Audi B8,5 steering wheel problems
Jusstassss
Lithuania
C?ID=375119
Hi, new guy in forum needs help, I am rebuilding smashed audi a4 b8,5 from USA. Main problem is steering wheel, after repair scaned for stored fault codes and my hexnet can not connect to J500 module (power steering control module. Find out that there are fuses under bonet and in panel(driver side), checked, all ok, then took off J500 from steering column and found that it was uner water(dont now how it get there), bought another module, installed, tryed to do adaptation, but wheel still locked, cant turn any direction at all, i will attach two auto scans before and after replacement without fault code erasing
Hi and welcome.
Please do post the scans. We don't attach them here. We paste them in-line, as explained here.
Jusstassss
Lithuania
C?ID=375119
This is old one
Friday,27,March,2020,19:20:42:60527
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUFFAFLXDN007656   License Plate: BALTA
Mileage: 200380km-124510mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
          72
VIN: WAUFFAFLXDN007656   Mileage: 200380km-124510miles
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 F    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF X09 0007
   Revision: ECX09---
   Coding: 4A2A0013242600062000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TFS0118K5907115F 001008
   ROD: EV_ECM20TFS0118K5907115F.rod
   VCID: B522845014AD99E7C6-80E0
          U1113 00 [046] - -
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 07:03:51
                    Engine speed: 759.00 /min
                    Normed load value: 18.4 %
                    Coolant temperature: 105 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 14.277 V
                    Median injection timing: 1.268 ms
                    Engine operating condition: Idling
          U1113 00 [038] - -
                    Mileage: 200382 km
                    Date: 2020.03.27
                    Time: 13:08:31
                    Engine speed: 1483.50 /min
                    Normed load value: 12.9 %
                    Coolant temperature: 9 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 11.567 V
                    Median injection timing: 2.601 ms
5664 - Mass Air Flow Sensor (G70)
          P0100 00 [172] - Supply Voltage
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 07:03:51
                    Engine speed: 770.00 /min
                    Voltage terminal 30: 14.324 V
                    Median injection timing: 1.292 ms
2985 - Solenoid Valve  for Boost Pressure Control (N75)
          P0243 00 [172] - Malfunction
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 07:03:51
                    Engine speed: 777.50 /min
                    Normed load value: 17.3 %
                    Voltage terminal 30: 14.206 V
                    Median injection timing: 1.199 ms
                    A/C compressor: load current: act. value: -495.50 A
   Part No SW: 8K0 927 158 T    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1002
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: C7DEFE987E411B77A4-8092
2505 - Torque Management Feedback Signal A
          P2637 00 [046] - -
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 07:03:53
                    Voltage terminal 30: 14.155 V
                    Transmission output speed: 0.00 /min
                    Driving position: P
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
                    Transfer speed from ESP: valid
                    Transfer speed from ESP: 0.00 km/h
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 2D1D18
   Shop #: WSC 02391 823 56573
   VCID: 8444299407F7F06F01-80D0
                    Fault Status: 00101101
                    Reset counter: 0
                    Mileage: 200382 km
                    Date: 2020.03.27
                    Time: 13:08:26
                    Hex Value: 0x0000
                    Hex Value: 0x2782
                    Hex Value: 0x000B
                    Hex Value: 0x4694
                    Hex Value: 0x0000
                    Reset counter: 215
                    Mileage: 200382 km
                    Date: 2020.03.27
                    Time: 13:08:26
                    Hex Value: 0x0000
                    Hex Value: 0x2782
                    Hex Value: 0x000C
                    Hex Value: 0xE394
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 FM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H10 0602
   Coding: 0D810000000000000000
   Shop #: WSC 02399 823 56573
   VCID: 804C258413EFEC4F25-80D4
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0816000077919007
   Serial number: 2312000094214007
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Revision: C1000000    Serial number: 01070520120951
   Coding: 6480208000
   VCID: B326BA4812D987D7E8-80E6
                    Fault Status: 01101101
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:45
                    Fault Status: 01101000
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:49
                    Temperature: 15.0°C
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:51
                    Temperature: 15.0°C
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:53
