2011 touareg - I not able to interpret the error log...
frodeih
Norway
C?ID=393485
Hi, I not able to sort out what errors are dependent of each other in this, hence not alble to figure out a good place to start fixing...
I assume many of the errors are linked to the ACC issue whit HW failure on a radar. But Im suddenly getting error messengers in car linked to gearbox and driving gear...
Many thanks for tips on where to start:-)
Monday,27,April,2020,17:39:40:19327
VIN: WVGZZZ7PZBD021962   License Plate: DN54777
Mileage: 143772km-89335mi   Repair Order: 6
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 34 36 3C 42 46 47 52
          53 55 56 5F 62 69 6C 6D 72 85 8B 8E 8F 90
VIN: WVGZZZ7PZBD021962   Mileage: 143772km-89335miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
85-On Board Cam. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CASA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401     HW: 7P0 907 401
   Component: 3.0TDI EDC17  H17 0007
   Revision: 51H17---
   Coding: 292A401A237E01020000
   Shop #: WSC 00010 218 999999
   ASAM Dataset: EV_ECM30TDI0117P0907401 002009
   ROD: EV_ECM30TDI0117P0907401.rod
   VCID: 6C81C296960F409B9FA-8038
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Fault Frequency: 29
                    Mileage: 143724 km
                    Date: 2020.04.23
                    Time: 20:52:24
                    Engine speed: 806.00 /min
                    Normed load value: 19.6 %
                    Coolant temperature: 48 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 11.880 V
                    Limitation: accelerator pedal: 22.8 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 48
                    selected gear-Bits 0-7: 6
   Part No SW: 0C8 927 750 H    HW: 0C8 927 750 H
   Component: AL1000 AISIN  001 1811
   Coding: 001568
   Shop #: WSC 47516 003 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 313F13E271ADED73ECC-8064
12816 - No Communication with Cruise Control Module
          U0104 00 [009] - -
                    Reset counter: 201
                    Engine speed: 1590.0 /min
                    Transmission input speed: 1590 /min
                    Transmission output speed: 1590 /min
                    Engine torque: -36 Nm
                    Transmission fluid temperature: 54 °C
                    Accelerator position: 3.2 %
                    Clutch_C1: Open
                    Clutch_C2: Close
                    Clutch_C3: Open
                    Clutch_C4: Close
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Close
                    EOP failure status 2: Normalcy
                    EOP target revolution: 0 /min
                    EOP actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    EOP failure status with EOP without HV 1: Motor normal stop
                    EOP target current: 65278 mA
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 E    HW: 7P0 907 379 A
   Component: MK25A         H33 0416
   Revision: --------    Serial number: 429500010EC010
   Coding: 5B6B13C30B262F54DAFDC899D0D4F4507700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 3FDB45DAB7F90B036A8-806A
337672 - Databus
          U1122 00 [072] - Implausible Message
          [Steuergerät für ADR unplausibles Signal]
                    Reset counter: 208
                    Mileage: 143658 km
                    Date: 2020.04.21
                    Time: 17:57:49
                    Standard Freeze  Frame Dynamic: 00 47 08 03 00 00 00 00 01 00 01 20 24
818436 - Databus
          [AWV CAN-Überwachung kein Signal / Kommunikation]
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:07
                    Standard Freeze  Frame Dynamic: 00 47 1A 40 00 00 00 00 01 00 01 20 34
337668 - Databus
          [Steuergerät für ADR kein Signal/Kommunikation]
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:08
                    Standard Freeze  Frame Dynamic: 00 47 1A 5C 00 00 00 00 01 00 01 20 0E
   Part No SW: 4H0 907 064 AM    HW: 4H0 907 064 AM
   Component: BCM2 2.0      H23 0208
   Coding: 05A60000000000000000
   VCID: 74B1DAF6CEBF985B47A-8020
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2310000022372011
03286 - Sensor for Contact with Door Handle; Front Right
            007 - Short to Ground
                    Fault Status: 00101011
                    Reset counter: 209
                    Mileage: 142934 km
                    Date: 2020.04.17
                    Time: 15:46:51
                    RPM: 14535
                    Raw, Form. N/A: 000 203 221
                    Raw, Index/Key Err.: 241 016 042
                    Raw, Index/Key Err.: 232 097 000
                    Attenuation: 76 dB
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 AJ    HW: 7P6 907 040 AJ
   Component: Klima 2 Zonen H18 0613
   Coding: 3696000A10
   VCID: 7CA1F2D6E66FD01B0FA-8028
          U1101 00 [008] - Active
                    Reset counter: 204
                    Mileage: 142882 km
                    Date: 2020.04.17
                    Time: 14:31:59
0309 - Local data bus 2
          U1076 00 [008] - Electrical malfunction
                    Reset counter: 197
                    Mileage: 142808 km
                    Date: 2020.04.08
                    Time: 01:28:04
   Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0083
   Revision: 15012002    Serial number: 00000000823201
   Coding: 26001011D1345D010021000300005D0C431C670806010241000000020000
   VCID: 290FFB8259FD95B324C-807C
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    101018  31  0020
   Serial number: 90243400101020051340
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10077843
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001510100647
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475     HW: 7P6 919 475
   Component: PARKHILFE 8K  H03 0016
   Revision: --------    Serial number: 38931028500253
   Coding: 518D01
   ASAM Dataset: EV_VW526ParkiAssis2 001008
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 55F787722585E153504-8000
11 Faults Found:
1078788 - Rear Left Parking Aid Sensor
          B1076 04 [008] - Internal System Fault
                    Reset counter: 199
                    Mileage: 142873 km
                    Date: 2020.04.14
                    Time: 16:44:15
1079556 - Rear Right Parking Aid Sensors
          B1079 04 [008] - Internal System Fault
                    Reset counter: 199
                    Mileage: 142873 km
                    Date: 2020.04.14
                    Time: 16:44:11
1079044 - Center Rear Left Parking Aid Sensor
          B1077 04 [008] - Internal System Fault
                    Reset counter: 199
                    Mileage: 142873 km
                    Date: 2020.04.14
                    Time: 16:44:11
1079300 - Center Rear Right Parking Aid Sensor
          B1078 04 [008] - Internal System Fault
                    Reset counter: 199
                    Mileage: 142873 km
                    Date: 2020.04.14
                    Time: 16:44:11
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [008] - Open or Short to Ground
                    Fault Frequency: 29
                    Reset counter: 204
                    Mileage: 142865 km
                    Date: 2020.04.14
                    Time: 16:12:04
1112594 - Front Right Parking Aid Sensor
          B10FA 12 [008] - Short to Plus
                    Fault Frequency: 11
                    Reset counter: 199
                    Mileage: 142865 km
                    Date: 2020.04.14
                    Time: 16:16:43
1112625 - Front Right Parking Aid Sensor
          B10FA 31 [008] - No Signal
                    Reset counter: 202
                    Mileage: 143183 km
                    Date: 2020.04.18
                    Time: 17:03:11
1111812 - Front Left Parking Aid Sensor
          B10F7 04 [008] - Internal System Fault
                    Reset counter: 199
                    Mileage: 142873 km
                    Date: 2020.04.14
                    Time: 16:44:11
1112580 - Front Right Parking Aid Sensor
          B10FA 04 [008] - Internal System Fault
                    Reset counter: 199
                    Mileage: 142870 km
                    Date: 2020.04.14
                    Time: 16:21:08
12658704 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 199
                    Mileage: 142808 km
                    Date: 2020.04.08
                    Time: 09:42:05
12727552 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Abstandsdistanzregelung - ACC_02_FR - kein Signal/keine Kommunikation]
                    Reset counter: 170
                    Mileage: 143772 km
                    Date: 2020.04.27
                    Time: 17:35:55
Address 13: Auto Dist. Reg
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag009 H05 0023
   Revision: --------    Serial number: 003JX000H52-
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 40D94626CA0774FB132-8014
   Serial number: 3575LRB405D04QLQ6H5Y
   Serial number: 3585LRB404P00BSOEP55
   Serial number: 3515RRB406501NFS91GF
