Hi
I have some issues with the aligment of the throttle body and its idling 1200 rpm, i bought a new throttle body and installed it but I have the same problem . when i start the car it idles normal but after a while of driving Idle is 1200 rpm. when i try to do a throttle body aligment on channel 98 i only got a error even with the new throttle body.
fault codes before this autoscan :
00282 throttle position actuator (v60)
27-10 implausible signal-intermittent
01165 throttle body control module
11-00 control limit not reached
VCDS-Mobile
Auto-Scan
Finished
VIN: IMMO-IDENTNR:2284
Chassis Type:1J or 9M
76
Address 01: Engine Labels: 06A-906-018-AGU.lbl
Part No SW: 06A 906 018 BB
Component: 1.8L R4/5VT MOTR HS D09
Coding: 04000
Shop #: WSC 00046 000
VCID: 63893C8F912BB96F2DF0D8-4B3C
01165 - Throttle Body Control Module (J338)
11-00 - Control Limit Not Reached
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No SW: 1J0 907 379
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
VCID: EE9FDDBBCAE98407325EA1-4B00
No fault codes found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No SW: 3B1 907 044 B
Component: CLIMATRONIC V 1.0.0
Coding: 01000
Shop #: WSC 31414 000
VCID: 20037383C0BDE2777052FF-4B3C
35-00 - -
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No SW: 1J0 909 609
Component: A AIRBAG VW3 SG 0002
Coding: 00065
VCID: EC9BD7B3FCF576171C2ABB-4B7A
01280 - Airbag; Passenger Side; Disabled
35-00 - -
Address 17: Instruments Labels: 1J0-919-xxx-17.lbl
Part No SW: 1J0 919 860 DX
Component: A4-KOMBIINSTR. VDO V61
Coding: 04142
Shop #: WSC 40152 000
VCID: 88538B23C84DBA37984247-5160
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No SW: 1J0 959 799 Q
Component: 4C Zentral-SG Komf. 0001
Coding: 04097
VCID: 4CDBF7331CB51617FCEADB-4B1E
Subsystem 1 - Part No SW: 1J1-959-801-C
Component: 4C Türsteuerger. FS0001r
00946 - Interior Light (W)
28-10 - Short to Plus - Intermittent
27-00 - Implausible Signal
End--(Elapsed Time: 06:10, VBatt start/end: 12.1/12.1 Vign: 0.0)-
