Remote Start with sacrificial Key - Tweak Help B9 RS5
rs5iswicked
C?ID=116247
Had remote start installed.
Required sacrificial key.
However, every time I open the door of the vehicle or start the car using the remote start, somehow the sacrificial key changes all the settings in the vehicle (seat position, lights, radio and sound settings, etc.
It defeats the purpose of the sacrificial key if the seat and settings change.
What's worse, is that if I have NO key in my pocket, car unlocked and open the doors, the settings all change to the sacrificial key....
I have seen settings for key memory somewhere in the VCDS coding and I would like to find a way to ignore key #3's user settings or copy Key #1's settings.....
Is this possible????
Do we have an Auto-Scan from this car somewhere?
One thing that's surely possible is to adjust all the settings for your 'sacrificial' key to match the settings you desire.
Spacewalker
Poland
C?ID=159607
there is a 2 options
Easy Entry - always move seat back and steering wheel to get as much as possible access space
memory seat / solumn memory - set up to Key profile
rs5iswicked
C?ID=116247
I can upload an autoscan this morning, do you also require an ADmap???
I have the Easy Entry enabled (there is no power steering column enabled).
I have tried to use the sacrificial key in the same way you would program a key profile normally.
Set the seat to the correct position.
His Set #2 on the memory.
Lock the vehicle using the Remote Start app.
But this doesn't work.
It did for both my other keys.....
