2010 Audi A6 no sound from speakers.....bad amp????
bhoag6276
C?ID=402519
No sound from speakers, I have a total scan below along with Optic Scan. Does anyone agree that my amp is junk? I hate to waste the money if I have a bigger problem that maybe causing this. Some forums say it could be a junk battery???? Hard to believe a battery would cause that.....but who knows! Any help or advice/info would be great!
Below is a scan with the Optic loop connected to all components, when this is the case I have no sound and no MMI screen.
Thursday,23,April,2020,06:16:30:44674
VCDS Version: Release 20.4.1 (x64)
Control Module Part Number: 4F0 907 468 N
  Component and/or Version: GW-BEM 5CAN-M H06 0035
Optical Bus Diagnostic : Standard
Controller                                                   Electrical           Optical
19-CAN Gateway                                         OK                  ERROR
5F-Information Electr.(High/D3)            OK                   OK
0E-Media Player 1                                       OK                   OK
47-Sound System                                        OK                   ERROR
56-Radio                                                          OK                   OK
This is the scan after installing a fiber optic loop at the Bose amplifier. Seems to me the amp is bad, would you say you agree?
19-CAN Gateway                                           OK                   OK
56-Radio                                                            OK                   OK
Wednesday,22,April,2020,18:05:09:44674
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUKGAFB9AN049170   License Plate:
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 3C 42 46 47 4C 4F 52 53
          55 56 5F 62 6C 72
VIN: WAUKGAFB9AN049170   Mileage: 149370km-92814miles
15-Airbags -- Status: Malfunction 1010
47-Sound System -- Status: Cannot be reached 1100
4C-Tire Pressure II -- Status: Malfunction 1010
6C-Back-up Cam. -- Status: Malfunction 1010
Address 01: Engine (CCA)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4F1 910 551 D    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0020
   Revision: --H06---    Serial number:
   Coding: 0105000A190F0120
   Shop #: WSC 02325 785 00200
   VCID: 2411E99B52D1170B173-8070
               U1017 - 000 -  - Intermittent
                    Fault Frequency: 20
                    Mileage: 149214 km
                    Date: 2009.06.02
                    Time: 00:01:30
                    RPM: 1280 /min
                    Mass Air / Rev.: 256.2 mg/str
                    Temperature: 15.0°C
                    Bin. Bits: 00000010
                    Load: 21.2 %
009523 - Ignition Switch; Run/Start Position Circuit
               P2533 - 000 - Open or Short to Ground - Intermittent
                    Fault Status: 00100001
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:18:01
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 7.5°C
                    Bin. Bits: 00000000
                    Voltage: 9.49 V
005386 - Engine Off Timer Performance
               P150A - 000 -
                    Fault Status: 01101000
                    Mileage: 149292 km
                    Date: 2009.06.02
                    Time: 00:42:26
                    RPM: 1472 /min
                    Mass Air / Rev.: 119.9 mg/str
                    Temperature: 88.5°C
                    Bin. Bits: 00000010
                    Voltage: 11.53 V
049489 - No Communications with Airbag Control Module
               U0151 - 000 -  - Intermittent
                    Fault Frequency: 16
                    Mileage: 149299 km
                    Date: 2009.06.03
                    Time: 00:10:49
                    RPM: 1344 /min
                    Time: 0.0 s
                    Bin. Bits: 00000010
                    Voltage: 10.30 V
   Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0010
   Revision: --H05---    Serial number:        4547014
   Coding: 0000002
   VCID: 2A0D07A330F5C17B2DF-807E
006289 - Signal Line for Tiptronic
               P1891 - 000 - Implausible Signal - Intermittent
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:21:52
006288 - Signal Line for Tiptronic
               P1890 - 000 - Electrical Malfunction - Intermittent
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:21:52
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H03 0060
   Coding: 0020921
   VCID: 6E85CBB3CC9DED5BB17-803A
                    Fault Frequency: 13
                    Reset counter: 87
                    Mileage: 149214 km
                    Date: 2009.06.02
                    Time: 00:01:30
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x0194
                    Hex Value: 0x00FF
                    Reset counter: 92
                    Mileage: 149365 km
                    Date: 2020.04.12
                    Time: 06:00:21
                    Hex Value: 0x0000
                    Hex Value: 0x4080
                    Hex Value: 0x0013
                    Hex Value: 0x169E
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602501458650
   Coding: 0000007
