2013 Audi A6
Simic S
Serbia
C?ID=397349
MMI update maps 2020
Saturday,25,April,2020,14:05:34:31636
VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4513.4
VIN: WAUZZZ4G6DN134302   License Plate:
Mileage: 178110km-110672mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 30 3B 42 44 46 52 53 55 5F
          62 72 8F 90
VIN: WAUZZZ4G6DN134302   Mileage: 178110km-110672miles
3B-Sensor Elect. -- Status: Malfunction 0010
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 0A034012242401080000
   Shop #: WSC 57020 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
   ROD: EV_ECM20TDI01103L906018HA.rod
   VCID: 75B7E75E55468FE370D-8020
          U1113 00 [032] - -
          U1113 00 [032] - -
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 4G2 927 155 D    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000000339
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMVL381 A02432
   ROD: EV_TCMVL381.rod
   VCID: 2E050832F090FC3BF17-807A
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 06A187016085E180DB00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 3635205208C0C4FBB97-8062
   Part No SW: 4H0 907 064 CN    HW: 4H0 907 064 CN
   Component: BCM2 2.0      H33 0433
   Coding: 01A83046000000000000
   VCID: 77ABED564FCAFDF3621-8022
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 AB    HW: 4G0 820 043 AB
   Component: KLIMA 2 ZONEN H11 0086
   Serial number: 16031300110761
   Coding: 34010008A1
   ASAM Dataset: EV_AirCondiBasisUDS 002044
   ROD: EV_AirCondiBasisUDS_002.rod
   VCID: 5F9BA5F6C7BA25B30A1-800A
   Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
   Revision: 19012002    Serial number: 00000001699334
   Coding: 2600201040349FE08181008000001D0C0F9CC30A26090201000004606101
   VCID: 6D87CF3E3D96472388D-8038
   Component: WWS57X 130313  H36 0080
   Serial number:         130315063401
   Coding: 0045F7
   Serial number: 21123961
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 15 03 2013  00000224
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: CCA88C96000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061308000703
   Coding: 08C305
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD34E212EA3C3AC5-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00CDW2B
   Coding: 30323436313230303039554A304C34473053
   Serial number: 3575HRB400450F5MGHC3
   Serial number: 3585HRB400850FBCBH0U
   Serial number: 3515JRB400E50FSQ69DJ
   Serial number: 3525JRB400850G4GJA8X
   Serial number: 3554VRB400S50EGOQHLQ
   Serial number: 3564VRB401G50EGOO10K
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20130322000309
   Coding: 000014
   VCID: 3039164AEA24EACBE3B-8064
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
00576 - Terminal 15
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:01
   Part No SW: 4G8 920 900 J    HW: 4G8 920 900 J
   Component: MDieRdw       H34 0306
   Revision: 26450232    Serial number: 658140313592008
   Coding: 13A608000B4100080D0000
   ASAM Dataset: EV_RBC7KMID 004045
   ROD: EV_RBC7KMID.rod
   VCID: 313F134EE1AEE3C3EC5-8064
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000871073
   Coding: 00CD074400
   ASAM Dataset: EV_GatewPkoUDS 001018
   Serial number: 9066060203
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 130119000000000004A5
8 Faults Found:
4230 - No Communications with Steering Angle Sender (G85)
          U0126 00 [008] - -
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:01
                    Voltage terminal 30: 12.0 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 25 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
4160 - No Communications with Airbag Control Module
          U0151 00 [008] - -
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:01
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5013 - Headlight Range Control Module
          U101E 00 [008] - No Communication
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:01
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5271 - No Communications with Parking Assist Control Module A
          U0159 00 [008] - -
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:00
                    Voltage terminal 30: 12.1 V
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
4228 - No Communication with ABS Brake Control Module
          U0121 00 [008] - -
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:01
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
5080 - Front Left belt tensioner control module
          U107C 00 [008] - No communication
          [Steuergerät für RGS Links Keine Kommunikation]
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:01
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5081 - Front Right belt tensioner control module
          U107D 00 [008] - No communication
          [Steuergerät für RGS Rechts Keine Kommunikation]
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:01
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0259 - Extended CAN Bus (SAE Bus C)
          U0047 00 [008] - Performance
          [Vehicle Communication Bus C Bus Performance]
                    Reset counter: 180
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:01
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000040564
   Coding: 01010101000000000001000203
   VCID: 6491AA1AEE5C066BD73-8030
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA8202YMT5
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
3801600 - Terminal 15
          U1405 00 [008] - Implausible signal
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:01
                    DCU_Internal_DTC: 3A 02 00
                    Ignition Cycle Count: 16738
                    DCU Temperature: 20 °C
                    Voltage terminal 30: 11.9 V
                    Voltage VBG 22: 2.5 V
                    Debug Data: 00 00 00 00 00 00 00 00
   Component: TSG FA        H03 0507
   Coding: 011C17004020628002080002
   VCID: 47CB5D967FAA4D73D21-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0008322465
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1C42E4A8D8DB95F-8066
   Revision: 00002001    Serial number: 0303309861
   Coding: 011A063800B908008320080408010E0F0000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Fault Status: 00101011
                    Fault Frequency: 15
                    Reset counter: 195
                    Mileage: 174736 km
                    Date: 2019.10.19
                    Time: 21:43:53
03026 - Enabling Terminal 15:
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:02
00165 - Switch for Transmission Position P/N
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:02
                    Reset counter: 192
                    Mileage: 177020 km
                    Date: 2020.02.17
                    Time: 18:10:53
03725 - Control Module for Seat Belt Tensioner; Left Front
                    Reset counter: 192
                    Mileage: 177020 km
                    Date: 2020.02.17
                    Time: 18:10:53
   Component: TSG BF        H03 0507
   VCID: 46D5509278A0547B297-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000631022
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B030126C3828913D69-807E
10613248 - Terminal 15
          [FC_IGNITION_CROSS_CHECK_FAULT]
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:01
                    Voltage terminal 30: 12.2 V
                    Internal Fault ID: 44
                    Network management state: Ready for busstat
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: No enabling
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
333312 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
          [FC_AIRBAG_02_MESSAGE_TIMEOUT]
459776 - Function Restriction due to Faults in Other Modules
          U1113 00 [000] - -
          [FC_SIGNAL_ESP_FR_RADGESCHW_ERROR_VALUE]
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 195
                    Mileage: 176019 km
                    Date: 2019.12.15
                    Time: 15:33:02
                    Internal Fault ID: 188
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Internal Parking Brake state: static
465152 - Function Restriction due to Faults in Other Modules
          U1113 00 [000] - -
          [FC_SIGNAL_DI_KL58D_ERROR_VALUE]
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 130321-0002-121
   Coding: 112196101002A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D070F3EFD968723C8D-8078
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G0 035 193 F    HW: 4G0 035 193 D
   Component: RMC Cnct Nav  H54 0801
   Coding: 0100000001415B47482B060301010000010000
   VCID: 2615F012D8E0B47B097-8072
   Subsystem 1 - Part No: 8X0 919 884 E
   Component: P18-50-12.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 A    HW: 4G0 919 603 A
   Component: DU6 Basic  H43 0084
   Serial number: 9464CM0D2580020
   Subsystem 3 - Part No SW: 4G1 919 610 B    HW: 4G1 919 610 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MCK000VN
   Component: TSG HL        H03 0507
   Coding: 010815004020628002080002
   VCID: 49CF5BAE69BEBB03C45-801C
   Component: TSG HR        H03 0507
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
End----(Elapsed Time: 01:42, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