   Serial number: 3525RRB406501NFS50C7
   Serial number: 3555NRB405R036N2LH7M
   Serial number: 3565NRB405T036N2A9NM
   Part No SW: 4H0 953 568 B    HW: 7P6 953 507 G
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815JJ400008
   Coding: 000C9D
   VCID: 323D1CEE742BD66B956-8066
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0032702
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 880 D    HW: 7P6 920 880 D
   Component: Kombi         H09 0114
   Revision: 08240053    Serial number: 658111010593026
   Coding: 071733007E080008000004
   ASAM Dataset: EV_KombiUDSRBVW526 001011
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 3C2132D6A6EF101B4FA-8068
16776960 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_02_FR keine Kommunikation]
                    Fault Frequency: 23
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:07
16776961 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_04_FR keine Kommunikation]
                    Fault Frequency: 26
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:07
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 7P0 963 272 B    HW: 7P0 963 272 B
   Component: Standheizung  H23 0240
   Revision: 56005006    Serial number: 20101005221831
   Coding: 594200
   VCID: 363520FE9843CA4BB9E-8062
   Part No SW: 7P6 907 530 D    HW: 7P6 907 530
   Component: GW-CAN-L-FR-M H08 5202
   Revision: --------    Serial number: 00000000050561
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 392F2BC2A9DD253354C-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005659274199
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 C    HW: 7PP 959 663 C
   Component: J532_DCDCStab  H17 0039
   Serial number: 10288001190011200180
4365 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
                    Fault Frequency: 28
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:07
                    Voltage terminal 30: 14.1 V
                    Voltage terminal 15: 14.1 V
                    Control Module temperature: 31 °C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
   Component: PASM          H01 1110
   Revision: 00000000    Serial number: 00000102770558
   Coding: 15210001
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
12656679 - Databus
          [CAN-Timeoutfehler ACC]
                    Fault Priority: 11
                    Fault Frequency: 170
                    Reset counter: 2
                    Mileage: 66560 km
                    Date: 2074.05.08
                    Time: 20:33:06
                    Default: 5C
                    Default: 86
                    Default: 00
0840 - Comfort limitation
          C10D7 00 [137] - -
          [Dämpferregelung - eingeschränkter Normalbetrieb - Notlauf 1]
                    Reset counter: 2
                    Mileage: 67840 km
                    Date: 2074.05.13
                    Time: 03:25:06
                    Default: 19
                    Default: 86
                    Default: 00
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00001002138297
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 34311AF68E3FD85B87A-8060
   Part No SW: 7P6 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH03 0110
   Revision: 00H03000    Serial number: 6PZ 010 316-01
   Coding: 0010151
   VCID: 7EA5F8DEFCF3C20B21E-802A
   Subsystem 1 - Part No: 7P6 907 568
   Component: J770  SWA Slave H01 0110
   Subsystem 2 - Serial number: 6PZ 010 316-21
   Subsystem 3 - Serial number: 5F23.09.1000H010003C521996ÿ
   Subsystem 4 - Serial number: 521996ÿ
   Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
   Component: TSG FA        H02 0166
   Revision: --------    Serial number: 0000176144736
   Coding: 011D1620DE00459005080003
   Shop #: WSC 42825 001 1048576
   VCID: 43D3492ADB916FE30E0-8016
   Revision: 00002001    Serial number: 0135898456
   Coding: 011A1E2028B91095832006242F0000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H05 0006
   Serial number:     WOO1067043
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H06 0006
   Serial number:     WOO1068160$
   Coding: 191100
01319 - Control Module for Distance Control (J428)
                    Fault Frequency: 23
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:08
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10810000220504
   VCID: 75B7E7F2C5C58153704-8020
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000109106053
   Coding: 011D1620DE00459005080000
   VCID: 3B2331CAA3611723460-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 D    HW: 7P0 907 801 D
