RS3 8v exhaust flaps not working
iPerformance
HC?ID=393147
Good morning all,
Customer came in today with exhaust flaps not working, fuses checked all were good, connectors plugged and no errors. Could somebody please check if anything doesn't check out?
Friday,24,April,2020,11:26:51:12448
Dealer/Shop Name: Garage R&S
Workshop Code: 070 00258 002525
VIN: WUAZZZ8V8GA902789   License Plate: SP630G
Mileage: 98984km-61505mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
          5F 6C A5 BB BC
VIN: WUAZZZ8V8GA902789   Mileage: 98984km-61505miles
Address 01: Engine (------CZGB)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404     HW: 07K 907 309 C
   Component: 2.5l R5/4V TF H52 0004
   Revision: NKH52---
   Coding: 12250032256601033620
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM25TFS0118V0907404 001007
   ROD: EV_ECM25TFS0118V0907404.rod
   VCID: 76B41C79D84437BB79E-8022
Readiness: 1110 0001
   Part No SW: 0DL 300 043 T    HW: 0BH 927 711 F
   Component: TVS DQ500     H10 5299
   Revision: 00H10V01
   Coding: 0018
   VCID: 3E24C459B0F4BFFB61E-806A
   Part No SW: 8V0 907 379     HW: 8V0 907 379
   Component: ESC           H42 0020
   Revision: 00000000    Serial number: 62475000000634
   Coding: 999CF08DAA9915AB4098096CC39AB20EC4990F55A80290C34D7023
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061003
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 015E7FA5818A00035CC-8054
   Revision: 00021000    Serial number: 0381077321
   Coding: 000C0C
   VCID: 3A2CC849ACDC93DB5D6-806E
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000742778
   Coding: 03000015000000001000000000001000
   VCID: 3332E56D8BB662939E0-8066
   Serial number: B7988AC7000000000001
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061526700598
   Coding: 04151D46C24106FD03844004B31C07A80800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094E6785B9BA484304C-805C
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150716  042 0580
   Serial number:         150909095513
   Coding: 0A47F7
   Serial number: 20695199
   Coding: 00006C
   Serial number: 11 07 2015  00000855
   Serial number: 000000000ZY1522904EV
   Serial number: 00000000000063774510
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000JDNP800000
   Coding: 901F00
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 177
                    Mileage: 98984 km
                    Date: 2020.04.24
                    Time: 08:33:50
   Revision: --------    Serial number: 39331527108983
   Coding: 0070150011
   VCID: 43D2B5ADDB16D2130E0-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 P    HW: 5Q0 907 567 P
   Component: ACC3          H10 0100
   Serial number: 06041603073241
   Coding: 003E1701FE0309
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 48C8A281E230F14BDB2-801C
1067 - Brake Temperature
          C10DF 00 [040] - -
                    Reset counter: 212
                    Mileage: 98614 km
                    Date: 2020.04.22
                    Time: 19:20:08
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 14.7 V
                    Vehicle speed: 32.42 m/s
                    Acceleration: -2.67 m/s²
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       230915042
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    012 0364
   Serial number: 003M1R124T9C
   Coding: 98CCC000008000005C540000004800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 4ACC9889FC3C035BCD6-801E
   Belt Pretensioner left:
   Serial number: 34215161A01091590705
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34215160A21071510448
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 409 15
   Serial number: 35767000000268FCE616
   Subsystem 4 - Part No SW: -----------    HW: 480 002 409 15
   Serial number: 35867000000168FCE616
   Subsystem 5 - Part No SW: -----------    HW: 480 402 309 15
   Serial number: 3516502B31CF2D7491DR
   Subsystem 6 - Part No SW: -----------    HW: 480 402 309 15
   Serial number: 3526502C71D25F73C0FT
   Subsystem 7 - Part No SW: -----------    HW: 480 403 108 15
   Serial number: 3556502BD1CB0C0530CK
   Part No SW: 8V0 953 521 GK    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 26091504401031
   Coding: EC18
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   Part No SW: 8V0 920 871 L    HW: 8V0 920 871 L
   Component: KOMBI         H02 6420
   Coding: 038D081A7F8C00080084EA001000000000000000
   VCID: 45D6ABB5D522EC23204-8010
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1224
   Revision: --------    Serial number: 0003947344
   Coding: 030100043F0860005B00027CB80B00000001010000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75B61B75C5423CA3704-8020
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 10 09 2015  B0022022
   Subsystem 3 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 6360867803
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7754
   Serial number: HA1-00009.06.15
   Coding: 0601
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   Revision: 00000000    Serial number: 15000215288002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3430E6718EB865AB87A-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Component: SWA Master    H05 0080
   Serial number: 0380016394
   Coding: 030311
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3828D24192D081CBAB2-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0080
   Serial number: 0379372874
   Coding: 030311
   Serial number: 080915BI601376
   Coding: 005D1A205C00048000001003
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 9103
   VCID: 392ED745A9DA98C354C-806C
   Serial number: 030915BI306828
   Coding: 005D12205E00048000001003
   VCID: 42DCB0A9C40CDB1B056-8016
   Component: AFS-ECU       H01 0110
   Coding: 01A200002B230200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FDAB95DB7FEB6F36A8-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 036 E    HW: 8V0 035 036 B
   Component: MU-H-LND-EU   H45 0397
   Serial number: A300I0F7553450
   Coding: 017303010000000021111102000A00132F000325010001009E
   ROD: EV_MUHig6C3HBAS_VW48.rod
   Subsystem 1 - Part No SW: V03 959 800 Q    HW: -----------
   Component: ECE 2015/2016  --- 0122
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY2040LE
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000013071500010196
   Compact Disc Database:
   Component: Gracenote  --- 1010
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 3038EA617AA0598BE32-8064
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000429624
   Coding: 0101010001010303000500010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C20CE51A6E8ADEB4FA-8068
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 210815BHK17403
   Coding: 004D12204000048000001002
   Serial number: 210815BHK17405
End----------(Elapsed Time: 01:50, VBatt start/end: 12.1V/12.2V)-----------
Thanks in advance
South Molton, UK
Are the exhaust flaps electrically or vacuum operated?
On the B7 RS4 they were vacuum operated ...
iPerformance
HC?ID=393147
Electrically, can’t find anything about them in the engine coding. According to the adv. measurement values they’re off and 136 (which apparently means that the valves are closed) but when I cycle trough the drive modes they stay open
United States
This is commented out of the label, likely because it isn't verified, but try turning on byte 9, bit 2:
;LC,09,2,Exhaust Flap(s) installed
I don't have any info for 9/5 (which is enabled) .. but my guess its that bit should stay on/enabled since we don't know what it does.