   Shop #: WSC 05323 001 1048576
   VCID: 2517F49F59EBEE0300D-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
00956 - Key 2
                    Reset counter: 84
                    Mileage: 149292 km
                    Date: 2009.06.02
                    Time: 00:45:06
                    Reset counter: 83
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:06:37
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000074    Serial number: 00000000693444
   Coding: 0524326
   VCID: 1D67DC7F71BB26C358D-8048
                    Reset counter: 92
                    Mileage: 149299 km
                    Date: 2009.06.03
                    Time: 00:10:54
   Part No SW: 4F0 910 279 M    HW: 4F0 907 279 A
   Component: ILM Fahrer      H22 0320
   Coding: 0139123
   Shop #: WSC 02335 785 00200
   VCID: 33331AC7E73F80B39E9-8066
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
Address 0E: Media Player 1
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003FA0014GPV
   Coding: 303142373034303030314A55304C34463053
   Shop #: WSC 02323 785 00200
   ROD: EV_Airba10AURB4.rod
   VCID: 363523D3F8CD959BB97-8062
   Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
   Component: BF-Gewichtss.  H03 0060
   Serial number: 5810000R0000003E0E
   Serial number: 3574SRB40000A49CA229
   Serial number: 3584SRB40000A4B89A8L
   Serial number: 3516HRB402F9MGGKS4H8
   Serial number: 3526HRB402B9MGGL0CR$
   Serial number: 3554NRB4000052048E0T
   Serial number: 3564NRB400005228294T
9441819 - Safety belt tensioner igniter; rear; center
          B1012 1B [136] - Resistance Too High
                    Mileage: 149099 km
                    Date: 2020.04.01
                    Time: 16:46:40
12583424 - Powertrain Databus
          U0002 00 [008] - No Communications
          [High Speed CAN Communication Bus no signal/communication]
                    Fault Frequency: 9
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0530
   Revision: 00H06000    Serial number: 90026093290026
   Coding: 0012341
   VCID: 270BFE9723E7FC13321-8072
   Component: E0221           H02 0030
                    Reset counter: 87
                    Mileage: 149292 km
                    Date: 2009.06.02
                    Time: 00:05:22
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
   Component: KOMBIINSTR.   H08 0144
   Revision: 00100000    Serial number: CN4223RC9
   Coding: 8BD60A050B00CF05020201
   Shop #: WSC 02391 823 56573
   VCID: 313F10CF1123B2A3EC5-8064
                    Reset counter: 92
                    Mileage: 149299 km
                    Date: 2009.06.03
                    Time: 00:10:50
                    Reset counter: 89
                    Mileage: 149320 km
                    Date: 2009.06.02
                    Time: 23:38:48
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0035
   Revision: MB200030    Serial number: 3000M09B24008E
   Coding: 000303
   VCID: 3A2D37E3CC5571FB5DF-806E
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790855007
8 Faults Found:
02256 - Quiescent Current
                    Fault Frequency: 14
                    Reset counter: 93
                    Mileage: 149212 km
                    Date: 2020.04.09
                    Time: 19:06:00
                    Reset counter: 91
                    Mileage: 149212 km
                    Date: 2020.04.09
                    Time: 22:26:00
                    Bin. Bits:    00000
                    Voltage: 11.90 V
                    Count: 18
                    Reset counter: 35
                    Mileage: 149212 km
                    Date: 2020.04.10
                    Time: 05:56:40
                    Bin. Bits:    11111
                    Voltage: 13.70 V
                    Count: 7
                    Bin. Bits:    10011
00384 - Optical Databus
                    Fault Frequency: 8
                    Reset counter: 53
                    Mileage: 149270 km
                    Date: 2020.04.14
                    Time: 15:28:45
                    Bin. Bits:    00000
                    Voltage: 12.40 V
                    Count: 11
                    Bin. Bits:    00000
                    Reset counter: 92
                    Mileage: 149299 km
                    Date: 2009.06.03
                    Time: 00:10:49
                    Bin. Bits:    00111
                    Voltage: 11.00 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 0.40 s
                    Reset counter: 89
                    Mileage: 149320 km
                    Date: 2009.06.02
                    Time: 23:34:49
                    Bin. Bits:    11111
                    Voltage: 14.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 25.40 s
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 89
                    Mileage: 149320 km
                    Date: 2009.06.02
                    Time: 23:38:47
                    Bin. Bits:    11111
                    Voltage: 14.30 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 25.40 s
00576 - Terminal 15
                    Reset counter: 90
                    Mileage: 149320 km
