Fabia III 2016 - Rear electric window retrofit problem
wirer
Slovakia
C?ID=319182
hello,
i retrofited rear electric window (from mechanical to electric pulling). the rear windows work fine for me. driver motor window is also changing (from 5JA 959 811 K to 6V1 959 801 B), modified I have a complete wiring according to the diagram. and there is a problem
coding changed according to another car with electric rear windows:
I already have a visible motor for the driver's door (left-hand drive) in the list of units:
the problem is that the driver's window reacts in the opposite way (if I press "up", the window goes down. if I press "down", the window goes up. I don't know where the error is. I don't have another engine to test yet. buttons I tried from another car - no change. I also tried my buttons in another car - the other car works properly ...
is it still possible to modify the encoding somewhere? in unit 09 for FHSG DRV, despite the original cable, I do not have a description of bytes and bits. coding is the same as another car with the original engine
full scan (errors unit 17 and 5F is from another modifiing):
Saturday,18,April,2020,20:32:00:21987
VCDS Version: 20.4.0.1  HEX-V2 CB: 0.4513.4
VIN: TMBJN6NJ7GZ173417   License Plate:
Mileage: 98956km-61488mi   Repair Order:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 10 15 17 19 20 44 5F
VIN: TMBJN6NJ7GZ173417   Mileage: 98956km-61488miles
Address 01: Engine (J623-CJZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H23 9086
   Revision: R4H23---
   Coding: 01190012232415080000
   Shop #: WSC 65048 003 104857
   ASAM Dataset: EV_ECM12TFS01104E906027BC 001009
   ROD: EV_ECM12TFS01104E906027BC.rod
   VCID: 669446AD08E2930BC9E-8032
   CAN Converter 01:
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08514048160314
   Coding: 41F5487D492A33C30918106A0058821292CC9008000DD7098F00
   Shop #: WSC 13765 031 00063
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 372ADBE91FC8DA83A28-8062
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6V0 820 045 A    HW: 6V0 820 045 A
   Component: AC Manuell    H01 0202
   Serial number:  1603091B-1445
   Coding: 100000001000100000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26_SK26.rod
   VCID: 3038E0F5FAA60DBBE32-8064
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-090-V1.clb
   Part No SW: 6C0 937 090 D    HW: 6C0 937 090
   Component: BCM PQ26 HiKR H10 0094
   Serial number: 006318037927
   Coding: 1C00095042158A7B43804000412F87080001D100D30A3500000000000000
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006_VW26.rod
   VCID: 290E0D91D97C7C7324C-807C
   Subsystem 1 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y15M09D15H00M44S58
   Coding: 00185E
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
   Component: FHSG DRV  007 0001
   Serial number: 00000000000009255270
   Coding: 011200
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 7K  H03 0048
   Revision: --------    Serial number: 39331431407392
   Coding: 0031151041
   Shop #: WSC 73430 790 00021
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 3D26C9C13DF4F0D3784-8068
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
   Component: VW20Airbag743 002 0380
   Revision: --------    Serial number: 003TJ00313GV
   Coding: 88CCC000000000005C5400CF000800000000
   Shop #: WSC 73430 790 00063
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3B22C7D923E0FEE3460-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 822 503 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H000E2957E71B11N
   Subsystem 2 - Part No SW: -----------    HW: 410 822 503 16
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00162957E74138J
   Subsystem 3 - Part No SW: -----------    HW: 442 152 103 16
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A31F93E220223
   Subsystem 4 - Part No SW: -----------    HW: 442 152 103 16
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00B31F93E33232A
   Part No SW: 6V0 920 740 A    HW: 6V0 920 740 A
   Component: KOMBI         205 1420
   Coding: 0BAD0900218000080108B6001C00000000000000
   Shop #: WSC 65517 001 104857
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 3332EFF90BB036A39E0-8066
16777024 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_BCME_0x23 keine Kommunikation]
                    Reset counter: 42
                    Mileage: 98482 km
                    Date: 2020.04.14
                    Time: 17:56:11
16777051 - Databus
          [TCO_01 keine Kommunikation]
                    Reset counter: 252
