Ho well must be record for fault codes
johne
Southampton, UK
C?ID=380307
Hi all, after a week of driving the airbag light popped on .. still starts and drives fine
so now have a serious looking problem, thinking the instruments cluster has died ?
all the gauges still work fine . no mil light. just the airbag light on . anyone with any ideas. ??
Monday,27,April,2020,15:32:26:62543
VIN: WV2ZZZ7HZ8H015277   License Plate: 27.04
Mileage: 496720km-308647mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ8H015277   Mileage: 496720km-308647miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 906 016 DS    HW: 070 906 016 DS
   Component: R5 2,5L EDC  000SG  1585
   Revision: --H05---    Serial number: VWZ7Z0G5463049
   Coding: 0001072
   Shop #: WSC 80093 222 69422
   VCID: 6491AC44A244FBDBD7A-5184
Address 03: ABS Brakes        Labels:. 7H0-907-37x-ABS.clb
   Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
   Component: (M)ABS MK25E        0103
   Revision: 00H21001
   Coding: 0000552
   Shop #: WSC 02756 790 00000
   VCID: 45D751C009BEA2D3204-513C
                    Reset counter: 14
                    Count: 4097
                    Count: 8208
                    Fault Status: 00101101
                    Reset counter: 9
                    Count: 4097
                    Count: 8193
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H0 820 045 AL
   Component: CLIMA/AC            0303
   VCID: 6FBBD3687B824883BA8-513C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 T
   Component: BORDNETZ SGVER 1.0  2001
   Coding: 0000101
   VCID: 43D34FD8078A9CE30E0-513C
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
01598 - Drive Battery Voltage
00925 - Fuse (30) for Interior Lamps (S261)
   Part No: 1C0 909 605 A
   Component: 3C AIRBAG VW51      0010
   Coding: 13123
   Shop #: WSC 02756
   VCID: 221DEA5CFDD0B5EB656-513C
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 951 T
   Coding: 00413
   Shop #: WSC 77824
   VCID: 3D273920646EEA13784-513C
   WV2ZZZ7HZ8H015277     VWZ7Z0G5463049
9 Faults Found:
01128 - Immobilizer Pickup Coil (D2)
            35-10 - - - Intermittent
01176 - Key
01322 - Control Module for Multi-Function Unit (MFA) (J501)
01304 - Radio
            49-00 - No Communications
Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
   Part No: 7H0 815 071 F
   Component: Standheizung        0209
   VCID: 2B0307788F1A74A3D60-513C
00667 - Ambient Temperature Signal
01126 - Engine Speed Signal
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02756
   VCID: 70B9D01463BC577BA32-513C
01304 - Radio
Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
   Part No: 7H0 951 171 B
   Component: Innenraumueberw.    2920
   Coding: 0000022
   Shop #: WSC 02757 790 00000
   VCID: 290FFD7085E666B324C-51CE
   Subsystem 1 - Part No: 7H5 951 178
   Component: Innenraumueberw.    1607
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C11 Komfortgerát     0004
   Coding: 00030
   Shop #: WSC 11788
   VCID: 323D1A1CAD30256B956-4B1E
End----------(Elapsed Time: 06:08, VBatt start/end: 12.2V/12.2V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
I'm seeing some communication issues between several modules (instrument, airbag, engine, ABS).
So I'm not sure whether this is a problem with the instrument cluster. There are several issues with other stuff (immo reader coil, sensor)
There are several possible explanations, probably even more:
- Problem with the CAN network for the powertrain and/or comfort (shorting wire, broken wire, bad module/gateway).
- Problem with the battery/alternator (low voltage error)
- Problem with power supply (defective fuse)
- Some GND issue
Perhaps a suggestion:
Clear all errors and drive for a while and see what errors return.
My money (but not a lot) is on a bad CAN gateway.
If you have some time:
Check all the fuses for corrosion
Check all the connectors of engine/ABS/Aux heater for corrosion
