2016 a7
adanr150
C?ID=303480
started by hearing whislteling sound. my 2010 A6 did that and it was the pcv. I purchased it for this car already but my ? is does this make all these codes come out??? once I heard the whistle sound drove home and started hearing flapping noise or knock rear eninge. I hope im right and its just the pcv… any help would be GREAT
Saturday,25,April,2020,07:44:52:10832
VIN: WAUWGAFC6GN058752   License Plate:
Mileage: 113073km-70260mi   Repair Order: 4-25
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 28 36 3B 3C 42 44 46 52
          53 55 5F 62 6C 6D 72 85 8B 8E 8F 90
VIN: WAUWGAFC6GN058752   Mileage: 113073km-70260miles
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G2 907 551 A    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0004
   Revision: --H10---
   Coding: 1A2A00340566010D3000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214G2907551A 002001
   ROD: EV_ECM30TFS0214G2907551A_002.rod
   VCID: 290CF42B197B874FBE9-807C
10 Faults Found:
23044 - Valve for Fuel Metering (N290)
          P0089 00 [096] - Implausible Signal
23045 - Valve for Fuel Metering (N290)
19457 - Cylinder 5 Knock Control
          P2340 00 [096] - Limit Reached
20605 - Leak in Air Intake System
          P2279 00 [104] - -
                    Mileage: 113063 km
                    Date: 2020.04.24
                    Time: 17:59:53
                    Engine speed: 692.50 /min
                    Normed load value: 24.3 %
                    Coolant temperature: 104 °C
                    Intake air temperature: 74 °C
                    Voltage terminal 30: 13.886 V
                    Air mass: actual value (mg/stroke): 155.02 mg/stroke
                    Charge press.: average: 0.470 bar
                    Throttle valve angle: 0.773 °
                    Pressure before throttle valve: corrected: 1.003 bar
                    TQ_LOSS: -28.93750 Nm
                    Engine torque: 31.78125 Nm
                    Ignition angle of current cylinder: actual value: -15.37 °
15077 - Idle Control System RPM
          P0507 00 [096] - Higher than Expected.
                    Mileage: 113073 km
                    Date: 2020.04.24
                    Time: 18:38:04
                    Engine speed: 1511.25 /min
                    Coolant temperature: 91 °C
                    Intake air temperature: 70 °C
                    Voltage terminal 30: 13.964 V
                    Ignition angle of current cylinder: actual value: 3.75 °
                    Throttle valve angle: 1.233 °
                    Charge press.: average: 0.281 bar
                    Secondary air system: status: cancelled
                    Engine torque: 24.59375 Nm
                    Ambient air pressure: 1.005 bar
                    Accelerator position: 0.00 %
20596 - Low Pressure Fuel regulation
          P310B 00 [096] - Fuel Pressure Outside Specification
15027 - Fuel Level too Low
          P1250 00 [032] - -
20679 - Coolant Pump for Intercooler
          P16BA 00 [096] - Running Dry
23126 - Fuel Level Sensor Circuit
          P0461 00 [096] - Implausible Signal
15271 - EVAP System
          P0456 00 [096] - Very Small Leak Detected
   Part No SW: 4G0 927 158 AM    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H19 1004
   Revision: --H19---
   VCID: 79ACE46BA95BF7CF8E9-802C
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 44A7964B22E569D21B00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 41DC4C8B810B6F0F869-8014
155392 - Tire Pressure Warning
          C102D 00 [032] - -
161024 - Tire Pressure Warning
          C102D 00 [032] - -
161280 - Tire Pressure Warning
          C102D 00 [032] - -
161536 - Tire Pressure Warning
          C102D 00 [032] - -
161792 - Tire Pressure Warning
          C102D 00 [032] - -
   Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
   Component: BCM2 2.0      H37 0572
   Coding: 0DAA6F4E000000000000
   VCID: 7F580A73B7FFD9FFB0D-802A
   Serial number: 3215000116725004
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 21071500040237
   Coding: 660331784D0000
   VCID: 6390A6033BD71D1FB45-8036
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0311
   Revision: 21020001    Serial number: 00001120971202
   Coding: 01050011043C9FE2C100488780007800CF9CC208AE0802218000089C710015020060002D0B0000
   VCID: 76B6EF5798C598B7E3B-8022
   Component: WWS57X 150704  H37 0080
   Serial number:         150709085227
   Coding: 0045F7
   Serial number: 24094226
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 25 06 2015  00001061
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01FF2FF8
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA121235000014435890
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: CEB94BB7000000000001
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7E01010201
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
82688 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_TSK_FAIL]
                    Reset counter: 127
                    Mileage: 113063 km
                    Date: 2020.04.24
                    Time: 17:59:53
                    Control Module temperature: 72 °C
                    Voltage terminal 15: 13.991 V
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0002BA76
   Coding: 303331333131303134354A55304C34473853
   VCID: 3432155FCEB9CAA71DF-8060
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y150001C23V0M