                    Date: 2009.06.02
                    Time: 23:44:47
                    Bin. Bits:    11110
                    Voltage: 14.20 V
                    Count: 8
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010035889
   Coding: 00581B00004011110000
                    Reset counter: 79
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:07:44
   Part No SW: 4L0 910 566 D    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0020
   Revision: 00H01000    Serial number: 6PZ 009 014-15
   Coding: 0000002
   VCID: 2F3B16B70B17A453FA1-807A
   Subsystem 1 - Part No: 4L0 910 568 D
   Component: J0770_SWA_Slave_H01 0020
   Subsystem 2 - Serial number: 6PZ 009 014-35
   Subsystem 3 - Serial number: 5F30.11.0900H010003CN11153ÿ
   Subsystem 4 - Serial number: N11153ÿ
02001 - Data-Bus Automatic Distance Regulation
                    Reset counter: 90
                    Date: 2009.01.01
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000102476291
   Coding: 011F57204E40410001
   VCID: 46D5531388AD051B297-8012
                    Reset counter: 83
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:06:43
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01246994530000
   Coding: 4618269
   VCID: 353724DFE94B9E83B0D-8060
                    Reset counter: 87
                    Mileage: 149299 km
                    Date: 2009.06.02
                    Time: 23:45:35
01366 - Opened Due to Crash Signal
                    Fault Frequency: 17
                    Reset counter: 92
                    Mileage: 149299 km
                    Date: 2009.06.03
                    Time: 00:10:51
Address 47: Sound System
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 A    HW: 4F0 907 274
   Component: J793  RKA+      H02 0100
   Revision: 00000506    Serial number: 00005061088551
   Coding: 0623301
   VCID: 221DEF8348C5193B65F-8076
                    Fault Status: 00101101
                    Fault Frequency: 24
                    Reset counter: 92
                    Mileage: 149214 km
                    Date: 2009.06.02
                    Time: 00:01:31
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 12.70 V
                    Temperature: 16.0°C
                    (no units): 0.0
                    Reset counter: 87
                    Mileage: 149214 km
                    Date: 2009.06.02
                    Time: 00:01:29
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 11.30 V
                    Temperature: 16.0°C
                    (no units): 0.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000539967
   Coding: 0002014
   VCID: 5EE59B733C3D7DDB017-800A
02072 - Control Module for Energy Management (J644)
                    Reset counter: 92
                    Mileage: 149368 km
                    Date: 2020.04.12
                    Time: 06:30:00
                    Voltage: 12.000 V
                    Temperature: 77.0°C
                    Reset counter: 92
                    Mileage: 149368 km
                    Date: 2020.04.12
                    Time: 06:30:00
                    Voltage: 12.000 V
                    Temperature: 77.0°C
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000102452656
   VCID: 45D7541FB5AB0E0320D-8010
                    Reset counter: 83
                    Mileage: 149292 km
                    Date: 2009.06.02
                    Time: 00:05:15
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   VCID: 211FE08F4DC302237C5-8074
                    Fault Frequency: 42
                    Reset counter: 92
                    Mileage: 149296 km
                    Date: 2009.06.02
                    Time: 13:26:04
                    Voltage: 13.56 V
                    Count: 236
                    Fault Frequency: 12
                    Reset counter: 92
                    Mileage: 149296 km
                    Date: 2009.06.02
                    Time: 13:15:41
                    Voltage: 10.56 V
                    Count: 244
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0060
   Coding: 0000026
   VCID: 698FB8AFF5730A63E45-803C
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
                    Reset counter: 39
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:06:28
Address 56: Radio
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000102482649
   Coding: 010E57204040220001
   VCID: 43D34A07BB9F30330E9-8016
                    Reset counter: 79
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:06:41
   Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J9Y22LL
   Coding: 1000204
                    Reset counter: 83
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:08:17
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   Revision:             Serial number: 0000102482966
                    Reset counter: 83
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:06:41
End----------(Elapsed Time: 01:49, VBatt start/end: 14.2V/14.5V)-----------
United States
This does look like a malfunctioning 47-Sound system/amplifier but I would repeat the Auto-Scan with the loop installed to verify 56 and 5F communicate.