   Component: EPB           H51 1000
   Revision: 00000000    Serial number: A109230012E
   Coding: 01040000
   Shop #: WSC 39924 001 1048576
   ROD: EV_ParkbA7.rod
   VCID: 34311AF68EBFD85B87A-8060
   Slave 3:
12656805 - Databus
          [CAN-Signalfehler ACC]
12656679 - Databus
          [CAN-Timeout ACC]
                    Reset counter: 165
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:08
                    Voltage: 14.4 V
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 01AA00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0006
   Coding: 130000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0006
   Coding: 130000
   Part No SW: 4F0 035 061 H    HW: 4F0 035 061
   Component: Radio U DAB   H46 0048
   Revision: AB001007    Serial number: 006DM0A7507160
   Coding: 010105010000000001
   VCID: 211FE3A221CD5DF37CC-8074
   Part No SW: 7P6 035 670     HW: 7P6 035 670
   Component: H-BNT-EU      H43 0203
   Revision: --------    Serial number: 478J.0A7525022
   Coding: 020100050040CBEF79102B0E00000003F0040101
   VCID: 72BDDCEEB4AB966B556-8026
   Subsystem 1 - Part No: 8R0 060 884 R
   Component: EUR 2010  1106
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H24 0045
   Serial number: VWZ8Z9K2800D8X
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  1886
                    Reset counter: 168
                    Mileage: 143652 km
                    Date: 2020.04.21
                    Time: 17:51:49
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000109084547
   Coding: 011C16200000259005080000
   VCID: 3A2D34CEAC5B2E2B5D6-806E
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 C    HW: 7P0 907 383 C
   Component: Anhaenger     H07 0100
   Revision: 5H001001    Serial number: 00000136437309
   Coding: 0106040000000000
   VCID: 38292EC692573C3BAB2-806C
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 D    HW: 7P6 907 441 D_
   Component: TopView       H05 0095
   Revision: 11001001    Serial number: 82330010114135
   Coding: 0100000001010000010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   VCID: 3A2D34CEACDB2E2B5D6-806E
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0611
   Revision: 09145444    Serial number: 289000023
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000109097312
   Part No SW: 7P6 907 217     HW: 7P6 907 217
   Component: DPC-SG        H22 0012
   Coding: E9070000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 77ABEDFADF49F343628-8022
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000003020503_1125
0724 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_timeout]
                    Fault Frequency: 24
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:08
                    Outside air temperature: -44.5 °C
                    Voltage terminal 15: 14.0 V
                    Control Module temperature: 22.0 °C
   Part No SW: 7P6 907 541 A    HW: 7P6 907 541
   Component: ACC3          H13 0230
   Coding: 3F04010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 001004
   ROD: EV_AdaptCruisContr2VW526_001.rod
   VCID: 38292EC692D73C3BAB2-806C
10 Faults Found:
29184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_GATEWAY_05]
                    Fault Frequency: 9
                    Reset counter: 210
                    Mileage: 143772 km
                    Date: 2020.04.23
                    Time: 21:44:40
                    Control Module temperature: 12 °C
                    Voltage terminal 15: 14.263 V
                    Velocity_vehicle_reference: 6.50 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.20 m/s²
76800 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_TSK_05]
                    Fault Frequency: 11
                    Reset counter: 210
                    Mileage: 143770 km
                    Date: 2020.04.23
                    Time: 21:42:09
                    Voltage terminal 15: 14.284 V
                    Velocity_vehicle_reference: 12.54 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.09 m/s²
94720 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_QDCACC_FAIL]
                    Reset counter: 170
                    Mileage: 143772 km
                    Date: 2020.04.27
                    Time: 17:37:20
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 12.019 V
94976 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_QDCPSS_FAIL]
                    Fault Frequency: 11
                    Reset counter: 170
                    Mileage: 143772 km
                    Date: 2020.04.27
