Lots of dash lights - 9682162 - Multiple collision brake?
Rob-S
C?ID=397111
Hi guys,
Can anyone assist?
I picked up a series of dash lights right after starting the car and moving out of the drive. The car is now also in limp mode and a P0237 manifold pressure sensor signal too low, the reading looks OK when I am looking at the channel.
The one fault that seems to be sticking around is with the 9682162 - Multiple collision brake fault B13BC.
Any assistance is greatly appreciated!!
Friday,24,April,2020,13:35:53:13744
VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G7GN037730   License Plate:
Mileage: 135755km-84354mi   Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 5F 62 69 6D
          72 AC
VIN: WAUZZZ4G7GN037730   Mileage: 135755km-84354miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FR    HW: 04L 907 309
   Component: R4 2,0L EDC   X23 0745
   Revision: 85X23---
   Coding: 12194012243401080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01104L906021FR 002003
   ROD: EV_ECM20TDI01104L906021FR_002.rod
   VCID: 7AADF46A1C5C02DB1DF-802E
          U1113 00 [038] - -
                    Mileage: 135755 km
                    Date: 2020.04.24
                    Time: 13:29:58
                    Engine speed: 0.00 /min
                    Coolant temperature: 86 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 12.580 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
5170 - Manifold Pressure / Boost Sensor (G31)
          P0237 00 [175] - Signal too Low
                    Mileage: 135752 km
                    Date: 2020.04.24
                    Time: 13:14:22
                    Engine speed: 830.50 /min
                    Normed load value: 49.4 %
                    Coolant temperature: 77 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 14.700 V
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 368.8 hPa
                    Engine status: COENG_RUNNING
Readiness: 1 1 0 0 1
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 06A09E4160057982BB00
   Shop #: WSC 02391 785 00200
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF4386310A91031C5-8014
201472 - Function Restriction due to Implausible Message(s)
          U1112 00 [046] - -
          [SCL_MO_Motormomente_Invalid]
                    Mileage: 135755 km
                    Date: 2020.04.24
                    Time: 13:29:58
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    Uz: A1
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Component: BCM2 2.0      H37 0572
   Coding: 03B9704E000000000000
   VCID: 7BA3F16E13E63BD3069-802E
   Serial number: 3215000088310012
   Part No SW: 4G0 820 043 CC    HW: 4G0 820 043 CC
   Serial number: 02061500040950
   Coding: 34220978210000
   VCID: 629DAC0A94CCEA1B25F-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001094742501
   Coding: 2600801401349F600481408000001D0C4F9DA60827090201000008206100140200400024030000
   VCID: 71BFD34641AA4183AC5-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150509  H37 0080
   Serial number:         150527062234
   Coding: 0045F7
   Serial number: 24012464
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 09 06 2015  00000077
   Serial number: E55841B7000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P10054N8Q
   Coding: 30333130313630323639554A305234473053
   VCID: 3B23316E53E6FBD3469-806E
   Serial number: 3575HRB40652UI66CHJS
   Serial number: 3585HRB40573AVPA89T2
   Serial number: 3515JRB401854SRG89U$
   Serial number: 3525JRB400O54SDQLH21
   Serial number: 3554VRB40673D7U8J04F
   Serial number: 3564VRB405P3D7UAB0L1
          B13BC F2 [137] - No function
                    Mileage: 135755 km
                    Date: 2020.04.24
                    Time: 13:31:42
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862OF9001O6
   Coding: 000015
   VCID: 3B23316E5366FBD3469-806E
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
   Serial number: 19 05 2015  B0043459
   Part No SW: 4G8 920 951 E    HW: 4G8 920 951 E
   Component: MDieGb        H43 0604
   Revision: 29450306    Serial number: 658120615592022
   Coding: 23A512000B412600010000
   ASAM Dataset: EV_RBC7KMID 004050
   ROD: EV_RBC7KMID.rod
   VCID: 323D1C4A84AC3A9B95F-8066
   Part No SW: 4G5 907 468 E    HW: 4G5 907 468 C
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001879873
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 372B2D5E6FCEDFB3A21-8062
   Serial number: 6999776803
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 150330000000000003A6
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 13061500040088
   Coding: 22
   VCID: 3D273F764DF2F5E378D-8068
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720J1PPU
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3333194E7BB633939E9-8066
   Component: TSG FA        H03 0507
   Coding: 011C16014401620002080002
   VCID: 47CB5D9E1FAEAF33D21-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0028869791
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 392F2B6659DAC9C3545-806C
   Revision: 00002001    Serial number: 0371201785
   Coding: 013B0622A0B930408320090420010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Component: TSG BF        H03 0507
   VCID: 46D5509A18A4B63B297-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001502654
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070F369D926563C8D-8078
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 147
                    Mileage: 135751 km
                    Date: 2020.04.24
                    Time: 11:49:23
                    Voltage terminal 30: 12.3 V
                    Internal Fault ID: 188
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 192 A    HW: 4G1 035 192 A
   Component: RMC Nav Plus  H61 0139
   Coding: 0101010001415B47083B060301010000000000
   VCID: 211FE306D1CAB1037C5-8074
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464E.0F2717281
   Subsystem 3 - Part No SW: 4G2 919 710 E    HW: 4G2 919 710 E
   Serial number: 90349OED000KI
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49CF5BA609BA5943C45-801C
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001002    Serial number: 0371702786
   Coding: 0100000202000000
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 149501059
   Coding: 093205C011
   ROD: EV_HDSGAu571.rod
   VCID: 3635205A68C426BBB97-8062
   Component: TSG HR        H03 0507
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 151450406
   ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 01:47, VBatt start/end: 13.3V/14.3V)-----------
Strange. Those faults seem like they should be unrelated. I'm not sure what to make of this.
Rob-S
C?ID=397111
Any ideas what the multiple collision brake fault could be linked to? I also have tyre pressure, seat belt, ESP faults that I can understand being linked in some way.
Rob-S
C?ID=397111
Just found the first scan, it didn't have the collision fault.
Maybe you could find something here -:)
Tuesday,21,April,2020,18:53:28:13744
Mileage: 135749km-84350mi   Repair Order:
          72 AC
VIN: WAUZZZ4G7GN037730   Mileage: 135749km-84350miles
   Revision: 85X23---
          U1113 00 [038] - -
                    Mileage: 135749 km
                    Date: 2020.04.21
                    Time: 18:40:39
                    Coolant temperature: 32 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 13.300 V
                    Cruise Control System (CCS): status-Bits 0-7: 44
          P0237 00 [167] - Signal too Low
                    Mileage: 135749 km
                    Date: 2020.04.21
                    Time: 18:40:25
                    Engine speed: 1330.50 /min
                    Normed load value: 99.2 %
                    Coolant temperature: 30 °C
                    Voltage terminal 30: 14.620 V
          U1112 00 [046] - -
                    Mileage: 135749 km
                    Date: 2020.04.21
                    Time: 18:40:39
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    Uz: AA
   Coding: 0045F7
   Coding: 02006D
   Coding: 000015
   Coding: C0CD074418
   Voltage stabilizer:
   Coding: 22
   ROD: EV_SARA2.rod
          U1113 00 [008] - -
                    Reset counter: 146
                    Mileage: 135749 km
                    Date: 2020.04.21
                    Time: 18:40:39
                    Voltage terminal 30: 13.3 V
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Coding: 093205C011
End----------(Elapsed Time: 01:42, VBatt start/end: 14.7V/14.7V)-----------
