminal 15 on: 5 s
                    Engine speed: 1240 /min
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
   Component: BCM A0 Std    H97 0916
   Serial number: 07001800500836
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 77ABEA41CF401643628-8022
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 2Q2 959 881 C    HW: 2Q2 959 881 C
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000018085567
   Coding: 1F0000
   Subsystem 2 - Part No SW: 2Q2 959 882     HW: 2Q2 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000018819834
   Coding: 050000
   Serial number: 000000000ZY173332RF9
   Serial number: 00000000000099776340
   Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000019008001
   Coding: 1F0000
   Subsystem 6 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000018843423
   Coding: 070000
12 Faults Found:
6154 - Bulb for Rear Right Turn Signal
          B11EB 15 [009] - Open or Short to Plus
                    Reset counter: 94
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 04:55:03
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: not activated
                    Zusaetzliche Umgebungsdaten-OFF: not activated
                    Zusaetzliche Umgebungsdaten-Outside air temperature: 0
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
                    Zusaetzliche Umgebungsdaten-Parking light: not activated
                    Zusaetzliche Umgebungsdaten-Parking light left: not activated
                    Zusaetzliche Umgebungsdaten-Parking light right: not activated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: 33
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.7 V
8458 - Bulb for Right DRL
          B121E 15 [009] - Open or Short to Plus
                    Reset counter: 94
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:05
                    Zusaetzliche Umgebungsdaten-last wakeup: 45
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
9994 - Bulb for Right Parking Lamp
          B12E9 15 [009] - Open or Short to Plus
                    Reset counter: 94
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 18:42:19
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.7 V
10762 - Bulb for Right Tail Light
          B12BF 15 [008] - Open or Short to Plus
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 18:42:19
14858 - Bulb for Right Brake Lamp / Tail Lamp
          B133C 15 [009] - Open or Short to Plus
                    Reset counter: 94
                    Mileage: 1917 km
                    Date: 2020.02.12
                    Time: 20:11:30
                    Zusaetzliche Umgebungsdaten-voltage measurement: 14.9 V
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung -unterer Grenzwert unterschritten>]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:07:35
                    Zusaetzliche Umgebungsdaten-voltage measurement: 8.7 V
227080 - Turn Signal Switch
          B1144 29 [008] - Signal Implausible
                    Fault Frequency: 8
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:04:32
                    Zusaetzliche Umgebungsdaten-voltage measurement: 10.4 V
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [008] - No Release by Immobilizer
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:07:13
                    Zusaetzliche Umgebungsdaten-voltage measurement: 10.0 V
528405 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:07:13
558101 - Databus
          [Airbag_02 Datenbus fehlende Botschaft]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 03:54:33
                    Zusaetzliche Umgebungsdaten-voltage measurement: 10.7 V
919560 - Light Switch
          B126A 29 [008] - Signal Implausible
                    Reset counter: 134
                    Date: 2020.02.14
                    Time: 19:04:26
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.1 V
950278 - Light recognition sensor
          B13CA 15 [008] - Open or Short to Plus
                    Reset counter: 134
                    Date: 2020.02.14
                    Time: 19:04:26
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.4 V
Address 10: Park/Steer Assist
Address 13: Auto Dist. Reg
   Part No SW: 2Q0 959 655 AG    HW: 2Q0 959 655 AG
   Component: VW22Airbag    010 0248
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF008800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X_VW27.rod
   VCID: 025D8B95948243EB456-8056
   Subsystem 1 - Part No SW: -----------    HW: 442 060 312 17
   Serial number: 3577Y21BF263F3C2F2EU
   Subsystem 2 - Part No SW: -----------    HW: 442 060 312 17
   Serial number: 3587Y21BF263F3C1C0FQ
   Subsystem 3 - Part No SW: -----------    HW: 442 0B0 701 18
   Serial number: 3517734BD28A7CD4225X
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 701 18
   Serial number: 3527734BD28A7CD1E2E9
   Subsystem 5 - Part No SW: -----------    HW: 442 130 502 18
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11BD275C884216Y
22 Faults Found:
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 95
                    Mileage: 1920 km
                    Date: 2020.03.20
                    Time: 31:01:02
          B1000 1B [136] - Resistance Too High
9437723 - Igniter for Passenger's Airbag
          B1002 1B [136] - Resistance Too High
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [136] - Resistance Too High
9438491 - Igniter for Driver head airbag
          B1005 1B [136] - Resistance Too High
          B1006 1B [137] - Resistance Too High
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [137] - Resistance Too High
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [137] - Resistance Too High
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [136] - Resistance Too High
9440027 - Driver's side; side-airbag igniter
          B100B 1B [136] - Resistance Too High
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [136] - Open or Short to Ground
9443091 - Driver's Side Airbag Crash Sensor
          B1017 13 [136] - Open Circuit
9443347 - Rear Side Airbag Crash Sensor (on driver's side)
          B1018 13 [136] - Open Circuit
9443603 - Rear Side Airbag Crash Sensor (on front passenger's side)
          B1019 13 [136] - Open Circuit
9443859 - Driver's Front Airbag Crash Sensor
          B101A 13 [136] - Open Circuit
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [136] - Open or Short to Plus
9446675 - Redundant signal path for airbag shut-off; passenger side
          B1025 13 [136] - Open Circuit
9447187 - Seat Occupied Sensor; Passenger's Side
          B1027 13 [136] - Open Circuit
9451027 - Crash sensor side airbag; passenger side
          B1036 13 [136] - Open Circuit
9629972 - Indicator Lamp for Passenger Airbag Enabled
          B12F1 14 [136] - Open or Short to Ground
   Part No SW: 2G0 920 940 A    HW: 2G0 920 940 A
   Component: KOMBI         309 0460
   Coding: 24A4010021802600018822011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
8 Faults Found:
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 03:54:39
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 03:54:39
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 94
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:05
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 94
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:02
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 94
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:02
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:07:11
16776980 - Databus
          [PLA_Status keine Kommunikation]
                    Reset counter: 94
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:02
9456433 - Key
          B104B 31 [008] - No Signal
                    Mileage: 1920 km
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
   Component: GW MQB A0     H97 0916
   Coding: 030100046F085600F8000048080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0_VW27.rod
   VCID: 6FBBD221B7105E83BA8-803A
   Subsystem 2 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 100403C1
8 Faults Found:
131594 - Parallel Parking Assistance Control Module
          U104E 00 [009] - No communication
          [Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
                    Reset counter: 94
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:03
                    Supply voltage: Terminal 30: 12.5 V
                    Terminal 15: On
131604 - No Communication with Instrument Cluster
          U0155 00 [008] - -
          [Timeout Knoten 0x14 / 17 - Steuergerät für Schalttafeleinsatz]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 19:04:32
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: OFF
131605 - No Communications with Airbag Control Module
          U0151 00 [008] - -
          [Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:07:14
                    Supply voltage: Terminal 30: 10.0 V
                    Terminal 15: On
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [008] - -
          [Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 00:00:02
                    Supply voltage: Terminal 30: 11.0 V
                    Terminal 15: OFF
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 94
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:03
                    Terminal 15: On
131699 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 17:10:12
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: OFF
66051 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
          [Globaler Timeout CAN-Komfort]
                    Fault Frequency: 73
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 19:27:36
                    Terminal 15: OFF
197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
          [MFL (LIN#2) Timeout]
                    Reset counter: 95
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:03
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 J    HW: 2Q2 909 144 F
   Component: TRW_G4L_MQBA0 620 6030
   Serial number: 0342263CB4J0383
   Coding: 00000000000000000101020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 3A2D3375BCD2CB2B5D6-806E
10486016 - Databus
          [DEM_AIRBAG_MESSAGE_ABSENT_FAULT]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 03:54:31
                    Engine speed: 0 /min
                    Voltage terminal 30: 10.74 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 215 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 65535 °
                    Electric motor speed: 45535 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.1 Nm
15788544 - Crash Shut-Down Activated
          P1609 00 [008] - -
          [DEM_FRONT_CRASH_FAULT]
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:29
                    Voltage terminal 30: 12.44 V
                    max.value: 0.5 A
   Part No SW: 3Q0 035 842 C    HW: 3Q0 035 842 C
   Component: MU-S-D-ER     H41 0468
   Serial number: VWZAZ2U0610664
   Coding: 02720000BE00000041110101008808001F0500C60120010003
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 2D0708297D9C6C93C84-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJV0481504
6179 - Display Module 1 for Multimedia System
          B1297 F6 [009] - Cable for Video Signal; Open Circuit
                    Reset counter: 94
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 04:57:23
                    Voltage terminal 30: 13.6 V
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 134
                    Mileage: 1920 km
                    Date: 2020.02.14
                    Time: 04:57:31
                    Network diagnosis-Status: Enabled
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 94
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:06
                    Voltage terminal 30: 12.4 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 94
                    Mileage: 1916 km
                    Date: 2020.02.12
                    Time: 20:07:05
End----(Elapsed Time: 00:57, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
Address 44,2Q2 909 144 J,channel IDE00820-Activating and deactivating all development messages,adapted from,not active ,to,active ,
downtime
Finland
C?ID=280813
Search the site here. Flash up, flash back the same sw as you have and online parameterize.
With VCDS you cannot fix this.
petesparks18
C?ID=43428
Thanks for your reply. I was suspecting that this was not something VCDS could do on a vehicle this new. I've never got involved in reflashing and simply don't have the knowledge to do this. I would be interested to know if anyone can tell me whether this can be done on ODIS (I have a contact with a licenced VAG ODIS that I could call in, but he's not sure whether he can do it either).
But from researching this forum, it looks like it can be done by factory resetting the ABS and steering assist controllers and then online recoding them.
Found some info on the link below.
https://forums.ross-tech.com/showth...609-found-in-Adress-44-New-Polo-AW-2018/page3
downtime
Finland
C?ID=280813
^I'm skeptical. Official guide from VW is replace rack if crash shutdown active. So why would they offer factory reset possibility for it?
Bruce
Near Philadelphia, PA, USA
It is not just the matter of "vehicle this new". VCDS cannot access data on the VAG server farm. We are not permitted to connect. For that reason we cannot do flash processes on any control module.
I would be interested to know if anyone can tell me whether this can be done on ODIS (I have a contact with a licensed VAG ODIS that I could call in, but he's not sure whether he can do it either).
Yes, ODIS would be the means to accomplish this. As the licensed product running on the VAG server farm, ODIS can draw the data needed to flash modules. To the best of our knowledge, it is the only tool that may accomplish the task. But as others have written, crash data usually cannot be deleted, reflashed and so on. At least not in air bag modules - can't say about steering...