In regards to the battery, this one uses the 19-CAN Gateway slave setup via CAN: http://wiki.ross-tech.com/wiki/index.php/Battery_Replacement#19-CAN_Gateway_using_CAN
You might want to make sure the battery isn't original (roughly10 years old) and that the installed battery was adapted when it was replaced.
bhoag6276
C?ID=402519
Here is the latest scan.....something seems to be draining my battery as well. I've read a bad amp can do this......looks like 56 and 5F are communicating now with the loop installed.
Thursday,23,April,2020,14:39:17:44674
          55 56 5F 62 6C 72
0E-Media Player 1 -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: Malfunction 0010
Readiness: 1000 1000
   Coding: 0000002
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:21:52
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:21:52
   Coding: 0020921
                    Fault Frequency: 14
                    Reset counter: 55
                    Mileage: 149214 km
                    Date: 2009.06.02
                    Time: 00:01:30
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x0194
                    Hex Value: 0x00FF
                    Reset counter: 92
                    Mileage: 149365 km
                    Date: 2020.04.12
                    Time: 06:00:21
                    Hex Value: 0x0000
                    Hex Value: 0x4080
                    Hex Value: 0x0013
                    Hex Value: 0x169E
                    Hex Value: 0x00FF
   Coding: 0000007
00956 - Key 2
                    Reset counter: 84
                    Mileage: 149292 km
                    Date: 2009.06.02
                    Time: 00:45:06
                    Fault Status: 01100010
                    Reset counter: 55
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:06:37
   Coding: 0524326
                    Reset counter: 92
                    Mileage: 149299 km
                    Date: 2009.06.03
                    Time: 00:10:54
   Coding: 0139123
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
                    Reset counter: 55
                    Mileage: 149372 km
                    Date: 2020.04.23
                    Time: 14:33:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 1577C45F858B7E8390D-8040
02244 - Button in Control Head is Stuck
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 82
                    Reset counter: 94
                    Mileage: 145538 km
                    Date: 2019.11.20
                    Time: 18:23:14
                    Bin. Bits: 10000000
   ROD: N/A
13635840 - Supply voltage
          U1011 00 [137] - Voltage too Low
          [Powersupply  lower threshold fall short of]
                    Reset counter: 92
                    Mileage: 149299 km
                    Date: 2009.06.03
                    Time: 00:10:50
                    Reset counter: 89
                    Mileage: 149320 km
                    Date: 2009.06.02
                    Time: 23:38:48
   Coding: 000303
                    Fault Status: 00101011
                    Reset counter: 94
                    Mileage: 149371 km
                    Date: 2009.06.02
                    Time: 11:45:20
                    Bin. Bits:    11111
                    Voltage: 14.50 V
                    Count: 7
                    Bin. Bits:    10011
                    Reset counter: 54
                    Mileage: 149371 km
                    Date: 2009.06.02
                    Time: 11:53:54
                    Bin. Bits:    10000
                    Voltage: 11.90 V
                    Count: 12
                    Bin. Bits:    10010
                    Reset counter: 94
                    Mileage: 149371 km
                    Date: 2009.06.02
                    Time: 15:09:00
                    Reset counter: 95
                    Mileage: 149371 km
                    Date: 2009.06.02
                    Time: 19:59:00
                    Bin. Bits:    00000
                    Voltage: 11.60 V
                    Count: 18
   VCID: 55F7845F458BBE8350D-8000
No ASAM data for: "Unknown" (AU56)
                    Reset counter: 55
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:06:43
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:34:21
   Coding: 4618269
                    Reset counter: 87
                    Mileage: 149299 km
                    Date: 2009.06.02
                    Time: 23:45:35
                    Fault Frequency: 17
                    Reset counter: 92
                    Mileage: 149299 km