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
   Component: BCM1 1.0      H14 0103
   Revision: 08014001    Serial number: 00000030099401
   Coding: 26000091863CAFC00000480300003D0D0F1C5208A2090221000008000000030100000030000000
   Shop #: WSC 08353 444 103400
   VCID: F8BC4D644B3FA48F1D-80AC
   Component: WWS 080512  H07 0070
   Serial number: SWF12050085692
   Coding: 00FD11
   Serial number: 20264835
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002704124816
03188 - Bulb for Side Marker Light; Front Left
                    Fault Status: 01101100
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:47
03189 - Bulb for Side Marker Light; Front Right
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:47
03020 - Local databus 2
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:49
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD90683
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 04134 002 1048576
   VCID: CAD8C7AC6D53E61FBB-809E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1200008TNR
   Serial number: 6334MSME6E514A69S
   Serial number: 6344MSME6F220B3AN
   Serial number: 6352QSME4D131C54K
   Serial number: 6362QSME3D1422407
   Serial number: 63732SME38140578Z
   Serial number: 63832SME07173C56+
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Component: Lenks.Modul   H03 0004
   Revision: --------    Serial number: 90372LE2000K5
   Coding: 000016
   VCID: C3C6EA884279375778-8096
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 A    HW: 8K0 920 982 A
   Component: KOMBIINSTR.   H35 0540
   Revision: 00000000    Serial number: NTC51V25D
   Coding: 0F3F090002000009020001
   VCID: B228BF4CEDC38EDFE3-80E6
                    Reset counter: 215
                    Mileage: 200382 km
                    Date: 2020.03.20
                    Time: 07:11:43
   Part No SW: 8R0 907 468 C    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H10 0025
   Revision: 1Y030014    Serial number: 1441Y125030203
   Coding: 00C303FF00
   VCID: BFCEE6782E9153B71C-80EA
   Serial number: 1677937401
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:46
                    Bin. Bits:    11111
                    Voltage: 14.10 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 0
                    Mileage: 200382 km
                    Date: 2020.03.20
                    Time: 10:51:01
                    Reset counter: 0
                    Mileage: 200382 km
                    Date: 2020.03.20
                    Time: 14:16:01
                    Bin. Bits:    00000
                    Voltage: 12.10 V
                    Count: 17
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000029147174
   Coding: 00000000000000000000
   VCID: BB3692683A894F9730-80EE
16347 - Control Module - EEPROM Error
                    Fault Status: 00101110
03330 - Motor for Fore/Aft Adjustment
                    Fault Status: 01100101
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:45
03331 - Motor for Backrest Angle Adjustment
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:45
03332 - Motor for Height Adjustment
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:45
03333 - Motor for Cushion Angle Adjustment
                    Reset counter: 215
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:45
   Part No SW: 8T0 959 793 G    HW: 8T0 959 793 G
   Component: TSG FA        H09 0302
   Coding: 011C13204E00410001
   VCID: CDD2CCB0943DF1279E-8098
Address 44: Steering Assist
   Revision: 00002001    Serial number: 0176189978
   Coding: 01061E3A00FA400580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000520106
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
   Component: TSG BF        H09 0302
   VCID: CCD4C1B46F27F82F89-8098
   Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component: EPB-4         H01 0001
   Revision: --------    Serial number: 00000000057798
   ROD: EV_ParkiBrake_AU48.rod
   VCID: B620835C09AB92FFCF-80E2
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 0
                    Mileage: 200380 km
                    Date: 2020.03.20
                    Time: 06:34:49
                    Voltage terminal 30: 14.6 V
                    Internal Fault ID: 188
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0112
   Revision: AB001007    Serial number: 236E/0C7538274
   Coding: 020007020100000001
   VCID: A10A4000B82505470A-80F4
   Part No SW: 8R1 035 746 B    HW: 8R1 035 746 A
   Component: H-BNT-NA      H42 0552
   Revision: --------    Serial number: 096EX0C7510273
   Coding: 0F0200000006A1EF41028B4E00000403140000000000000000
   VCID: B620835C01AB92FFCF-80E2
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130DB0CS148638
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001146792
   Component: CD-Database  3371
00822 - Connection DSP to Radio
                    Reset counter: 215
                    Mileage: 200382 km
                    Date: 2020.03.27
                    Time: 13:08:29
                    Voltage: 11.80 V
   Part No SW: 8T0 959 795 H    HW: 8T0 959 795 H
   Component: TSG HL        H07 0302
   Coding: 010C13204000210001
   VCID: D0ECD5C4830FDCCFF5-8084
   Revision: --H07---    Serial number: 525PA8-J24920L
   Coding: 1000006
   Shop #: WSC 02391 785 00200
   VCID: B83C8D64CBBF648FDD-80EC
   Component: TSG HR        H07 0302
End----------(Elapsed Time: 02:01, VBatt start/end: 14.6V/14.6V)-----------
Address 09,8K0 907 063 DH,recoded (Long Coding),from,26000091863CAFC00000480300003D0D0F1C5208A2090221000008000000030100000030000000,to,26000011863CAFC00000400300003D0D0F1C5208A2090221000008000000030100000030000000,(08353/444/103400),
Address 09: DTCs cleared
This is new one
 Monday,20,April,2020,19:32:34:60527
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUFFAFLXDN007656   License Plate: MANO VAIRAS
                Address 44: Steering Assist       Labels: 8K0-909-144.clb
Control Module Part Number: 8K0 909 144 P    HW: 8K0 909 144 B
  Component and/or Version: RCEPS         H43 0510
           Software Coding: 100000000001
            Work Shop Code: WSC 40568 001 1048576
              ASAM Dataset: EV_RCEPSAU48X 008018 (AU48)
                       ROD: EV_RCEPSAU48X_008.rod
                      VCID: BE309B7C219B5A76B0-80EA
2107920 - Steering Torque Sensor 1
          C10F0 29 [008] - Signal Implausible
          [Signalfehler DME-Kanal 1]
                    Reset counter: 17
                    Write only channel
2107936 - Steering Torque Sensor 2
          C10F1 29 [008] - Signal Implausible
          [Signalfehler DME-Kanal 2]
                    Reset counter: 17
                    Write only channel
5258753 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
          [Lenkungsendanschläge nicht angelernt]
                    Reset counter: 0
                    Mileage: 200382 km
                    Date: 2020.04.20
                    Time: 18:30:40
                    Write only channel
2117648 - Steering Torque Sensor
          C10AA 31 [008] - No Signal
          [Fehler Kommunikation DME]
                    Reset counter: 17
                    Write only channel
7341632 - Position Sensor for Motor
          C10AD 29 [137] - Signal Implausible
          [Unplausible Werte vom Resolver (kritischer Fehler)]
                    Write only channel
          72
09-Cent. Elect. -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 1010
36-Seat Mem. Drvr -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
6C-Back-up Cam. -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
   Revision: ECX09---
   VCID: B522845014AD992E61-80E0
   Revision: --H16---
   Coding: 000002
   VCID: C7DEFE987E411BBE03-8092
   Coding: 2D5D18
   VCID: 8444299407F7F0A6A6-80D0
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:14:39
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0015
                    Hex Value: 0x1099
                    Hex Value: 0x0000
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:14:39
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x000C
                    Hex Value: 0xE399
                    Hex Value: 0x0000
01200 - ABS Valves Supply Voltage
            000 - - - Intermittent - MIL ON
                    Fault Status: 10100000
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:18:15
                    Hex Value: 0x0000
                    Hex Value: 0x02A0
                    Hex Value: 0x0046
                    Hex Value: 0x409A
                    Hex Value: 0x0000
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:54
                    Hex Value: 0x0000
                    Hex Value: 0x02A0
                    Hex Value: 0x001A
                    Hex Value: 0x8496
                    Hex Value: 0x0000
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:14:39
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x000C
                    Hex Value: 0xE399
                    Hex Value: 0x0000
   VCID: 804C258413EFEC8682-80D4
   Subsystem 2 - Part No: 8K0 905 852 E
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:17:56
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:18
   Coding: 6480208000
   VCID: B326BA4812D9871E4F-80E6
                    Fault Frequency: 11
                    Reset counter: 218
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:08:57
                    Temperature: 15.0°C
                    Reset counter: 217
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:08:53
                    Fault Frequency: 16
                    Reset counter: 218
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:08:58
                    Temperature: 15.0°C
                    Fault Frequency: 16
                    Reset counter: 218
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:09:02
   Coding: 26000095863CAF400001400300003D0D0F1C5208A2090221000008000000030100000030000000
   VCID: F8BC4D644B3FA446BA-80AC
   Coding: 00FD11
   Coding: 02005D
                    Reset counter: 218
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 17:32:40
   VCID: CAD8C7AC6D53E6D61C-809E
   Coding: 000016
   VCID: C3C6EA884279379EDF-8096
   VCID: B228BF4CEDC38E1644-80E6
                    Reset counter: 217
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:08:54
   Coding: 00C303FF00
   VCID: BFCEE6782E91537EBB-80EA
12 Faults Found:
                    Reset counter: 3
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:08:54
                    Bin. Bits:    11111
                    Voltage: 14.40 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:16
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 2.90 s
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:22
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 10
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:54
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 10
                    Bin. Bits:    10000
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:54
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 10
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:54
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 10
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:54
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 10
                    Bin. Bits:    10000
                    Time: 25.40 s
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:54
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 10
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:54
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 10
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:00:54
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 10
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:02:25
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 10
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 3
                    Mileage: 200382 km
                    Date: 2020.04.17
                    Time: 17:15:55
                    Bin. Bits:    10000
                    Voltage: 11.70 V
                    Count: 16
   VCID: BB3692683A894F5E97-80EE
                    Reset counter: 217
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:08:53
                    Reset counter: 217
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:08:53
                    Reset counter: 217
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:08:53
                    Reset counter: 217
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 14:08:53
   VCID: CDD2CCB0943DF1EE39-8098
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0020152230
   Shop #: WSC 40568 001 1048576
                    Reset counter: 17
                    Write only channel
                    Reset counter: 17
                    Write only channel
                    Reset counter: 0
                    Mileage: 200382 km
                    Date: 2020.04.20
                    Time: 18:30:40
                    Write only channel
                    Reset counter: 17
                    Write only channel
                    Write only channel
   Coding: 01061F3A00FA400583B0013200000000
11 Faults Found:
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:17:56
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:18:09
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:18:09
01512 - Control Module for Sliding Roof
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:19:12
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:03:14
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:03:14
03123 - Terminal 30 - 2
                    Fault Status: 00101011
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:32:08
03124 - Terminal 30 - 3
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:32:15
00926 - Terminal 30
                    Reset counter: 1
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:32:18
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 00101001
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.11
                    Time: 16:24:21
02615 - Fuel Tank Cap; Lock
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.17
                    Time: 17:15:43
   Coding: 011C13205E00410001
   VCID: CCD4C1B46F27F8E62E-8098
   VCID: B620835C09AB923668-80E2
68352 - Control Module Left Channel Voltage Supply
          C1012 14 [008] - Open or Short to GND
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 00:03:09
                    Voltage terminal 30: 12.2 V
                    Internal Fault ID: 14
                    Network management state: Ready for busstat
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Terminal 15 status: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Internal Parking Brake state: No enabling
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
68608 - Control Module Right Channel Voltage Supply
          C1013 14 [008] - Open or Short to GND
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:32:02
                    Internal Fault ID: 15
                    Red warning lamp: On
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
197120 - Indicator Lamp in Controls
          C1014 14 [008] - Short to Plus
                    Reset counter: 2
                    Mileage: 200382 km
                    Date: 2020.04.05
                    Time: 16:31:57
                    Internal Fault ID: 57
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   VCID: A10A4000B825058EAD-80F4
   VCID: B620835C01AB923668-80E2
   VCID: D0ECD5C4830FDC0652-8084
   Coding: 1000006
   VCID: B83C8D64CBBF64467A-80EC
End----------(Elapsed Time: 02:04, VBatt start/end: 14.0V/14.6V)-----------
United States
The early RCEPS racks were notorious for issues like that in addition to failure. For instance, C10AD links to a thread with some additional info.
