DSG 7 speed DQ200 - Shift time measurment
andyb2004
C?ID=207725
My DSG seems slow to shift, it's as if both clutches are open for too long when changing up - I can hear the revs rise momentarily and the rev counter nudges up slightly.
Is it possible to measure the time between clutch operations?
Or maybe I could plot the engine RPM to show the spikes during shift, and therefore a) prove if there is an issue, b) get at least an idea of the shift delay.
Any pointers to get me started much appreciated :-) Thanks.
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum.
You must have read posts on here? If you have a problem/query you post a full AutoScan in between CODE tags [CODE] Full AutoScan [/CODE]
Yep, and Auto Scan would be handy here, since it would help identify the data that your transmission has available to be logged, and to see if maybe there's a clutch adaptation possible.
andyb2004
C?ID=207725
Ok, thanks - hopefully this is what's needed...
To add to the info - I already successfully completed the basic settings of the DSG including the driving sequence to complete the calibrations, but that didn't improve matters :(
The car is under warranty but the dealer doesn't agree that there is an issue seemingly based upon the lack of a fault code - they say that they have no justification to spend time on the vehicle.
I'm not saying they are wrong, but if I could show them some data, and better still collect a comparison from another car, that will hopefully convince them, or me, as the case may be.
Thanks again.
Chassis Type: 1T (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 52 56 61 62
          69 72 77
VIN: WVGZZZ1TZDW052692   Mileage: 57210km-35548miles
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PJ    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 1842
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00254014032500080000
   ASAM Dataset: EV_ECM16TDI02103L906023PJ 003004
   ROD: EV_ECM16TDI02103L906023NB_VW36.rod
   VCID: 7DDF13A8EC54ACC904D-8028
Address 02: Auto Trans        Labels: 0AM-927-769.lbl
   Part No SW: 0AM 300 058 S    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5270
   Revision: 00043014    Serial number: CU501210296255
   Shop #: WSC 62324 000 1048576
   VCID: 41A7AF58182C0829205-8014
   Revision: 00H31001
   Coding: 333B4016092706FCCC1102ED901B6081310150
   VCID: 7DDF13A8E454ACC904D-8028
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010004002
   ROD: EV_ACManueBHBVW36X_SE36.rod
   VCID: 7AD518B4FD7A9BF121F-802F
   Part No SW: 5K0 937 084 H    HW: 5K0 937 084 H
   Component: BCM PQ35 B    021 0068
   Revision: BA021001
   Coding: 48180A38E025F1E0408800C0140000644B518E08526DA160648042000040
   VCID: 3753C18086E846999E1-8062
   Subsystem 1 - Part No: 1T2 955 119 A
   Component: Wischer 05101  26  0512
   Coding: 009795
   Component: RLS 271012 05  54  0403
   Coding: 0630ED
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
Address 10: Park/Steer Assist
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 E    HW: 1T0 909 605 E
   Component: 02 AIRBAG VW8   022 0100
   Revision: 02022000    Serial number: 003K4D082JN6
   Coding: 0012338
   VCID: 3753C18046E846999E1-8062
   Subsystem 1 - Serial number: 6332QSME09255764D
   Subsystem 2 - Serial number: 6342QSME0925284CI
   Subsystem 3 - Serial number: 6352QSME05234B56D
   Subsystem 4 - Serial number: 6362QSME23255762A
   Revision: --------    Serial number:  90440LJD000YC
   Coding: 1882140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 76CD0C84C962FF91457-8023
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0326564
   Coding: 820000
   Part No SW: 1T0 920 975 C    HW: 1T0 920 975 C
   Component: KOMBI         H05 0705
   Coding: 181B00
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 3851C2BC83F649E197B-806D
   Part No: 7N0 963 271 E
   Component: Zuheizer        051 2940
   Revision: 00051000    Serial number: 09024297000000
   Coding: 0000011
   VCID: 364DCC8441E2BF91857-8063
   Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
   Component: J533  Gateway H53 1634
   Revision:   H53       Serial number: 271012F6000283
   Coding: 358003
   VCID: 75CF0B88DC64F4894CD-8020
Address 25: Immobilizer
   Revision: A1001003    Serial number: 7663744586
   Coding: 010100
   VCID: 2A75E8F4455AEB7111F-807F
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2122
   Coding: 0000693
   VCID: 48B1B27C3B163961E7B-801D
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 01324 785 00200
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000693
   VCID: 47B3B14036083619EE1-8012
   Part No SW: 1K0 035 186 AQ    HW: 1K0 035 186 AQ
   Component: Radio RCD310  004 0119
   Revision: 01000001    Serial number: VWZ1Z2M9675630
   Coding: 01000400040009
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
   Component: Batt.regelung H53 1634
   Coding: 01040859
   VCID: 71C73F98A80CD8A9905-8024
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2104
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 3245F094AD8AA3B1A9F-8067
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Revision: 3A001001    Serial number: 00008030512272
   Coding: 0100000100000000
   VCID: 3041FA9C638691A1DFB-8065
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 334BF5905290AAB9A29-8066
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007663705544
   Coding: 0A11000000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3957C7B8B8FC50E9685-806C
OK, that's a straightforward (non-UDS!) transmission still. Have a look at MVB 005 and 006 for all the speeds. It should be straightforward to log these as you drive. There's also detailed data bout the clutches, for clutch 1 its in MVB 090-099 and for clutch 2, it's in 110-119.
andyb2004
C?ID=207725
Thanks for the pointers - I'm away for a week or so now, but I'll look at this as soon as I can and report back...