                    Mileage: 98405 km
                    Date: 2020.04.12
                    Time: 14:24:28
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 090
   Component: GW MQB A0     H10 0094
   Revision: --------    Serial number: 006318037927
   Coding: 030100042F0A640000000000000300010001000000000000000000000000
   Shop #: WSC 73430 790 12345
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_SK25.rod
   VCID: 261406ADC862530B09E-8072
   Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000D2251200218
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 53079716042821739041
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 AG    HW: 3G0 857 511 AG
   Component: FLA           H08 0001
   Revision: AA001001
   Coding: 010100E500000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001016
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6D8639812D14A053884-8038
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: CG460016
   Coding: 800700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   Part No SW: 6V0 035 871 J    HW: 6V0 035 871 J
   Component: MU-E--US      690 8740
   Serial number: 24081800021394
   Coding: 03620200BE0000001111000401000A00AF0003D40000010004
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 3E24CECD30F2EBCB61E-806A
          U1014 00 [009] - -
                    Reset counter: 252
                    Mileage: 98405 km
                    Date: 2020.04.12
                    Time: 14:23:53
                    Voltage terminal 30: 11.9 V
1564 - Microphone 1
          B129B 13 [008] - Open Circuit
                    Reset counter: 44
                    Mileage: 98504 km
                    Date: 2020.04.15
                    Time: 05:47:47
                    Voltage terminal 30: 11.7 V
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 252
                    Mileage: 98405 km
                    Date: 2020.04.12
                    Time: 14:23:56
                    BAP-BAP_Function_ID: 00
End----------(Elapsed Time: 00:44, VBatt start/end: 12.3V/12.3V)-----------
thanks for any solutions and sorry for my english :)
iichel
Eindhoven, NB, NL
C?ID=284912
is 6V1 959 801 B the correct part according to ETKA for a Fabia III with 4x electric window?
wirer
Slovakia
C?ID=319182
Yes
wirer
Slovakia
C?ID=319182
I probably won't change it at home via VCDS?
A friend was watching sets for VCP and there's nothing there. ODIS will try out tonight
wirer
Slovakia
C?ID=319182
A friend also watched the dataset in ODIS, he didn't find anything there. Is there an alternative? Or would anyone know how to do it remotely for a small fee? I've been here briefly, I don't know exactly how it goes. I have VCDS, a friend of VCP and ODIS
An alternative according to another forum is possible in adjusting the connection of the buttons. I haven't looked at it yet, it's supposed to change 2 resistors and it will work
wirer
Slovakia
C?ID=319182
Hi,
I still don't have those windows solved. I pull the driver's window in the opposite direction, ie by pressing the button up.
Can't it be a problem that I once changed the BCM bought for Allegro and I don't know what car it came from? maybe nonsense, but I was wondering if anyone has coding BCM and window units from the English version (steering wheel on the right). wouldn't that help turn the whole window control system on?
well thank you
iichel
Eindhoven, NB, NL
C?ID=284912
did you have a look at the codings for the window motors themselves?
I had a look at a polo 6c with 4 electic windows. the bcm coding for byte 21 is '01'. did you give that a try?
wirer
Slovakia
C?ID=319182
sorry for the late reply.
I have 0A set, like about all the Fabia I've watched
if I change it to 01, the diagnostics will report an error to both front window motors
which is still without error, so is 02
wirer
Slovakia
C?ID=319182
in the end it didn't bother me, i tried to order another, another window download engine. managed to! physically the engines are the same, this one had according to the seller designation for the right front door, I do not understand why, when the number fits the left front (left-hand drive)
the important thing is that it works. I still don't understand the given logic, I didn't change the coding after replacing the motorbike, it remained the original one
in Slovak I wrote it as an article for a complete addition of rear electric windows, maybe it will help someone ....
https://wirer.sk/f3_okna/
the problem is solved after a year and a half :)
