Polo 6C MFSW retrofit
iichel
Eindhoven, NB, NL
C?ID=284912
So today I retrofitted an MFSW to a Polo 6C 1.4 TDI Bluemotion with BCM 6C0937089
The wheel itself and the airbag were re-used.
Monday,27,April,2020,05:43:23:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ6RZFY177xxx   License Plate:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZFY177xxx   Mileage:
Address 01: Engine (J623-CUSA)       Labels:. 04B-907-445-V1.clb
   Part No SW: 04B 997 027 K    HW: 04B 907 445
   Component: R3 1.4l TDI   H07 5569
   Revision: 21003001
   Coding: 01114032432401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM14TDI03004B997027K 004003
   ROD: EV_ECM14TDI03004B997027F.rod
   VCID: 3333E28D6BB78D539E9-8067
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08502162140913
   Coding: 21DD2485892A33C7091910720051842491CC90080007C9098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H02 0105
   Serial number:  1410021B-0802
   Coding: 201000001000000200
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1D672435FD332B2358D-8049
   Part No HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H06 0047
   Serial number: 009458013815
   Coding: 000008404253005B4B844080B10703480000590257010000000000000000
   ASAM Dataset: EV_BCMA0 004003
   ROD: EV_MQBA0.rod
   VCID: 55F77C15C583B36350D-8001
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU007101442800897
   Coding: 0400A0
   Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU002101442757734
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY142453ML1
   Serial number: 00000000000030222137
   Subsystem 5 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU008101442811832
   Coding: 0400A0
   Subsystem 6 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU008101442816936
   Coding: 1400A0
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391424803373
   Coding: 0031051001
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 3D27C4B55DF34B2378D-8069
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag01B 001 0330
   Revision: --------    Serial number: 003LM005K67+
   Coding: 88C0C000000000005C0000CA000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 313FE88591ABBF43EC5-8065
   Subsystem 1 - Part No SW: -----------    HW: 410 820 409 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A915DADC2232X
   Subsystem 2 - Part No SW: -----------    HW: 410 820 509 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H009F15A4BE3D295
   Subsystem 3 - Part No SW: -----------    HW: 442 150 410 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A3176F5E1F25O
   Subsystem 4 - Part No SW: -----------    HW: 442 150 410 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A3176F5E232BK
   Part No SW: 6C0 920 741 A    HW: 6C0 920 741 A
   Component: KOMBI         211 0290
   Coding: 032D09002180000800087A001000000000000000
   Shop #: WSC 12345 123 61029
   VCID: 211F18C5C14B0FC37C5-8075
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H06 0047
   Revision: --------    Serial number: 009458013815
   Coding: 030100044F0A590071000000000000010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: 65974CD595E323E3C0D-8031
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 51281411542821922228
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Serial number: PEAN0182
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 323DE78994AD845B95F-8067
   Part No SW: 3Q0 035 864     HW: 3Q0 035 864
   Component: MU-S-N-ER     H10 0133
   Serial number: VWZAZ2P4581168
   Coding: 02620001BE00000011110001000808001F01048401200100C6
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 6E8533F94015E0BBB17-803B
   Subsystem 1 - Part No SW: 6C0 919 603 A    HW: 6C0 919 603 A
   Component: ABTm_Std2_Nav  H41 1015
   Serial number: VWZ8Z9PH200FUS
   Subsystem 2 - Part No SW: 5NA 919 866 R    HW: -----------
   Component: ECE AS 19/20  --- 1115
End----------(Elapsed Time: 00:51, VBatt start/end: 12.2V/12.2V)-----------
Preparation:
- Disconnect battery
- Remove the airbag
- Remove upper and lower steering column trim
- Remove BCM
- Remove steering wheel trim.
- The steering wheel was never removed
Needed parts:
Steering wheel trim 6C0419685A with MFSW buttons 6C0959442
Airbag wiring harness 6C0971584C
Wiring
You'll need to add two wires:
T16c/3 LIN to T73c/13 on BCM (MQS on both sides)
T16c/4 +30a to SC14 (MQS on T16c side).
T16c is the connector on the bottom of the slip ring.
T73c is the large connector on BCM, on the side of the centre console (LHD). Check you have pin 13 present.
There is a shortcut to connect the wire to SC14. since this positive wire also goes to several points in the steering column.
I connected it to the positive connection of the high beam stalk (grey/red wire).
Coding
This was a leap into the unknown but I've managed :)
09 BCM: Byte 15 bit 7 ON
09 BCM: Byte 20 bit 6 OFF
19 Gateway: Byte 1 bit 0 ON
Pics :mrgreen: :mrgreen:
Wiring:
Parts:
Fitting:
