Bentley Continental GT 2005 Check Oil Level warning
patrascul25
Romania
C?ID=374594
Hey, guys,
I've had some trouble with a 2005 Bentley Continental GT. The car was not used for a long time and the oil level was low. The owner went to a car repair shop and changed engine oil and filters. After that the instrument panel still displayed message "Check engine oil level". Based on my previous experience with VAG cars i've checked the bonnet switch that was malfunctioning and the warning message did not appeared anymore. The car did not detect the bonnet being open.
Is there a way to see this error with VCDS, because when the care was scanned it didn't show errors related to the bonnet switch or the instrument panel? I'll post autoscan results below (ignore most errors being reported as a consequence of a discharged battery).
Thank you!
Saturday,25,April,2020,10:30:24:15962
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
Dealer/Shop Name: ul25
VIN: SCBCE63W15Cxxxxxx   License Plate: BENTLEY
Mileage: 155710km-96753mi   Repair Order:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
          37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCE63W15C028058   Mileage: 155710km-96753miles
   Part No: 07C 997 018
   Component: BY-6.0L-TT      G  ª6728
   Revision: 03ÿTT       Serial number:  000-00009.01.
   Coding: 0000173
   Shop #: WSC 66565 257 00032
   VCID: EC945566CEB52DE647-513C
18331 - Please Check DTC Memory of ECU Number 2
            P1923 - 008 -
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 09E 927 760 G    HW: GS1 904 1
   Component: AG6 09E 6.0L W12TT  1905
   Coding: 0000101
   Shop #: WSC 00083 000 00000
   VCID: B4248D06D605B5265F-5160
Address 03: ABS Brakes        Labels: 3W0-614-517-V1.lbl
   Part No: 3W0 614 517 D
   Component: ESP 5.7 4WD     H01 0021
   Coding: 0007878
   Shop #: WSC 60703 000 00000
   VCID: B620B70EC079A73661-51CE
   Part No SW: 3D0 909 135 Q    HW: 5WK 470 22
   Component: 13 Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0D3288981
   Coding: 0159981
   VCID: B3268E1AD30BB21E46-5160
   Subsystem 1 - Part No: 4E0 905 852 D
   Component: ELV                 1834
00087 - Terminal 30 for Starting Relevant Consumers
Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
   Part No: 3W0 959 759 A
   Component:    CM Seat Pass.    0009
   Coding: 0000002
   Shop #: WSC 07189 106 181341
   VCID: C7DECACAB7932EBE0A-5160
02569 - Control Module for Massage (J740)
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3W0 035 007 G
   Component:    ZAB COCKPIT      0223
   Coding: 0000000
   VCID: B02C8116221D89063B-5160
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 B
   Component: Climatronic BY614   0030
   Coding: 0000001
00445 - Loss of Refrigerant
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 H
   Component: STG.Bordnetz        5101
   Coding: 0000107
   VCID: AF2E826A3F2396FE22-5160
Address 11: Engine II        Labels: None
   Revision: 68ÿTT       Serial number:  000-00009.01.
   Coding: 0000173
   Shop #: WSC 07191 106 60138
16932 - Sensor 1 for Exhaust Temp Bank 2 (G236)
            P0548 - 002 - Short to Ground
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 001 -  - Intermittent
16694 - Cylinder 10
            P0310 - 008 - Misfire Detected - Intermittent
   Part No: 3D0 909 601 E
   Component: 0P Airbag 8.4E+ H10 0936
   Coding: 0012368
   VCID: A50260426DDFDCAED8-5160
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 D
   Coding: 0000012
   VCID: AE109F6E38299FF629-5160
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No: 3W0 920 840 T
   Component: KOMBIINSTRUMENT RB8 0514
   Coding: 0023103
   VCID: C5C2C0C28D9F3CAEF8-5160
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: F0AC4116E29DC9067B-5160
Address 34: Level Control        Labels: 3D0-907-553-V1.clb
   Part No: 3W0 907 553
   Component: LUFTFDR.-CDC- 3C1V0 7014
   Coding: 0015500
   VCID: F7BE7A0A87F39E3EBA-5160
01598 - Drive Battery Voltage
Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
   Part No: 3W0 959 760 A
   Component:    CM Seat Driver   0008
   Coding: 0000002
   VCID: BFCED22AEF43667EB2-5160
Address 37: Navigation        Labels: None
   Part No: 3W0 919 887 B
   Component:    NAVIGATION       0168
   Coding: 0400000
   VCID: C6C0C7CEB09937B6F1-5160
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 C
   Component: Dachmodul           0703
   Coding: 0000157
   VCID: B620B70EC079A73661-5160
00926 - Terminal 30
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 F
   Component: 1Y HSG              0101
   Coding: 0000032
   Shop #: WSC 21454 000 1048576
   VCID: B3268E1AD30BB21E46-4B00
   Subsystem 1 - Part No: 3W1 959 701
   Component: Tuersteuergeraet FS 0702
   Subsystem 2 - Part No: 3W1 959 702
   Component: Tuersteuergeraet BF 0702
   Subsystem 3 - Part No: 3W3 959 703
   Component: Tuersteuergeraet HL 0702
   Subsystem 4 - Part No: 3W3 959 704
   Component: Tuersteuergeraet HR 0702
   Subsystem 5 - Part No: 7L0 907 719
9 Faults Found:
   Part No: 3W0 035 456 C
   Component: 12K-AUDIOVERST      4121
Address 53: Parking Brake        Labels: 3W0-907-801.clb
   Part No SW: 3W0 907 801 B    HW: 3W0 907 801 B
   Component: EPB  BC6HX23    HC6 X230
   Coding: 0022413
   VCID: B522B002DD7FAC2E68-5160
                    Reset counter: 120
                    Voltage: 6.94 V
                    Count: 200
                    Reset counter: 120
                    Voltage: 8.90 V
                    Count: 238
Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
   Part No: 1C0 959 733 H
   Component: Heckspoiler         0002
   VCID: B02C8116721D89063B-51CE
Address 57: TV Tuner        Labels: 3D0-919-146.lbl
   Part No: 3D0 919 146
   Component: TV Tuner        H07 1205
   Coding: 0000010
   VCID: E58220422D5F1CAE18-5160
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W1 955 023 C
   Component: WischeX
   Shop #: WSC 00000 725 65552
00003 - Control Module
            014 - Defective
00459 - Control Module for Display and Input; Front (J523)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 C
   Component: Batteriemanagement  2700
   VCID: A3067E5A63EB229EB6-5160
00086 - Parallel Battery Connection Relay (J581)
   Part No: 3W0 919 283
   Component: 02 Einparkhilfe     0203
   VCID: FAB8633EB4E18356C5-5160
End----(Elapsed Time: 07:19, VBatt start/end: 11.5V/11.3V. VIgn 0.0V)------
NEtech
Denmark
C?ID=56995
That should be possible to check in, [17-Instrument] MWB 202 field 1
Open or Closed.
patrascul25
Romania
C?ID=374594
Thanks for the tip. I've found that the bonnet switch was disconnected by the previous owner since was showing open bonnet all the time. Since the trouble code was stored in the instrument panel i was wondering if is possible to see (using VCDS) that the "Check oil level" warning was active and what could be the reason for this. I will check [17-Instrument] MWB 202 field 1 to see if the switch state is Open or Closed with the switch disconnected.
