TPMS via ABS activation VW Polo 2019
joaofrigotto
Brazil
C?ID=370491
I´m trying to activate the indirect TPMS (via ABS sensors) on my VW Polo 2019.
I was able to activate it in module 17 and module 5F (multimedia), but still missing module 03 ABS coding.
It has no long coding information. Find above an auto scan of the module.
Can someone help me?
> Address 03: ABS Brakes (J104) Labels: Redir Fail!
> Part No SW: 2Q0 614 517 AB HW: 2Q0 614 517 L
> Component: ESC_base H13 0223
> Serial number: 86403954180524
> Coding: 33044C673747CCB432FCEC1E14DC126A49444D26226A242444541254452848569222B26444562424222A482AA229344004942C0220
> Shop #: WSC 01530 935 00200
> ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
> ROD: EV_Brake1BOSCHESPMQBA0_004.rod
> VCID: 6E85CF587011680BB1E-803A
> No fault code found.
joaofrigotto
Brazil
C?ID=370491
Here´s the full auto scan:
Chassis Type: BZ-VW27 (2QW)
Scan: 01 02 03 08 09 10 15 17 19 44 5F
VIN: 9BWAH5BZ3KP5XXXXX   Mileage: 21742km-13509miles
Address 01: Engine (J623-DHSB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 BT    HW: 04C 907 309 AH
   Component: R3 1.0l TFS   H21 5244
   Revision: WVH21---
   Coding: 011A0012230400000000
   ASAM Dataset: EV_ECM10TFS01104C906026BT 001002
   ROD: EV_ECM10TFS01104C906026BT.rod
   VCID: 74B1DD301E3D42DB47A-8020
   CAN Converter 01:
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [032] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 21659 km
                    Date: 2020.04.17
                    Time: 13:33:11
                    Engine speed: 0.00 /min
                    Coolant temperature: 16 °C
                    Intake air temperature: 18 °C
                    Ambient air pressure: 910 mbar
                    Voltage terminal 30: 12.109 V
                    Unlearning counter according OBD: 35
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
4714 - Steering Column Control Module
          U0212 00 [032] - No Communications
                    Mileage: 21659 km
                    Voltage terminal 30: 12.015 V
                    Outside air temperature: 215 °C
                    Absolute intake pressure: 92 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 47.9 l
                    Oxygen sensor bank 1 sensor 1: specified value: 11.3462
                    Engine operating condition: Idling
   Part No SW: 09G 927 158 CL    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3409
   Coding: 0000000000000000010000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW27.rod
   VCID: 7F5B021C277B11832A8-802A
   Part No SW: 6EA 820 045 A    HW: 6EA 820 045 A
   Component: SG_AC_Manuell H50 0301
   Coding: 012000000400000000000000020000000000000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001011
   ROD: EV_ACManuePrehMQBA0_VW27.rod
   VCID: 30391120AAA53EFBE32-8064
   Part No SW: 2QW 937 090     HW: 2QW 937 090
   Component: BCM A0 Entry  H65 0612
   Serial number: 20118160003701
   ASAM Dataset: EV_BCMA0 104001
   ROD: EV_BCMA0_104.rod
   VCID: 1675C7B82801F0CB99E-8042
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 2Q3 959 881 A    HW: 2Q3 959 881 A
   Component: FHSG_DRV  001 0005
   Serial number: 08644209170507180625
   Coding: 038008
   Subsystem 2 - Part No SW: 2Q3 959 882 A    HW: 2Q3 959 882 A
   Component: FHSG_PSG  001 0004
   Serial number: 08644219682907181403
   Coding: 098008
   Subsystem 3 - Part No SW: 6EA 951 171     HW: 6EA 951 171
   Component: Sensor, DWA  006 0109
   Serial number:  2FL0091402RIQ000KIS
   Subsystem 4 - Part No SW: 2Q0 959 811 A    HW: 2Q0 959 811 A
   Component: FOND_FHSG_DRV  001 0004
   Serial number: 08644203100206180511
   Coding: 030008
   Subsystem 5 - Part No SW: 2Q0 959 812 A    HW: 2Q0 959 812 A
   Component: FOND_FHSG_PSG  001 0004
   Serial number: 08644218281905182113
   Coding: 0B0008
   Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0056
   Revision: --------    Serial number: 55301826045931
   Coding: 0001150011
   ROD: EV_EPHVA14AU3700000_002_VW27.rod
   VCID: 3D2738146DF7C393784-8068
   Part No SW: 2QB 959 655 B    HW: 2QB 959 655 B
   Component: VW22Airbag    010 0248
   Revision: --------
   Coding: 88C0C00000000000540000CF000000000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X_VW27.rod
   VCID: 4EC56FD8D051480B91E-801A
   Subsystem 1 - Part No SW: -----------    HW: 442 1A1 108 18
   Component: SideSensor_Df  2C4 0148
   Serial number: 349B4D2B72B63FB661D9
   Subsystem 2 - Part No SW: -----------    HW: 442 1A1 108 18
   Component: SideSensor_Pf  2C4 0148
   Serial number: 350B4D1B72B63FB2E36%
   Subsystem 3 - Part No SW: -----------    HW: 442 132 605 18
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11BD29B6A72D7FI
   Part No SW: 6EA 920 740 C    HW: 6EA 920 740 C
   Component: KOMBI         310 2600
   Coding: 042D02082000000C020836001001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001034
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 3537203455C71BD3B04-8060
16776980 - Databus
          [PLA_Status keine Kommunikation]
                    Reset counter: 81
                    Mileage: 21742 km
                    Date: 2020.04.23
                    Time: 10:41:58
   Part No SW: 2QW 909 901     HW: 2QW 937 090
   Component: GW MQB A0     H65 0612
   Coding: 0101000020085600F80000081C0F00000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0_VW27.rod
   Subsystem 2 - Part No SW: 18D 959 442     HW: 18D 959 442
   Component: E221__MFL-YLG  H01 0120
   Serial number: 000000000A0099160418
   Coding: 200000
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 610 6030
   Serial number: 02I2K1H6CB4J214
   Coding: 00000001000000000101020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 392F2C0479DFFFB354C-806C
   Part No SW: 5G0 035 280 C    HW: 5G0 035 280 C
   Component: MU-G--RW      557 5518
   Serial number: VWZ7Z2U0650048
   Coding: 02721000BE0000000022000101000000AF0203140000010003
   ASAM Dataset: EV_MUGlb4CGen25TPWR 001001
   ROD: EV_MUGlb4CGen25TPWR_VW27.rod
   VCID: 211FE464F14F87737CC-8074
joaofrigotto
Brazil
C?ID=370491
Does anyone know what bites in witch byte should I change?
ho8882000
Cape Town, South Africa
C?ID=372981
I saw the following TMPS via ABS coding method on a German forum (I use Google Translate to translate it into English.), but please make a backup of your original coding and adaptation before trying this:
Tire pressure control indicator (direct, TPMS) - Activation/activation
STG 19 > Activate the construction list > "65 - tyre pressure"
STG 03 > Coding > ...
                             > Disable bytes 27 > Bit 4, 5 and 6
                             > Byte 28 > Disable Bit 7
STG 17 > Coding > ...
                             > Activate byte 03 > Bit 7 ("Tire pressure control,yes")
                            > Disable byte 04 > Bit 0 ("Tire control indicator,yes")
                            > Byte 11 > Activate bit 2 ("Tire pressure control: BAP track,yes")
STG 5F > Adjustment > ...
                                    > Channel "Vehicle Function List BAP-tire_pressure_system_0x07" > Set value to "Activated"
                                    > Channel "Vehicle Function List BAP-tire_pressure_system_0x07_msg_bus" > Set value to "Data Bus Extended"
STG 65 > Zugriffsberechtigung: 20103
             > Channel "Sensor identification number write wheel position" > Set value to "Back right"
After completion of the coding, parameters for the tire pressures still have to be generated and uploaded with VCP or similar. The TPMS tool can be used by jolt to create the parameters.
When re-posting something like that, please include a link to the original source.
Mari
C?ID=150535
@ho8882000 what you have found is for direct TPMS, not for indirect TPMS... TopicStarter does not have module 65, so this method will not work for him!
On the website MyTurboDiesel.Com you can find information over activating indirect TPMS for MK6, maybe the part of coding ABS will work...
https://www.myturbodiesel.com/pages/tdi-wiki/ search for the page: TPMS activation, reset, and disable coding with VCDS - mk6 VW
ho8882000
C?ID=372981
Sorry, my bad.
The follow is the correct method for TPMS via ABS (Indirect):
Tire pressure control indicator(indirect, via ABS) - Activation/activation (retrofitting)
                             > Byte 27 > Enable Bit 5
                             > Byte 28 > Enable Bit 7
                                    > Set channel "Vehicle function list BAP-tire_pressure_system_0x07" > Value to "active"
                                    > Channel "Vehicle function list BAP-tire_pressure_system_0x07_msg_bus" > Set value to "Suspension data bus"
                                    > Channel "Vehicle menu operationmenu_display_rdk" > Set value to "active"
                                    > Channel "Vehicle menu operationmenu_display_rdk_over_treshold_high" > Value set to "active"
STG 17 > Coding > Byte 04 > Activate Bit 0 ("Indirect Tire Pressure Control System (TPMS)")
And I found the above information from the following link:
https://onedrive.live.com/view.aspx...t=file,docx&app=Word&authkey=!ACw9SCZllyg95KU
