2017 A3 DPF issue
colin41
C?ID=242997
Currently looking at a 2017 A3 with DPF issues. ive tried static and driving regens but neither raise the exhaust temp enough. sensor 1 rises to about 400-450C then falls again soon after reaching that temp.
Thursday,23,April,2020,20:45:42:58568
VIN: WAUZZZ8VXHA041210   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 29 39 42 44 52 55 5F BB BC D6 D7
VIN: WAUZZZ8VXHA041210   Mileage: 34459km-21411miles
Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 D    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 2510
   Revision: 22004001
   Coding: 02194012432501092000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM16TDI03004L906056D 002006
   ROD: EV_ECM16TDI03004L906056_002_VW37.rod
   VCID: 2E04F75B509909FBF1E-807A
23902 - Diesel Particle Filter
          P2463 00 [163] - Excessive Soot Accumulation
                    Mileage: 34459 km
                    Date: 2020.04.23
                    Time: 20:35:04
                    Engine speed: 0.00 /min
                    Coolant temperature: 77 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 12.687 V
                    Zähler der Regenerationszeit des Partikelfilters: 10801 s
                    Particle filter: kilometers since last regeneration: 1201.5
                    Particle filter: soot mass measured: 1.45 g
                    Particle filter: soot mass calculated: 54.11 g
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 9.0 mbar
                    Particle filter: field regeneration lock status: 0
23967 - Diesel Particulate Filter
          P2458 00 [163] - Regeneration Duration
                    Mileage: 34459 km
                    Date: 2020.04.23
                    Time: 20:35:04
                    Voltage terminal 30: 12.671 V
                    Particle filter: field regeneration lock status: 227
Readiness: N/A
   Part No SW: 5Q0 614 517 AR    HW: 5Q0 614 517 AG
   Component: ESC           H62 0642
   Revision: 00000000    Serial number: 62296000002885
   Coding: 12F18AA224240A6D49790E0140C32548512450927002A472024100788008420000000012121212B835351919323200
   VCID: 015E7CE7B18746835CC-8054
   Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001013586
   Coding: 03100104002000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 3C20CD1396E5EB6B4FA-8068
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 0459044800PAG0MUFU03
328963 - Motor for Front Air Distribution Flap
          B1091 13 [008] - Open Circuit
                    Reset counter: 86
                    Mileage: 33493 km
                    Date: 2020.03.13
                    Time: 12:53:13
                    Voltage terminal 30: 14.0 V
                    Interior temperature: 23.8 °C
                    Outside air temperature: 11 °C
                    Front air distribution flap: actual value: 0
                    Front air distribution flap: actual value: 97.0 %
                    Front air distribution flap: specified value: 103
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001623101154
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA4071BC079397B21E-802A
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160809  043 0580
   Serial number:         160816094131
   Coding: 0A47F7
   Serial number: 62158394
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Serial number: 30 06 2016  00001350
   Serial number: 000000000ZY16202123L
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066831176
   Part No SW: 5QA 919 283     HW: 5QA 919 283
   Component: PDC 4 KanalH07 0031
   Serial number: 000308419616217
   Coding: 0700040001
   ASAM Dataset: EV_EPHVA14AU3700000 009027
   ROD: EV_EPHVA14AU3700000_009_AU37.rod
   VCID: 074A62FF9FA378B3128-8052
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0315
   Serial number: 003TDR21WXFQ
   Coding: 98CCC0000C0000005C5400CA00C800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 107849A3EAED3F0BC32-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 001 908 16
   Serial number: 35700000000F0260FD1O
   Subsystem 2 - Part No SW: -----------    HW: 480 001 908 16
   Serial number: 35800000000112B0CD1E
   Subsystem 3 - Part No SW: -----------    HW: 480 402 208 16
   Serial number: 3510001C921DBA054742
   Subsystem 4 - Part No SW: -----------    HW: 480 402 208 16
   Serial number: 3520001C921DBA0492EC
   Subsystem 5 - Part No SW: -----------    HW: 480 402 507 16
   Serial number: 35500029D211FA33B322
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 908 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001C121DBA0481C2
   Subsystem 7 - Part No SW: -----------    HW: 480 401 908 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001BB21A81F51755
   Subsystem 8 - Part No SW: -----------    HW: 480 003 007 16
   Serial number: I0M00000000BAB1D6D1K
   Subsystem 9 - Part No SW: -----------    HW: 480 003 007 16