   Serial number: 3575HRB404R3H46ABOBO
   Serial number: 3585HRB405T3C3S8D92K
   Serial number: 3515JRB401453400LHVW
   Serial number: 3525JRB405P3G5J4294$
   Serial number: 3554VRB405T3H6G4K09R
   Serial number: 3564VRB40693H6G4BH5D
   Revision: --------    Serial number: 90372OGN000F5
   Coding: 0000FC
   VCID: 37282253DF4F21BF38D-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 19 05 2015  F0042010
   Part No SW: 4G8 920 987 B    HW: 4G8 920 987 B
   Component: TBenUsaAcc    H10 0104
   Revision: 06001087    Serial number: 658210715596041
   Coding: 0BC601060F53D705020100
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 382A216FD2D12EC7317-806C
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001931276
   Coding: C0CD073010
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 3B203E63E3E705DFDC5-806E
   Serial number: 1088847103
   Voltage stabilizer:
   Serial number: 1505060000000000003C
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04018E64747464545425363E00
   VCID: 6788B213CF6F713F68D-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 22071500041011
   Coding: 20
   VCID: 3D24307BFDF30BEFE21-8068
   Revision: AA000000    Serial number: 00000157898455
   VCID: 77A8E2539FCFE1BFF8D-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8209X058
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 36362F57D8C5D8B723B-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H06 0060
   Serial number: 0374170948
   Coding: 040211
   VCID: 392C246BE9DB37CFCE9-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0060
   Serial number: 0373763352
   Coding: 040211
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F57035E00628002000413
   VCID: 45D4589B95A3432FBA1-8010
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0025982456
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0374671879
   Coding: 0126063A20BAF08580B00A0402030D470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000300633
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000EX2XA00000
   Coding: 101F02
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA121266000014399102
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93538078
   Component: TSG BF        H03 0507
   Coding: 011F57035E00628002000402
   VCID: 46D65F97A8A54837B3B-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001544800
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D04003B2D939B6F521-8078
   Coding: 05FA021122600400
   Coding: E02000
   Coding: E02000
   Part No SW: 4G1 035 025 K    HW: 4G1 035 025
   Component: MU-H-LNS-US   042 0143
   Serial number: A278G0F7507028
   Coding: 01750302FF0A000013220001041A00102F000CE5F1700104FE
   VCID: 2616FF170865A83793B-8072
   Subsystem 1 - Part No SW: V03 959 801 GE    HW: -----------
   Component: NAR 2016  --- 0048
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0006
   Serial number: AUZ8Z9FY8025ZL
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349OGH0007Y
   Compact Disc Database:
   Component: Gracenote2  --- 3006
          B11CF 53 [009] - Deactivated
                    Reset counter: 235
                    Mileage: 110742 km
                    Date: 2020.01.17
                    Time: 11:16:15
                    Voltage terminal 30: 14.6 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Audio Signal: Available
                    Satellite radio tuner status-Reception quality: optimum_signal
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Component: TSG HL        H03 0507
   Coding: 010F17024000628002000002
   VCID: 49CC54ABB9BBA74F5E9-801C
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0241563
   Coding: 0216000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   VCID: 2E0607372095E0776BB-807A
   Part No SW: 4G8 959 107 T    HW: 4G8 959 107 J
   Component: HDSG-Modul    H14 0049
   Revision: 12014001    Serial number: 193500959
   Coding: 0A3305C122
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 46D65F97A8254837B3B-8012
   Component: TSG HR        H03 0507
   Component: DPC-SG        H27 0081
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C020D3F1689926745F-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E01010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 2708F2130F6FB13FA8D-8072
          U1113 00 [008] - -
                    Reset counter: 127
                    Mileage: 113063 km
                    Date: 2020.04.24
                    Time: 17:59:53
                    Control Module temperature: 76 °C
                    Voltage terminal 15: 14.013 V
                    Velocity_vehicle_reference: -0.00 m/s
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000622107157
   Coding: 03C1B8180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313C1C4B31ABFF8F769-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323E134734ADC4970F3-8066
End----------(Elapsed Time: 02:31, VBatt start/end: 12.6V/12.1V)-----------
patrascul25
Romania
C?ID=374594
There seems to be a problem with the intake system (A gasket, hoseclamp or something like this...). The fuel/air mixture is not correct and the missfire detected and the increased idle rpm is high could be a consequence of this incorrect mixture (the engine draws more air than needed). The cooland temp of 104 celsius degrees is probably related to a low level for coolant (Coolant Pump for Intercooler P16BA 00 [096] - Running Dry). EVAP System is also reporting a leak but the two are related.
