Oil level rising - 2015 Crafter - Injectors?
Redmoor
C?ID=402037
Hi All,
I have a 2015 VW Crafter 2.0 (E) diesel which was showing small loss of power - Nothing like limp mode but noticeably down on what it was.
Had a warning come up that the oil level was too high.
Decided it was about time for an oil change anyway so did a filter/oil change - making sure the oil level was in the middle of the stick (after starting and settling overnight)
After a few days the same warning, oil level too high - indeed dipstick confirms.
Water level is perfect so I start thinking a leaking injector (given the high pressure fuel pump is cambelt driven)
Looking at some Injection amount deviation data and, at idle they dont look too bad.
Engine speed 920 rpm
Injection amount deviation cylinder 1 -1.05
Injection amount deviation cylinder 2 0.93
Injection amount deviation cylinder 3 -0.13
Injection amount deviation cylinder 4 0.24
When I take the Engine speed up to 2000 rpm they dont look as good:
Injection amount deviation cylinder 1 -1.7
Injection amount deviation cylinder 2 0.82
Injection amount deviation cylinder 3 0.71
Injection amount deviation cylinder 4 0.18
From what I have read on the forums/web this engine should be +/- 1.8 at idle.
I did read on a passat forum that the deviation should approach 0 as the engine speed increases? Not sure about that.
The engine does run lumpy at idle.
Anyway, given the symptoms I am still leaning towards a faulty injector, the engine runs too well for any head gasket type thoughts.
Final test was fuel consumption at idle - When first started this was 1.1l/h which dropped to 0.94l/h when warm - maybe a bit high for a 2.0 engine?
Any advice on this I could look at next would be much appreciated.
(I can only access Adv. Meas. Values and not Meas Blocks as its a Crafter)
Mike
Auto-Scan below
Tuesday,28,April,2020,10:54:54:38732
VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4524.4
VIN: WV1ZZZ2EZF6031449   License Plate: 15
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTB)       Labels:. 03L-906-012-CKT.clb
   Part No SW: 03L 906 012 A    HW: 03L 906 012 A
   Component: R4 2.0l TDI   H26 9977
   Revision: 72H26---    Serial number: VWXDZ0O1001354
   Coding: 0119401020440C080000
   ASAM Dataset: EV_ECM20TDI01103L906012A 002016
   ROD: EV_ECM20TDI01103L906012A_002.rod
   VCID: 221C1369C44685DB65F-8076
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 843 C    HW: 906 900 590 2
   Component: IMMO          1231  1322
   Revision: 00231000    Serial number: VWXDZ0O1001354
   VCID: 270A027DA3E460F3321-8072
Address 94: LT3 Airbag
   Part No HW: 9069005701
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F678B5C588226350D-8000
Address 95: LT3 ESP
   Part No HW: 0009013202
   Serial number: 000901320210851
   ASAM Dataset: CRFT2_ESP 3
   ROD: CRFT1_ESP.rod
No Faults Found
Address 96: LT3 Instruments
   Part No SW: 9069026601    HW: 9069014501
   ASAM Dataset: 32 1056
   ROD: CRFT_KOMBI_32_1056.rod
   VCID: 074A62FD4FA440F3121-8052
Address 99: LT3 Ign. Switch
   Part No HW: 9069005902
   ASAM Dataset: 67 259
   ROD: CRFT_EZS_67_259.rod
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        1231  1322
   Revision: 00231000    Serial number: 12345678901234
00172 - Key 2 not learned
Address 9B: LT3 Driver Door
   Part No HW: 9069000501
   ASAM Dataset: 33 263
   ROD: CRFT_FTUHR_33_263.rod
Address B0: LT3 Roof Display
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BA20E0D036C1413069-802E
Address B4: LT3 Central Elec.
   Part No SW: 9069024301    HW: 9069017501
   ASAM Dataset: 33 852
   ROD: CRFT_EZE_33_851.rod (*)
   VCID: 025C73E9648665DB45F-8056
90C1 - Emergency light activated; rotary light switch: implausible condition
            Test Complete - Stored
Address B6: LT3 Steering Wheel
   Part No SW: 9065402545    HW: 9065402545
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 084861C142BA4F8B1BB-805C
End----------(Elapsed Time: 01:07, VBatt start/end: 14.2V/14.2V)-----------
Tuesday,28,April,2020,11:08:06:38732
Address 95: LT3 ESP
   ROD: CRFT1_ESP.rod
No Faults Found
   ASAM Dataset: 21 3
End----------(Elapsed Time: 01:08, VBatt start/end: 12.7V/12.7V)-----------
How many miles on it?
How much does the oil smell of fuel?
Redmoor
C?ID=402037
Hey Uwe,
Thanks for the reply.
It has done 95,000 miles but has already had a clutch so I think in a past life it was used as a multi-drop van (or clocked, no idea how plausible that is nowadays).
Oil does have a tinge of diesel smell, hard to judge as its not long since the oil was changed, local mechanic said he smelt diesel in the oil but I was not blown away when I smelt the oil.
Mike