   Serial number: I0N00000000226B80D1+
   Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 08081604400567
   Coding: A408
   ROD: EV_SMLSKLOMQB_019_AU37.rod
   Part No SW: 8V0 920 972 L    HW: 8V0 920 972 L
   Component: KOMBI         H04 8316
   Coding: 27A40A002B8026000100E8001001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   VCID: 47CAA2FFDF23B8B3D28-8012
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 98
                    Mileage: 33461 km
                    Date: 2020.03.12
                    Time: 13:32:00
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 103
                    Mileage: 33499 km
                    Date: 2020.03.13
                    Time: 15:36:13
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 13081610800295
   Coding: 030100041F0873005B000248080B00000001010000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA00D13D6652B6B0FA-8028
   Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
   Component: J453 MFL  H04 0003
   Serial number: 20160804122003 00253
   Serial number: 75410803001608171360
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0016
   ASAM Dataset: EV_LCMLeftCONTIAU426 001008
   VCID: 42DCB3EBF4019D9B056-8016
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   ASAM Dataset: EV_LCMRightCONTIAU426 001008
   Serial number: 300716EGT04156
   Coding: 001C8A204001040000001002
   VCID: 43D2B6EFEB1B94930E0-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D6A8F7E52FAAA3204-8010
   Serial number: 060816EH504277
   Coding: 001C82204001040000001002
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0ECE00102B230200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E24C71B80F9F97B61E-806A
   Part No SW: 81A 035 192     HW: 81A 035 192
   Component: MU-HS-LND-EU  045 0148
   Coding: 01730301FF00000011111101000A00102F002AC601F00100CE
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 5EE4679B60B9D97B01E-800A
   Subsystem 1 - Part No SW: 8W0 919 866 C    HW: -----------
   Component: ECE 2016  --- 0009
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY20797C
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL119051600010479
2562 - Navigation System
          B126C F0 [008] - Navigation Database Faulty
                    Fault Frequency: 11
                    Reset counter: 69
                    Mileage: 29347 km
                    Date: 2019.10.26
                    Time: 13:44:45
                    Voltage terminal 30: 12.4 V
   Serial number: 280716EGS07269
   Coding: 000C82204001040000001002
   Serial number: 280716EGS07265
   ROD: EV_LEDModLeftMELCOAU736_AU37.rod
   VCID: 176A32BFCF03E833828-8042
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.4V)-----------
colin41
C?ID=242997
according to erwin there is a software update for this vehicle. can anyone confirm if it involves DPF regen changes?
colin41
C?ID=242997
Thank you for the reply. The customer is contacting Audi directly to see if any “good will” can be done as it’s barely a month outside warranty and given the covid lockdowns currently.
colin41
C?ID=242997
does anybody know the maximum soot mass allowed before the DPF needs replacing?
Jacek
Poland
C?ID=360566
IDE06060, Filling limit: ash mass: particulate filter, 80.00, g
colin41
C?ID=242997
Audi dealership are saying the DPF needs replacing at current ash(around 55g) and regen is not possible.
Jacek
Poland
C?ID=360566
They should disassemble it and subject it to cleaning (washing) with appropriate chemistry. It certainly has too much soot and not ashes.
IDE01409, Filling limit for service regeneration, 40.00, g
IDE01410, Fill limit - overfill, 50.00, g
Fatbloke
Scotland
There are places that can clean the DPF off the car (had it done on Skoda VRS) and there are now some garages that can clean them on the car at reasonable cost.
http://www.dpfdeepclean.co.uk
MartinsX
Riga, Latvia
C?ID=268515
This product helps not in all but a lot of cases ;) It works perfectly where DPF is mounted vertical, horizontal installations sometimes requires two attempts=two cans.
colin41
C?ID=242997
i reported to the customer that the DPF will need to be replaced or removed and chemically cleaned. unfortunately they dont want to spend money :banghead:
Gone But Not Forgotten
the Audi dealership said it didnt change the regen strategy lol
all i could find on it was field measure 23BR
Do you doubt me?
Who are you going to believe them or me? :rolleyes:
I guess the question is are the updates more or less helpful on the Audi side or VAG side of town, I wonder?
Westbury, UK
Sounds like you have an impasse - the dpf needs cleaning or replacing but the customer won't pay, so the customer will have to live with the fault codes and problems - that's how it looks to me?
Jacek
Poland
C?ID=360566
This is "eat an apple and have an apple".
Jacek
Poland
C?ID=360566
It is "eat an apple and have an apple".