                    Time: 17:37:20
                    Voltage terminal 15: 12.021 V
95232 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_QEPBACC_FAIL]
                    Fault Frequency: 29
                    Reset counter: 170
                    Mileage: 143772 km
                    Date: 2020.04.27
                    Time: 17:38:40
                    Voltage terminal 15: 12.041 V
95488 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_QDISACC_FAIL]
                    Fault Frequency: 8
                    Reset counter: 170
                    Mileage: 143772 km
                    Date: 2020.04.27
                    Time: 17:35:55
                    Control Module temperature: 8 °C
                    Voltage terminal 15: 11.762 V
77312 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FAULT_CIM_TIMEOUT_LRRM_TRIG]
                    Fault Frequency: 24
                    Reset counter: 210
                    Mileage: 143726 km
                    Date: 2020.04.23
                    Time: 20:59:09
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 14.258 V
                    Velocity_vehicle_reference: 4.29 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.45 m/s²
77568 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FAULT_CIM_TIMEOUT_LRRM_DEJU]
                    Fault Frequency: 19
                    Reset counter: 210
                    Mileage: 143726 km
                    Date: 2020.04.23
                    Time: 20:59:09
                    Voltage terminal 15: 14.237 V
                    Velocity_vehicle_reference: 4.16 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.46 m/s²
144896 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_US_FAIL]
                    Fault Frequency: 67
                    Reset counter: 170
                    Mileage: 143772 km
                    Date: 2020.04.27
                    Time: 17:35:55
82688 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_TSK_FAIL]
                    Reset counter: 170
                    Mileage: 143772 km
                    Date: 2020.04.27
                    Time: 17:35:53
                    Voltage terminal 15: 11.257 V
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107     HW: 7P6 907 107
   Component: BV-SG         H28 0003
   Serial number: 000040172709107
   Coding: 0AA0BE04
   ASAM Dataset: EV_BTR 001001
   ROD: EV_BTR_001.rod
   VCID: 75B7E7F2C5458153704-8020
0046 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_timeout]
                    Fault Frequency: 22
                    Reset counter: 210
                    Mileage: 143726 km
                    Date: 2020.04.23
                    Time: 20:59:09
0051 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BCM1_Timeout]
                    Fault Frequency: 9
                    Reset counter: 210
                    Mileage: 143758 km
                    Date: 2020.04.23
                    Time: 21:28:53
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 006606000317037F00033811594097000000
   Shop #: WSC 00001 790 00001
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW52.rod
   VCID: 6FBBD59AA719BB83BA8-803A
12583680 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 25
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:08
12583693 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 24
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:08
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   Coding: 00660600031F037F00033811594097000000
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW52.rod
   VCID: 70B9D6E6BA27A47BA32-8024
          U1111 00 [009] - -
                    Fault Frequency: 25
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:08
          U1111 00 [009] - -
                    Fault Frequency: 24
                    Reset counter: 169
                    Mileage: 143620 km
                    Date: 2020.04.20
                    Time: 21:05:08
End----------(Elapsed Time: 02:34, VBatt start/end: 12.1V/12.1V)-----------
Jef
HQ
Thank you for posting the Auto-Scan! :thumbs:
Yes, a large chunk of the fault codes is due to the "Address 13: Auto Dist. Reg" being dead/offline.
I see there are a lot of "Intermittent" codes in Address 10, do they clear out now? And address 05 has codes for the front right door handle... wiring harness to factory design for that?
golfi_vend
Tartu, Estonia
C?ID=195131
Parking sensor "Internal Fault" can also occur from oxidized wiring.
I'd check the connector wherever it is underneath bumper.