I would want to perform a voltage drop test to the wiring at the used rack but it is entirely possible the used one you received is faulty.
Jusstassss
Lithuania
C?ID=375119
Saturday,25,April,2020,17:36:16:60527
VIN: WAUFFAFLXDN007656   License Plate: 0425BALTA2
          72
   Revision: ECX09---
   Revision: --H16---
   Coding: 000002
   Coding: 2D5D18
01486 - System Function Test Activated
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 15:58:43
                    Hex Value: 0x00C0
                    Hex Value: 0x4282
                    Hex Value: 0x0019
                    Hex Value: 0x3194
                    Hex Value: 0x0000
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 15:58:43
                    Hex Value: 0x00C0
                    Hex Value: 0x4282
                    Hex Value: 0x000C
                    Hex Value: 0xC094
                    Hex Value: 0x0000
   Coding: 6480208000
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 00:03:59
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 00:04:03
                    Temperature: 12.0°C
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 00:04:04
                    Temperature: 12.0°C
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 00:04:08
   Coding: 26000095863CAF600001400300003D0D0F1C5208A2090221000008000000030100000030000000
   Coding: 00FD11
   Coding: 02005D
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 00:04:03
   Coding: 000016
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 00:04:00
   Coding: 00C303FF00
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 16:27:05
                    Bin. Bits:    10111
                    Voltage: 10.90 V
                    Count: 6
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 00:03:59
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 00:03:59
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 00:03:59
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 00:03:59
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H38 0507
   Revision: 00001000    Serial number: 0030539954
   Shop #: WSC 06334 123 12345
   VCID: BB36926832894F5E97-80EE
5258756 - Steering
          C10AC 07 [137] - Mechanical Failure
          [Blockieren der Lenkung]
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 15:31:39
                    Write only channel
1052420 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal electronic failure
          [Unplausibler Signalverlauf Motortemperatursensor (zu hoher Temperaturgradient)]
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 15:31:37
                    Write only channel
7341570 - Position Sensor for Motor
          [Unplausible Werte vom Resolver (beherrschbarer Fehler)]
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 15:39:31
                    Write only channel
                    Reset counter: 220
                    Mileage: 200382 km
                    Date: 2020.04.25
                    Time: 16:30:08
                    Write only channel
   Coding: 1000006
End----------(Elapsed Time: 02:09, VBatt start/end: 13.1V/13.1V)-----------
hi again,got another module, still cant turn wheel at all, bad module again?
NostraJackAss
Yeah it's bad again.....
You could check and overlay wiring to test but that's mechanical with eeprom error.
Jusstassss
Lithuania
C?ID=375119
Is it matters, if I change only electrical part of steering rack, or all of it? wiring cecked 2 times, all ok
Jusstassss
Lithuania
C?ID=375119
Ok boys, fixed, there was water not just in power steering control unit, but also in steering rank,motor was rusted,
needed to replace all rank with control module(first time I only changed J500 separately from steering rank)
44 - Steering Assis
then security access-47302
- basic settings - reset learned values, press go,wait until pops up ,,not working,,(or something similar) press stop, close
- run engine- turn wheels fully to right, hold until beep
- turn wheels fully to left, wait for beep
- done
Easy, when know whats wrong...
