Golf 1J AGU basic settings Throttle body
Klesk
Sweden
C?ID=395119
Hi
I have some issues with the aligment of the throttle body and its idling 1200 rpm, i bought a new throttle body and installed it but I have the same problem . when i start the car it idles normal but after a while of driving Idle is 1200 rpm. when i try to do a throttle body aligment on channel 98 i only got a error even with the new throttle body.
fault codes before this autoscan :
00282 throttle position actuator (v60)
27-10 implausible signal-intermittent
01165 throttle body control module
11-00 control limit not reached
 VCDS-Mobile
Auto-Scan
Finished
VIN: IMMO-IDENTNR:2284
Chassis Type:1J or 9M
	 76
Address 01: Engine	Labels: 06A-906-018-AGU.lbl
	Part No SW: 06A 906 018 BB
	Component: 1.8L R4/5VT MOTR HS D09
	Coding: 04000
	Shop #: WSC 00046 000
	VCID: 63893C8F912BB96F2DF0D8-4B3C
01165 - Throttle Body Control Module (J338)
	11-00 - Control Limit Not Reached
Address 03: ABS Brakes	Labels: 1J0-907-37x-ABS.lbl
	Part No SW: 1J0 907 379
	Component: ABS/EDS 20 IE CAN 0001
	Coding: 13504
	VCID: EE9FDDBBCAE98407325EA1-4B00
No fault codes found.
Address 08: Auto HVAC	Labels: 3Bx-907-044.lbl
	Part No SW: 3B1 907 044 B
	Component: CLIMATRONIC V 1.0.0
	Coding: 01000
	Shop #: WSC 31414 000
	VCID: 20037383C0BDE2777052FF-4B3C
	35-00 - -
Address 15: Airbags	Labels: 1J0-909-60x-VW3.lbl
	Part No SW: 1J0 909 609
	Component: A AIRBAG VW3 SG 0002
	Coding: 00065
	VCID: EC9BD7B3FCF576171C2ABB-4B7A
01280 - Airbag; Passenger Side; Disabled
	35-00 - -
Address 17: Instruments	Labels: 1J0-919-xxx-17.lbl
	Part No SW: 1J0 919 860 DX
	Component: A4-KOMBIINSTR. VDO V61
	Coding: 04142
	Shop #: WSC 40152 000
	VCID: 88538B23C84DBA37984247-5160
Address 46: Central Conv.	Labels: 1J0-959-799.lbl
	Part No SW: 1J0 959 799 Q
	Component: 4C Zentral-SG Komf. 0001
	Coding: 04097
	VCID: 4CDBF7331CB51617FCEADB-4B1E
	Subsystem 1 - 	Part No SW: 1J1-959-801-C
	Component: 4C Türsteuerger. FS0001r
00946 - Interior Light (W)
	28-10 - Short to Plus - Intermittent
	27-00 - Implausible Signal
End--(Elapsed Time: 06:10, VBatt start/end: 12.1/12.1 Vign: 0.0)-
Klesk
Sweden
C?ID=395119
No, sits a little loose, as i should
Klesk
Sweden
C?ID=395119
Tried that without success, looks like it suddenly stucks in part throttle when i am looking at the measuring values. Where can i find a ecu pinout schedule for this engine? thanks
Klesk
Sweden
C?ID=395119
Wiring check done, and all of it is ok and according to spec. Measured all of them with my fluke instrument . The cars ecu is chipped with a, for me, unknown chip and I am starting to believe that the chip is the issue. It still, sometimes stucks in part throttle and I am unable to do a basic setting with Vcds. Any more ideas about this issue before i change the ecu?
NostraJackAss
Ahhhh FOD huh?
Can you adapt any similar TV just plugging it in with success and did you try defaulting ECU by re-code and battery Jesus yet?
Klesk
Sweden
C?ID=395119
i can try to find another TV just for testning. i still have the old TV. i can try that one once again. i dont know how to default the ecu by code. The battery connections are cleaned up very carefully. Please describe the process of defaulting ecu by code. thank you for the response
Klesk
Sweden
C?ID=395119
i will try this!!
Thank you
Klesk
Sweden
C?ID=395119
It did not help to code the ECU. Only thing left to do is to replace the ECU as it dis not seem to work propertly. Thank you all for your advice :thumbs:
