I would like to change my max speed limiter to 93 from 85.
PS... The Ross-Tech wiki seems to be down.
Autoscan =
Autoscan =
Sunday,26,April,2020,19:00:02:61936
VCDS Version: 20.4.1.0 (x64)
VIN: WVWKR7AU7JW****** License Plate: 2018 EGOLF
Mileage: 19947km-12394mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 15 16 17 19 23 2B 42 44 51 52 5F 75 8C BD C0
C6
VIN: WVWKR7AU7JW****** Mileage: 19947km-12394miles
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
Address 01: Engine (J623-EAZA) Labels:. 0EA-907-309-V1.clb
Part No SW: 0EA 906 016 F HW: 0EA 907 309 A
Component: E-Vehicle H24 4238
Revision: WMH24---
Coding: 000D0012002400007000
ASAM Dataset: EV_VCU00XXX0110EA906016F 004005
ROD: EV_VCU00XXX0110EA906016F_004.rod
VCID: 326B032B65DE9116CD-8066
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 614 517 BL HW: 5Q0 614 517 AH
Component: ESC H62 0855
Revision: 00000000 Serial number: 63337000000416
Coding: 01FA40A12C202173857A0208A1C62980023484A14085943202815058C24203
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003.rod
VCID: 7CF7ED13F71A976657-8028
16401 - Tire Pressure Warning
C102D 00 [032] - -
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0463235047
Coding: 032C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C772D13B79A576617-8068
Part No SW: 5GE 907 044 AN HW: 5GE 907 044 AN
Component: Climatronic H04 1702
Revision: 00001K01
Coding: 0002220020011001040500421211102A
VCID: 081F81C3B3C2CBC643-805C
Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
Subsystem 3 - Part No SW: 12E 963 231 G HW: 12E 963 231 G
Component: J848 HV-PTC H09 0208
Serial number: LR173383003810000075
Air quality sensor:
H02
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 01001733600116
ROD: EV_BCMBOSCH_018.rod
VCID: 06038FFBB9D6DDB631-8052
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 171120 043 0551
Serial number: 171125213505
Component: RLHS 047 0105
Serial number: S5Y17M12D08H08M34S55
Coding: 00A8DD
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 177
Mileage: 2014 km
Date: 2019.03.02
Time: 18:50:32
Serial number: 003GCR08UCE-
Coding: 8CCCFC00002000005000001AC20800000065
VCID: 479D42FFFE5C04BE8A-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000007WYOS%
Coding: 303253
Subsystem 2 - Part No SW: ----------- HW: 480 000 812 17
Serial number: 35700000000E4830482F
Subsystem 3 - Part No SW: ----------- HW: 480 000 112 17
Serial number: 35800000000D3D28482Q
Subsystem 4 - Part No SW: ----------- HW: 480 401 112 17
Serial number: 3510001BF28637D4C74G
Subsystem 5 - Part No SW: ----------- HW: 480 401 112 17
Serial number: 3520001C128AD0648470
Subsystem 6 - Part No SW: ----------- HW: 480 400 812 17
Component: FrontSensor_D 000 6149
Serial number: 3550001C128637F1136-
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 812 17
Component: FrontSensor_P 000 6149
Serial number: 3560001BD28637E1B6CN
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 04121704400714
Coding: 0410
VCID: 071D82FFBEDCC4BE4A-8052
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 5GE 920 855 C HW: 5GE 920 855 C
Component: KOMBI 302 0310
Coding: 0BB4281A2380CF05020829001700032080000000
VCID: 41895CE7D0783A8E44-8014
Part No SW: 3Q0 907 530 M HW: 3Q0 907 530 D
Component: GW MQB EV 618 6322
Serial number: 24111710520722
Coding: 0201001704F81000FB001200081D00000001070100070000000300000000
ROD: EV_GatewNF_VW37.rod
VCID: 39793407B8A8624E0C-806C
Subsystem 1 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 29170002322470107421
Coding: 30FFFF
Subsystem 2 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 6318546004
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 G HW: 5QE 909 059 B
Component: EBKV H14 0211
Serial number: 085460011232
Coding: 06720100321A02030002000500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
VCID: 52AB63AB051EB116ED-8006
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 D HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0155
Serial number: 05802861251117031138
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000357002010
Coding: 7900000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 346705339FCA9F26DF-8060
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 170917EIG2546A
Coding: 003013208000040000000000
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000017935568
Coding: 111000
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1081
Coding: C1020000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73E5C62FDA44D81E06-8026
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5QE 907 080 L HW: 5QE 907 080 L
Component: LE Gen 3.3H16 2053
Revision: 00H16000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM10030115QE907080L 001008
ROD: EV_DMCM10030115QE907080K.rod
VCID: 4FAD6ADF162CDCFEC2-801A
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 291017EJT14707
VCID: 408F59E3DB7233864B-8014
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000017999262
Coding: 091000
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 722 0867
Coding: 02738000FF00000051220001001808009F0505D40120050002
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 2E53175B71E6B5F6A9-807A
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJT3276802
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 175
Mileage: 14982 km
Date: 2020.02.16
Time: 12:47:13
Voltage terminal 30: 12.1 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 102 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Component: OCULowMQBUS 009 0570
Coding: 02737002C2829A017FFE06000000
ROD: EV_OCULowMQB.rod
VCID: 438556EFCA64289E56-8016
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5GE 915 225 A HW: 5GE 915 225 A
Component: K8C 005 0350
Serial number: 31101707010206
ASAM Dataset: EV_BECM08820215GE915225A 001003
ROD: EV_BECM08820215GE915225A.rod
VCID: 3A7B2B0BBDAE695605-806E
Battery Junction Box:
Subsystem 1 - Part No SW: 5GE 915 316 A HW: 5GE 915 316 A
Component: A2 HVSMBJBECU 011 0300
Serial number: 00000022111705010029
Subsystem 2 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J991Battmod1 H08 0322
Serial number: 17A07Y18AH0803227804
Subsystem 3 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J992Battmod2 H08 0322
Serial number: 17A07Y18AH0803227425
Subsystem 4 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J993Battmod3 H08 0322
Serial number: 17A07Y18AH0803227238
Subsystem 5 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J994Battmod4 H08 0322
Serial number: 17A05Y18AH0803225308
Subsystem 6 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J995Battmod5 H08 0322
Serial number: 17A07Y18AH0803227320
Subsystem 7 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J996Battmod6 H08 0322
Serial number: 17A07Y18AH0803225061
Subsystem 8 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J997Battmod7 H08 0322
Serial number: 17A07Y18AH0803227964
Subsystem 9 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J998Battmod8 H08 0322
Serial number: 17A06Y18AH0803227987
Address BD: Hi Volt. Batt. Charg. (J966) Labels:| 5QE-915-022.clb
Part No SW: 5QE 915 022 AN HW: 12E 915 022 G
Component: LMSG H20 1096
Serial number: 01146070470019
Coding: 484914000400
ASAM Dataset: EV_HVChargManagVWMQB 003004
ROD: EV_HVChargManagVWMQB.rod
VCID: 0D11B0D7DCA0AEEE70-8058
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Part No SW: 5QE 035 335 M HW: 5QE 035 335 B
Component: E_SOUND_SG H10 0223
Serial number: EN174604000000
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 007015
ROD: EV_ENoiseS1NNVW3707_007.rod
VCID: 4B957ECFE234E0DEAE-801E
Address C6: Batt. Chrg. (J1050) Labels: 5QE-915-681.clb
Part No SW: 5QE 915 681 B HW: 5QE 915 681 B
Component: OBC Delta-ES H59 1560
ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
ROD: EV_OBCTwoPhaseDT2VW3707.rod
End-------------------------(Elapsed Time: 04:44)--------------------------