                    Date: 2009.06.03
                    Time: 00:10:51
   Coding: 0623301
            002 - Lower Limit Exceeded - MIL ON
                    Fault Status: 11100010
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:34:39
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0003
                    Voltage: 7.60 V
                    Temperature: 5.0°C
                    (no units): 255.0
                    Fault Status: 11101101
                    Fault Frequency: 26
                    Reset counter: 55
                    Mileage: 149214 km
                    Date: 2009.06.02
                    Time: 00:01:31
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 12.70 V
                    Temperature: 16.0°C
                    (no units): 0.0
                    Reset counter: 55
                    Mileage: 149214 km
                    Date: 2009.06.02
                    Time: 00:01:29
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 11.30 V
                    Temperature: 16.0°C
                    (no units): 0.0
   Coding: 0002014
                    Reset counter: 92
                    Mileage: 149368 km
                    Date: 2020.04.12
                    Time: 06:30:00
                    Voltage: 12.000 V
                    Temperature: 77.0°C
                    Reset counter: 92
                    Mileage: 149368 km
                    Date: 2020.04.12
                    Time: 06:30:00
                    Voltage: 12.000 V
                    Temperature: 77.0°C
                    Reset counter: 55
                    Mileage: 149372 km
                    Date: 2020.04.23
                    Time: 14:33:00
                    Voltage: 8.300 V
                    Temperature: 8.0°C
                    Reset counter: 55
                    Mileage: 149292 km
                    Date: 2009.06.02
                    Time: 00:05:15
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:34:38
   Revision: --H05---
   Coding: 0000222
                    Reset counter: 55
                    Mileage: 149368 km
                    Date: 2020.04.23
                    Time: 14:34:38
                    Voltage: 6.83 V
                    Count: 200
                    Fault Frequency: 42
                    Reset counter: 92
                    Mileage: 149296 km
                    Date: 2009.06.02
                    Time: 13:26:04
                    Voltage: 13.56 V
                    Count: 236
                    Fault Frequency: 12
                    Reset counter: 92
                    Mileage: 149296 km
                    Date: 2009.06.02
                    Time: 13:15:41
                    Voltage: 10.56 V
                    Count: 244
   Coding: 0000026
                    Fault Status: 00110010
                    Reset counter: 39
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:06:28
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:34:19
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335LY097543143
   Coding: 020000010000000000
   VCID: 1D67DC7F7DBB26C358D-8048
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:34:18
                    Voltage: 7.80 V
                    Reset counter: 55
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:07:25
                    Voltage: 9.00 V
                    Reset counter: 95
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 06:15:54
                    Bin. Bits: 00000001 11101100
   Part No SW: 4E0 035 664 A    HW: 4E0 035 664 A
   Component: H-BN-NA       H47 0042
   Revision: --------    Serial number: 488L5097522574
   Coding: 010200000002E1EE51000304EF6300030000
   VCID: 221DEF8344C5193B65F-8076
   Subsystem 1 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356L/091152795
   Subsystem 2 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 T
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001459853
                    Reset counter: 94
                    Mileage: 149262 km
                    Date: 2020.04.12
                    Time: 15:16:35
                    Voltage: 12.70 V
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:34:55
                    Voltage: 7.60 V
                    Reset counter: 95
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 06:15:54
                    Bin. Bits: 10000000 10000000
                    Bin. Bits: 00000100 00001110
                    Bin. Bits: 00000000 00000000
03367 - Supply Voltage for Display Module
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:34:16
                    Voltage: 8.30 V
                    Reset counter: 95
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 06:15:54
                    Bin. Bits: 00100001 00010000
                    Bin. Bits: 00000000 00000010
00822 - Connection DSP to Radio
                    Reset counter: 34
                    Mileage: 149209 km
                    Date: 2020.04.09
                    Time: 16:14:14
                    Voltage: 14.50 V
                    Reset counter: 55
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:06:41
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:34:24
   Coding: 1000204
                    Fault Status: 01101101
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:32:09
                        Reverse OFF
                    Count: 3
                    Reset counter: 55
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:08:17
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:33:46
                        Reverse OFF
                    Count: 3
                    Reset counter: 55
                    Mileage: 149262 km
                    Date: 2020.04.14
                    Time: 06:06:41
                    Reset counter: 55
                    Mileage: 149374 km
                    Date: 2020.04.23
                    Time: 14:34:39
End-----(Elapsed Time: 02:40, VBatt start/end: 9.0V/6.5V. VIgn 6.5V)-------
United States
I can easily tweak it for you but please add [code] before the scan text followed by [/code] at the end so it wraps the scan. That may be easier to visualize with the formatting here.
It does look like the Amp is faulty but ouch @ (Elapsed Time: 02:40, VBatt start/end: 9.0V/6.5V. VIgn 6.5V) If the battery wasn't faulty ... it will be soon. I'd be tempted to fully charge the battery, clear all fault codes and then leave the amp electrically unplugged entirely -and- looped out.
If the battery (still) goes flat within a few days of normal use the Amp isn't your guy. Instead, you might want to have the battery tested and see this: https://forums.ross-tech.com/showthread.php?9468-The-Best-Way-to-Perform-a-Parasitic-Draw-Test
bhoag6276
C?ID=402519
Thanks for the help Dana! I have been having battery drain since I lost sound (or around there). I will charge it and then unplug it completely and see what happens. Guess i start amp shopping too and see if that does the trick! Thanks again!
bhoag6276
C?ID=402519
I think I found the battery drain issue.....I left my dome light on yesterday. ooops lol I charged the battery and it turned over just fine this morning. I pulled the amp out last night to open it up and get a visual on the board. This thing looks brand new, no dark spots or burn marks anywhere. I checked the harness to make sure its getting power (pin 1) and I have power there. Is there anyway to test the amp? Can I get power to it and test the speaker lines with a multimeter? I'm struggling to think this thing is bad. I hate to spend the money for repair and re-coding if its not going to solve the issue. My only other thought was my friend has a 2011 A6, if he has the same amp can I take his and put it my car? I know it will have the component protection, but I should get sound out of at least one speaker, correct? I just don't want to mess up the coding on his. I wouldn't think it would, but do you see a problem with trying his in my car? His should work just fine after being plugged back into his I would think. Thanks again for your help!
United States
Bench testing a MOST module wouldn't be that easy. Borrowing a known good amp would be far easier.
CP DTCs should clear out of his after amp reinstalling it back into the original car as long as Coding and/or Adaptation modifications aren't performed with the test unit installed. If you do try that make sure to run the MOST test and a full scan.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I have seen in past that AMP go bad on this car . So there is a possibility that AMP is bad.
Just to let you know on that car AMP has CP-Cmponent protection , So if you install second hand AMP you will have only one seeker working . Just to not get confuse .
And this can not be fix/programed with VCDS .
If you end up with second hand AMP , I have solution to make it work , just contact me .
bhoag6276
C?ID=402519
I’ve read about the CP, but if i could borrow one i would at least determine if mine is truly bad. When i get a different one for my car i will reach out to see if you help with the coding. Dealership wants $160 for it. Geesh.
